GD150HFU120C2S
IGBT Module
STARPOWER
IGBT
SEMICONDUCTORTM
GD150HFU120C2S
Molding Type Module
1200V/150A 2 in one-package
General Description
STARPOWER IGBT Power Module provides ultrafast
switching speed as well as short circuit ruggedness.
It’s designed for the applications such as electronic
welder and inductive heating.
Features
NPT IGBT technology
10μs short circuit capability
Low switching losses
Rugged with ultrafast performance
VCE(sat) with positive temperature coefficient
Low inductance case
Fast & soft reverse recovery anti-parallel FWD
Isolated copper baseplate using DBC technology
Equivalent Circuit Schematic
Typical Applications
Switching mode power supplies
Inductive heating
Electronic welder
©2014 STARPOWER Semiconductor Ltd.
11/17/2014
1/9
Rev.C
GD150HFU120C2S
IGBT Module
Absolute Maximum Ratings TC=25℃ unless otherwise noted
Symbol
Description
GD150HFU120C2S
Units
VCES
Collector-Emitter Voltage
1200
V
VGES
Gate-Emitter Voltage
±20
V
IC
Collector Current @ TC=25℃
@ TC=80℃
280
150
A
ICM(1)
Pulsed Collector Current tp=1ms
300
A
IF
Diode Continuous Forward Current
150
A
IFM(1)
Diode Maximum Forward Current
300
A
PD
Maximum power Dissipation @ Tj=150℃
1147
W
Tj
Maximum Junction Temperature
150
TSTG
Storage Temperature Range
-40 to +125
VISO
Isolation Voltage RMS,f=50Hz,t=1min
2500
V
Power Terminal Screw:M6
2.5 to 5.0
N.m
Mounting Screw:M6
3.0 to 6.0
N.m
Mounting Torque
Notes:
(1) Repetitive rating: Pulse width limited by max. junction temperature
Electrical Characteristics of IGBT TC=25℃ unless otherwise noted
Off Characteristics
Symbol
Parameter
Test Conditions
Min.
Typ.
Max.
Units
V(BR)CES
Collector-Emitter
Breakdown Voltage
Tj=25℃
ICES
Collector Cut-Off Current
VCE=VCES,VGE=0V,
Tj=25℃
5.0
mA
IGES
Gate-Emitter Leakage
Current
VGE=VGES,VCE=0V,
Tj=25℃
400
nA
1200
V
On Characteristics
Symbol
Parameter
VGE(th)
Gate-Emitter Threshold
Voltage
VCE(sat)
Collector to Emitter
Saturation Voltage
Test Conditions
Min.
Typ.
Max.
Units
IC=1.5mA,VCE=VGE,
Tj=25℃
4.4
5.2
6.0
V
IC=150A,VGE=15V,
Tj=25℃
3.10
3.60
IC=150A,VGE=15V,
Tj=125℃
3.45
11/17/2014
V
2/9
Rev.C
GD150HFU120C2S
IGBT Module
Switching Characteristics
Symbol
Parameter
Test Conditions
Min.
Typ.
Max.
Units
td(on)
Turn-On Delay Time
612
ns
tr
Rise Time
116
ns
td(off)
Turn-Off Delay Time
546
ns
tf
Fall Time
125
ns
Eon
Turn-On Switching
Loss
14.7
mJ
Eoff
Turn-Off Switching
Loss
8.9
mJ
td(on)
Turn-On Delay Time
609
ns
tr
Rise Time
116
ns
td(off)
Turn-Off Delay Time
564
ns
tf
Fall Time
148
ns
Eon
Turn-On Switching
Loss
17.5
mJ
Eoff
Turn-Off Switching
Loss
11.0
mJ
Cies
Input Capacitance
12.7
nF
Coes
Output Capacitance
1.14
nF
Cres
Reverse Transfer
Capacitance
0.46
nF
1400
A
2.4
Ω
VCC=600V,IC=150A,
RG=6.8Ω,VGE=±15V,
L=200nH,Tj=25℃
VCC=600V,IC=150A,
RG=6.8Ω,VGE=±15V,
L=200nH,Tj=125℃
VCE=30V,f=1MHz,
VGE=0V
TP≤10μs,VGE=15V,
Tj=25℃,VCC=600V,
VCEM≤1200V
ISC
SC Data
RGint
Internal Gate Resistance
LCE
Stray Inductance
RCC’+EE’
Module Lead Resistance,
Terminal To Chip
18
0.32
TC=25℃
nH
mΩ
Electrical Characteristics of DIODE TC=25℃ unless otherwise noted
Symbol
Parameter
VF
Diode Forward
Voltage
Qr
Recovered Charge
IRM
Peak Reverse
Recovery Current
Erec
Reverse Recovery
Energy
Test Conditions
IF=150A
IF=150A,
VR=600V,
di/dt=-1500A/μs,
VGE=-15V
Typ.
Max.
Tj=25℃
1.75
2.15
Tj=125℃
1.80
Tj=25℃
8.2
Tj=125℃
19.1
Tj=25℃
85
Tj=125℃
125
Tj=25℃
4.2
Tj=125℃
8.4
11/17/2014
Min.
3/9
Units
V
μC
A
mJ
Rev.C
GD150HFU120C2S
IGBT Module
Thermal Characteristics
Symbol
Parameter
Typ.
Max.
Units
RθJC
Junction-to-Case (per IGBT)
0.109
K/W
RθJC
Junction-to-Case (per DIODE)
0.180
K/W
RθCS
Case-to-Sink (Conductive grease applied)
G
Weight of Module
11/17/2014
0.035
K/W
300
g
4/9
Rev.C
GD150HFU120C2S
IGBT Module
Fig 1. IGBT Typical Output Characteristics Fig 2. IGBT Typical Transfer Characteristics
Fig 3. IGBT Switching Loss vs. IC
Fig 4. IGBT Switching Loss vs. RG
11/17/2014
5/9
Rev.C
GD150HFU120C2S
Fig 5. RBSOA
IGBT Module
Fig 6. IGBT Transient Thermal Impedance
Fig 7. Diode Typical Forward Characteristics
Fig 8. Diode Switching Loss vs. IF
11/17/2014
6/9
Rev.C
GD150HFU120C2S
Fig 9. Diode Switching Loss vs. RG
IGBT Module
Fig 10. Diode Transient Thermal Impedance
11/17/2014
7/9
Rev.C
GD150HFU120C2S
IGBT Module
Package Dimension
Dimensions in Millimeters
11/17/2014
8/9
Rev.C
GD150HFU120C2S
IGBT Module
Terms and Conditions of Usage
The data contained in this product datasheet is exclusively intended for technically trained staff.
You and your technical departments will have to evaluate the suitability of the product for the
intended application and the completeness of the product data with respect to such application.
This product data sheet is describing the characteristics of this product for which a warranty is
granted. Any such warranty is granted exclusively pursuant the terms and conditions of the supply
agreement. There will be no guarantee of any kind for the product and its characteristics.
Should you require product information in excess of the data given in this product data sheet or
which concerns the specific application of our product, please contact the sales office, which is
responsible for you (see www.powersemi.cc), For those that are specifically interested we may
provide application notes.
Due to technical requirements our product may contain dangerous substances. For information on
the types in question please contact the sales office, which is responsible for you.
Should you intend to use the Product in aviation applications, in health or live endangering or life
support applications, please notify.
If and to the extent necessary, please forward equivalent notices to your customers.
Changes of this product data sheet are reserved.
11/17/2014
9/9
Rev.C
很抱歉,暂时无法提供与“GD150HFU120C2S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+334.96200
- 30+318.12480
