DIO2051SC5
DIO2051SC5
    DIOO(帝奥)
    SC-70-5
    DIO2051SC5
DIO2051SC5 数据手册
Limited Datasheet For full content datatasheet, please go to www.dioo.com/support/doc.html or Email datasheet.requiry@dioo.com DIO2051/2052/DIO2054 /DIO2054 Single/Dual/Quad, Rail-to-Rail Rail Low Power Amplifier Features Descriptions s  Rail-to-Rail Input and Output DIO2051/2052/2054 is single/dual/quad single channel  0.65 mV Typical offset (VOS) rail-to-rail rail CMOS operational amplifier with ultra  Unity Gain Stable low  Gain Bandwidth Product: 550KHz common-mode mode voltage range and broad broa output  Very low input bias currents : 0.5pA voltage swing with operating supply voltage from  Wide supply range: 1.8V to 5.5V 1.8V to 5.5 V. Products are fully specified over the  Input Voltage Range: extended –40°C 40°C to +125°C temperature temperat range. -0.1V to +5.6V with V+ = 5.5V DIO2051/2052/2054 provides 550kHz bandwidth  Ultra low power: 16µA per channel consuming ultra low w current of 16µA per channel.  Small size packaging best for portable Very low input bias curre ents of 0.5pA enable the applications: DIO2051/2052/2054 5 and SOT23-5 SOT23 DIO2051 Available in SC70-5 photodiode amplifiers, and d piezoelectric sensors. offset. Features include ideal wide for input integrators, DIO2052 Available in SOIC-8, MSOP-8 and DQFN-9 DIO2054 Available in TSSOP-14 14 and SOIC-14 Typical Application Applicatio Applications    ASIC Input or Output Amplifier plifier Sensor Interface Piezo Electric Transducer Amp plifier  Medical Instrumentation  Audio Output  Portable Systems  Smoke Detectors  Notebook PC Ordering Information Order Part Number Top Marking TA Package DIO2051ST5 YW(X)Z RoHS/Green -40 to +125°C SOT23 SOT23-5 Tape & Reel, 3000 DIO2051SC5 YW(X)Z RoHS/Green -40 to +125°C SC70--5 Tape & Reel, 3000 DIO2052MP8 DIO2052 RoHS/Green -40 to +125°C MSOP--8 Tape & Reel, 3000 DIO2052SO8 DIO2052 RoHS/Green -40 to +125°C SOIC-8 Tape & Reel, 2500 DIO2052LN9 2Q Green -40 to +125°C DQFN--9 Tape & Reel, 3000 DIO2054SO14 DIO2054 RoHS/Green -40 to +125°C SOIC-14 14 Tape & Reel, 2500 DIO2054TP14 DIO2054 RoHS/Green -40 to +125°C TSSOP--14 Tape & Reel, 2500 www.dioo.com © 2012 DIOO MICROCIRCUITS CO., LTD DIO DIO2051/2052/2054• Rev. 0.3 DIO2051/2052/2054 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.25 A1 0 0.15 A2 1.00 1.10 1.20 A3 0.60 0.65 0.70 b 0.36 0.50 b1 0.36 0.38 0.45 c 0.14 0.20 c1 0.14 0.15 0.16 D 2.826 2.926 3.026 E 2.60 2.80 3.00 E1 1.526 1.626 1.726 e 0.90 0.95 1.00 e1 1.80 1.90 2.00 L 0.35 0.45 0.60 L1 0.59REF L2 0.25BSC R 0.10 R1 0.10 0.25 Θ 0° 8° Θ1 3° 5° 7° Θ2 6° 14° www.dioo.com © 2012 DIOO MICROCIRCUITS CO., LTD DIO2051/2052/2054• Rev. 0.3 Single/Dual/Quad Rail-to-Rail Low Power Amplifier Physical Dimensions: SOT-23-5 DIO2051/2052/2054 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN MAX A 0.85 - 1.05 A1 0 - 0.10 A2 0.80 0.90 1.00 A3 0.47 0.52 0.57 b 0.22 - 0.29 b1 0.22 0.25 0.28 c 0.115 - 0.15 c1 0.115 0.13 0.14 D 2.02 2.07 2.12 E 2.20 2.30 2.40 E1 1.25 1.30 1.35 e 0.65BSC e1 L www.dioo.com NOM 1.30BSC 0.28 0.33 L1 0.50REF L2 0.15BSC 0.38 R 0.10 - - R1 0.10 - 0.25 Θ 0° - 8° Θ1 6° 9° 12° Θ2 6° 9° 12° © 2012 DIOO MICROCIRCUITS CO., LTD DIO2051/2052/2054• Rev. 0.3 Single/Dual/Quad Rail-to-Rail Low Power Amplifier Physical Dimensions: SC70-5 DIO2051/2052/2054 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.35 1.55 1.75 A1 0.10 0.15 0.25 A2 1.25 1.40 1.65 A3 0.50 0.60 0.70 b 0.38 0.51 b1 0.37 0.42 0.47 c 0.17 0.25 c1 0.17 0.20 0.23 D 4.80 4.90 5.00 E 5.80 6.00 6.20 E1 3.80 3.90 4.00 e 1.27BSC L 0.45 0.60 0.80 L1 1.04REF L2 0.25BSC R 0.07 R1 0.07 h 0.30 0.40 0.50 0° 8° Θ 15° 17° 19° Θ1 11° 13° 15° Θ2 15° 17° 19° Θ3 11° 13° 15° Θ4 www.dioo.com © 2012 DIOO MICROCIRCUITS CO., LTD DIO2051/2052/2054• Rev. 0.3 Single/Dual/Quad Rail-to-Rail Low Power Amplifier Physical Dimensions: SOIC-8 DIO2051/2052/2054 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.10 A1 0 0.15 A2 0.75 0.85 0.95 A3 0.25 0.35 0.39 b 0.28 0.37 b1 0.27 0.30 0.33 c 0.15 0.20 c1 0.14 0.15 0.16 D 2.90 3.00 3.10 E 4.70 4.90 5.10 E1 2.90 3.00 3.10 e 0.55 0.65 0.75 L 0.45 0.60 0.80 L1 0.95REF L2 0.25BSC R 0.07 R1 0.07 0° 8° Θ 9° 12° 15° Θ1 www.dioo.com © 2012 DIOO MICROCIRCUITS CO., LTD DIO IO2051/2052/2054• Rev. 0.3 Single/Dual/Quad Rail-to-Rail Low Power Amplifier Physical Dimensions: MSOP-8 DIO2051/2052/2054 Single/Dual/Quad Rail-to-Rail Low Power Amplifier Physical Dimensions: DQFN-9 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM A >0.50 0.55 0.60 A1 0.00 - 0.05 A3 D 0.15REF 1.45 1.50 1.55 E 1.45 1.50 1.55 b D0.250 D0.275 D0.300 e www.dioo.com MAX 0.50BSC © 2012 DIOO MICROCIRCUITS CO., LTD DIO2051/2052/2054• Rev. 0.3 DIO2051/2052/2054 Single/Dual/Quad Rail-to-Rail Low Power Amplifier Physical Dimensions: TSSOP-14 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A - - 1.20 A1 0.05 - 0.15 A2 0.90 1.00 1.05 A3 0.34 0.44 0.54 b 0.20 - 0.28 b1 0.20 0.22 0.24 c 0.10 - 0.19 c1 0.10 0.13 0.15 D 4.86 4.96 5.06 E 6.20 6.40 6.60 E1 4.30 4.40 4.50 e L 0.65BSC 0.45 L1 0.75 1.00REF L2 www.dioo.com 0.60 0.25BSC R 0.09 - - R1 0.09 - - S 0.20 - - Θ1 0° - 8° Θ2 10° 12° 14° Θ3 10° 12° 14° © 2012 DIOO MICROCIRCUITS CO., LTD DIO IO2051/2052/2054• Rev. 0.3 DIO2051/2052/2054 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.35 1.60 1.75 A1 0.10 0.15 0.25 A2 1.25 1.45 1.65 A3 0.55 0.65 0.75 b 0.36 - 0.49 b1 0.35 0.40 0.45 c 0.17 - 0.25 c1 0.17 0.20 0.23 D 8.53 8.63 8.73 E 5.80 6.00 6.20 E1 3.80 3.90 4.00 e L www.dioo.com 1.27BSC 0.45 0.60 L1 1.04REF L2 0.25BSC 0.80 R 0.07 - - R1 0.07 - - h 0.30 0.40 0.50 Θ 0° - 8° Θ1 6° 8° 10° Θ2 6° 8° 10° Θ3 5° 7° 9° Θ4 5° 7° 9° © 2012 DIOO MICROCIRCUITS CO., LTD DIO2051/2052/2054• Rev. 0.3 Single/Dual/Quad Rail-to-Rail Low Power Amplifier Physical Dimensions: SOIC-14 DIO2051/2052/2054 Dioo is a professional design and sales corporation for high-quality and performance analog semiconductors. The company focuses on industry markets, such as, cell phone, handheld products, laptop, and medical equipments and so on. Dioo’s product families include analog signal processing and amplifying, LED drivers and charger IC. Go to http://www.dioo.com for a complete list of Dioo product families. For additional product information, or full datasheet, please contact with our Sales Department or Representatives. www.dioo.com © 2012 DIOO MICROCIRCUITS CO., LTD DIO2051/2052/2054• Rev. 0.3 Single/Dual/Quad Rail-to-Rail Low Power Amplifier CONTACT US
DIO2051SC5 价格&库存
很抱歉,暂时无法提供与“DIO2051SC5”相匹配的价格&库存,您可以联系我们找货
