DIO6930TST6
DIO6930TST6
    DIOO(帝奥)
    TSOT-23-6
    DIO6930是一款高效率、高频的同步降压DC-DC调节器IC,输入电压范围为4.5V至24V,最大输出电流为3A。该器件集成了顶部和底部开关,具有低导通电阻,内置软启动功能,可限制浪涌电流。保护功能...
DIO6930TST6 数据手册
Rev 1.1 DIO6930 High-Efficiency 3A, 24V Input Synchronous Step Down Converter Features Descriptions Low RDS(ON) for internal switches (top/bottom) The DIO6930 is high-efficiency, high frequency 80mΩ/40mΩ, 3.0A synchronous step-down DC-DC regulator ICs 4.5-24V input voltage range capable of delivering up to 3A output currents. High-Efficiency Synchronous-Mode The DIO6930 family operate over a wide input Internal soft start limits the inrush current voltage range from 4.5V to 24V and integrate main Over Current protection switch and synchronous switch with very low Thermal shutdown RDS(ON) to minimize the conduction loss. Available in TSOT23-6 packages The COT architecture with Pseudo fixed switching frequency operation provides fast transient response and eases loop stabilization. Protection features include over-current protection and thermal shutdown. The DIO6930 requires a minimal number of readily-available, standard, external components and is available in a space-saving TSOT23-6 package. Applications Function Block Portable Navigation Device Set Top Box Portable TV LCD TV Ordering Information Order Part Number DIO6930TST6 www.dioo.com Top Marking 30YW TA Green -40 to +85°C Package TSOT23-6 Tape & Reel, 3000 © 2018 DIOO MICROCIRCUITS CO., LTD DIO6930• V1.1 DIO6930 TSOT23-6 Figure 1 Pin Assignment (Top View) Pin Definitions Pin Name GND Description Power Ground SW Inductor pin. Connect this pin to the switching node of inductor. VIN Power Input Output Feedback Pin. Connect this pin to the center point of the output resistor divider FB (as shown in Figure 1) to program the output voltage: VOUT=0.765*(1+R1/R2).Add optional C2 (10pF~47pF) to speed up the transient response. EN Enable control. Pull high to turn on. Do not float. Bootstrap. Connect a capacitor and a resistor between SW and BS pins to form a floating supply BS www.dioo.com across the high-side switch driver. Recommend to use 0.1µF BS capacitor. © 2018 DIOO MICROCIRCUITS CO., LTD DIO6930• V1.1 High-Efficiency 3A, 24V Input Synchronous Step Down Converter Pin Assignments DIO6930 Stresses beyond those listed under “Absolute Maximum Rating” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maxim rating conditions for extended periods may affect device reliability. Parameter Rating Unit 28 V VIN+0.3 V FB Voltage 6 V BS Voltage SW+6 V Supply Voltage (V+ – V-) EN, SW Voltage ӨJA 87.9 ӨJC 42.2 Package Thermal Resistance °C/W Storage Temperature Range -65 to 150 °C Junction Temperature Range 125 °C Lead Temperature Range 260 °C Recommend Operating Conditions The Recommended Operating Conditions table defines the conditions for actual device operation. Recommended Operating conditions are specified to ensure optimal performance to the datasheet specifications. DIOO does not Recommend exceeding them or designing to Absolute Maximum Ratings. Parameter Rating Unit Supply Voltage 4.5 to 24 V Junction Temperature Range -40 to 125 °C Ambient Temperature Range -40 to 85 °C www.dioo.com © 2018 DIOO MICROCIRCUITS CO., LTD DIO6930• V1.1 High-Efficiency 3A, 24V Input Synchronous Step Down Converter Absolute Maximum Ratings DIO6930 VIN = 12V, VOUT = 1.2V, L = 2.2µH, COUT = 47µF, TA = 25°C, IOUT=1A unless otherwise specified. Symbol Parameter Test Conditions VIN Input Voltage Range IQ Quiescent Current IOUT=0, VFB=VREF⋅105% ISHDN Shutdown Current EN=0 VREF Feedback Reference Voltage IFB FB Input Current Min Typ 4.5 Unit 24 V 140 0.758 VFB=3.3V Max µA 5 10 µA 0.765 0.772 V 50 nA -50 RDS(ON) Top FET RON 80 mΩ RDS(ON) Bottom FET RON 40 mΩ 4.0 A ILIM Low side power FET current limit 3.0 VENH EN Rising Threshold 1.5 VENL EN Falling Threshold VUVLO fSW V VIN Under-Voltage Unlock Threshold, Rising 0.4 V 4.45 V Switching Frequency 500 kHz Min ON Time 40 ns Min OFF Time 180 ns TSS Soft Start Time 1 ms TSD Thermal Shutdown Temperature 148 °C THYS Thermal Shutdown Hysteresis 20 °C Specifications subject to change without notice. www.dioo.com © 2018 DIOO MICROCIRCUITS CO., LTD DIO6930• V1.1 High-Efficiency 3A, 24V Input Synchronous Step Down Converter Electrical Characteristics DIO6930 Typical Performance Characteristics Start up from VIN (VIN=12V,VOUT=3.3V,Load=1Ω) www.dioo.com Shut down from VIN (VIN=12V,VOUT=3.3V,Load=1Ω) Start up from Enable Shut down from Enable (VIN=12V,VOUT=3.3V,Load=1Ω) (VIN=12V,VOUT=3.3V,Load=1Ω) © 2018 DIOO MICROCIRCUITS CO., LTD DIO6930• V1.1 High-Efficiency 3A, 24V Input Synchronous Step Down Converter Typical Application DIO6930 (VIN=12V,VOUT=3.3V,Load=0.3-3A) Ripple (VIN=12V,VOUT=3.3V,Load=0A) Short Circuit Protection (VIN=12V,VOUT=3.3V,Load=3A) www.dioo.com Load transient (VIN=12V,VOUT=3.3V,Load=1.5-3A) Ripple (VIN=12V,VOUT=3.3V,Load=3A) Short Circuit Recovery (VIN=12V,VOUT=3.3V,Load=3A) © 2018 DIOO MICROCIRCUITS CO., LTD DIO6930• V1.1 High-Efficiency 3A, 24V Input Synchronous Step Down Converter Load transient DIO6930 DIO6930 is a synchronous buck regulator IC that integrates the COT control, top and bottom switches on the same die to minimize the switching transition loss and conduction loss. With ultra low RDS(ON) power switches and proprietary COT control, this regulator IC can achieve the highest efficiency and the highest switch frequency simultaneously to minimize the external inductor and capacitor size, and thus achieving the minimum solution footprint. Because of the high integration in the DIO6930 IC, the application circuit based on this regulator IC is rather simple. Only input capacitor CIN, output capacitor COUT, output inductor L and feedback resistors (R1 and R2) need to be selected for the targeted applications specifications. Feedback resistor dividers R1 and R2 Choose R1 and R2 to program the proper output voltage. To minimize the power consumption under light loads, it is desirable to choose large resistance values for both R1 and R2. A value of between 10k and 1M is highly recommended for both resistors. If Vout is 3.3V, R1=40.2k is chosen, then R2 can be calculated to be 12k. R2= 0.765V R1 VOUT − 0.765V Input capacitor CIN This ripple current through input capacitor is calculated as: ICIN_RMS=IOUT ⋅ D(1 − D) This formula has a maximum at VIN=2VOUT condition, where ICIN_RMS=IOUT/2. This simple worst-case condition is commonly used for DC/DC design. To minimize the potential noise problem, place a typical X5R or better grade ceramic capacitor really close to the IN and GND pins. Care should be taken to minimize the loop area formed by CIN, and IN/GND pins. In this case, a 10µF low ESR ceramic capacitor is recommended. Output capacitor COUT The output capacitor is selected to handle the output ripple noise requirements. Both steady state ripple and transient requirements must be taken into consideration when selecting this capacitor. For the best performance, it is recommended to use X5R or better grade ceramic capacitor greater than 22µF capacitance. www.dioo.com © 2018 DIOO MICROCIRCUITS CO., LTD DIO6930• V1.1 High-Efficiency 3A, 24V Input Synchronous Step Down Converter Application Information DIO6930 There are several considerations in choosing this inductor. 1) Choose the inductance to provide the desired ripple current. It is suggested to choose the ripple current to be about 40% of the maximum output current. The inductance is calculated as: L= VOUT (1 − VOUT / VIN , MAX ) FSW × IOUT , MAX × 40% where Fsw is the switching frequency and IOUT,MAX is the maximum load current. The DIO6930 regulator IC is quite tolerant of different ripple current amplitude. Consequently, the final choice of inductance can be slightly off the calculation value without significantly impacting the performance. 2) The saturation current rating of the inductor must be selected to be greater than the peak inductor current under full load conditions. ISAT,MIN>IOUT,MAX + VOUT (1 − VOUT / VIN , MAX ) 2 ⋅ FSW ⋅ L 3) The DCR of the inductor and the core loss at the switching frequency must be low enough to achieve the desired efficiency requirement. It is desirable to choose an inductor with DCR
DIO6930TST6
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一款高性能光耦器件,具有高速响应和高隔离电压特性。
3. 引脚分配:EL817共有6个引脚,分别为输入侧的发光二极管引脚、输出侧的光敏三极管引脚和电源引脚。
4. 参数特性:包括最大正向电流、最大反向电压等电气参数。
5. 功能详解:EL817通过内部发光二极管和光敏三极管实现电信号的光电隔离。
6. 应用信息:广泛应用于工业控制、医疗设备等领域。
7. 封装信息:EL817采用DIP-6封装形式。
