GD400HFX65C2S
GD400HFX65C2S
    STARPOWER(斯达)
    STARPOWER - GD400HFX65C2S - IGBT Module, Half Bridge, 509 A, 1.45 V, 1.26 kW, 150 °C, Module
GD400HFX65C2S 数据手册
GD400HFX65C2S IGBT Module STARPOWER IGBT SEMICONDUCTOR GD400HFX65C2S 650V/400A 2 in one-package General Description STARPOWER IGBT Power Module provides ultra low conduction loss as well as short circuit ruggedness. They are designed for the applications such as general inverters and UPS. Features        Low VCE(sat) Trench IGBT technology 6μs short circuit capability VCE(sat) with positive temperature coefficient Maximum junction temperature 175oC Low inductance case Fast & soft reverse recovery anti-parallel FWD Isolated copper baseplate using DBC technology Typical Applications    Automotive application Hybrid and electric vehicle Inverter for motor drive Equivalent Circuit Schematic ©2018 STARPOWER Semiconductor Ltd. 2/23/2018 1/9 Preliminary GD400HFX65C2S IGBT Module Absolute Maximum Ratings TC=25oC unless otherwise noted IGBT Symbol VCES VGES IC ICM PD Description Collector-Emitter Voltage Gate-Emitter Voltage Collector Current @ TC=25oC @ TC=65oC Pulsed Collector Current tp=1ms Maximum Power Dissipation @ Tj=175oC Value 650 ±20 509 400 800 1260 Unit V V Description Repetitive Peak Reverse Voltage Diode Continuous Forward Current Diode Maximum Forward Current tp=1ms Value 650 400 800 Unit V A A Value 175 -40 to +150 -40 to +125 4000 Unit o C o C o C V A A W Diode Symbol VRRM IF IFM Module Symbol Tjmax Tjop TSTG VISO Description Maximum Junction Temperature Operating Junction Temperature Storage Temperature Range Isolation Voltage RMS,f=50Hz,t=1min ©2018 STARPOWER Semiconductor Ltd. 2/23/2018 2/9 Preliminary GD400HFX65C2S IGBT Module IGBT Characteristics TC=25oC unless otherwise noted Symbol VCE(sat) VGE(th) ICES IGES RGint Cies Cres QG td(on) tr td(off) tf Eon Eoff td(on) tr td(off) tf Eon Eoff td(on) tr td(off) tf Eon Eoff ISC Parameter Collector to Emitter Saturation Voltage Gate-Emitter Threshold Voltage Collector Cut-Off Current Gate-Emitter Leakage Current Internal Gate Resistance Input Capacitance Reverse Transfer Capacitance Gate Charge Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss SC Data Test Conditions IC=400A,VGE=15V, Tj=25oC IC=400A,VGE=15V, Tj=125oC IC=400A,VGE=15V, Tj=150oC IC=6.40mA,VCE=VGE, Tj=25oC VCE=VCES,VGE=0V, Tj=25oC VGE=VGES,VCE=0V, Tj=25oC Min. 1.45 1.90 Unit V 1.70 5.1 5.8 VGE=-15…+15V VCC=300V,IC=400A, RG=1.8Ω,VGE=±15V, Tj=25oC VCC=300V,IC=400A, RG=1.8Ω,VGE=±15V, Tj=125oC VCC=300V,IC=400A, RG=1.8Ω,VGE=±15V, Tj=150oC tP≤6μs,VGE=15V, Tj=150oC,VCC=360V, VCEM≤650V 2/23/2018 Max. 1.60 VCE=25V,f=1MHz, VGE=0V ©2018 STARPOWER Semiconductor Ltd. Typ. 3/9 6.5 V 1.0 mA 400 nA 1.0 46.4 Ω nF 0.91 nF 2.77 80 64 368 40 μC ns ns ns ns 2.3 mJ 10.4 mJ 88 64 400 56 ns ns ns ns 3.4 mJ 12.8 mJ 96 64 400 64 ns ns ns ns 3.6 mJ 13.6 mJ 2000 A Preliminary GD400HFX65C2S IGBT Module Diode Characteristics TC=25oC unless otherwise noted Symbol VF Qr IRM Erec Qr IRM Erec Qr IRM Erec Parameter Diode Forward Voltage Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Test Conditions IF=400A,VGE=0V,Tj=25oC IF=400A,VGE=0V,Tj=125oC IF=400A,VGE=0V,Tj=150oC Min. Typ. 1.55 1.50 1.45 19.8 VR=300V,IF=400A, -di/dt=6050A/μs,VGE=-15V Tj=25oC VR=300V,IF=400A, -di/dt=6050A/μs,VGE=-15V Tj=125oC VR=300V,IF=400A, -di/dt=6050A/μs,VGE=-15V Tj=150oC Max. 2.00 Unit V μC 231 A 3.96 mJ 33.0 μC 308 A 7.98 mJ 37.4 μC 330 A 9.13 mJ Module Characteristics TC=25oC unless otherwise noted Symbol LCE RCC’+EE’ RthJC RthCH M G Parameter Min. Stray Inductance Module Lead Resistance, Terminal to Chip Junction-to-Case (per IGBT) Junction-to-Case (per Diode) Case-to-Heatsink (per IGBT) Case-to-Heatsink (per Diode) Case-to-Heatsink (per Module) Terminal Connection Torque, Screw M6 Mounting Torque, Screw M6 Weight of Module ©2018 STARPOWER Semiconductor Ltd. Typ. Max. 20 0.35 0.119 0.218 0.031 0.057 0.010 2.5 3.0 2/23/2018 4/9 K/W K/W 5.0 5.0 300 Unit nH mΩ N.m g Preliminary GD400HFX65C2S IGBT Module 800 800 VGE=15V 700 600 600 500 500 IC [A] IC [A] 700 400 300 200 200 Tj=25℃ Tj=125℃ Tj=150℃ Tj=25℃ Tj=125℃ Tj=150℃ 100 0 0 0 0.5 1 1.5 2 VCE [V] 2.5 3 5 Fig 1. IGBT Output Characteristics 6 7 8 9 VGE [V] 10 11 12 Fig 2. IGBT Transfer Characteristics 40 60 Eon,Tj=125℃ Eoff,Tj=125℃ Eon,Tj=150℃ Eoff,Tj=150℃ 35 30 40 E [mJ] 20 Eon,Tj=125℃ Eoff,Tj=125℃ Eon,Tj=150℃ Eoff,Tj=150℃ 50 VCC=600V RG=1.8Ω VGE=±15V 25 E [mJ] 400 300 100 VCE=20V 15 30 20 10 VCC=600V IC=400A VGE=±15V 10 5 0 0 0 200 400 IC [A] 600 800 Fig 3. IGBT Switching Loss vs. IC ©2018 STARPOWER Semiconductor Ltd. 0 5 10 RG [Ω] 15 Fig 4. IGBT Switching Loss vs. RG 2/23/2018 5/9 Preliminary 20 GD400HFX65C2S IGBT Module 1 1000 Module 800 IGBT 0.1 IC [A] ZthJC [K/W] 600 400 0.01 RG=1.8Ω VGE=±15V Tj=150oC 200 i: 1 2 3 4 ri[K/W]: 0.0071 0.0392 0.0381 0.0346 0.01 0.02 0.05 0.1 τi[s]: 0 0 0.001 0.001 100 200 300 400 500 600 700 VCE [V] Fig 5. RBSOA 0.01 0.1 t [s] 1 10 Fig 6. IGBT Transient Thermal Impedance 800 12 Tj=25℃ Tj=125℃ Tj=150℃ 700 Erec,Tj=125℃ Erec,Tj=150℃ 10 600 8 E [mJ] IF [A] 500 400 300 6 4 200 VCC=600V RG=1.8Ω VGE=-15V 2 100 0 0 0 0.5 1 1.5 VF [V] 2 2.5 Fig 7. Diode Forward Characteristics ©2018 STARPOWER Semiconductor Ltd. 0 200 400 IF [A] 600 Fig 8. Diode Switching Loss vs. IF 2/23/2018 6/9 Preliminary 800 GD400HFX65C2S IGBT Module 1 10 Erec,Tj=125℃ Erec,Tj=150℃ Diode 8 0.1 E [mJ] ZthJC [K/W] 6 4 0.01 2 VCC=600V IF=400A VGE=-15V i: 1 2 3 4 ri[K/W]: 0.0130 0.0720 0.0698 0.0632 0.01 0.02 0.05 0.1 τi[s]: 0 0 5 10 RG [Ω] 15 20 Fig 9. Diode Switching Loss vs. RG ©2018 STARPOWER Semiconductor Ltd. 0.001 0.001 0.01 0.1 t [s] 1 10 Fig 10. Diode Transient Thermal Impedance 2/23/2018 7/9 Preliminary GD400HFX65C2S IGBT Module Circuit Schematic Package Dimensions Dimensions in Millimeters ©2018 STARPOWER Semiconductor Ltd. 2/23/2018 8/9 Preliminary GD400HFX65C2S IGBT Module Terms and Conditions of Usage The data contained in this product datasheet is exclusively intended for technically trained staff. you and your technical departments will have to evaluate the suitability of the product for the intended application and the completeness of the product data with respect to such application. This product data sheet is describing the characteristics of this product for which a warranty is granted. Any such warranty is granted exclusively pursuant the terms and conditions of the supply agreement. There will be no guarantee of any kind for the product and its characteristics. Should you require product information in excess of the data given in this product data sheet or which concerns the specific application of our product, please contact the sales office, which is responsible for you (see www.powersemi.cc), For those that are specifically interested we may provide application notes. Due to technical requirements our product may contain dangerous substances. For information on the types in question please contact the sales office, which is responsible for you. Should you intend to use the Product in aviation applications, in health or live endangering or life support applications, please notify. If and to the extent necessary, please forward equivalent notices to your customers. Changes of this product data sheet are reserved. ©2018 STARPOWER Semiconductor Ltd. 2/23/2018 9/9 Preliminary
GD400HFX65C2S 价格&库存
很抱歉,暂时无法提供与“GD400HFX65C2S”相匹配的价格&库存,您可以联系我们找货
GD400HFX65C2S
  • 1+916.09484
  • 10+824.46348
库存:12
