GD400SGY120C2S
GD400SGY120C2S
    STARPOWER(斯达)
    STARPOWER - GD400SGY120C2S - IGBT Module, Single, 630 A, 1.65 V, 2.083 kW, 150 °C, Module
GD400SGY120C2S 数据手册
GD400SGY120C2S IGBT Module STARPOWER IGBT SEMICONDUCTOR GD400SGY120C2S 1200V/400A 1 in one-package General Description STARPOWER IGBT Power Module provides ultra low conduction loss as well as short circuit ruggedness. They are designed for the applications such as general inverters and UPS. Features        Low VCE(sat) Trench IGBT technology 10μs short circuit capability VCE(sat) with positive temperature coefficient Maximum junction temperature 175oC Low inductance case Fast & soft reverse recovery anti-parallel FWD Isolated copper baseplate using DBC technology Typical Applications    Inverter for motor drive AC and DC servo drive amplifier Uninterruptible power supply Equivalent Circuit Schematic ©2016 STARPOWER Semiconductor Ltd. 5/20/2015 1/9 Preliminary GD400SGY120C2S IGBT Module Absolute Maximum Ratings TC=25oC unless otherwise noted IGBT Symbol VCES VGES IC ICM PD Description Collector-Emitter Voltage Gate-Emitter Voltage Collector Current @ TC=25oC @ TC=100oC Pulsed Collector Current tp=1ms Maximum Power Dissipation @ Tj=175oC Value 1200 ±20 630 400 800 2083 Unit V V Description Repetitive Peak Reverse Voltage Diode Continuous Forward Current Diode Maximum Forward Current tp=1ms Value 1200 400 800 Unit V A A Value 175 -40 to +150 -40 to +125 4000 Unit o C o C o C V A A W Diode Symbol VRRM IF IFM Module Symbol Tjmax Tjop TSTG VISO Description Maximum Junction Temperature Operating Junction Temperature Storage Temperature Range Isolation Voltage RMS,f=50Hz,t=1min ©2016 STARPOWER Semiconductor Ltd. 5/20/2015 2/9 Preliminary GD400SGY120C2S IGBT Module IGBT Characteristics TC=25oC unless otherwise noted Symbol VCE(sat) VGE(th) ICES IGES RGint td(on) tr td(off) tf Eon Eoff td(on) tr td(off) tf Eon Eoff td(on) tr td(off) tf Eon Eoff ISC Parameter Collector to Emitter Saturation Voltage Gate-Emitter Threshold Voltage Collector Cut-Off Current Gate-Emitter Leakage Current Internal Gate Resistance Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Switching Loss Turn-Off Switching Loss SC Data Test Conditions IC=400A,VGE=15V, Tj=25oC IC=400A,VGE=15V, Tj=125oC IC=400A,VGE=15V, Tj=150oC IC=10.0mA,VCE=VGE, Tj=25oC VCE=VCES,VGE=0V, Tj=25oC VGE=VGES,VCE=0V, Tj=25oC Min. VCC=600V,IC=400A, RG=2.0Ω,VGE=±15V, Tj=25oC VCC=600V,IC=400A, RG=2.0Ω,VGE=±15V, Tj=125oC VCC=600V,IC=400A, RG=2.0Ω,VGE=±15V, Tj=150oC tP≤10μs,VGE=15V, Tj=150oC,VCC=900V, VCEM≤1200V ©2016 STARPOWER Semiconductor Ltd. 5/20/2015 Typ. Max. 1.65 2.10 1.95 Unit V 2.00 5.2 6.0 6.8 V 5.0 mA 400 nA 1.9 257 96 628 103 Ω ns ns ns ns 23.5 mJ 34.0 mJ 268 107 659 144 ns ns ns ns 35.3 mJ 51.5 mJ 278 118 680 155 ns ns ns ns 38.5 mJ 56.7 mJ 1600 A 3/9 Preliminary GD400SGY120C2S IGBT Module Diode Characteristics TC=25oC unless otherwise noted Symbol VF Qr IRM Erec Qr IRM Erec Qr IRM Erec Parameter Diode Forward Voltage Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Recovered Charge Peak Reverse Recovery Current Reverse Recovery Energy Test Conditions IF=400A,VGE=0V,Tj=25oC IF=400A,VGE=0V,Tj=125oC IF=400A,VGE=0V,Tj=150oC Min. Typ. 1.80 1.85 1.85 38.0 VR=600V,IF=400A, -di/dt=5000A/μs,VGE=-15V Tj=25oC VR=600V,IF=400A, -di/dt=5000A/μs,VGE=-15V Tj=125oC VR=600V,IF=400A, -di/dt=5000A/μs,VGE=-15V Tj=150oC Max. 2.25 Unit V μC 285 A 19 mJ 66.5 μC 380 A 36.6 mJ 76.0 μC 399 A 41.8 mJ Module Characteristics TC=25oC unless otherwise noted Symbol LCE RCC’+EE’ RthJC RthCH M G Parameter Min. Stray Inductance Module Lead Resistance, Terminal to Chip Junction-to-Case (per IGBT) Junction-to-Case (per Diode) Case-to-Heatsink (per IGBT) Case-to-Heatsink (per Diode) Case-to-Heatsink (per Module) Terminal Connection Torque, Screw M6 Mounting Torque, Screw M6 Weight of Module ©2016 STARPOWER Semiconductor Ltd. Typ. Max. 20 0.18 0.072 0.095 0.062 0.081 0.035 2.5 3.0 5/20/2015 4/9 K/W K/W 5.0 5.0 300 Unit nH mΩ N.m g Preliminary GD400SGY120C2S IGBT Module 800 800 VGE=15V VCE=20V 600 600 IC [A] IC [A] 25oC 150oC 400 200 400 200 150oC 25oC 0 0 0 0.5 1 1.5 2 2.5 VCE [V] 3 3.5 5 Fig 1. IGBT Output Characteristics 7 8 9 10 11 12 13 VGE [V] Fig 2. IGBT Transfer Characteristics 140 350 VCC=600V RG=2.0Ω VGE=±15V Tj=150oC 120 100 VCC=600V IC=400A VGE=±15V Tj=150oC 300 250 80 E [mJ] E [mJ] 6 Eoff 60 40 200 Eon 150 100 Eon 20 50 0 Eoff 0 0 200 400 IC [A] 600 800 Fig 3. IGBT Switching Loss vs. IC ©2016 STARPOWER Semiconductor Ltd. 0 4 8 12 RG [Ω] 16 Fig 4. IGBT Switching Loss vs. RG 5/20/2015 5/9 Preliminary 20 GD400SGY120C2S IGBT Module 0.1 1000 IGBT Module 800 IC [A] ZthJC [K/W] 600 400 0.01 RG=2.0Ω VGE=±15V Tj=150oC 200 i: 1 2 3 4 ri[K/W]: 0.0041 0.0239 0.0231 0.0209 0.01 0.02 0.05 0.1 τi[s]: 0 0 350 700 1050 VCE [V] 0.001 0.001 1400 Fig 5. RBSOA 0.01 0.1 t [s] 1 10 Fig 6. IGBT Transient Thermal Impedance 60 800 50 Erec 600 E [mJ] IF [A] 40 400 30 20 200 VCC=600V RG=2.0Ω VGE=-15V Tj=150oC 150oC 10 25oC 0 0 0 0.5 1 1.5 VF [V] 2 2.5 Fig 7. Diode Forward Characteristics ©2016 STARPOWER Semiconductor Ltd. 0 200 400 IF [A] 600 Fig 8. Diode Switching Loss vs. IF 5/20/2015 6/9 Preliminary 800 GD400SGY120C2S IGBT Module 45 0.1 Diode 40 35 Erec 25 ZthJC [K/W] E [mJ] 30 20 0.01 15 VCC=600V IF=400A VGE=-15V Tj=150oC 10 5 i: 1 2 3 4 ri[K/W]: 0.0056 0.0313 0.0305 0.0276 τi[s]: 0.01 0.02 0.05 0.1 0 0 4 8 12 RG [Ω] 16 20 Fig 9. Diode Switching Loss vs. RG ©2016 STARPOWER Semiconductor Ltd. 0.001 0.001 0.01 0.1 t [s] 1 10 Fig 10. Diode Transient Thermal Impedance 5/20/2015 7/9 Preliminary GD400SGY120C2S IGBT Module Circuit Schematic Package Dimensions Dimensions in Millimeters ©2016 STARPOWER Semiconductor Ltd. 5/20/2015 8/9 Preliminary GD400SGY120C2S IGBT Module Terms and Conditions of Usage The data contained in this product datasheet is exclusively intended for technically trained staff. you and your technical departments will have to evaluate the suitability of the product for the intended application and the completeness of the product data with respect to such application. This product data sheet is describing the characteristics of this product for which a warranty is granted. Any such warranty is granted exclusively pursuant the terms and conditions of the supply agreement. There will be no guarantee of any kind for the product and its characteristics. Should you require product information in excess of the data given in this product data sheet or which concerns the specific application of our product, please contact the sales office, which is responsible for you (see www.powersemi.cc), For those that are specifically interested we may provide application notes. Due to technical requirements our product may contain dangerous substances. For information on the types in question please contact the sales office, which is responsible for you. Should you intend to use the Product in aviation applications, in health or live endangering or life support applications, please notify. If and to the extent necessary, please forward equivalent notices to your customers. Changes of this product data sheet are reserved. ©2016 STARPOWER Semiconductor Ltd. 5/20/2015 9/9 Preliminary
GD400SGY120C2S 价格&库存
很抱歉,暂时无法提供与“GD400SGY120C2S”相匹配的价格&库存,您可以联系我们找货
GD400SGY120C2S
  • 1+710.56735
  • 10+639.53456
库存:12
