DG2R1500L
DG2R1500L
    DC(东晨)
    插件,8x6mm
    1500V 10KA 2端 插件GDT
DG2R1500L 数据手册
Surge arrester 2-Electrode arrester Series/Type: DG2R1500L Customer: Version/Date: Issue 01/2017-8-17 DC Elec. 2017 . Reproduction,publication and dissemination of this document, enclosures here to and the information contained therein without DC' prior express consent is prohibited. Surge arrester 2-Electrode arrester Features DG2R1500L Applications ● Extremely small size ● Consumer electronics ● Extremely fast response time ● Stable performance over life ● AC Power line devices ● Power supplier ● Very low capacitance ● High insulation resistance ● RoHS-compatible ● UL-identification No:E498658 Electrical specifications DC breakdown voltage 1)2) 1500 ±20 1200 1800 Tolerance Min. Max. Impulse breakdown voltage at 1kv/us V % V V ≤2200 –For 99% measure values –Typical values of distribution ≤2100 Service life 10 operations 50Hz,1S 10 operations 8/20us Insulation resistance at DC 100V Capacitance at 1MHz Weight Storage and operations temperature Climatic category(IEC60068-1) Marking,Blue positive V V 5 10 ≥1 A KA GΩ pF g °C ≤1.5 1.5 -40…+90 40/90/21 DG2R1500L Tel: Fax: +86-510-81707285 +86-510-81707277 www.jsdgme.com DC Elec. Please read Cautions and warnings and important notes at the end of this document. Issue 01/2017-8-17 Page 2 of 4 Surge arrester 2-Electrode arrester DG2R1500L DC breakdown voltage 8/20us, Test wave 10/700us,Test Wave 10/1000us,Test Wave T1=1.25T=8us±20% T1=1.67T=10us±20% T1=1.67T=10us±20% T2=20us±20% T2=700us±20% T2=1000us±20% Recommended wave slodering profile DC Elec. Please read Cautions and warnings and important notes at the end of this document. Issue 01/2017-8-17 Page 3 of 4 Surge arrester 2-Electrode arrester 1)Sampling size in accordance to AQL(C=0) 2) In ionized mode 3) Tests according to ITU-T Rec. K. 12 IEC61663-2 and IEC61643-311 DG2R1500L Dimensions Cautions and warnings Surge arresters must not be operated directly in power supply networks,whose maximum operating voltage exceeds the minimum spark-over voltage of the surge arresters. ● ● Surge arresters may become hot in case of longer periods of current stress (danger of burning). ● If the contacts of the surge arrester are defective, current stress can lead to the formation of sparks and loud noises. Surge arresters may be used only within their specified values. In case of overload, the head contacts may fail or the component may be destroyed. ● ● Damaged surge arresters must not be re-used. DC Elec. Please read Cautions and warnings and important notes at the end of this document. Issue 01/2017-8-17 Page 4 of 4
DG2R1500L
1. 物料型号:DG2R1500L 2. 器件简介: - 特点:极小尺寸、极快响应时间、稳定性能、低电容值、高绝缘电阻、符合RoHS标准、UL认证编号E498658。 - 应用:消费电子产品、交流电源线设备、电源供应商。 3. 引脚分配:文档中未明确提供引脚分配信息。 4. 参数特性: - 直流击穿电压:1500V,公差±20%,最小1200V,最大1800V。 - 冲击击穿电压(1kv/us):99%测量值不超过2200V,典型分布值2100V。 - 工作寿命:在50Hz、1S条件下10次操作;8/20us条件下10次操作,10次。 - 绝缘电阻(DC 100V):≥1GΩ。 - 电容(1MHz):≤1.5pF。 - 重量:1.5g。 - 存储和操作温度:-40°C至+90°C。 - 气候类别(IEC60068-1):40/90/21。 - 标记:蓝色正极,型号DG2R1500L。 5. 功能详解:文档提供了电涌保护器的测试波形和推荐波形缓降曲线。 6. 应用信息:适用于消费电子产品、交流电源线设备和电源供应商。 7. 封装信息:尺寸、镀锡引线、包装(100pcs/盒)。
DG2R1500L 价格&库存
很抱歉,暂时无法提供与“DG2R1500L”相匹配的价格&库存,您可以联系我们找货
