GD100FFY120C5S
GD100FFY120C5S
    STARPOWER(斯达)
    STARPOWER - GD100FFY120C5S - IGBT Array & Module Transistor, Six N Channel, 157 A, 1.7 V, 512 W, 1.2...
GD100FFY120C5S 数据手册
GD100FFY120C5S IGBT Module STARPOWER SEMICONDUCTOR IGBT GD100FFY120C5S 1200V/100A 6 in one-package General Description STARPOWER IGBT Power Module provides ultra low conduction loss as well as short circuit ruggedness. They are designed for the applications such as general inverters and UPS. Features        Low VCE(sat) Trench IGBT technology 10μs short circuit capability VCE(sat) with positive temperature coefficient Maximum junction temperature 175oC Low inductance case Fast & soft reverse recovery anti-parallel FWD Isolated copper baseplate using DBC technology Typical Applications    Inverter for motor drive AC and DC servo drive amplifier Uninterruptible power supply Equivalent Circuit Schematic ©2016 STARPOWER Semiconductor Ltd. 4/30/2016 1/9 SN0B GD100FFY120C5S IGBT Module Absolute Maximum Ratings TC=25oC unless otherwise noted IGBT Symbol VCES VGES IC ICM PD Description Collector-Emitter Voltage Gate-Emitter Voltage Collector Current @ TC=25oC @ TC=100oC Pulsed Collector Current tp=1ms Maximum Power Dissipation @ Tj=175oC Value 1200 ±20 157 100 200 512 Unit V V Description Repetitive Peak Reverse Voltage Diode Continuous Forward Current Diode Maximum Forward Current tp=1ms Value 1200 100 200 Unit V A A Value 175 -40 to +150 -40 to +125 4000 Unit o C o C o C V A A W Diode Symbol VRRM IF IFM Module Symbol Tjmax Tjop TSTG VISO Description Maximum Junction Temperature Operating Junction Temperature Storage Temperature Range Isolation Voltage RMS,f=50Hz,t=1min ©2016 STARPOWER Semiconductor Ltd. 4/30/2016 2/9 SN0B GD100FFY120C5S IGBT Module IGBT Characteristics TC=25oC unless otherwise noted Symbol VCE(sat) VGE(th) ICES IGES RGint td(on) tr td(off) tf Eon Eoff td(on) tr td(off) tf Eon Eoff td(on) tr td(off) tf Eon Eoff ISC Parameter Collector to Emitter Saturation Voltage Gate-Emitter Threshold Voltage Collector Cut-Off Current Gate-Emitter Leakage Current Internal Gate Resistance Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss SC Data Test Conditions IC=100A,VGE=15V, Tj=25oC IC=100A,VGE=15V, Tj=125oC IC=100A,VGE=15V, Tj=150oC IC=2.5mA,VCE=VGE, Tj=25oC VCE=VCES,VGE=0V, Tj=25oC VGE=VGES,VCE=0V, Tj=25oC Min. Max. 1.70 2.15 1.95 Unit V 2.00 5.2 VCC=600V,IC=100A, RG=1.6Ω,VGE=±15V, Tj=25oC VCC=600V,IC=100A, RG=1.6Ω,VGE=±15V, Tj=125oC VCC=600V,IC=100A, RG=1.6Ω,VGE=±15V, Tj=150oC tP≤10μs,VGE=15V, Tj=150oC,VCC=900V, VCEM≤1200V ©2016 STARPOWER Semiconductor Ltd. Typ. 4/30/2016 6.0 6.8 V 1.0 mA 100 nA 7.5 170 32 360 86 Ω ns ns ns ns 5.90 mJ 6.05 mJ 180 42 470 165 ns ns ns ns 9.10 mJ 9.35 mJ 181 43 480 186 ns ns ns ns 10.0 mJ 10.5 mJ 400 A 3/9 SN0B GD100FFY120C5S IGBT Module Diode Characteristics TC=25oC unless otherwise noted Symbol VF Qr IRM Erec Qr IRM Erec Qr IRM Erec Parameter Diode Forward Voltage Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Test Conditions IF=100A,VGE=0V,Tj=25oC IF=100A,VGE=0V,Tj=125oC IF=100A,VGE=0V,Tj=150oC Min. Typ. 1.70 1.65 1.65 9.0 VR=600V,IF=100A, -di/dt=2800A/μs,VGE=-15V Tj=25oC VR=600V,IF=100A, -di/dt=2800A/μs,VGE=-15V Tj=125oC VR=600V,IF=100A, -di/dt=2800A/μs,VGE=-15V Tj=150oC Max. 2.15 Unit V μC 110 A 3.32 mJ 16.2 μC 120 A 5.70 mJ 19.5 μC 123 A 7.13 mJ NTC Characteristics TC=25oC unless otherwise noted Symbol R25 ∆R/R P25 Parameter Rated Resistance Deviation of R100 Power Dissipation B25/50 B-value B25/80 B-value B25/100 B-value Test Conditions Min. TC=100oC,R100=493.3Ω Typ. 5.0 -5 Max. 5 20.0 R2=R25exp[B25/50(1/T21/(298.15K))] R2=R25exp[B25/80(1/T21/(298.15K))] R2=R25exp[B25/100(1/T21/(298.15K))] Unit kΩ % mW 3375 K 3411 K 3433 K Module Characteristics TC=25oC unless otherwise noted Symbol LCE RCC’+EE’ RthJC RthCH M G Parameter Stray Inductance Module Lead Resistance, Terminal to Chip Junction-to-Case (per IGBT) Junction-to-Case (per Diode) Case-to-Heatsink (per IGBT) Case-to-Heatsink (per Diode) Case-to-Heatsink (per Module) Mounting Torque, Screw M5 Weight of Module ©2016 STARPOWER Semiconductor Ltd. Min. Typ. 19 1.80 Max. 0.293 0.505 0.190 0.327 0.020 K/W K/W 3.0 6.0 200 4/30/2016 Unit nH mΩ 4/9 N.m g SN0B GD100FFY120C5S IGBT Module 200 200 VGE=15V 175 150 150 125 125 IC [A] IC [A] 175 100 100 75 75 50 50 Tj=25℃ Tj=125℃ Tj=150℃ 25 VCE=20V Tj=25℃ Tj=125℃ Tj=150℃ 25 0 0 0 0.5 1 1.5 2 2.5 VCE [V] 3 3.5 4 Fig 1. IGBT Output Characteristics 5 6 7 8 9 10 11 12 13 VGE [V] Fig 2. IGBT Transfer Characteristics 25 35 Eon Tj=125℃ Eoff Tj=125℃ Eon Tj=150℃ Eoff Tj=150℃ 30 Eon Tj=125℃ Eoff Tj=125℃ Eon Tj=150℃ Eoff Tj=150℃ 20 VCC=600V RG=1.6Ω VGE=±15V 20 15 15 E [mJ] E [mJ] 25 10 10 VCC=600V IC=100A VGE=±15V 5 5 0 0 0 25 50 75 100 125 150 175 200 IC [A] Fig 3. IGBT Switching Loss vs. IC ©2016 STARPOWER Semiconductor Ltd. 0 4 8 RG [Ω] 12 Fig 4. IGBT Switching Loss vs. RG 4/30/2016 5/9 SN0B 16 GD100FFY120C5S IGBT Module 1 220 200 Module 180 IGBT 160 ZthJC [K/W] IC [A] 140 120 100 0.1 80 60 RG=1.6Ω VGE=±15V Tj=150oC 40 20 i: 1 2 3 4 ri[K/W]: 0.0176 0.0967 0.0937 0.0850 0.01 0.02 0.05 0.1 τi[s]: 0 0 350 700 VCE [V] 1050 0.01 0.001 1400 Fig 5. RBSOA 0.1 t [s] 1 10 Fig 6. IGBT Transient Thermal Impedance 200 9 Tj=25℃ Tj=125℃ Tj=150℃ 175 Erec Tj=125℃ 8 Erec Tj=150℃ 7 150 6 E [mJ] 125 IF [A] 0.01 100 75 5 4 3 50 VCC=600V RG=1.6Ω VGE=-15V 2 25 1 0 0 0 0.5 1 1.5 VF [V] 2 2.5 Fig 7. Diode Forward Characteristics ©2016 STARPOWER Semiconductor Ltd. 0 25 50 75 100 125 150 175 200 IF [A] Fig 8. Diode Switching Loss vs. IF 4/30/2016 6/9 SN0B GD100FFY120C5S IGBT Module 1 8 Erec Tj=125℃ 7 Diode Erec Tj=150℃ ZthJC [K/W] E [mJ] 6 5 4 0.1 3 VCC=600V IF=100A VGE=-15V 2 i: 1 2 3 4 ri[K/W]: 0.0303 0.1667 0.1616 0.1464 0.01 0.02 0.05 0.1 τi[s]: 1 0 4 8 RG [Ω] 12 16 Fig 9. Diode Switching Loss vs. RG 0.01 0.001 0.01 0.1 t [s] 1 Fig 10. Diode Transient Thermal Impedance 100 R [kΩ] 10 1 0.1 0 30 60 90 o TC [ C] 120 10 150 Fig 11. NTC Temperature Characteristic ©2016 STARPOWER Semiconductor Ltd. 4/30/2016 7/9 SN0B GD100FFY120C5S IGBT Module Circuit Schematic Package Dimensions Dimensions in Millimeters ©2016 STARPOWER Semiconductor Ltd. 4/30/2016 8/9 SN0B GD100FFY120C5S IGBT Module Terms and Conditions of Usage The data contained in this product datasheet is exclusively intended for technically trained staff. you and your technical departments will have to evaluate the suitability of the product for the intended application and the completeness of the product data with respect to such application. This product data sheet is describing the characteristics of this product for which a warranty is granted. Any such warranty is granted exclusively pursuant the terms and conditions of the supply agreement. There will be no guarantee of any kind for the product and its characteristics. Should you require product information in excess of the data given in this product data sheet or which concerns the specific application of our product, please contact the sales office, which is responsible for you (see www.powersemi.cc), For those that are specifically interested we may provide application notes. Due to technical requirements our product may contain dangerous substances. For information on the types in question please contact the sales office, which is responsible for you. Should you intend to use the Product in aviation applications, in health or live endangering or life support applications, please notify. If and to the extent necessary, please forward equivalent notices to your customers. Changes of this product data sheet are reserved. ©2016 STARPOWER Semiconductor Ltd. 4/30/2016 9/9 SN0B
GD100FFY120C5S 价格&库存
很抱歉,暂时无法提供与“GD100FFY120C5S”相匹配的价格&库存,您可以联系我们找货
