DIO2362CN8
DIO2362CN8
    DIOO(帝奥)
    DFN8_2X2MM_EP
    超低失调电压、低功耗运算放大器,具备轨到轨CMOS输入/输出,单/双通道可选
DIO2362CN8 数据手册
Rev 1.2 DIO236X Ultra Low Vos, Low Power Amplifier Features  Descriptions Ultra low VOS: DIO2361A/2A: 10μV(Max) DIO236x is a family of ultra low VOS operational DIO2361B/2B: 20μV(Max) amplifier, with rail-to-rail CMOS input/output and DIO2361/2: 40μV(Max) single/dual channels selectable. DIO236x family DIO2361M/2M: 65μV(Max) has a gain-bandwidth product of 300kHz(typ.),  Low Power: 17.0μA(typ.) wide operating supply voltage from 1.8V to 5.5V  Unity Gain Stable and broad output voltage swing.  Gain Bandwidth Product: 300kHz(typ.)  Wide supply range: 1.8V to 5.5V  Available in SOT23-5, SC70-5, SOIC-8, MSOP-8, DFN2*2-8 and DFN3*3-8 packages  Temperature Range: DIO236x consumes ultra low power, with each channel 17.0μA(typ.) of bias current, which makes DIO236x be ideal for battery powered device, temperature-sense device, etc. -Industrial: -40°C to 85°C -Extended: -40°C to 125°C Typical Applications Applications  Active Filters  Broadband Communication  Data Acquisition  Process Control  Portable Equipment  Audio and Video Processing  Test Equipment www.dioo.com   © 2018 DIOO MICROCIRCUITS CO., LTD DIO236X• Rev. 1.2 DIO236X Order Part Number Top Marking TA Package DIO2361ASC5 W361 Green or RoHS -40 to 125°C SC70-5 Tape & Reel, 3000 DIO2361AST5 W361 Green or RoHS -40 to 125°C SOT23-5 Tape & Reel, 3000 DIO2361ASO8 DIO2361 Green or RoHS -40 to 125°C SOIC-8 Tape & Reel, 2500 DIO2361AMP8 DIO2361 Green or RoHS -40 to 125°C MSOP-8 Tape & Reel, 3000 DIO2361BSC5 W361 Green or RoHS -40 to 125°C SC70-5 Tape & Reel, 3000 DIO2361BST5 W361 Green or RoHS -40 to 125°C SOT23-5 Tape & Reel, 3000 DIO2361BSO8 DIO2361 Green or RoHS -40 to 125°C SOIC-8 Tape & Reel, 2500 DIO2361BMP8 DIO2361 Green or RoHS -40 to 125°C MSOP-8 Tape & Reel, 3000 DIO2361SC5 W361 Green or RoHS -40 to 125°C SC70-5 Tape & Reel, 3000 DIO2361ST5 W361 Green or RoHS -40 to 125°C SOT23-5 Tape & Reel, 3000 DIO2361SO8 DIO2361 Green or RoHS -40 to 125°C SOIC-8 Tape & Reel, 2500 DIO2361MP8 DIO2361 Green or RoHS -40 to 125°C MSOP-8 Tape & Reel, 3000 DIO2361MSC5 W361 Green or RoHS -40 to 125°C SC70-5 Tape & Reel, 3000 DIO2361MST5 W361 Green or RoHS -40 to 125°C SOT23-5 Tape & Reel, 3000 DIO2361MSO8 DIO2361 Green or RoHS -40 to 125°C SOIC-8 Tape & Reel, 2500 DIO2361MMP8 DIO2361 Green or RoHS -40 to 125°C MSOP-8 Tape & Reel, 3000 DIO2362ACN8 2362 Green or RoHS -40 to 125°C DFN2*2-8 Tape & Reel, 3000 DIO2362ACD8 D2362 Green or RoHS -40 to 125°C DFN3*3-8 Tape & Reel, 5000 DIO2362ASO8 DIO2362 Green or RoHS -40 to 125°C SOIC-8 Tape & Reel, 2500 DIO2362AMP8 DIO2362 Green or RoHS -40 to 125°C MSOP-8 Tape & Reel, 3000 DIO2362BCN8 2362 Green or RoHS -40 to 125°C DFN2*2-8 Tape & Reel, 3000 DIO2362BCD8 D2362 Green or RoHS -40 to 125°C DFN3*3-8 Tape & Reel, 5000 DIO2362BSO8 DIO2362 Green or RoHS -40 to 125°C SOIC-8 Tape & Reel, 2500 DIO2362BMP8 DIO2362 Green or RoHS -40 to 125°C MSOP-8 Tape & Reel, 3000 DIO2362CN8 2362 Green or RoHS -40 to 125°C DFN2*2-8 Tape & Reel, 3000 DIO2362CD8 D2362 Green or RoHS -40 to 125°C DFN3*3-8 Tape & Reel, 5000 DIO2362SO8 DIO2362 Green or RoHS -40 to 125°C SOIC-8 Tape & Reel, 2500 DIO2362MP8 DIO2362 Green or RoHS -40 to 125°C MSOP-8 Tape & Reel, 3000 DIO2362MCN8 2362 Green or RoHS -40 to 125°C DFN2*2-8 Tape & Reel, 3000 DIO2362MCD8 D2362 Green or RoHS -40 to 125°C DFN3*3-8 Tape & Reel, 5000 DIO2362MSO8 DIO2362 Green or RoHS -40 to 125°C SOIC-8 Tape & Reel, 2500 DIO2362MMP8 DIO2362 Green or RoHS -40 to 125°C MSOP-8 Tape & Reel, 3000 Ordering Information Complimentary Note Ordering Code = Part No. + Package Code SC5: stands for SC70-5 ST5: stands for SOT23-5 SO8: stands for SOIC-8 DIO2361A/2A MP8: stands for MSOP-8 DIO2361B/2B CN8: stands for DFN2*2-8 DIO2361/2 CD8: stands for DFN3*3-8 DIO2361M/2M www.dioo.com   © 2018 DIOO MICROCIRCUITS CO., LTD DIO236X• Rev. 1.2 Ultra Low Vos, Low Power Amplifier Ordering Information DIO236X MSOP-8 / SOIC-8 SO T23-5/SC70-5 OUT 1 V- 2 5 + +IN V+ NC 1 8 NC -IN 2 7 V+ +IN 3 6 OUT V- 4 5 NC - 4 3 -IN DIO2361 DIO2361 SO IC-8/M SO P-8 O UTA DFN2*2-8/DFN3*3-8 V+ OUTA 1 8 -INA 2 7 OUTB +INA 3 6 -INB V- 4 5 +INB GND -INA +INA V- DIO2362 1 8 V+ 7 OUTB 3 6 -INB 4 5 +INB 2 - + +- DIO2362 Figure 1 Top View Pin Description www.dioo.com   Pin name Description V+ Positive supply V- Negative supply +INX Positive Input -INX Negative Input OUTX Output NC No connect © 2018 DIOO MICROCIRCUITS CO., LTD DIO236X• Rev. 1.2 Ultra Low Vos, Low Power Amplifier Pin Assignments DIO236X Stresses beyond those listed under “Absolute Maximum Rating” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maxim rating conditions for extended periods may affect device reliability. Parameter Rating Unit 7 V (V-)-0.3V to (V+) 0.3V V |V+ – V-| V -65 to 150 °C Junction Temperature 150 °C Lead Temperature Range 260 °C 8 kV Supply Voltage ( V+ – V-) Input Voltage Difference Input Voltage Storage Temperature Range ESD HBM, JEDEC: JESD22-A114 Recommended Operating Conditions The Recommended Operating Conditions table defines the conditions for actual device operation to ensure optimal performance to the datasheet specifications. DIOO does not recommend exceeding them or designing to Absolute Maximum Ratings. Parameter Supply Voltage Input Voltage Operating Temperature Range www.dioo.com   Rating Unit 1.8 to 5.5 V 0 to 5 V -40 to 125 °C © 2018 DIOO MICROCIRCUITS CO., LTD DIO236X• Rev. 1.2 Ultra Low Vos, Low Power Amplifier Absolute Maximum Ratings DIO236X Typical value: VCC=5V, RL=1MΩ to VCC/2, VCM=1/2VCC, TA = 25°C, unless otherwise specified. Symbol Parameter Conditions Min. Typ. Max. Unit INPUT CHARACTERISTICS VOS Input Offset Voltage V+=1.8V to 5.5V DIO2361A/2A -10 10 DIO2361B/2B -20 20 DIO2361/2 -40 40 DIO2361M/2M -65 65 μV IB Input Bias Current V+=1.8V to 5.5V 1 pA IOS Input Offset Current V+=1.8V to 5.5V 1 pA VCM Common Mode Voltage Range (V+) -0.1 +0.1 CMRR Common Mode Rejection Ratio -40°C≤TA≤125°C, AOL Open Loop Voltage Gain RL=50kΩ, VO= 0.1 to (V+)-0.1 ∆VOS/∆T Input Offset Voltage Drift -40°C≤TA≤125°C 0.05 80 V 130 dB 110 dB µV/° C OUTPUT CHARACTERISTICS VOH Output Voltage High RL=50kΩ -40°C≤TA≤125°C 4.992 V VOL Output Voltage Low RL=50kΩ -40°C≤TA≤125°C 8 mV Source ISC, V+=5V 34 ISC Output Short Circuit Current Sink ISC, V+=5V 34 mA POWER SUPPLY PSRR IS 100 Power Supply Rejection Ration Supply Current per Channel/Amp dB -40°C≤TA≤125°C 17 27 μA Gain Bandwidth Product CL=100pF, RL=1MΩ 300 kHz Slew Rate G=1, 2V Output Step 160 V/ms Setting Time G=1, 2V Output Step 1 ms Phase Margin 62 Deg Overload Recovery Time 40 μs 0.33 % DYNAMIC PERFORMANCE GBP SR tS Θm tr NOISE PERFORMANCE THD Total Harmonic Distortion www.dioo.com   f=1kHz, 4VPP, RL=5kΩ, © 2018 DIOO MICROCIRCUITS CO., LTD DIO236X• Rev. 1.2 Ultra Low Vos, Low Power Amplifier Electrical Characteristics DIO236X Voltage Noise Density f=1kHz 70 nV/√ Hz Specifications subject to change without notice. Typical Performance Characteristics IS vs. VCC VOS vs. VCC www.dioo.com   IS vs. Temperature VOS vs. Temperature © 2018 DIOO MICROCIRCUITS CO., LTD DIO236X• Rev. 1.2 Ultra Low Vos, Low Power Amplifier en DIO236X Small-signal Response (VCC=5V, CL=200pF) Small-signal Response (VCC=5V, CL=200pF) Large-signal Response (VCC=5V, RL=5.1kΩ) www.dioo.com   © 2018 DIOO MICROCIRCUITS CO., LTD DIO236X• Rev. 1.2 Ultra Low Vos, Low Power Amplifier Typical Performance Characteristics (Continue) DIO236X COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 0.85 1.05 A1 0 0.10 A2 0.80 0.90 1.00 A3 0.47 0.52 0.57 b 0.23 0.33 b1 0.22 0.25 0.28 c 0.12 0.18 c1 0.115 0.13 0.14 D 2.02 2.07 2.12 E 2.20 2.30 2.40 E1 1.25 1.30 1.35 e 0.65BSC e1 1.30BSC L 0.28 0.33 0.38 L1 0.50REF L2 0.15BSC R 0.10 R1 0.10 0.25 0° 8° Θ 6° 9° 12° Θ1 6° 9° 12° Θ2 www.dioo.com   © 2018 DIOO MICROCIRCUITS CO., LTD DIO236X• Rev. 1.2 Ultra Low Vos, Low Power Amplifier Physical Dimensions: SC70-5 DIO236X COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.25 A1 0 0.15 A2 1.00 1.10 1.20 A3 0.60 0.65 0.70 b 0.36 0.50 b1 0.36 0.38 0.45 c 0.14 0.20 c1 0.14 0.15 0.16 D 2.826 2.926 3.026 E 2.60 2.80 3.00 E1 1.526 1.626 1.726 e 0.90 0.95 1.00 e1 1.80 1.90 2.00 L 0.35 0.45 0.60 L1 0.59REF L2 0.25BSC R 0.10 R1 0.10 0.25 Θ 0° 8° Θ1 3° 5° 7° Θ2 6° 14° www.dioo.com   © 2018 DIOO MICROCIRCUITS CO., LTD DIO236X• Rev. 1.2 Ultra Low Vos, Low Power Amplifier Physical Dimensions: SOT23-5 DIO236X Ultra Low Vos, Low Power Amplifier Physical Dimensions: DFN2*2-8 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 0.50 0.55 0.65 A1 0.00 0.02 0.05 A3 0.10REF b 0.20 0.25 0.30 D 1.90 2.00 2.10 E 1.90 2.00 2.10 D2 0.80 0.90 1.00 E2 1.50 1.60 1.70 e 0.40 0.50 0.60 H www.dioo.com   0.20REF K 0.15 0.25 0.35 L 0.25 0.30 0.35 © 2018 DIOO MICROCIRCUITS CO., LTD DIO236X• Rev. 1.2 DIO236X COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 0.80 0.85 0.90 A1 0.00 0.02 0.05 A3 0.20REF b 0.25 0.30 0.35 D 2.90 3.00 3.10 E 2.90 3.00 3.10 D2 1.40 1.50 1.60 E2 2.20 2.30 2.40 e 0.55 0.65 0.75 H 0.30REF K 0.25 0.35 0.45 L 0.35 0.40 0.45 R 0.13 - www.dioo.com   © 2018 DIOO MICROCIRCUITS CO., LTD DIO236X• Rev. 1.2 Ultra Low Vos, Low Power Amplifier Physical Dimensions: DFN3*3-8 DIO236X COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.35 1.55 1.75 A1 0.10 0.15 0.25 A2 1.25 1.40 1.65 A3 0.50 0.60 0.70 b 0.38 0.51 b1 0.37 0.42 0.47 c 0.17 0.25 c1 0.17 0.20 0.23 D 4.80 4.90 5.00 E 5.80 6.00 6.20 E1 3.80 3.90 4.00 e 1.27BSC L 0.45 0.60 0.80 L1 1.04REF L2 0.25BSC R 0.07 R1 0.07 h 0.30 0.40 0.50 Θ 0° 8° Θ1 15° 17° 19° Θ2 11° 13° 15° Θ3 15° 17° 19° Θ4 11° 13° 15° www.dioo.com   © 2018 DIOO MICROCIRCUITS CO., LTD DIO236X• Rev. 1.2 Ultra Low Vos, Low Power Amplifier Physical Dimensions: SOIC-8 DIO236X COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.10 A1 0 0.15 A2 0.75 0.85 0.95 A3 0.25 0.35 0.39 b 0.28 0.37 b1 0.27 0.30 0.33 c 0.15 0.20 c1 0.14 0.15 0.16 D 2.90 3.00 3.10 E 4.70 4.90 5.10 E1 2.90 3.00 3.10 e 0.55 0.65 0.75 L 0.40 0.60 0.80 L1 0.95REF L2 0.25BSC R 0.07 R1 0.07 Θ 0° 8° Θ1 9° 12° 15° www.dioo.com   © 2018 DIOO MICROCIRCUITS CO., LTD DIO236X• Rev. 1.2 Ultra Low Vos, Low Power Amplifier Physical Dimensions: MSOP-8 DIO236X Dioo is a professional design and sales corporation for high-quality and performance analog semiconductors. The company focuses on industry markets, such as, cell phone, handheld products, laptop, and medical equipment and so on. Dioo’s product families include analog signal processing and amplifying, LED drivers and charger IC. Go to http://www.dioo.com for a complete list of Dioo product families. For additional product information, or full datasheet, please contact with our Sales Department or Representatives. www.dioo.com   © 2018 DIOO MICROCIRCUITS CO., LTD DIO236X• Rev. 1.2 Ultra Low Vos, Low Power Amplifier CONTACT US
DIO2362CN8 价格&库存
很抱歉,暂时无法提供与“DIO2362CN8”相匹配的价格&库存,您可以联系我们找货
