GD150PIY120C6SN
GD150PIY120C6SN
    STARPOWER(斯达)
    STARPOWER - GD150PIY120C6SN - IGBT Module, PIM Three Phase Input Rectifier, 292 A, 1.7 V, 1.111 kW, ...
GD150PIY120C6SN 数据手册
GD150PIY120C6SN IGBT Module STARPOWER SEMICONDUCTOR IGBT GD150PIY120C6SN 1200V/150A PIM in one-package General Description STARPOWER IGBT Power Module provides ultra low conduction loss as well as short circuit ruggedness. They are designed for the applications such as general inverters and UPS. Features        Low VCE(sat) Trench IGBT technology 10μs short circuit capability VCE(sat) with positive temperature coefficient Maximum junction temperature 175oC Low inductance case Fast & soft reverse recovery anti-parallel FWD Isolated copper baseplate using DBC technology Typical Applications    Inverter for motor drive AC and DC servo drive amplifier Uninterruptible power supply Equivalent Circuit Schematic ©2017 STARPOWER Semiconductor Ltd. 1/29/2017 1/13 SN0C GD150PIY120C6SN IGBT Module Absolute Maximum Ratings TC=25oC unless otherwise noted IGBT-inverter Symbol VCES VGES IC ICM PD Description Collector-Emitter Voltage Gate-Emitter Voltage Collector Current @ TC=25oC @ TC=100oC Pulsed Collector Current tp=1ms Maximum Power Dissipation @ Tj=175oC Values 1200 ±20 292 150 300 1111 Unit V V Values 1200 150 300 Unit V A A Value 1600 150 1800 16200 Unit V A A A2s Value 1200 ±20 200 100 200 833 Unit V V Value 1200 50 100 Unit V A A Value 175 150 -40 to +150 -40 to +125 2500 Unit A A W Diode-inverter Symbol VRRM IF IFM Description Repetitive Peak Reverse Voltage Diode Continuous Forward Current Diode Maximum Forward Current tp=1ms Diode-rectifier Symbol VRRM IO IFSM I2t Description Repetitive Peak Reverse Voltage Average Output Current 50Hz/60Hz,sine wave Surge Forward Current VR=0V,tp=10ms,Tj=45oC I2t-value,VR=0V,tp=10ms,Tj=45oC IGBT-brake Symbol VCES VGES IC ICM PD Description Collector-Emitter Voltage Gate-Emitter Voltage Collector Current @ TC=25oC @ TC=100oC Pulsed Collector Current tp=1ms Maximum Power Dissipation @ Tj=175oC A A W Diode-brake Symbol VRRM IF IFM Description Repetitive Peak Reverse Voltage Diode Continuous Forward Current Diode Maximum Forward Current tp=1ms Module Symbol Tjmax Tjop TSTG VISO Description Maximum Junction Temperature(inverter,brake) Maximum Junction Temperature (rectifier) Operating Junction Temperature Storage Temperature Range Isolation Voltage RMS,f=50Hz,t=1min ©2017 STARPOWER Semiconductor Ltd. 1/29/2017 2/13 o C o C C V o SN0C GD150PIY120C6SN IGBT Module IGBT-inverter Characteristics TC=25oC unless otherwise noted Symbol VCE(sat) VGE(th) ICES IGES RGint Cies Cres QG td(on) tr td(off) tf Eon Eoff td(on) tr td(off) tf Eon Eoff td(on) tr td(off) tf Eon Eoff ISC Parameter Collector to Emitter Saturation Voltage Gate-Emitter Threshold Voltage Collector Cut-Off Current Gate-Emitter Leakage Current Internal Gate Resistance Input Capacitance Reverse Transfer Capacitance Gate Charge Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss SC Data Test Conditions IC=150A,VGE=15V, Tj=25oC IC=150A,VGE=15V, Tj=125oC IC=150A,VGE=15V, Tj=150oC IC=3.75mA,VCE=VGE, Tj=25oC VCE=VCES,VGE=0V, Tj=25oC VGE=VGES,VCE=0V, Tj=25oC Min. Max. 1.70 2.15 1.95 Unit V 2.00 5.2 VCE=25V,f=1MHz, VGE=0V VGE=-15…+15V VCC=600V,IC=150A, RG=1.1Ω,VGE=±15V, Tj=25oC VCC=600V,IC=150A, RG=1.1Ω,VGE=±15V, Tj=125oC VCC=600V,IC=150A, RG=1.1Ω,VGE=±15V, Tj=150oC tP≤10μs,VGE=15V, Tj=150oC,VCC=900V, VCEM≤1200V ©2017 STARPOWER Semiconductor Ltd. Typ. 1/29/2017 6.0 6.8 V 1.0 mA 400 nA 5.0 10.5 Ω nF 0.60 nF 1.30 123 27 407 66 μC ns ns ns ns 5.35 mJ 11.0 mJ 139 32 495 116 ns ns ns ns 9.63 mJ 16.5 mJ 144 32 528 138 ns ns ns ns 10.7 mJ 17.6 mJ 600 A 3/13 SN0C GD150PIY120C6SN IGBT Module Diode-inverter Characteristics TC=25oC unless otherwise noted Symbol VF Qr IRM Erec Qr IRM Erec Qr IRM Erec Parameter Diode Forward Voltage Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Test Conditions IF=150A,VGE=0V,Tj=25oC IF=150A,VGE=0V,Tj=125oC IF=150A,VGE=0V,Tj=150oC Min. VR=600V,IF=150A, -di/dt=5800A/μs,VGE=-15V Tj=25oC VR=600V,IF=150A, -di/dt=5800A/μs,VGE=-15V Tj=125oC VR=600V,IF=150A, -di/dt=5800A/μs,VGE=-15V Tj=150oC Typ. 1.65 1.65 1.65 13.3 Max. 2.10 Units V μC 209 A 6.65 mJ 23.8 μC 228 A 10.9 mJ 26.6 μC 238 A 12.8 mJ Diode-rectifier Characteristics TC=25oC unless otherwise noted Symbol VF IR Parameter Diode Forward Voltage Reverse Current Test Conditions Min. IC=150A,Tj=150oC Typ. Max. 1.17 Tj=150oC,VR=1600V ©2017 STARPOWER Semiconductor Ltd. V 2.0 1/29/2017 4/13 Unit mA SN0C GD150PIY120C6SN IGBT Module IGBT-brake Characteristics TC=25oC unless otherwise noted Symbol VCE(sat) VGE(th) ICES IGES RGint Cies Cres QG td(on) tr td(off) tf Eon Eoff td(on) tr td(off) tf Eon Eoff td(on) tr td(off) tf Eon Eoff ISC Parameter Collector to Emitter Saturation Voltage Gate-Emitter Threshold Voltage Collector Cut-Off Current Gate-Emitter Leakage Current Internal Gate Resistance Input Capacitance Reverse Transfer Capacitance Gate Charge Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss SC Data Test Conditions IC=100A,VGE=15V, Tj=25oC IC=100A,VGE=15V, Tj=125oC IC=100A,VGE=15V, Tj=150oC IC=2.50mA,VCE=VGE, Tj=25oC VCE=VCES,VGE=0V, Tj=25oC VGE=VGES,VCE=0V, Tj=25oC Min. Max. 1.70 2.15 1.95 Unit V 2.00 5.2 VCE=25V,f=1MHz, VGE=0V VGE=-15…+15V VCC=600V,IC=100A, RG=1.6Ω,VGE=±15V, Tj=25oC VCC=600V,IC=100A, RG=1.6Ω,VGE=±15V, Tj=125oC VCC=600V,IC=100A, RG=1.6Ω,VGE=±15V, Tj=150oC tP≤10μs,VGE=15V, Tj=150oC,VCC=900V, VCEM≤1200V ©2017 STARPOWER Semiconductor Ltd. Typ. 1/29/2017 6.0 6.8 V 1.0 mA 100 nA 7.5 7.00 Ω nF 0.40 nF 0.88 170 32 360 86 μC ns ns ns ns 5.90 mJ 6.05 mJ 180 42 470 165 ns ns ns ns 9.10 mJ 9.35 mJ 181 43 480 186 ns ns ns ns 10.0 mJ 10.5 mJ 400 A 5/13 SN0C GD150PIY120C6SN IGBT Module Diode-brake Characteristics TC=25oC unless otherwise noted Symbol VF Qr IRM Erec Qr IRM Erec Qr IRM Erec Parameter Diode Forward Voltage Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Test Conditions IF=50A,VGE=0V,Tj=25oC IF=50A,VGE=0V,Tj=125oC IF=50A,VGE=0V,Tj=150oC Min. VR=600V,IF=50A, -di/dt=1400A/μs,VGE=-15V Tj=25oC VR=600V,IF=50A, -di/dt=1400A/μs,VGE=-15V Tj=125oC VR=600V,IF=50A, -di/dt=1400A/μs,VGE=-15V Tj=150oC Typ. 1.70 1.65 1.65 5.2 Max. 2.15 Unit V μC 51 A 1.62 mJ 8.4 μC 57 A 2.85 mJ 9.5 μC 60 A 3.52 mJ NTC Characteristics TC=25oC unless otherwise noted Symbol R25 ∆R/R P25 Parameter Rated Resistance Deviation of R100 Power Dissipation B25/50 B-value B25/80 B-value B25/100 B-value Test Conditions Min. TC=100 oC,R100=493.3Ω Max. -5 R2=R25exp[B25/50(1/T21/(298.15K))] R2=R25exp[B25/80(1/T21/(298.15K))] R2=R25exp[B25/100(1/T21/(298.15K))] ©2017 STARPOWER Semiconductor Ltd. Typ. 5.0 1/29/2017 5 Unit kΩ % 20.0 mW 3375 K 3411 K 3433 K 6/13 SN0C GD150PIY120C6SN IGBT Module Module Characteristics TC=25oC unless otherwise noted Symbol LCE RCC’+EE’ RAA’+CC’ RthJC RthCH M G Parameter Min. Stray Inductance Module Lead Resistance,Terminal to Chip Junction-to-Case (per IGBT-inverter) Junction-to-Case (per Diode-inverter) Junction-to-Case (per Diode-rectifier) Junction-to-Case (per IGBT-brake) Junction-to-Case (per Diode-brake) Case-to-Heatsink (per IGBT-inverter) Case-to-Heatsink (per Diode-inverter) Case-to-Heatsink (per Diode-rectifier) Case-to-Heatsink (per IGBT-brake) Case-to-Heatsink (per Diode-brake) Case-to-Heatsink (per Module) Mounting Torque, Screw:M5 Weight of Module ©2017 STARPOWER Semiconductor Ltd. Typ. 40 4.00 3.00 Max. mΩ 0.135 0.300 0.249 0.180 0.472 0.117 0.260 0.216 0.156 0.409 0.009 K/W K/W 3.0 6.0 300 1/29/2017 Unit nH 7/13 N.m g SN0C GD150PIY120C6SN IGBT Module 300 300 250 250 200 200 IC [A] IC [A] VGE=15V 150 100 150 100 Tj=25℃ Tj=125℃ Tj=150℃ 50 50 0 Tj=25℃ Tj=125℃ Tj=150℃ 0 0 0.5 1 1.5 2 2.5 VCE [V] 3 3.5 Fig 1. IGBT-inverter Output Characteristics 5 6 7 8 9 10 11 12 13 VGE [V] Fig 2. IGBT-inverter Transfer Characteristics 35 35 Eon Tj=125℃ Eoff Tj=125℃ Eon Tj=150℃ Eoff Tj=150℃ 30 Eon Tj=125℃ Eoff Tj=125℃ Eon Tj=150℃ Eoff Tj=150℃ 30 25 25 VCC=600V RG=1.1Ω VGE=±15V 20 E [mJ] E [mJ] VCE=20V 15 10 20 15 10 5 VCC=600V IC=150A VGE=±15V 5 0 0 0 50 100 150 200 IC [A] 250 300 Fig 3. IGBT-inverter Switching Loss vs. IC ©2017 STARPOWER Semiconductor Ltd. 0 2 4 6 8 RG [Ω] 10 12 Fig 4. IGBT-inverter Switching Loss vs. RG 1/29/2017 8/13 SN0C GD150PIY120C6SN IGBT Module 1 350 Module 300 IGBT 250 ZthJC [K/W] IC [A] 0.1 200 150 0.01 100 RG=1.1Ω VGE=±15V Tj=150oC 50 i: 1 2 3 4 ri[K/W]: 0.0080 0.0445 0.0433 0.0392 0.01 0.02 0.05 0.1 τi[s]: 0 0 350 700 VCE [V] 1050 0.001 0.001 1400 Fig 5. IGBT-inverter RBSOA 0.1 t [s] 1 10 Fig 6. IGBT-inverter Transient Thermal Impedance 300 18 Tj=25℃ Tj=125℃ Tj=150℃ 250 Erec Tj=125℃ Erec Tj=150℃ 15 12 E [mJ] 200 IF [A] 0.01 150 100 9 6 50 VCC=600V RG=1.1Ω VGE=-15V 3 0 0 0 0.5 1 1.5 VF [V] 2 2.5 Fig 7. Diode-inverter Forward Characteristics ©2017 STARPOWER Semiconductor Ltd. 0 50 100 150 200 IF [A] 250 300 Fig 8. Diode-inverter Switching Loss vs. IF 1/29/2017 9/13 SN0C GD150PIY120C6SN IGBT Module 1 13 Erec Tj=125℃ 12 Diode Erec Tj=150℃ 11 ZthJC [K/W] E [mJ] 0.1 10 9 0.01 8 VCC=600V IF=150A VGE=-15V 7 i: 1 2 3 4 ri[K/W]: 0.0180 0.0990 0.0960 0.0870 0.01 0.02 0.05 0.1 τi[s]: 6 0 2 4 6 8 RG [Ω] 10 0.001 0.001 12 Fig 9. Diode-inverter Switching Loss vs. RG 0.01 0.1 t [s] 1 10 Fig 10. Diode-inverter Transient Thermal Impedance 200 300 Tj=25℃ VGE=15V 175 Tj=150℃ 250 150 125 IC [A] IF [A] 200 150 100 75 100 50 50 Tj=25℃ Tj=125℃ Tj=150℃ 25 0 0 0.4 0.6 0.8 1 1.2 VF [V] 1.4 1.6 Fig 11. Diode-rectifier Forward Characteristics ©2017 STARPOWER Semiconductor Ltd. 0 0.5 1 1.5 2 2.5 VCE [V] 3 3.5 Fig 12. IGBT-brake-chopper Output Characteristics 1/29/2017 10/13 SN0C GD150PIY120C6SN IGBT Module 100 100 Tj=25℃ Tj=125℃ Tj=150℃ 75 R [kΩ] IF [A] 10 50 1 25 0 0.1 0 0.5 1 1.5 VF [V] 2 2.5 Fig 13. Diode-brake-chopper Forward Characteristics ©2017 STARPOWER Semiconductor Ltd. 0 30 60 90 TC [oC] 120 Fig 14. NTC Temperature Characteristic 1/29/2017 11/13 SN0C 150 GD150PIY120C6SN IGBT Module Circuit Schematic 39,40,41 33,34,35 10 22 1,2,3 4,5,6 14 11,12,13 36,37,38 7,8,9 18 15,16,17 19,20,21 23 42,43,44 29 30,31,32 28 26 24 25 27 Package Dimensions Dimensions in Millimeters ©2017 STARPOWER Semiconductor Ltd. 1/29/2017 12/13 SN0C GD150PIY120C6SN IGBT Module Terms and Conditions of Usage The data contained in this product datasheet is exclusively intended for technically trained staff. you and your technical departments will have to evaluate the suitability of the product for the intended application and the completeness of the product data with respect to such application. This product data sheet is describing the characteristics of this product for which a warranty is granted. Any such warranty is granted exclusively pursuant the terms and conditions of the supply agreement. There will be no guarantee of any kind for the product and its characteristics. Should you require product information in excess of the data given in this product data sheet or which concerns the specific application of our product, please contact the sales office, which is responsible for you (see www.powersemi.cc), For those that are specifically interested we may provide application notes. Due to technical requirements our product may contain dangerous substances. For information on the types in question please contact the sales office, which is responsible for you. Should you intend to use the Product in aviation applications, in health or live endangering or life support applications, please notify. If and to the extent necessary, please forward equivalent notices to your customers. Changes of this product data sheet are reserved. ©2017 STARPOWER Semiconductor Ltd. 1/29/2017 13/13 SN0C
GD150PIY120C6SN 价格&库存
很抱歉,暂时无法提供与“GD150PIY120C6SN”相匹配的价格&库存,您可以联系我们找货
