DIO32358MP8
DIO32358MP8
    DIOO(帝奥)
    MSOP-8
    DIO32358MP8
DIO32358MP8 数据手册
Rev 1.0 DIO32358 1.4MHz, 60µA, Rail-to-Rail I/O CMOS Amplifier Features Descriptions  Rail-to-Rail Input and Output DIO32358 is rail-to-rail CMOS  Maxim offset (VOS):@ >0mV amplifiers with ultra low offset. Features include  Unity Gain Stable wide input common-mode voltage range and broad  Gain Bandwidth Product:1.4MHz output voltage swing with operating supply voltage  Very low input bias currents:5pA from 2.0V to 5.5V. Products are fully specified over  Wide supply range:2.0V to 5.5V the extended –40 to +125°C temperature range.  Input Voltage Range:0V to +5V  Ultra low power:60µA per channel DIO32358 provide 1.4MHz bandwidth consuming  Small size packaging best for portable ultra low current of 60µA per channel. Very low applications, available in SOIC-8 and input bias currents of 5pA enable them ideal for MSOP-8 integrators, photodiode operational amplifiers, and piezoelectric sensors. Applications  ASIC Input or Output Amplifier  Sensor Interface  Piezo Electric Transducer Amplifier  Medical Instrumentation  Audio Output  Portable Systems  Smoke Detectors  Notebook PC  Battery-Powered equipment www.dioo.com   Typical Application © 2018 DIOO MICROCIRCUITS CO., LTD DIO32358• Rev. 1.0 DIO32358 Order Part Number Top Marking TA Package DIO32358MP8 DIO2358 RoHS or Green -40 to +125°C MSOP-8 Tape & Reel, 3000 DIO32358SO8 DIO2358 RoHS or Green -40 to +125°C SOIC-8 Tape & Reel, 2500 Pin Assignments SOIC-8/MSOP-8 OUTA 1 8 V+ -INA 2 7 OUTB +INA 3 6 -INB V- 4 5 +INB Figure 1 Pin Assignment Pin Description www.dioo.com   Pin name Description V+ Positive supply V- Negative supply +INX Positive Input -INX Negative Input OUTX Output © 2018 DIOO MICROCIRCUITS CO., LTD DIO32358• Rev. 1.0 1.4MHz, 60µA, Rail-to-Rail I/O CMOS Amplifier Ordering Information DIO32358 Stresses beyond those listed under “Absolute Maximum Rating” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maxim rating conditions for extended periods may affect device reliability. Parameter Rating Unit 7 V (V-)-0.5 to 7 V -65 to 150 °C Junction Temperature 150 °C Lead Temperature Range 260 °C Supply Voltage Input Voltage Storage Temperature Range HBM, JEDEC: JESD22-A114 8 CDM, JEDEC: JESD22-C101 2 ESD kV Recommended Operating Conditions The Recommended Operating Conditions table defines the conditions for actual device operation to ensure optimal performance to the datasheet specifications. DIOO does not recommend exceeding them or designing to Absolute Maximum Ratings. Parameter Supply Voltage Input Voltage Operating Temperature Range www.dioo.com   Rating Unit 2.1 to 5.5 V 0 to 5 V -40 to 125 °C © 2018 DIOO MICROCIRCUITS CO., LTD DIO32358• Rev. 1.0 1.4MHz, 60µA, Rail-to-Rail I/O CMOS Amplifier Absolute Maximum Ratings DIO32358 Typical value: V+=5V, RL=100kΩ to V+/2, TA = 25°C, unless otherwise specified. Symbol Parameter Conditions Min. Typ. Max. Unit 0 3 6 mV INPUT CHARACTERISTICS VOS Input Offset Voltage -40°C≤TA≤125°C, V+=2V to 5V IB Input Bias Current -40°C≤TA≤125°C, V+=2V to 5V 5 pA IOS Input Offset Current -40°C≤TA≤125°C, V+=2V to 5V 5 pA VCM Common Mode Voltage Range CMRR Common Mode Rejection Ratio AOL ∆VOS/∆T (V+) 0.1 +0.1 75 -40°C≤TA≤125°C, VCM=-0.1 to (V+)+0.1 RL=5kΩ, VO= 0.1 to (V+)-0.1 80 100 RL=200kΩ, VO= 0.1 to (V+)-0.1 90 110 dB dB Open Loop Voltage Gain Input Offset Voltage Drift V 5 -40°C≤TA≤125°C µV/°C OUTPUT CHARACTERISTICS VOH VOL ISC V+=5V, RL=100kΩ, -40°C≤TA≤125°C 4.995 V+=2.0V, RL=100kΩ, -40°C≤TA≤125°C 1.958 V Output Voltage High V+=5V, RL=100kΩ, -40°C≤TA≤125°C 5 V+=2.0V, RL=100kΩ, -40°C≤TA≤125°C 5 Source ISC, V+=5V 40 Sink ISC, V+=5V 40 mV Output Voltage Low mA Output Short Circuit Current POWER SUPPLY PSRR IS 65 85 dB -40°C≤TA≤125°C 60 µA Gain Bandwidth Product RL=100K, CL=100pF 1.4 MHz Slew Rate G=1, 2V Output Step 0.6 V/µs Setting Time G=1, 2V Output Step 2.4 µs 0.019 % Power Supply Rejection Ration Supply Current per Channel/Amp DYNAMIC PERFORMANCE GBP SR tS NOISE PERFORMANCE THD en Total Harmonic Distortion f=10kHz,2V Output Step, RL=10kΩ f=1kHz 45 f=10kHz 35 nV/√Hz Voltage Noise Density Specifications subject to change without notice. www.dioo.com   © 2018 DIOO MICROCIRCUITS CO., LTD DIO32358• Rev. 1.0 1.4MHz, 60µA, Rail-to-Rail I/O CMOS Amplifier Electrical Characteristics DIO32358 All typical value are at V+=2.5V, V-=-2.5V,TA = 25°C, unless otherwise specified. Input Offset Voltage Vs. Supply Voltage Input Offset Voltage Vs. Temperature Input Offset Voltage Vs. Common Voltage Supply Current Vs. Supply Voltage Per Channel Supply Current Vs. Temperature Isource Vs. Output Voltage www.dioo.com   © 2018 DIOO MICROCIRCUITS CO., LTD DIO32358• Rev. 1.0 1.4MHz, 60µA, Rail-to-Rail I/O CMOS Amplifier Typical Performance Characteristics DIO32358 All typical value are at V+=2.5V, V-=-2.5V,TA = 25°C, unless otherwise specified. Isink Vs. Output Voltage Gain Vs. Frequency Gain Linearity Vs. Input Voltage PSRR Vs. Frequency                             www.dioo.com   © 2018 DIOO MICROCIRCUITS CO., LTD DIO32358• Rev. 1.0 1.4MHz, 60µA, Rail-to-Rail I/O CMOS Amplifier Typical Performance Characteristics(continued)  DIO32358 All typical value are at V+=2.5V, V-=-2.5V, G=1, RL=1MΩ,TA = 25°C, unless otherwise specified. Slew Rate Slew Rate Small-Signal Response (CL=No Load) Small-Signal Response (CL=No Load) Small-Signal Response (CL=200pF) Small-Signal Response (CL=200pF www.dioo.com   © 2018 DIOO MICROCIRCUITS CO., LTD DIO32358• Rev. 1.0 1.4MHz, 60µA, Rail-to-Rail I/O CMOS Amplifier Typical Performance Characteristics(continued)  DIO32358                  COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.10 A1 0 0.15 A2 0.75 0.85 0.95 A3 0.25 0.35 0.39 b 0.28 0.37 b1 0.27 0.30 0.33 c 0.15 0.20 c1 0.14 0.15 0.16 D 2.90 3.00 3.10 E 4.70 4.90 5.10 E1 2.90 3.00 3.10 e 0.55 0.65 0.75 L 0.45 0.60 0.80 L1 0.95REF L2 0.25BSC R 0.07 R1 0.07 Θ 0° 8° Θ1 9° 12° 15°   www.dioo.com   © 2018 DIOO MICROCIRCUITS CO., LTD DIO32358• Rev. 1.0 1.4MHz, 60µA, Rail-to-Rail I/O CMOS Amplifier Physical Dimensions: MSOP-8 DIO32358             www.dioo.com   COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.35 1.55 1.75 A1 0.10 0.15 0.25 A2 1.25 1.40 1.65 A3 0.50 0.60 0.70 b 0.38 0.51 b1 0.37 0.42 0.47 c 0.17 0.25 c1 0.17 0.20 0.23 D 4.80 4.90 5.00 E 5.80 6.00 6.20 E1 3.80 3.90 4.00 e 1.27BSC L 0.45 0.60 0.80 L1 1.04REF L2 0.25BSC R 0.07 R1 0.07 h 0.30 0.40 0.50 Θ 0° 8° Θ1 15° 17° 19° Θ2 11° 13° 15° Θ3 15° 17° 19° Θ4 11° 13° 15° © 2018 DIOO MICROCIRCUITS CO., LTD DIO32358• Rev. 1.0 1.4MHz, 60µA, Rail-to-Rail I/O CMOS Amplifier Physical Dimensions: SOIC-8 DIO32358 CONTACT US Dioo is a professional design and sales corporation for high-quality and performance analog semiconductors. The company focuses on industry markets, such as, cell phone, handheld products, laptop, and medical equipment and so on. Dioo’s product families include analog signal processing and amplifying, LED drivers and charger IC. Go to http://www.dioo.com for a complete list of Dioo product families. For additional product information, or full datasheet, please contact with our Sales Department or Representatives. www.dioo.com   © 2018 DIOO MICROCIRCUITS CO., LTD DIO32358• Rev. 1.0 1.4MHz, 60µA, Rail-to-Rail I/O CMOS Amplifier
DIO32358MP8 价格&库存
很抱歉,暂时无法提供与“DIO32358MP8”相匹配的价格&库存,您可以联系我们找货
DIO32358MP8
    • 1+1.57140
    • 200+0.60815
    • 500+0.58677
    • 1000+0.57618
