GD35PJY120F5S
GD35PJY120F5S
    STARPOWER(斯达)
    STARPOWER - GD35PJY120F5S - IGBT Module, PIM Three Phase Input Rectifier, 63 A, 1.7 V, 225 W, 150 °C...
GD35PJY120F5S 数据手册
GD35PJY120F5S IGBT Module STARPOWER IGBT SEMICONDUCTOR GD35PJY120F5S 1200V/35A PIM in one-package General Description STARPOWER IGBT Power Module provides ultra low conduction loss as well as short circuit ruggedness. They are designed for the applications such as general inverters and UPS. Features        Low VCE(sat) Trench IGBT technology 10μs short circuit capability VCE(sat) with positive temperature coefficient Maximum junction temperature 175oC Low inductance case Fast & soft reverse recovery anti-parallel FWD Isolated heatsink using DBC technology Typical Applications    Inverter for motor drive AC and DC servo drive amplifier Uninterruptible power supply Equivalent Circuit Schematic ©2016 STARPOWER Semiconductor Ltd. 8/1/2016 1/13 SX0A GD35PJY120F5S IGBT Module Absolute Maximum Ratings TC=25oC unless otherwise noted IGBT-inverter Symbol VCES VGES IC ICM PD Description Collector-Emitter Voltage Gate-Emitter Voltage Collector Current @ TC=25oC @ TC=100oC Pulsed Collector Current tp=1ms Maximum Power Dissipation @ Tj=175oC Value 1200 ±20 63 35 70 225 Unit V V Value 1200 35 70 Unit V A A Value 1600 35 320 510 Unit V A A A2s Value 1200 ±20 30 15 30 129 Unit V V Value 1200 15 30 Unit V A A Value 175 150 -40 to +150 -40 to +125 2500 Unit A A W Diode-inverter Symbol VRRM IF IFM Description Repetitive Peak Reverse Voltage Diode Continuous Forward Current Diode Maximum Forward Current tp=1ms Diode-rectifier Symbol VRRM IO IFSM I2t Description Repetitive Peak Reverse Voltage Average Output Current 50Hz/60Hz,sine wave Surge Forward Current VR=0V,tp=10ms,Tj=45oC I2t-value,VR=0V,tp=10ms,Tj=45oC IGBT-brake Symbol VCES VGES IC ICM PD Description Collector-Emitter Voltage Gate-Emitter Voltage Collector Current @ TC=25oC @ TC=100oC Pulsed Collector Current tp=1ms Maximum Power Dissipation @ Tj=175oC A A W Diode-brake Symbol VRRM IF IFM Description Repetitive Peak Reverse Voltage Diode Continuous Forward Current Diode Maximum Forward Current tp=1ms Module Symbol Tjmax Tjop TSTG VISO Description Maximum Junction Temperature(inverter,brake) Maximum Junction Temperature (rectifier) Operating Junction Temperature Storage Temperature Range Isolation Voltage RMS,f=50Hz,t=1min ©2016 STARPOWER Semiconductor Ltd. 8/1/2016 2/13 o C o C C V o SX0A GD35PJY120F5S IGBT Module IGBT-inverter Characteristics TC=25oC unless otherwise noted Symbol VCE(sat) VGE(th) ICES IGES RGint td(on) tr td(off) tf Eon Eoff td(on) tr td(off) tf Eon Eoff td(on) tr td(off) tf Eon Eoff ISC Parameter Collector to Emitter Saturation Voltage Gate-Emitter Threshold Voltage Collector Cut-Off Current Gate-Emitter Leakage Current Internal Gate Resistance Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss SC Data Test Conditions IC=35A,VGE=15V, Tj=25oC IC=35A,VGE=15V, Tj=125oC IC=35A,VGE=15V, Tj=150oC IC=0.88mA,VCE=VGE, Tj=25oC VCE=VCES,VGE=0V, Tj=25oC VGE=VGES,VCE=0V, Tj=25oC Min. VCC=600V,IC=35A, RG=13Ω,VGE=±15V, Tj=25oC VCC=600V,IC=35A, RG=13Ω,VGE=±15V, Tj=125oC VCC=600V,IC=35A, RG=13Ω,VGE=±15V, Tj=150oC tP≤10μs,VGE=15V, Tj=150oC,VCC=900V, VCEM≤1200V ©2016 STARPOWER Semiconductor Ltd. 8/1/2016 Typ. Max. 1.70 2.15 1.95 Unit V 2.00 5.2 6.0 6.8 V 1.0 mA 400 nA 0 156 28 215 323 Ω ns ns ns ns 1.94 mJ 2.55 mJ 156 30 229 507 ns ns ns ns 2.38 mJ 3.83 mJ 153 32 234 522 ns ns ns ns 2.60 mJ 4.02 mJ 140 A 3/13 SX0A GD35PJY120F5S IGBT Module Diode-inverter Characteristics TC=25oC unless otherwise noted Symbol VF Qr IRM Erec Qr IRM Erec Qr IRM Erec Parameter Diode Forward Voltage Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Test Conditions IF=35A,VGE=0V,Tj=25oC IF=35A,VGE=0V,Tj=125oC IF=35A,VGE=0V,Tj=150oC Min. VR=600V,IF=35A, -di/dt=1050A/μs,VGE=-15V Tj=25oC VR=600V,IF=35A, -di/dt=1050A/μs,VGE=-15V Tj=125oC VR=600V,IF=35A, -di/dt=1050A/μs,VGE=-15V Tj=150oC Typ. 2.00 1.90 1.88 1.9 Max. 2.45 Unit V μC 43 A 1.01 mJ 3.1 μC 51 A 2.37 mJ 3.5 μC 53 A 2.77 mJ Diode-rectifier Characteristics TC=25oC unless otherwise noted Symbol VF IR Parameter Diode Forward Voltage Reverse Current Test Conditions Min. IF=35A,Tj=150oC Typ. 1.12 Tj=150oC,VR=1600V ©2016 STARPOWER Semiconductor Ltd. Max. V 2.0 8/1/2016 4/13 Unit mA SX0A GD35PJY120F5S IGBT Module IGBT-brake Characteristics TC=25oC unless otherwise noted Symbol VCE(sat) VGE(th) ICES IGES RGint td(on) tr td(off) tf Eon Eoff td(on) tr td(off) tf Eon Eoff td(on) tr td(off) tf Eon Eoff ISC Parameter Collector to Emitter Saturation Voltage Gate-Emitter Threshold Voltage Collector Cut-Off Current Gate-Emitter Leakage Current Internal Gate Resistance Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss SC Data Test Conditions IC=15A,VGE=15V, Tj=25oC IC=15A,VGE=15V, Tj=125oC IC=15A,VGE=15V, Tj=150oC IC=0.38mA,VCE=VGE, Tj=25oC VCE=VCES,VGE=0V, Tj=25oC VGE=VGES,VCE=0V, Tj=25oC Min. VCC=600V,IC=15A, RG=39Ω,VGE=±15V, Tj=25oC VCC=600V,IC=15A, RG=39Ω,VGE=±15V, Tj=125oC VCC=600V,IC=15A, RG=39Ω,VGE=±15V, Tj=150oC tP≤10μs,VGE=15V, Tj=150oC,VCC=900V, VCEM≤1200V ©2016 STARPOWER Semiconductor Ltd. 8/1/2016 Typ. Max. 1.70 2.15 1.95 Unit V 2.00 5.2 6.0 6.8 V 1.0 mA 400 nA 0 59 63 201 149 Ω ns ns ns ns 1.39 mJ 0.85 mJ 59 70 283 196 ns ns ns ns 1.87 mJ 1.24 mJ 59 70 288 221 ns ns ns ns 2.09 mJ 1.39 mJ 60 A 5/13 SX0A GD35PJY120F5S IGBT Module Diode-brake Characteristics TC=25oC unless otherwise noted Symbol VF Qr IRM Erec Qr IRM Erec Qr IRM Erec Parameter Diode Forward Voltage Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Test Conditions IF=15A,VGE=0V,Tj=25oC IF=15A,VGE=0V,Tj=125oC IF=15A,VGE=0V,Tj=150oC Min. VR=600V,IF=15A, -di/dt=450A/μs,VGE=-15V Tj=25oC VR=600V,IF=15A, -di/dt=450A/μs,VGE=-15V Tj=125oC VR=600V,IF=15A, -di/dt=450A/μs,VGE=-15V Tj=150oC Typ. 2.05 2.20 2.25 0.5 Max. 2.50 Unit V μC 15 A 0.29 mJ 1.0 μC 16 A 0.64 mJ 1.1 μC 17 A 0.80 mJ NTC Characteristics TC=25oC unless otherwise noted Symbol R25 ∆R/R P25 B25/50 Parameter Rated Resistance Deviation of R100 Power Dissipation Test Conditions TC=100 oC,R100=1486.1Ω B-value R2=R25exp[B25/50(1/T21/(298.15K))] ©2016 STARPOWER Semiconductor Ltd. Min. 8/1/2016 Typ. 22 -5 Max. 5 Unit kΩ % 200 mW 4000 K 6/13 SX0A GD35PJY120F5S IGBT Module Module Characteristics TC=25oC unless otherwise noted Symbol RthJC RthCH M G Parameter Junction-to-Case (per IGBT-inverter) Junction-to-Case (per Diode-inverter) Junction-to-Case (per Diode-rectifier) Junction-to-Case (per IGBT-brake) Junction-to-Case (per Diode-brake) Case-to-Heatsink (per IGBT-inverter) Case-to-Heatsink (per Diode-inverter) Case-to-Heatsink (per Diode-rectifier) Case-to-Heatsink (per IGBT-brake) Case-to-Heatsink (per Diode-brake) Case-to-Heatsink (per Module) Mounting Torque, Screw M4 Weight of Module ©2016 STARPOWER Semiconductor Ltd. Min. Typ. 0.605 1.023 1.019 1.053 1.610 0.422 0.713 0.710 0.734 1.122 0.030 2.0 7/13 Unit K/W K/W 2.2 42 8/1/2016 Max. 0.666 1.125 1.121 1.158 1.771 N.m g SX0A GD35PJY120F5S IGBT Module 70 70 VGE=15V 50 50 40 40 30 20 30 20 Tj=25℃ Tj=125℃ Tj=150℃ 10 Tj=25℃ Tj=125℃ Tj=150℃ 10 0 0 0 0.5 1 1.5 2 2.5 VCE [V] 3 3.5 Fig 1. IGBT-inverter Output Characteristics 5 6 7 8 9 10 11 12 13 VGE [V] Fig 2. IGBT-inverter Transfer Characteristics 10 14 Eon Tj=125℃ Eoff Tj=125℃ Eon Tj=150℃ Eoff Tj=150℃ 9 8 Eon Tj=125℃ Eoff Tj=125℃ Eon Tj=150℃ Eoff Tj=150℃ 12 10 7 5 E [mJ] VCC=600V RG=13Ω VGE=±15V 6 E [mJ] VCE=20V 60 IC [A] IC [A] 60 4 3 8 6 4 VCC=600V IC=35A VGE=±15V 2 2 1 0 0 0 10 20 30 40 IC [A] 50 60 70 Fig 3. IGBT-inverter Switching Loss vs. IC ©2016 STARPOWER Semiconductor Ltd. 0 20 40 60 80 100 120 140 RG [Ω] Fig 4. IGBT-inverter Switching Loss vs. RG 8/1/2016 8/13 SX0A GD35PJY120F5S IGBT Module 80 10 Module 70 60 IGBT 1 ZthJH [K/W] IC [A] 50 40 30 0.1 20 RG=13Ω VGE=±15V Tj=150oC 10 i: 1 2 3 4 ri[K/W]: 0.0497 0.1155 0.4022 0.4596 0.0005 0.005 0.05 0.2 τi[s]: 0 0 0.01 0.001 200 400 600 800 1000 1200 1400 VCE [V] Fig 5. IGBT-inverter RBSOA 0.01 0.1 t [s] 1 10 Fig 6. IGBT-inverter Transient Thermal Impedance 70 4 Tj=25℃ Tj=125℃ Tj=150℃ 60 Erec Tj=125℃ 3.5 Erec Tj=150℃ 3 50 E [mJ] IF [A] 2.5 40 30 2 1.5 20 1 10 VCC=600V RG=13Ω VGE=-15V 0.5 0 0 0 0.5 1 1.5 2 VF [V] 2.5 3 Fig 7. Diode-inverter Forward Characteristics ©2016 STARPOWER Semiconductor Ltd. 0 10 20 30 IF [A] 40 50 Fig 8. Diode-inverter Switching Loss vs. IF 8/1/2016 9/13 SX0A GD35PJY120F5S IGBT Module 10 3 Erec Tj=125℃ Erec Tj=150℃ 2.5 Diode 1 ZthJH [K/W] E [mJ] 2 1.5 0.1 1 VCC=600V IF=35A VGE=-15V 0.5 i: 1 2 3 4 ri[K/W]: 0.1165 0.2654 0.7124 0.6417 τi[s]: 0.0005 0.005 0.05 0.2 0 0 20 40 0.01 0.1 t [s] 1 10 Fig 10. Diode-inverter Transient Thermal Impedance 30 Tj=25℃ VGE=15V Tj=150℃ 25 20 IC [A] IF [A] Fig 9. Diode-inverter Switching Loss vs. RG 70 65 60 55 50 45 40 35 30 25 20 15 10 5 0 0.01 0.001 60 80 100 120 140 RG [Ω] 15 10 5 Tj=25℃ Tj=125℃ Tj=150℃ 0 0.5 0.7 0.9 1.1 VF [V] 1.3 1.5 Fig 11. Diode-rectifier Forward Characteristics ©2016 STARPOWER Semiconductor Ltd. 0 0.5 1 1.5 2 2.5 VCE [V] 3 3.5 Fig 12. IGBT-brake-chopper Output Characteristics 8/1/2016 10/13 SX0A GD35PJY120F5S IGBT Module 100 30 Tj=25℃ Tj=125℃ Tj=150℃ 25 10 R [kΩ] IF [A] 20 15 1 10 5 0 0.1 0 0.5 1 1.5 2 VF [V] 2.5 3 Fig 13. Diode-brake-chopper Forward Characteristics ©2016 STARPOWER Semiconductor Ltd. 0 30 60 90 TC [oC] 120 Fig 14. NTC Temperature Characteristic 8/1/2016 11/13 SX0A 150 GD35PJY120F5S IGBT Module Circuit Schematic 4,5 6,7 8 28 29 30 31 20 21 19 23 24 22 26 27 25 9 17 18 1 2,3 32 14 15 16 11 12 13 10 Package Dimensions Dimensions in Millimeters ©2016 STARPOWER Semiconductor Ltd. 8/1/2016 12/13 SX0A GD35PJY120F5S IGBT Module Terms and Conditions of Usage The data contained in this product datasheet is exclusively intended for technically trained staff. you and your technical departments will have to evaluate the suitability of the product for the intended application and the completeness of the product data with respect to such application. This product data sheet is describing the characteristics of this product for which a warranty is granted. Any such warranty is granted exclusively pursuant the terms and conditions of the supply agreement. There will be no guarantee of any kind for the product and its characteristics. Should you require product information in excess of the data given in this product data sheet or which concerns the specific application of our product, please contact the sales office, which is responsible for you (see www.powersemi.cc), For those that are specifically interested we may provide application notes. Due to technical requirements our product may contain dangerous substances. For information on the types in question please contact the sales office, which is responsible for you. Should you intend to use the Product in aviation applications, in health or live endangering or life support applications, please notify. If and to the extent necessary, please forward equivalent notices to your customers. Changes of this product data sheet are reserved. ©2016 STARPOWER Semiconductor Ltd. 8/1/2016 13/13 SX0A
GD35PJY120F5S 价格&库存
很抱歉,暂时无法提供与“GD35PJY120F5S”相匹配的价格&库存,您可以联系我们找货
