DG3R420L
DG3R420L
    DC(东晨)
    SMD,5x7.6mm
    420V 5KA 3端 贴片GDT
DG3R420L 数据手册
Surge arrester 3-Electrode arrester Series/Type: DG3R420L Customer: Version/Date: Issue 01/2013-11-02 DC Elec. . Reproduction,publication and dissemination of this document, enclosures here to and the information contained therein without DC' prior express consent is prohibited. Surge arrester 3-Electrode arrester DG3R420L Features Applications ● Extremely small size ● Splitter ● Extremely fast response time ● PCI Cards ● Stable performance over life ● Morden ● Very low capacitance ● Line Cards ● High insulation resistance ● RoHS-compatible ● UL Certicfication :E311500 Electrical specifications DC breakdown voltage 1)2) Min. Max. Impulse breakdown voltage at 1kv/μs –For 99% measure values Service life 10 operations 8/20us 300 operations 10/1000us 10 operations 50Hz,1S Insulation resistance at DC 100V Capacitance at 1MHz Storage and operations temperature Climatic category(IEC60068-1) Marking,Blue positive 420 336 504 V V V ≤900 V 5 200 5 ≥1 ≤1.5 -40…+90 40/90/21 DG3R420L kA A A GΩ pF °C www.jsdgme.com DC Elec. Please read Cautions and warnings and important notes at the end of this document. Issue 01/2013-11-02 Page 2 of 3 Surge arrester 3-Electrode arrester DG3R420L 1) Sampling size in accordance to AQL0.65 II 2) In ionized mode 3) current from one side electode to center electode , and 2 times current through center electode Tests according to ITU-T Rec. K. 12 IEC61663-2 and IEC61643-311 Dimensions Cautions and warnings Surge arresters must not be operated directly in power supply networks,whose maximum operating voltage exceeds the minimum spark-over voltage of the surge arresters. ● ● Surge arresters may become hot in case of longer periods of current stress (danger of burning). ● If the contacts of the surge arrester are defective, current stress can lead to the formation of sparks and loud noises. Surge arresters may be used only within their specified values. In case of overload, the head contacts may fail or the component may be destroyed. ● ● Damaged surge arresters must not be re-used. DC Elec. Please read Cautions and warnings and important notes at the end of this document. Issue 01/2013-11-02 Page 3 of 3
DG3R420L 价格&库存
很抱歉,暂时无法提供与“DG3R420L”相匹配的价格&库存,您可以联系我们找货
