GD150HFY120C1S
GD150HFY120C1S
    STARPOWER(斯达)
    GD150HFY120C1S
GD150HFY120C1S 数据手册
GD150HFY120C1S IGBT Module STARPOWER IGBT SEMICONDUCTOR GD150HFY120C1S 1200V/150A 2 in one-package General Description STARPOWER IGBT Power Module provides ultra low conduction loss as well as short circuit ruggedness. They are designed for the applications such as general inverters and UPS. Features        Low VCE(sat) Trench IGBT technology 10μs short circuit capability VCE(sat) with positive temperature coefficient Maximum junction temperature 175oC Low inductance case Fast & soft reverse recovery anti-parallel FWD Isolated copper baseplate using DBC technology Typical Applications    Inverter for motor drive AC and DC servo drive amplifier Uninterruptible power supply Equivalent Circuit Schematic ©2015 STARPOWER Semiconductor Ltd. 10/15/2013 1/6 Preliminary GD150HFY120C1S IGBT Module Absolute Maximum Ratings TC=25oC unless otherwise noted IGBT Symbol VCES VGES IC ICM PD Description Collector-Emitter Voltage Gate-Emitter Voltage Collector Current @ TC=25oC @ TC=100oC Pulsed Collector Current tp=1ms Maximum Power Dissipation @ Tj=175oC Value 1200 ±20 230 150 300 746 Unit V V Description Repetitive Peak Reverse Voltage Diode Continuous Forward Current Diode Maximum Forward Current tp=1ms Value 1200 150 300 Unit V A A Value 175 -40 to +150 -40 to +125 4000 Unit o C o C o C V A A W Diode Symbol VRRM IF IFM Module Symbol Tjmax Tjop TSTG VISO Description Maximum Junction Temperature Operating Junction Temperature Storage Temperature Range Isolation Voltage RMS,f=50Hz,t=1min ©2015 STARPOWER Semiconductor Ltd. 10/15/2013 2/6 Preliminary GD150HFY120C1S IGBT Module IGBT Characteristics TC=25oC unless otherwise noted Symbol VCE(sat) VGE(th) ICES IGES RGint Cies Cres QG td(on) tr td(off) tf Eon Eoff td(on) tr td(off) tf Eon Eoff td(on) tr td(off) tf Eon Eoff ISC Parameter Collector to Emitter Saturation Voltage Gate-Emitter Threshold Voltage Collector Cut-Off Current Gate-Emitter Leakage Current Internal Gate Resistance Input Capacitance Reverse Transfer Capacitance Gate Charge Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss SC Data Test Conditions IC=150A,VGE=15V, Tj=25oC IC=150A,VGE=15V, Tj=125oC IC=150A,VGE=15V, Tj=150oC IC=3.75mA,VCE=VGE, Tj=25oC VCE=VCES,VGE=0V, Tj=25oC VGE=VGES,VCE=0V, Tj=25oC Min. Max. 1.65 2.10 1.95 Unit V 2.00 5.2 VCE=30V,f=1MHz, VGE=0V VGE=-15…+15V VCC=600V,IC=150A, RG=1.0Ω,VGE=±15V, Tj=25oC VCC=600V,IC=150A, RG=1.0Ω,VGE=±15V, Tj=125oC VCC=600V,IC=150A, RG=1.0Ω,VGE=±15V, Tj=150oC tP≤10μs,VGE=15V, Tj=150oC,VCC=900V, VCEM≤1200V ©2015 STARPOWER Semiconductor Ltd. Typ. 10/15/2013 6.0 6.8 V 5.0 mA 400 nA 2.0 13.0 Ω nF 0.42 nF 0.82 292 59 344 191 μC ns ns ns ns 4.55 mJ 11.6 mJ 297 65 370 315 ns ns ns ns 6.85 mJ 16.1 mJ 288 65 373 342 ns ns ns ns 7.45 mJ 18.8 mJ 600 A 3/6 Preliminary GD150HFY120C1S IGBT Module Diode Characteristics TC=25oC unless otherwise noted Symbol VF Qr IRM Erec Qr IRM Erec Qr IRM Erec Parameter Diode Forward Voltage Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Test Conditions IF=150A,VGE=0V,Tj=25oC IF=150A,VGE=0V,Tj=125oC IF=150A,VGE=0V,Tj=150oC Min. Typ. 1.65 1.65 1.65 17.0 VR=600V,IF=150A, -di/dt=2700A/μs,VGE=-15V Tj=25oC VR=600V,IF=150A, -di/dt=2700A/μs,VGE=-15V Tj=125oC VR=600V,IF=150A, -di/dt=2700A/μs,VGE=-15V Tj=150oC Max. 2.05 Unit V μC 140 A 9.75 mJ 27.8 μC 175 A 14.9 mJ 31.8 μC 184 A 17.0 mJ Module Characteristics TC=25oC unless otherwise noted Symbol LCE RCC’+EE’ RθJC RθCS RθCS M G Parameter Min. Stray Inductance Module Lead Resistance, Terminal to Chip Junction-to-Case (per IGBT) Junction-to-Case (per Diode) Case-to-Sink (per IGBT) Case-to-Sink (per Diode) Case-to-Sink Terminal Connection Torque, Screw M5 Mounting Torque, Screw M6 Weight of Module ©2015 STARPOWER Semiconductor Ltd. Typ. Max. 30 0.75 0.201 0.326 0.162 0.262 0.05 2.5 3.0 10/15/2013 4/6 K/W K/W K/W 5.0 5.0 150 Unit nH mΩ N.m g Preliminary GD150HFY120C1S IGBT Module Circuit Schematic Package Dimensions Dimensions in Millimeters ©2015 STARPOWER Semiconductor Ltd. 10/15/2013 5/6 Preliminary GD150HFY120C1S IGBT Module Terms and Conditions of Usage The data contained in this product datasheet is exclusively intended for technically trained staff. you and your technical departments will have to evaluate the suitability of the product for the intended application and the completeness of the product data with respect to such application. This product data sheet is describing the characteristics of this product for which a warranty is granted. Any such warranty is granted exclusively pursuant the terms and conditions of the supply agreement. There will be no guarantee of any kind for the product and its characteristics. Should you require product information in excess of the data given in this product data sheet or which concerns the specific application of our product, please contact the sales office, which is responsible for you (see www.powersemi.cc), For those that are specifically interested we may provide application notes. Due to technical requirements our product may contain dangerous substances. For information on the types in question please contact the sales office, which is responsible for you. Should you intend to use the Product in aviation applications, in health or live endangering or life support applications, please notify. If and to the extent necessary, please forward equivalent notices to your customers. Changes of this product data sheet are reserved. ©2015 STARPOWER Semiconductor Ltd. 10/15/2013 6/6 Preliminary
GD150HFY120C1S 价格&库存
很抱歉,暂时无法提供与“GD150HFY120C1S”相匹配的价格&库存,您可以联系我们找货
GD150HFY120C1S
  • 1+492.70988
  • 10+443.42119
库存:74
