DG75X12T2
DG75X12T2
    STARPOWER(斯达)
    STARPOWER - DG75X12T2 - IGBT, 150 A, 1.75 V, 1.415 kW, 1.2 kV, TO-247 Plus, 3 Pins
DG75X12T2 数据手册
DG75X12T2 IGBT Discrete DOSEMI IGBT DG75X12T2 1200V/75A IGBT with Diode General Description DOSEMI IGBT Power Discrete provides ultra low conduction loss as well as low switching loss. They are designed for the applications such as general inverters and UPS. Features       Low VCE(sat) Trench IGBT technology Low switching loss Maximum junction temperature 175oC VCE(sat) with positive temperature coefficient Fast & soft reverse recovery anti-parallel FWD Lead free package Typical Applications    Inverter for motor drive AC and DC servo drive amplifier Uninterruptible power supply Equivalent Circuit Schematic ©2020 STARPOWER Semiconductor Ltd. 8/5/2020 1/9 Preliminary DG75X12T2 IGBT Discrete Absolute Maximum Ratings TC=25oC unless otherwise noted IGBT Symbol VCES VGES IC ICM PD Description Collector-Emitter Voltage Gate-Emitter Voltage Collector Current @ TC=25oC @ TC=137oC Pulsed Collector Current tp=1ms Maximum Power Dissipation @ Tj=175oC Values 1200 ±20 150 75 300 1415 Unit V V Description Repetitive Peak Reverse Voltage Diode Continuous Forward Current Diode Maximum Forward Current tp=1ms Values 1200 75 300 Unit V A A Values -40 to +175 -55 to +150 260 Unit o C o C o C A A W Diode Symbol VRRM IF IFM Discrete Symbol Tjop TSTG TS Description Operating Junction Temperature Storage Temperature Range Soldering Temperature,1.6mm from case for 10s ©2020 STARPOWER Semiconductor Ltd. 8/5/2020 2/9 Preliminary DG75X12T2 IGBT Discrete IGBT Characteristics TC=25oC unless otherwise noted Symbol VCE(sat) VGE(th) ICES IGES RGint Cies Cres QG td(on) tr td(off) tf Eon Eoff td(on) tr td(off) tf Eon Eoff td(on) tr td(off) tf Eon Eoff ISC Parameter Collector to Emitter Saturation Voltage Gate-Emitter Threshold Voltage Collector Cut-Off Current Gate-Emitter Leakage Current Internal Gate Resistance Input Capacitance Reverse Transfer Capacitance Gate Charge Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss SC Data Test Conditions IC=75A,VGE=15V, Tj=25oC IC=75A,VGE=15V, Tj=125oC IC=75A,VGE=15V, Tj=150oC IC=2.72mA,VCE=VGE, Tj=25oC VCE=VCES,VGE=0V, Tj=25oC VGE=VGES,VCE=0V, Tj=25oC VCE=25V,f=1MHz, VGE=0V VGE=-15…+15V VCC=600V,IC=75A, RG=2.2Ω,VGE=±15V, Tj=25oC VCC=600V,IC=75A, RG=2.2Ω,VGE=±15V, Tj=125oC VCC=600V,IC=75A, RG=2.2Ω,VGE=±15V, Tj=150oC tP≤10μs,VGE=15V, Tj=150oC,VCC=900V, VCEM≤1200V ©2020 STARPOWER Semiconductor Ltd. 8/5/2020 Min. Typ. Max. 1.75 2.20 2.00 Unit V 2.05 5.6 6.2 6.8 V 5.0 mA 400 nA 2.0 7.04 Ω nF 0.20 nF 0.53 137 26 333 78 μC ns ns ns ns 2.91 mJ 4.11 mJ 146 34 421 147 ns ns ns ns 6.25 mJ 6.26 mJ 146 34 441 166 ns ns ns ns 7.28 mJ 7.05 mJ 300 A 3/9 Preliminary DG75X12T2 IGBT Discrete Diode Characteristics TC=25oC unless otherwise noted Symbol VF Qr IRM Erec Qr IRM Erec Qr IRM Erec Parameter Diode Forward Voltage Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Test Conditions IF=75A,VGE=0V,Tj=25oC IF=75A,VGE=0V,Tj=125oC IF=75A,VGE=0V,Tj=150oC Min. Typ. 2.15 2.15 2.15 6.0 VR=600V,IF=75A, -di/dt=2300A/μs,VGE=-15V Tj=25oC VR=600V,IF=75A, -di/dt=2300A/μs,VGE=-15V Tj=125oC VR=600V,IF=75A, -di/dt=2300A/μs,VGE=-15V Tj=150oC Max. 2.60 Unit V μC 74 A 2.67 mJ 9.4 μC 70 A 3.61 mJ 9.6 μC 63 A 3.74 mJ Discrete Characteristics TC=25oC unless otherwise noted Symbol RthJC RthJA Parameter Junction-to-Case (per IGBT) Junction-to-Case (per Diode) Junction-to-Ambient ©2020 STARPOWER Semiconductor Ltd. Min. 8/5/2020 Typ. Max. 0.106 0.174 Unit K/W 40 K/W 4/9 Preliminary DG75X12T2 IGBT Discrete 150 150 125 125 100 100 IC [A] IC [A] VGE=15V 75 50 75 50 Tj=25℃ Tj=125℃ Tj=150℃ 25 25 0 Tj=25℃ Tj=125℃ Tj=150℃ 0 0 0.5 1 1.5 2 2.5 VCE [V] 3 3.5 Fig 1. IGBT-inverter Output Characteristics 5 25 Eon,Tj=125℃ Eoff,Tj=125℃ Eon,Tj=150℃ Eoff,Tj=150℃ 25 20 8 9 10 11 12 13 VGE [V] 15 E [mJ] 15 7 Eon,Tj=125℃ Eoff,Tj=125℃ Eon,Tj=150℃ Eoff,Tj=150℃ 20 VCC=600V RG=2.2Ω VGE=±15V 6 Fig 2. IGBT-inverter Transfer Characteristics 30 E [mJ] VCE=20V 10 10 5 5 0 VCC=600V IC=75A VGE=±15V 0 0 25 50 75 100 IC [A] 125 150 Fig 3. IGBT-inverter Switching Loss vs. IC ©2020 STARPOWER Semiconductor Ltd. 0 4.4 8.8 13.2 RG [Ω] 17.6 22 Fig 4. IGBT-inverter Switching Loss vs. RG 8/5/2020 5/9 Preliminary DG75X12T2 IGBT Discrete 160 1 140 Module 120 ZthJC [K/W] IC [A] 100 80 60 40 IGBT 0.1 RG=2.2Ω VGE=±15V Tj=150oC 20 i: 1 2 3 4 5 ri[K/W]: 0.0150 0.0315 0.0580 0.0013 0.0002 τi[s]: 0.0004 0.0027 0.0199 0.5051 12.9567 0 0 350 700 VCE [V] 1050 Fig 5. IGBT-inverter RBSOA 150 0.01 0.001 1400 0.01 0.1 t [s] 1 10 Fig 6. IGBT-inverter Transient Thermal Impedance 6 Tj=25℃ Tj=125℃ Tj=150℃ Erec Tj=125℃ Erec Tj=150℃ 5 4 IF [A] E [mJ] 100 50 3 2 VCC=600V RG=2.2Ω VGE=-15V 1 0 0 0 0.5 1 1.5 2 VF [V] 2.5 3 Fig 7. Diode-inverter Forward Characteristics ©2020 STARPOWER Semiconductor Ltd. 0 30 60 90 IF [A] 120 150 Fig 8. Diode-inverter Switching Loss vs. IF 8/5/2020 6/9 Preliminary DG75X12T2 IGBT Discrete 4 1 Erec Tj=125℃ Erec Tj=150℃ Diode E [mJ] ZthJC [K/W] 3.5 0.1 3 VCC=600V IF=75A VGE=-15V i: 1 2 3 4 5 ri[K/W]: 0.0069 0.0676 0.0976 0.0017 0.0002 τi[s]: 0.0004 0.0027 0.0168 0.4486 12.1124 2.5 0 5 10 15 RG [Ω] 20 25 Fig 9. Diode-inverter Switching Loss vs. RG ©2020 STARPOWER Semiconductor Ltd. 0.01 0.001 0.01 0.1 t [s] 1 10 Fig 10. Diode-inverter Transient Thermal Impedance 8/5/2020 7/9 Preliminary DG75X12T2 IGBT Discrete Circuit Schematic Package Dimensions Dimensions in Millimeters ©2020 STARPOWER Semiconductor Ltd. 8/5/2020 8/9 Preliminary DG75X12T2 IGBT Discrete Terms and Conditions of Usage The data contained in this product datasheet is exclusively intended for technically trained staff. you and your technical departments will have to evaluate the suitability of the product for the intended application and the completeness of the product data with respect to such application. This product data sheet is describing the characteristics of this product for which a warranty is granted. Any such warranty is granted exclusively pursuant the terms and conditions of the supply agreement. There will be no guarantee of any kind for the product and its characteristics. Should you require product information in excess of the data given in this product data sheet or which concerns the specific application of our product, please contact the sales office, which is responsible for you (see www.powersemi.cc), For those that are specifically interested we may provide application notes. Due to technical requirements our product may contain dangerous substances. For information on the types in question please contact the sales office, which is responsible for you. Should you intend to use the Product in aviation applications, in health or live endangering or life support applications, please notify. If and to the extent necessary, please forward equivalent notices to your customers. Changes of this product data sheet are reserved. ©2020 STARPOWER Semiconductor Ltd. 8/5/2020 9/9 Preliminary
DG75X12T2 价格&库存
很抱歉,暂时无法提供与“DG75X12T2”相匹配的价格&库存,您可以联系我们找货
DG75X12T2
  • 1+103.77389
  • 10+93.42254
  • 100+86.17451
  • 500+79.84289
  • 1000+64.85738
库存:28
