GD600HFX170C6S
GD600HFX170C6S
    STARPOWER(斯达)
    STARPOWER - GD600HFX170C6S - IGBT Module, Half Bridge, 1.069 kA, 1.85 V, 4.166 kW, 150 °C, Module
GD600HFX170C6S 数据手册
GD600HFX170C6S IGBT Module STARPOWER IGBT SEMICONDUCTOR GD600HFX170C6S 1700V/600A 2 in one-package General Description STARPOWER IGBT Power Module provides ultra low conduction loss as well as short circuit ruggedness. They are designed for the applications such as general inverters and UPS. Features        Low VCE(sat) Trench IGBT technology 10μs short circuit capability VCE(sat) with positive temperature coefficient Maximum junction temperature 175oC Low inductance case Fast & soft reverse recovery anti-parallel FWD Isolated copper baseplate using DBC technology Typical Applications    Inverter for motor drive AC and DC servo drive amplifier Uninterruptible power supply Equivalent Circuit Schematic ©2019 STARPOWER Semiconductor Ltd. 7/3/2019 1/9 preliminary GD600HFX170C6S IGBT Module Absolute Maximum Ratings TC=25oC unless otherwise noted IGBT Symbol VCES VGES IC ICM PD Description Collector-Emitter Voltage Gate-Emitter Voltage Collector Current @ TC=25oC @ TC=100oC Pulsed Collector Current tp=1ms Maximum Power Dissipation @ Tj=175oC Value 1700 ±20 1069 600 1200 4166 Unit V V Description Repetitive Peak Reverse Voltage Diode Continuous Forward Current Diode Maximum Forward Current tp=1ms Value 1700 600 1200 Unit V A A Value 175 -40 to +150 -40 to +125 4000 Unit o C o C o C V A A W Diode Symbol VRRM IF IFM Module Symbol Tjmax Tjop TSTG VISO Description Maximum Junction Temperature Operating Junction Temperature Storage Temperature Range Isolation Voltage RMS,f=50Hz,t=1min ©2019 STARPOWER Semiconductor Ltd. 7/3/2019 2/9 preliminary GD600HFX170C6S IGBT Module IGBT Characteristics TC=25oC unless otherwise noted Symbol VCE(sat) VGE(th) ICES IGES RGint Cies Cres QG td(on) tr td(off) tf Eon Eoff td(on) tr td(off) tf Eon Eoff td(on) tr td(off) tf Eon Eoff ISC Parameter Collector to Emitter Saturation Voltage Gate-Emitter Threshold Voltage Collector Cut-Off Current Gate-Emitter Leakage Current Internal Gate Resistance Input Capacitance Reverse Transfer Capacitance Gate Charge Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss SC Data Test Conditions IC=600A,VGE=15V, Tj=25oC IC=600A,VGE=15V, Tj=125oC IC=600A,VGE=15V, Tj=150oC IC=12.0mA,VCE=VGE, Tj=25oC VCE=VCES,VGE=0V, Tj=25oC VGE=VGES,VCE=0V, Tj=25oC VCE=25V,f=1MHz, VGE=0V VGE=-15…+15V VCC=900V,IC=600A, RG=1.0Ω,VGE=±15V, Tj=25oC VCC=900V,IC=600A, RG=1.0Ω,VGE=±15V, Tj=125oC VCC=900V,IC=600A, RG=1.0Ω,VGE=±15V, Tj=150oC tP≤10μs,VGE=15V, Tj=150oC,VCC=1000V, VCEM≤1700V ©2019 STARPOWER Semiconductor Ltd. 7/3/2019 Min. Typ. Max. 1.85 2.20 2.25 Unit V 2.35 5.6 6.2 6.8 V 5.0 mA 400 nA 1.3 72.3 Ω nF 1.75 nF 5.66 170 67 527 138 μC ns ns ns ns 154 mJ 132 mJ 168 80 619 196 ns ns ns ns 236 mJ 198 mJ 192 80 640 216 ns ns ns ns 259 mJ 215 mJ 2400 A 3/9 preliminary GD600HFX170C6S IGBT Module Diode Characteristics TC=25oC unless otherwise noted Symbol VF Qr IRM Erec Qr IRM Erec Qr IRM Erec Parameter Diode Forward Voltage Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Test Conditions IF=600A,VGE=0V,Tj=25oC IF=600A,VGE=0V,Tj=125oC IF=600A,VGE=0V,Tj=150oC Min. Typ. 1.80 1.95 1.90 165 VR=900V,IF=600A, -di/dt=7475A/μs,VGE=-15V Tj=25oC VR=900V,IF=600A, -di/dt=7475A/μs,VGE=-15V Tj=125oC VR=900V,IF=600A, -di/dt=7475A/μs,VGE=-15V Tj=150oC Max. 2.25 Units V μC 638 A 86.3 mJ 275 μC 683 A 170 mJ 314 μC 670 A 198 mJ NTC Characteristics TC=25oC unless otherwise noted Symbol R25 ∆R/R P25 Parameter Rated Resistance Deviation of R100 Power Dissipation B25/50 B-value B25/80 B-value B25/100 B-value Test Conditions Min. TC=100 oC,R100=493.3Ω Typ. 5.0 -5 R2=R25exp[B25/50(1/T21/(298.15K))] R2=R25exp[B25/80(1/T21/(298.15K))] R2=R25exp[B25/100(1/T21/(298.15K))] Max. 5 Unit kΩ % 20.0 mW 3375 K 3411 K 3433 K Module Characteristics TC=25oC unless otherwise noted Symbol LCE RCC’+EE’ RthJC RthCH M G Parameter Stray Inductance Module Lead Resistance, Terminal to Chip Junction-to-Case (per IGBT) Junction-to-Case (per Diode) Case-to-Heatsink (per IGBT) Case-to-Heatsink (per Diode) Case-to-Heatsink (per Module) Terminal Connection Torque, Screw M6 Mounting Torque, Screw M5 Weight of Module ©2019 STARPOWER Semiconductor Ltd. Min. Typ. 20 1.10 Max. 0.036 0.077 0.026 0.057 0.009 3.0 3.0 7/3/2019 4/9 K/W K/W 6.0 6.0 350 Unit nH mΩ N.m g preliminary GD600HFX170C6S IGBT Module 1200 1200 1000 1000 800 800 IC [A] IC [A] VGE=15V 600 400 VCE=20V 600 400 Tj=25℃ 200 200 Tj=25℃ Tj=125℃ Tj=150℃ Tj=125℃ Tj=150℃ 0 0 0 0.5 1 1.5 2 2.5 3 3.5 4 VCE [V] 5 Fig 1. IGBT Output Characteristics 7 8 9 10 VGE [V] 11 12 Fig 2. IGBT Transfer Characteristics 800 1,200 Eon Tj=125℃ Eoff Tj=125℃ Eon Tj=150℃ Eoff Tj=150℃ VCC=900V RG=1.0Ω VGE=±15V 800 600 Eon Tj=125℃ Eoff Tj=125℃ Eon Tj=150℃ Eoff Tj=150℃ 700 600 500 E [mJ] 1,000 E [mJ] 6 400 300 400 200 200 VCC=900V IC=600A VGE=±15V 100 0 0 0 200 400 600 800 1000 1200 IC [A] Fig 3. IGBT Switching Loss vs. IC ©2019 STARPOWER Semiconductor Ltd. 0 2 4 6 RG [Ω] 8 Fig 4. IGBT Switching Loss vs. RG 7/3/2019 5/9 preliminary 10 GD600HFX170C6S IGBT Module 0.1 1400 Module 1200 IGBT ZthJC [K/W] IC [A] 1000 800 600 0.01 400 RG=1.0Ω VGE=±15V Tj=150oC 200 i: 1 2 3 4 ri[K/W]: 0.0021 0.0119 0.0115 0.0105 0.01 0.02 0.05 0.1 τi[s]: 0 0 0.001 0.001 300 600 900 1200 1500 1800 VCE [V] Fig 5. RBSOA 0.01 0.1 t [s] 1 10 Fig 6. IGBT Transient Thermal Impedance 250 1200 Tj=25℃ Tj=125℃ Tj=150℃ 1000 Erec Tj=125℃ Erec Tj=150℃ 200 800 E [mJ] IF [A] 150 600 100 400 50 200 0 VCC=900V RG=1.0Ω VGE=±15V 0 0.0 0.5 1.0 1.5 2.0 VF [V] 2.5 3.0 Fig 7. Diode Forward Characteristics ©2019 STARPOWER Semiconductor Ltd. 0 200 400 600 800 1000 1200 IF [A] Fig 8. Diode Switching Loss vs. IF 7/3/2019 6/9 preliminary GD600HFX170C6S IGBT Module 0.1 250 Erec Tj=125℃ Diode Erec Tj=150℃ 200 E [mJ] ZthJC [K/W] 150 100 50 0.01 VCC=900V IF=600A VGE=-15V i: 1 2 3 4 ri[K/W]: 0.0046 0.0253 0.0248 0.0223 τi[s]: 0.01 0.02 0.05 0.1 0 0 2 4 6 RG [Ω] 8 10 Fig 9. Diode Switching Loss vs. RG 0.001 0.001 0.01 0.1 t [s] 1 Fig 10. Diode Transient Thermal Impedance 100 R [kΩ] 10 1 0.1 0 30 60 90 o TC [ C] 120 10 150 Fig 11. NTC Temperature Characteristic ©2019 STARPOWER Semiconductor Ltd. 7/3/2019 7/9 preliminary GD600HFX170C6S IGBT Module Circuit Schematic Package Dimensions Dimensions in Millimeters 9 8 6 7 5 4 10 11 3 1 2 A B ©2019 STARPOWER Semiconductor Ltd. 7/3/2019 8/9 preliminary GD600HFX170C6S IGBT Module Terms and Conditions of Usage The data contained in this product datasheet is exclusively intended for technically trained staff. you and your technical departments will have to evaluate the suitability of the product for the intended application and the completeness of the product data with respect to such application. This product data sheet is describing the characteristics of this product for which a warranty is granted. Any such warranty is granted exclusively pursuant the terms and conditions of the supply agreement. There will be no guarantee of any kind for the product and its characteristics. Should you require product information in excess of the data given in this product data sheet or which concerns the specific application of our product, please contact the sales office, which is responsible for you (see www.powersemi.cc), For those that are specifically interested we may provide application notes. Due to technical requirements our product may contain dangerous substances. For information on the types in question please contact the sales office, which is responsible for you. Should you intend to use the Product in aviation applications, in health or live endangering or life support applications, please notify. If and to the extent necessary, please forward equivalent notices to your customers. Changes of this product data sheet are reserved. ©2019 STARPOWER Semiconductor Ltd. 7/3/2019 9/9 preliminary
GD600HFX170C6S 价格&库存
很抱歉,暂时无法提供与“GD600HFX170C6S”相匹配的价格&库存,您可以联系我们找货
GD600HFX170C6S
  • 1+2318.21386
库存:10
GD600HFX170C6S
    • 10+2426.50000
    • 20+2232.15000
    • 40+2037.80000
    • 100+1941.20000
    库存:1200
