DIO1717LP10
DIO1717LP10
    DIOO(帝奥)
    QFN-10(1.4x1.8)
    具备负摆幅音频功能的2.8Ω、300MHZ双路单刀双掷(SPDT)模拟开关
DIO1717LP10 数据手册
Limited Datasheet For full content datatasheet, please go to www.dioo.com/support/doc.html or Email datasheet.requiry@dioo.com DIO1717 2.8Ω, 300MHz Dual-SPDT SPDT Analog Switch with Negative Swing Audio Capability Features Descriptions s  Voltage Operation: +2.5V to +5.0V The DIO1717 717 is a dual, bidirectional, single-pole/ single  -2.0V 2.0V to V+ Signal Passing Ability double-throw throw  On-Resistance: 2.8Ω (TYP) at +4.5V + designed to operate from a single +2.5V to +5.0V  High Bandwidth: 300MHz supply. It features high-bandwidth bandwidth (300MHz) ( and  Fast Switching Times: tON 1.8µs low on-resistance (2.8Ω Ω TYP), the lowest -2.0V tOFF 350ns 350 (SPDT) CMOS analog switch negative signal can pass switch.  High Off-Isolation: -49dB 49dB at 10MHz  Low Crosstalk: -52dB 52dB at 10MHz DIO1717 717  Negative signal handling: the lowest -2.0V matching (0.05Ω 5Ω TYP) between switches. This  negative signal pass ensures excellent linearity and low distortion  TTL/CMOS Compatible when switching audio signals.  Break-Before-Make Switching  Extended Industrial Temperature Range: features guaranteed on on-resistance 717 is a committed dual single-pole/ single The DIO1717 double-throw throw (SPDT) that consist of two normally -40℃ to +85℃ open (NO) and two normally close (NC) switches. This configuration can be used as a dual 2-to-1 2 Applications multiplexer.  Cell Phone, and Digital Camera  PDA , and Notebook  LCD Monitor  TV, and Set-Top Box DIO1717 is available in DQFN-10 DQFN package. Block Diagram NO1 V+ 2 1 COM COM1 3 10 IN1 4 9 COM2 NC1 5 8 IN2 6 7 GND NC2 NO2 Ordering Information Order Part Number DIO1717LP10 www.dioo.com Top Marking YW(X)Z TA Green -40 to +85°C Package DQFN-10 10 Tape & Reel, 3000 © 2014 DIOO MICROCIRCUITS CO., LTD DIO DIO1717• Rev. 1.0 DIO1717 COMMON DIMENSIONS(MM) PKG. UT:ULTRA THIN REF MIN NOM MAX A 0.50 0.55 0.60 A1 0.00 -- 0.05 A3 D 1.35 1.40 1.45 E 1.75 1.80 1.85 b 0.15 0.20 0.25 L 0.30 0.40 0.50 L1 0.40 0.50 0.60 e www.dioo.com 0.15REF. 0.40BSC © 2014 DIOO MICROCIRCUITS CO., LTD DIO IO1717• Rev. 1.0 2.8Ω, 300MHz Dual-SPDT Analog Switch with Negative Swing Audio Capability Physical Dimensions: DQFN-10 DIO1717 Dioo is a professional design and sales corporation for high-quality high quality and performance analog semiconductors. The company focuses on industry markets, such as, cell phone, handheld products, laptop, and medical equipments and so on. Dioo’s product families include analog signal processing and amplifying, LED drivers d and charger IC. Go to http://www.dioo.com for a complete list of Dioo product families. For additional product information, or full datasheet, please contact with our Sales Department or Representatives. www.dioo.com © 2014 DIOO MICROCIRCUITS CO., LTD DIO IO1717• Rev. 1.0 2.8Ω, 300MHz Dual-SPDT Analog Switch with Negative Swing Audio Capability CONTACT US
DIO1717LP10 价格&库存
很抱歉,暂时无法提供与“DIO1717LP10”相匹配的价格&库存,您可以联系我们找货
