GD15PJY120F2S
GD15PJY120F2S
    STARPOWER(斯达)
    STARPOWER - GD15PJY120F2S - IGBT Module, PIM Three Phase Input Rectifier, 30 A, 1.7 V, 141 W, 150 °C...
GD15PJY120F2S 数据手册
GD15PJY120F2S IGBT Module STARPOWER IGBT SEMICONDUCTOR GD15PJY120F2S 1200V/15A PIM in one-package General Description STARPOWER IGBT Power Module provides ultra low conduction loss as well as short circuit ruggedness. They are designed for the applications such as general inverters and UPS. Features      Low VCE(sat) Trench IGBT technology 10μs short circuit capability VCE(sat) with positive temperature coefficient Maximum junction temperature 175oC Fast & soft reverse recovery anti-parallel FWD Typical Applications    Inverter for motor drive AC and DC servo drive amplifier Uninterruptible power supply Equivalent Circuit Schematic ©2016 STARPOWER Semiconductor Ltd. 2/3/2016 1/12 SX0A GD15PJY120F2S IGBT Module Absolute Maximum Ratings TC=25oC unless otherwise noted IGBT-inverter Symbol VCES VGES IC ICM PD Description Collector-Emitter Voltage Gate-Emitter Voltage Collector Current @ TC=25oC @ TC=100oC Pulsed Collector Current tp=1ms Maximum Power Dissipation @ Tj=175oC Value 1200 ±20 30 15 30 141 Unit V V Value 1200 15 30 Unit V A A Value 1600 15 320 510 Unit V A A A2s Value 1200 ±20 20 10 20 110 Unit V V Value 1200 10 20 Unit V A A Value 175 150 -40 to +150 -40 to +125 4000 Unit A A W Diode-inverter Symbol VRRM IF IFM Description Repetitive Peak Reverse Voltage Diode Continuous Forward Current Diode Maximum Forward Current tp=1ms Diode-rectifier Symbol VRRM IO IFSM I2t Description Repetitive Peak Reverse Voltage Average Output Current 50Hz/60Hz,sine wave Surge Forward Current VR=0V,tp=10ms,Tj=45oC I2t-value,VR=0V,tp=10ms,Tj=45oC IGBT-brake Symbol VCES VGES IC ICM PD Description Collector-Emitter Voltage Gate-Emitter Voltage Collector Current @ TC=25oC @ TC=100oC Pulsed Collector Current tp=1ms Maximum Power Dissipation @ Tj=175oC A A W Diode-brake Symbol VRRM IF IFM Description Repetitive Peak Reverse Voltage Diode Continuous Forward Current Diode Maximum Forward Current tp=1ms Module Symbol Tjmax Tjop TSTG VISO Description Maximum Junction Temperature(inverter,brake) Maximum Junction Temperature (rectifier) Operating Junction Temperature Storage Temperature Range Isolation Voltage RMS,f=50Hz,t=1min ©2016 STARPOWER Semiconductor Ltd. 2/3/2016 2/12 o C o C C V o SX0A GD15PJY120F2S IGBT Module IGBT-inverter Characteristics TC=25oC unless otherwise noted Symbol VCE(sat) VGE(th) ICES IGES RGint td(on) tr td(off) tf Eon Eoff td(on) tr td(off) tf Eon Eoff td(on) tr td(off) tf Eon Eoff ISC Parameter Collector to Emitter Saturation Voltage Gate-Emitter Threshold Voltage Collector Cut-Off Current Gate-Emitter Leakage Current Internal Gate Resistance Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss SC Data Test Conditions IC=15A,VGE=15V, Tj=25oC IC=15A,VGE=15V, Tj=125oC IC=15A,VGE=15V, Tj=150oC IC=0.38mA,VCE=VGE, Tj=25oC VCE=VCES,VGE=0V, Tj=25oC VGE=VGES,VCE=0V, Tj=25oC Min. VCC=600V,IC=15A, RG=39Ω,VGE=±15V, Tj=25oC VCC=600V,IC=15A, RG=39Ω,VGE=±15V, Tj=125oC VCC=600V,IC=15A, RG=39Ω,VGE=±15V, Tj=150oC tP≤10μs,VGE=15V, Tj=150oC,VCC=900V, VCEM≤1200V ©2016 STARPOWER Semiconductor Ltd. 2/3/2016 Typ. Max. 1.70 2.15 1.95 Unit V 2.00 5.2 6.0 6.8 V 1.0 mA 400 nA 0 59 63 201 149 Ω ns ns ns ns 1.39 mJ 0.85 mJ 59 70 283 196 ns ns ns ns 1.87 mJ 1.24 mJ 59 70 288 221 ns ns ns ns 2.09 mJ 1.39 mJ 60 A 3/12 SX0A GD15PJY120F2S IGBT Module Diode-inverter Characteristics TC=25oC unless otherwise noted Symbol VF Qr IRM Erec Qr IRM Erec Qr IRM Erec Parameter Diode Forward Voltage Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Test Conditions IF=15A,VGE=0V,Tj=25oC IF=15A,VGE=0V,Tj=125oC IF=15A,VGE=0V,Tj=150oC Min. VR=600V,IF=15A, -di/dt=550A/μs,VGE=-15V Tj=25oC VR=600V,IF=15A, -di/dt=550A/μs,VGE=-15V Tj=125oC VR=600V,IF=15A, -di/dt=550A/μs,VGE=-15V Tj=150oC Typ. 2.05 2.00 2.00 1.1 Max. 2.50 Unit V μC 12 A 0.35 mJ 1.9 μC 11 A 0.65 mJ 2.3 μC 11 A 0.76 mJ Diode-rectifier Characteristics TC=25oC unless otherwise noted Symbol VF IR Parameter Diode Forward Voltage Reverse Current Test Conditions Min. IF=15A,Tj=150oC Typ. 0.90 Tj=150oC,VR=1600V ©2016 STARPOWER Semiconductor Ltd. Max. V 2.0 2/3/2016 4/12 Unit mA SX0A GD15PJY120F2S IGBT Module IGBT-brake Characteristics TC=25oC unless otherwise noted Symbol VCE(sat) VGE(th) ICES IGES RGint td(on) tr td(off) tf Eon Eoff td(on) tr td(off) tf Eon Eoff td(on) tr td(off) tf Eon Eoff ISC Parameter Collector to Emitter Saturation Voltage Gate-Emitter Threshold Voltage Collector Cut-Off Current Gate-Emitter Leakage Current Internal Gate Resistance Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss SC Data Test Conditions IC=10A,VGE=15V, Tj=25oC IC=10A,VGE=15V, Tj=125oC IC=10A,VGE=15V, Tj=150oC IC=0.25mA,VCE=VGE, Tj=25oC VCE=VCES,VGE=0V, Tj=25oC VGE=VGES,VCE=0V, Tj=25oC Min. VCC=600V,IC=10A, RG=47Ω,VGE=±15V, Tj=25oC VCC=600V,IC=10A, RG=47Ω,VGE=±15V, Tj=125oC VCC=600V,IC=10A, RG=47Ω,VGE=±15V, Tj=150oC tP≤10μs,VGE=15V, Tj=150oC,VCC=800V, VCEM≤1200V ©2016 STARPOWER Semiconductor Ltd. 2/3/2016 Typ. Max. 1.70 2.15 1.95 Unit V 2.00 5.2 6.0 6.8 V 1.0 mA 400 nA 0 48 47 185 170 Ω ns ns ns ns 0.96 mJ 0.57 mJ 48 65 252 221 ns ns ns ns 1.44 mJ 0.82 mJ 48 67 283 232 ns ns ns ns 1.66 mJ 0.90 mJ 40 A 5/12 SX0A GD15PJY120F2S IGBT Module Diode-brake Characteristics TC=25oC unless otherwise noted Symbol VF Qr IRM Erec Qr IRM Erec Qr IRM Erec Parameter Diode Forward Voltage Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Test Conditions IF=10A,VGE=0V,Tj=25oC IF=10A,VGE=0V,Tj=125oC IF=10A,VGE=0V,Tj=150oC Min. Typ. 1.85 2.05 2.10 0.5 VR=600V,IF=10A, -di/dt=260A/μs,VGE=-15V Tj=25oC VR=600V,IF=10A, -di/dt=260A/μs,VGE=-15V Tj=125oC VR=600V,IF=10A, -di/dt=260A/μs,VGE=-15V Tj=150oC Max. 2.30 Unit V μC 13 A 0.28 mJ 0.7 μC 14 A 0.48 mJ 0.8 μC 15 A 0.58 mJ NTC Characteristics TC=25oC unless otherwise noted Symbol R25 ∆R/R P25 Parameter Rated Resistance Deviation of R100 Power Dissipation B25/50 B-value Test Conditions Min. TC=100oC,R100=1486.1Ω Typ. 22.0 -5 Max. 5 200 R2=R25exp[B25/50(1/T21/(298.15K))] 4000 Unit kΩ % mW K Module Characteristics TC=25oC unless otherwise noted Symbol RthJC RthCH M G Parameter Junction-to-Case (per IGBT-inverter) Junction-to-Case (per Diode-inverter) Junction-to-Case (per Diode-rectifier) Junction-to-Case (per IGBT-brake) Junction-to-Case (per Diode-brake) Case-to-Heatsink (per IGBT-inverter) Case-to-Heatsink (per Diode-inverter) Case-to-Heatsink (per Diode-rectifier) Case-to-Heatsink (per IGBT-brake) Case-to-Heatsink (per Diode-brake) Case-to-Heatsink (per Module) Mounting Torque, Screw M4 Weight of Module ©2016 STARPOWER Semiconductor Ltd. Min. Typ. 0.962 1.426 1.019 1.232 1.866 0.493 0.731 0.523 0.632 0.957 0.029 2.0 6/12 Unit K/W K/W 2.2 42 2/3/2016 Max. 1.058 1.569 1.121 1.355 2.053 N.m g SX0A GD15PJY120F2S IGBT Module 30 30 VGE=15V VCE=20V 25 25 20 20 IC [A] IC [A] 25oC 150oC 15 10 15 10 150oC 5 5 25oC 0 0 0 0.5 1 1.5 2 2.5 VCE [V] 3 3.5 Fig 1. IGBT-inverter Output Characteristics 5 7 8 9 10 11 12 13 VGE [V] Fig 2. IGBT-inverter Transfer Characteristics 10 7 VCC=600V RG=39Ω VGE=±15V Tj=150oC 6 5 VCC=600V IC=15A VGE=±15V Tj=150oC 9 8 7 6 4 3 E [mJ] E [mJ] 6 Eon Eon 5 4 3 2 2 Eoff 1 1 0 Eoff 0 0 5 10 15 20 IC [A] 25 30 Fig 3. IGBT-inverter Switching Loss vs. IC ©2016 STARPOWER Semiconductor Ltd. 0 100 200 RG [Ω] 300 400 Fig 4. IGBT-inverter Switching Loss vs. RG 2/3/2016 7/12 SX0A GD15PJY120F2S IGBT Module 10 35 Module 30 25 ZthJH [K/W] IC [A] IGBT 20 15 1 10 RG=39Ω VGE=±15V Tj=150oC 5 i: 1 2 3 4 ri[K/W]: 0.0704 0.1636 0.5698 0.6512 0.0005 0.005 0.05 0.2 τi[s]: 0 0 350 700 VCE [V] 1050 0.1 0.001 1400 Fig 5. IGBT-inverter RBSOA 0.01 0.1 t [s] 1 10 Fig 6. IGBT-inverter Transient Thermal Impedance 20 1 18 16 0.8 Erec 14 0.6 E [mJ] IF [A] 12 10 8 0.4 150oC VCC=600V RG=39Ω VGE=-15V Tj=150oC 6 25oC 4 0.2 2 0 0 0 0.5 1 1.5 VF [V] 2 2.5 Fig 7. Diode-inverter Forward Characteristics ©2016 STARPOWER Semiconductor Ltd. 0 5 10 15 20 IF [A] 25 30 Fig 8. Diode-inverter Switching Loss vs. IF 2/3/2016 8/12 SX0A GD15PJY120F2S IGBT Module 0.8 10 0.7 0.6 Diode Erec ZthJH [K/W] E [mJ] 0.5 0.4 0.3 1 VCC=600V IF=15A VGE=-15V Tj=150oC 0.2 0.1 i: 1 2 3 4 ri[K/W]: 0.1447 0.3298 0.8852 0.7973 τi[s]: 0.0005 0.005 0.05 0.2 0 0 100 200 RG [Ω] 300 0.1 0.001 400 Fig 9. Diode-inverter Switching Loss vs. RG 0.01 10 20 VGE=15V 18 25 16 14 20 IC [A] 12 IF [A] 1 Fig 10. Diode-inverter Transient Thermal Impedance 30 15 0.1 t [s] 150oC 25oC 150oC 10 8 10 25oC 6 4 5 2 0 0 0.5 0.6 0.7 0.8 0.9 1 VF [V] 1.1 1.2 1.3 Fig 11. Diode-rectifier Forward Characteristics ©2016 STARPOWER Semiconductor Ltd. 0 0.5 1 1.5 2 2.5 VCE [V] 3 3.5 Fig 12. IGBT-brake Output Characteristics 2/3/2016 9/12 SX0A GD15PJY120F2S IGBT Module 100 20 18 16 14 10 R [kΩ] IF [A] 12 25oC 10 150oC 8 1 6 4 2 0 0.1 0 0.5 1 1.5 2 VF [V] 2.5 3 Fig 13. Diode-brake Forward Characteristics ©2016 STARPOWER Semiconductor Ltd. 0 30 60 90 TC [oC] 120 150 Fig 14. NTC Temperature Characteristic 2/3/2016 10/12 SX0A GD15PJY120F2S IGBT Module Circuit Schematic 4,5 6,7 8 28 29 30 31 20 21 19 23 24 22 26 27 25 9 17 18 1 2,3 32 14 15 16 11 12 13 10 Package Dimensions Dimensions in Millimeters ©2016 STARPOWER Semiconductor Ltd. 2/3/2016 11/12 SX0A GD15PJY120F2S IGBT Module Terms and Conditions of Usage The data contained in this product datasheet is exclusively intended for technically trained staff. you and your technical departments will have to evaluate the suitability of the product for the intended application and the completeness of the product data with respect to such application. This product data sheet is describing the characteristics of this product for which a warranty is granted. Any such warranty is granted exclusively pursuant the terms and conditions of the supply agreement. There will be no guarantee of any kind for the product and its characteristics. Should you require product information in excess of the data given in this product data sheet or which concerns the specific application of our product, please contact the sales office, which is responsible for you (see www.powersemi.cc), For those that are specifically interested we may provide application notes. Due to technical requirements our product may contain dangerous substances. For information on the types in question please contact the sales office, which is responsible for you. Should you intend to use the Product in aviation applications, in health or live endangering or life support applications, please notify. If and to the extent necessary, please forward equivalent notices to your customers. Changes of this product data sheet are reserved. ©2016 STARPOWER Semiconductor Ltd. 2/3/2016 12/12 SX0A
GD15PJY120F2S 价格&库存
很抱歉,暂时无法提供与“GD15PJY120F2S”相匹配的价格&库存,您可以联系我们找货
