GD600SGX170C2S
GD600SGX170C2S
    STARPOWER(斯达)
    STARPOWER - GD600SGX170C2S - IGBT Module, Single, 958 A, 1.85 V, 3.448 kW, 150 °C, Module
GD600SGX170C2S 数据手册
GD600SGX170C2S IGBT Module STARPOWER IGBT SEMICONDUCTOR GD600SGX170C2S 1700V/600A 1 in one-package General Description STARPOWER IGBT Power Module provides ultra low conduction loss as well as short circuit ruggedness. They are designed for the applications such as general inverters and UPS. Features        Low VCE(sat) Trench IGBT technology 10μs short circuit capability VCE(sat) with positive temperature coefficient Maximum junction temperature 175oC Low inductance case Fast & soft reverse recovery anti-parallel FWD Isolated copper baseplate using DBC technology Typical Applications    Inverter for motor drive AC and DC servo drive amplifier Uninterruptible power supply Equivalent Circuit Schematic ©2018 STARPOWER Semiconductor Ltd. 9/26/2018 1/9 Preliminary GD600SGX170C2S IGBT Module Absolute Maximum Ratings TC=25oC unless otherwise noted IGBT Symbol VCES VGES IC ICM PD Description Collector-Emitter Voltage Gate-Emitter Voltage Collector Current @ TC=25oC @ TC=100oC Pulsed Collector Current tp=1ms Maximum Power Dissipation @ Tj=175oC Value 1700 ±20 958 600 1200 3448 Unit V V Description Repetitive Peak Reverse Voltage Diode Continuous Forward Current Diode Maximum Forward Current tp=1ms Value 1700 600 1200 Unit V A A Value 175 -40 to +150 -40 to +125 4000 Unit o C o C o C V A A W Diode Symbol VRRM IF IFM Module Symbol Tjmax Tjop TSTG VISO Description Maximum Junction Temperature Operating Junction Temperature Storage Temperature Range Isolation Voltage RMS,f=50Hz,t=1min ©2018 STARPOWER Semiconductor Ltd. 9/26/2018 2/9 Preliminary GD600SGX170C2S IGBT Module IGBT Characteristics TC=25oC unless otherwise noted Symbol VCE(sat) VGE(th) ICES IGES RGint Cies Cres QG td(on) tr td(off) tf Eon Eoff td(on) tr td(off) tf Eon Eoff td(on) tr td(off) tf Eon Eoff ISC Parameter Collector to Emitter Saturation Voltage Gate-Emitter Threshold Voltage Collector Cut-Off Current Gate-Emitter Leakage Current Internal Gate Resistance Input Capacitance Reverse Transfer Capacitance Gate Charge Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss SC Data Test Conditions IC=600A,VGE=15V, Tj=25oC IC=600A,VGE=15V, Tj=125oC IC=600A,VGE=15V, Tj=150oC IC=24.0mA,VCE=VGE, Tj=25oC VCE=VCES,VGE=0V, Tj=25oC VGE=VGES,VCE=0V, Tj=25oC Min. VCE=25V,f=1MHz, VGE=0V VGE=-15V…+15V VCC=900V,IC=600A, RG=1.2Ω,VGE=±15V, Tj=25oC VCC=900V,IC=600A, RG=1.2Ω,VGE=±15V, Tj=125oC VCC=900V,IC=600A, RG=1.2Ω,VGE=±15V, Tj=150oC tP≤10μs,VGE=15V, Tj=150oC,VCC=1000V, VCEM≤1700V ©2018 STARPOWER Semiconductor Ltd. 9/26/2018 Typ. Max. 1.85 2.20 2.25 Unit V 2.35 5.6 6.2 6.8 V 5.0 mA 400 nA 1.25 72.3 Ω nF 1.75 nF 5.66 204 48 60 100 μC ns ns ns ns 93.5 mJ 127 mJ 224 55 61 159 ns ns ns ns 135 mJ 198 mJ 240 55 62 180 ns ns ns ns 155 mJ 210 mJ 2400 A 3/9 Preliminary GD600SGX170C2S IGBT Module Diode Characteristics TC=25oC unless otherwise noted Symbol VF Qr IRM Erec Qr IRM Erec Qr IRM Erec Parameter Diode Forward Voltage Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Test Conditions IF=600A,VGE=0V,Tj=25oC IF=600A,VGE=0V,Tj=125oC IF=600A,VGE=0V,Tj=150oC Min. Typ. 1.80 1.90 1.95 127 VR=900V,IF=600A, -di/dt=6800A/μs,VGE=-15V Tj=25oC VR=900V,IF=600A, -di/dt=6800A/μs,VGE=-15V Tj=125oC VR=900V,IF=600A, -di/dt=6800A/μs,VGE=-15V Tj=150oC Max. 2.25 Unit V μC 682 A 82.8 mJ 231 μC 819 A 165 mJ 264 μC 830 A 198 mJ Module Characteristics TC=25oC unless otherwise noted Symbol LCE RCC’+EE’ RthJC RthCH M G Parameter Min. Stray Inductance Module Lead Resistance, Terminal to Chip Junction-to-Case (per IGBT) Junction-to-Case (per Diode) Case-to-Heatsink (per IGBT) Case-to-Heatsink (per Diode) Case-to-Heatsink (per Module) Terminal Connection Torque, Screw M4 Terminal Connection Torque, Screw M6 Mounting Torque, Screw M6 Weight of Module ©2018 STARPOWER Semiconductor Ltd. Typ. 15 0.18 Max. 0.043 0.063 0.017 0.025 0.010 1.1 2.5 3.0 9/26/2018 4/9 K/W K/W 2.0 5.0 5.0 300 Unit nH mΩ N.m g Preliminary GD600SGX170C2S IGBT Module 1200 1200 1000 1000 800 800 IC [A] IC [A] VGE=15V 600 400 VCE=20V 600 400 Tj=25℃ 200 200 Tj=25℃ Tj=125℃ Tj=150℃ Tj=125℃ Tj=150℃ 0 0 0 0.5 1 1.5 2 2.5 3 3.5 4 VCE [V] 5 Fig 1. IGBT Output Characteristics 700 Eon Tj=125℃ Eoff Tj=125℃ Eon Tj=150℃ Eoff Tj=150℃ 400 8 9 10 11 12 13 VGE [V] Eon Tj=125℃ Eoff Tj=125℃ Eon Tj=150℃ Eoff Tj=150℃ 600 500 VCC=900V RGon=1.2Ω VGE=±15V 300 250 200 150 E [mJ] 350 E [mJ] 7 Fig 2. IGBT Transfer Characteristics 500 450 6 400 300 200 100 VCC=900V IC=600A VGE=±15V 100 50 0 0 0 200 400 600 800 1000 1200 IC [A] Fig 3. IGBT Switching Loss vs. IC ©2018 STARPOWER Semiconductor Ltd. 0 2 4 6 8 RG [Ω] 10 Fig 4. IGBT Switching Loss vs. RG 9/26/2018 5/9 Preliminary 12 GD600SGX170C2S IGBT Module 0.1 1400 Module IGBT 1200 ZthJC [K/W] IC [A] 1000 800 600 0.01 400 RGon=1.2Ω VGE=±15V Tj=150oC 200 i: 1 2 3 4 ri[K/W]: 0.0025 0.0143 0.0138 0.0124 0.01 0.02 0.05 0.1 τi[s]: 0 0 0.001 0.001 300 600 900 1200 1500 1800 VCE [V] Fig 5. RBSOA 0.01 0.1 t [s] 1 10 Fig 6. IGBT Transient Thermal Impedance 250 1200 Tj=25℃ Tj=125℃ Tj=150℃ 1000 Erec Tj=125℃ Erec Tj=150℃ 200 800 E [mJ] IF [A] 150 600 100 400 50 200 0 VCC=900V RGon=1.2Ω VGE=±15V 0 0.0 0.5 1.0 1.5 2.0 VF [V] 2.5 3.0 Fig 7. Diode Forward Characteristics ©2018 STARPOWER Semiconductor Ltd. 0 100 200 300 400 500 600 700 800 IF [A] Fig 8. Diode Switching Loss vs. IF 9/26/2018 6/9 Preliminary GD600SGX170C2S IGBT Module 0.1 200 Erec Tj=125℃ Diode Erec Tj=150℃ 180 ZthJC [K/W] E [mJ] 160 140 120 0.01 100 VCC=900V IF=600A VGE=-15V 80 i: 1 2 3 4 ri[K/W]: 0.0037 0.0208 0.0202 0.0183 τi[s]: 0.01 0.02 0.05 0.1 60 0 1 2 3 4 5 6 RG [Ω] 7 8 9 Fig 9. Diode Switching Loss vs. RG ©2018 STARPOWER Semiconductor Ltd. 0.001 0.001 0.01 0.1 t [s] 1 10 Fig 10. Diode Transient Thermal Impedance 9/26/2018 7/9 Preliminary GD600SGX170C2S IGBT Module Circuit Schematic Package Dimensions Dimensions in Millimeters ©2018 STARPOWER Semiconductor Ltd. 9/26/2018 8/9 Preliminary GD600SGX170C2S IGBT Module Terms and Conditions of Usage The data contained in this product datasheet is exclusively intended for technically trained staff. you and your technical departments will have to evaluate the suitability of the product for the intended application and the completeness of the product data with respect to such application. This product data sheet is describing the characteristics of this product for which a warranty is granted. Any such warranty is granted exclusively pursuant the terms and conditions of the supply agreement. There will be no guarantee of any kind for the product and its characteristics. Should you require product information in excess of the data given in this product data sheet or which concerns the specific application of our product, please contact the sales office, which is responsible for you (see www.powersemi.cc), For those that are specifically interested we may provide application notes. Due to technical requirements our product may contain dangerous substances. For information on the types in question please contact the sales office, which is responsible for you. Should you intend to use the Product in aviation applications, in health or live endangering or life support applications, please notify. If and to the extent necessary, please forward equivalent notices to your customers. Changes of this product data sheet are reserved. ©2018 STARPOWER Semiconductor Ltd. 9/26/2018 9/9 Preliminary
GD600SGX170C2S 价格&库存
很抱歉,暂时无法提供与“GD600SGX170C2S”相匹配的价格&库存,您可以联系我们找货
GD600SGX170C2S
  • 1+1259.04332
库存:6
