DIO32020LP10
DIO32020LP10
    DIOO(帝奥)
    QFN-10(1.4x1.8)
    具备负摆幅能力的USB 2.0高速及音频/USB/通用异步收发传输器开关
DIO32020LP10 数据手册
Rev 1.1 DIO32020 USB2.0 High-Speed and Audio/USB/UART Switch with Negative Swing Capacity Features Descriptions  Low Ron Audio/USB analog switch The DIO32020 is dual SPDT (Single Pole/Double  Low USB Con: 7pF Throw) switch which combines low distortion  Negative Signal Swing Capable audio/USB/UART and USB2.0 high-speed data  Low Audio Distortion signal switching in the same low voltage device.  USB Switch -3dB Bandwidth: 1100MHz This architecture is designed to allow negative  High Crosstalk and Off-isolation signal passing as low as 3V below ground. When  Voltage Supply Operation: 2.7 to 5.5V a voltage is detected on VBUS, DIO32020 will  Three Green Packages: DQFN-10, immediately switch to USB mode. Due to ultra low QFN-10, MSOP-10 capacitance design, the audio channels (pin 3 and pin 4 input/outputs) are able to not only switch Applications audio signal but also high speed USB signal or  Cell-Phone/PDA  MP3/MP4/PMP  Portable Instrumentation DIO32020 provides packages with Green or RoHS  Battery Powered Communications tiny  Computer Peripherals temperature range of -40°C to 85°C. low voltage UART signal as well. 10L packages, and operates over a Block Diagram DIO32020 Ordering Information Order Part Number Top Marking TA Package DIO32020LP10 YW0A Green -40 to 85°C DQFN-10 Tape & Reel, 3000 DIO32020QN10 YW0A Green -40 to 85°C QFN-10 Tape &Reel, 3000 DIO32020MP10 D32020 Green -40 to 85°C MSOP-10 Tape &Reel, 3000 www.dioo.com © 2019 DIOO MICROCIRCUITS CO., LTD DIO32020• Rev. 1.1 DIO32020 DQFN-10 QFN-10 MSOP-10 VBUS R/D2+ L/D2- D1- 2 3 1 D1+ 10 D1+ GND 4 9 VBUS Vcc 5 8 Sel 6 7 COM- COM+ D1R/D2+ L/D2GND 1 10 2 9 3 8 4 7 5 6 10 VBUS D1+ 1 9 Sel D1- 2 8 COM+ R/D2+ 3 7 COM- L/D2- 4 6 Vcc Sel COM+ COMVcc 5 GND Figure 1 Top View Pin Descriptions Pin Name Direction Description D1+, D1- I/O Differential USB Data Input 1 R/D2+, L/D2- I/O Audio R/L or differential USB data input 2 VBUS I COM+/COM- I/O Sel I Control Input Vcc/ GND P Power Switch Select Data/Audio Common Port Truth Table Sel VBUS L/D2-, R/D2+ D1+, D1- Low Low ON OFF Low High OFF ON High X ON OFF www.dioo.com © 2019 DIOO MICROCIRCUITS CO., LTD DIO32020• Rev. 1.1 USB2.0 High-Speed and Audio Switch with Negative Swing Capacity Pin Assignment DIO32020 Stresses beyond those listed under “Absolute Maximum Rating” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Symbol Parameter Rating Unit VCC Supply Voltage -0.5 to 6.5 V VBUS VBUS Control Input Voltage -0.5 to 6.5 V VIN ASEL Control Input Voltage -0.5 to 6.5 V USB Path Analog Signal Voltage -0.5 to 6.5 Audio Path Analog Signal Voltage -3.5 to 6.5 Storage Temperature -65 to 150 VSW V ASEL Control Input Current 5 VBUS Control Input Current 5 IIN °C μA ISW_CON Analog Signal Continuous Current ±100 mA ISW_PK Analog Signal Peak Current ±500 mA ESD HBM, JEDEC: JESD22-A114 I/O to GND 5 Others 8 kV Recommend Operating Conditions The Recommended Operating Conditions table defines the conditions for actual device operation. Recommended Operating conditions are specified to ensure optimal performance to the datasheet specifications. DIOO does not Recommend exceeding them or designing to Absolute Maximum Ratings. Symbol VCC Parameter Supply Voltage Rating Unit 2.7 to 5.5 V VBUS Control Input Voltage 0 to 5.5 ASEL Control Input Voltage 0 to VCC USB to COM Analog Signal Voltage 0 to VCC Audio to COM Analog Signal Voltage -3 to VCC Operating Temperature Range -40 to 85 VIN V VSW TA www.dioo.com V °C © 2019 DIOO MICROCIRCUITS CO., LTD DIO32020• Rev. 1.1 USB2.0 High-Speed and Audio Switch with Negative Swing Capacity Absolute Maximum Ratings DIO32020 All typical value are at TA = 25°C unless otherwise specified. Symbol Parameter Conditions Min. Typ. Max. Unit CONTROL INPUT (TA=25°C, VCC=3.3V) VIH VIL IIN VIH VIL IIN RVBUS_PD ASEL Control Input High Voltage ASEL Control Input Low Voltage ASEL Control Input Leakage Current VBUS Control Input High Voltage VBUS Control Input Low Voltage VBUS Control Input Leakage Current VBUS_CTRL Pull down Resistance 1.3 VCC=2.7-4.2V V VCC=2.7-4.2V 1 0≤VSW≤VCC 0.5 V 2 µA 1.3 VCC=2.7-4.2V V VCC=2.7-4.2V 0≤VSW≤VCC 1 ION=10mA 4000 0.5 V 2 µA kΩ SUPPLY CURRENT AND LEAKAGE (TA=25°C, VCC=3.3V) IOZ-USB Off Leakage Current of port DN/DP DN/DP=0V to 4.2V, R, L, COM+, COM- float -1 1 uA IOZ-AUDIO Off Leakage Current of port R/L R/L=-3V to 3V, DN, DP, COM+, COM- float -1 1 uA ION-USB On Leakage Current of USB Switch COM+/COM- =0V to 4.2V, R, L, DN, DP float -1 1 uA ION-AUDIO On Leakage Current of AUDIO Switch COM+/COM- =-3V to 3V, R, L, DN, DP float -1 1 uA Ioff Power off leakage VCC=0V -1 1 uA ICC Quiescent Supply 35 µA 18 USB SWITCHES (D+, D-) (TA=25°C, VCC=3.3V) RON On Resistance ION=10mA, VSW =0V to VCC 3.8 Ω RFLATE On Resistance Flatness ION=10mA, VSW =0V to VCC 15 mΩ ∆RON On Resistance Matching ION=10mA, VSW =0V to VCC 100 mΩ AUDIO SWITCHES (R, L) (TA=25°C, VCC=3.3V) RON On Resistance ION=100mA, VSW =-3 to 3V 0.8 Ω RFLATE On Resistance Flatness ION=100mA, VSW =-3 to 3V 2 mΩ ∆RON On Resistance Matching ION=100mA, VSW =-3 to 3V 50 mΩ www.dioo.com © 2019 DIOO MICROCIRCUITS CO., LTD DIO32020• Rev. 1.1 USB2.0 High-Speed and Audio Switch with Negative Swing Capacity DC Electrical Characteristics DIO32020 All typical value are at TA =25°C unless otherwise specified. Symbol Parameter Conditions Min. Typ. Max. Unit AC Parameter (TA=25°C, VCC=3.3V, RL=50Ω, CL=5pF, unless otherwise specified) USB Turn-on Time DP=DN=1.5V, RL=50Ω, CL=35pF 32 μs Audio Turn-on Time L=R=1.5V, RL=50Ω, CL=35pF 32 μs USB Turn-off Time DP=DN=1.5V, RL=50Ω, CL=35pF 100 ns Audio Turn-off Time L=R=1.5V, RL=50Ω, CL=35pF 150 ns Audio off to USB on 30 µs USB off to Audio on 30 µs 1100 MHz tON tOFF TBBM BW Break Before Make Time -3dB Bandwidth USB Channel RL=50Ω, CL=5pF USB OFF-Isolation VSW=1VRMS, RL=50Ω, f=240MHz -23 dB Audio OFF-Isolation VSW=1VRMS, RL=50Ω, f=1kHz -110 dB USB Crosstalk RL=50Ω, f=240MHz -45 dB Audio Crosstalk RL=50Ω, f=1kHz -80 dB OIRR XTALK RL=600Ω, f=1kHz, -110 VSW=2VRMS, With A-weighted THD+N Total Harmonic Distortion + Noise RL=32Ω, f=1kHz, -100 VSW=1VRMS, With A-weighted RL=16Ω, f=1kHz, -100 VSW=0.5VRMS, With A-weighted PSRR Power Supply Rejection Ratio dB f=10kHz, RCOM=50Ω -75 dB 2 pF 7 pF CAPACITANCE (TA=25°C, VCC=3.3V, RL=50Ω, CL=5pF, f=1MHz, ASEL=0V, unless otherwise specified) CIN ASEL Control Input Capacitance CON USB ON Capacitance www.dioo.com VCC= 0V f=1MHz, VBUS=VDD, VSEL=LOW, VD- or VD+ = VCOMX = 0V © 2019 DIOO MICROCIRCUITS CO., LTD DIO32020• Rev. 1.1 USB2.0 High-Speed and Audio Switch with Negative Swing Capacity Electrical Characteristics (Continued) DIO32020 Audio ON Capacitance VBUS=LOW, VSEL=LOW 7 pF COFF USB OFF Capacitance VBUS=VDD, VSEL=LOW 3 pF COFF Audio OFFCapacitance VBUS=LOW, VSEL=LOW 4 pF Typical Performance Characteristics TA=25°C, Vcc=3.3V, unless other otherwise specified. DIO32020 USB 2.0 high speed (480Mbps) eye pattern TIME SCALE (0.2ns/DIV) Figure 2 Eye Pattern: 480Mbps with USB switch In signal path www.dioo.com © 2019 DIOO MICROCIRCUITS CO., LTD DIO32020• Rev. 1.1 USB2.0 High-Speed and Audio Switch with Negative Swing Capacity CON DIO32020 DIO32020 is used in applications where the slim and thin smart phone designs are expected. By sharing the USB connector between USB2.0 data lines and audio headphone outputs, the designers can eliminate the using of bulky headphone jacks. Meanwhile, using the mini-USB connectors as audio outputs allows the end users to reduce the cost to buy too many different types of cell phone accessories. DIO32020 unique architectures allow the part to allow the part to have constant Ron, Ron (flatness) and THD performance independent of Vcc supply value. So in some applications such as mobile cell phone designs, if the designers want to achieve the lowest standby power consumption when the battery is turned OFF, it is highly recommended that DIO32020 be powered by 2.8V, no need of being powered by battery (4.3V) directly. This will help designers to be freed from the complex logic designs to ensure the part will get into sleep mode. DIO32020’s control pins are 1.8V control logic compatible, so the parts can be controlled by baseband processor GPIO directly without worrying about the level shifting issues. Regarding high speed signal integrity, DIO32020 is recommended to be placed as close as possible to the USB controller outputs to reduce the signal reflection under high speed mode (480Mbps). In the meanwhile, the Vcc pin of DIO32020 is required to have decoupling capacitors to reduce the supply ripples. The below is the DIO32020 USB 2.0 high speed (480Mbps) eye diagram compliance test under near-end mode (most challenging mode). 2.8V 10nF D+ DUT DIO32020 USB Host Device DFigure 3 USB2.0 high speed eye diagram test circuit www.dioo.com © 2019 DIOO MICROCIRCUITS CO., LTD DIO32020• Rev. 1.1 USB2.0 High-Speed and Audio Switch with Negative Swing Capacity Applications Design Guide DIO32020 When DIO32020 is powered under audio mode, audio channel can pass at least -3V negative audio signal with up to 100dB THD performance. Under USB mode or device being powered OFF(VCC=0), the negative audio signal on audio ports can be isolated as well to allow flexible design needs. www.dioo.com © 2019 DIOO MICROCIRCUITS CO., LTD DIO32020• Rev. 1.1 USB2.0 High-Speed and Audio Switch with Negative Swing Capacity DIO32020 features not only 100dB total harmonic distortion (THD), but also superior off isolation capability. DIO32020 COMMON DIMENSIONS(MM) PKG. UT:ULTRA THIN REF. MIN. NOM MAX A 0.5 0.55 0.6 A1 0 A3 0.15REF. D 1.35 1.4 1.45 E 1.75 1.8 1.85 b 0.15 0.2 0.25 L 0.3 0.4 0.5 L1 0.4 0.5 0.6 e www.dioo.com 0.05 0.4BSC © 2019 DIOO MICROCIRCUITS CO., LTD DIO32020• Rev. 1.1 USB2.0 High-Speed and Audio Switch with Negative Swing Capacity Physical Dimensions: DQFN-10 DIO32020 COMMON DIMENSIONS(MM) PKG. UT:ULTRA THIN REF. MIN. NOM MAX A 0.50 0.55 0.60 A1 0.00 A3 0.15REF. D 1.95 2.00 2.05 E 1.45 1.50 1.55 b 0.15 0.20 0.25 b1 0.20 0.25 0.30 b2 0.25 0.30 0.35 L 0.30 0.35 0.40 L1 0.35 0.40 0.45 e www.dioo.com 0.05 0.50 BSC © 2019 DIOO MICROCIRCUITS CO., LTD DIO32020• Rev. 1.1 USB2.0 High-Speed and Audio Switch with Negative Swing Capacity Physical Dimensions: QFN-10 DIO32020 www.dioo.com Symbol Min Typ Max A - - 1.10 A1 0 - 0.15 A2 0.75 0.85 0.95 A3 0.25 0.35 0.39 b 0.18 - 0.27 b1 0.17 0.20 0.23 c 0.15 - 0.20 c1 0.14 0.15 0.16 D 2.90 3.00 3.10 E 4.70 4.90 5.10 E1 2.90 3.00 3.10 e 0.40 0.50 0.60 L 0.40 0.60 0.80 L1 0.95REF L2 0.25BSC R 0.07 - - R1 0.07 - - Θ 0° - 8° Θ1 9° 12° 15° © 2019 DIOO MICROCIRCUITS CO., LTD DIO32020• Rev. 1.1 USB2.0 High-Speed and Audio Switch with Negative Swing Capacity Physical Dimensions: MSOP-10 DIO32020 Dioo is a professional design and sales corporation for high-quality and performance analog semiconductors. The company focuses on industry markets, such as, cell phone, handheld products, laptop, and medical equipment and so on. Dioo’s product families include analog signal processing and amplifying, LED drivers and charger IC. Go to http://www.dioo.com for a complete list of Dioo product families. For additional product information, or full datasheet, please contact with our Sales Department or Representatives. www.dioo.com © 2019 DIOO MICROCIRCUITS CO., LTD DIO32020• Rev. 1.1 USB2.0 High-Speed and Audio Switch with Negative Swing Capacity CONTACT US
DIO32020LP10
物料型号:DIO32020
器件简介:DIO32020是一款双SPDT(单刀双掷)开关,集成了低失真音频/USB/UART和USB2.0高速数据信号切换功能。它设计用于允许低至3V以下的负信号通过,当VBUS上检测到电压时,DIO32020会立即切换到USB模式。
引脚分配:DIO32020有10个引脚,包括差分USB数据输入1(D1+,D1-)、音频R/L或差分USB数据输入2(R/D2+,L/D2-)、开关选择(VBus)、数据/音频公共端口(COM+/COM-)、控制输入(Sel)和电源(Vcc/GND)。
参数特性: - 供电电压范围:2.7V至5.5V - USB开关-3dB带宽:1.1GHz - 音频通道的低失真和高串扰、关断隔离度 - 封装类型:DQFN-10、QFN-10、MSOP-10
功能详解:DIO32020具有超低电容设计,能够切换音频信号、高速USB信号或低电压UART信号。它还具有低RON音频/USB模拟开关、负信号摆幅能力、低音频失真等特性。
应用信息:适用于手机/PDA、MP3/MP4/PMP、便携式仪器、电池供电通信设备和计算机外围设备。
封装信息:DIO32020提供三种绿色或RoHS兼容的10引脚封装,工作温度范围为-40°C至85°C。
DIO32020LP10 价格&库存
很抱歉,暂时无法提供与“DIO32020LP10”相匹配的价格&库存,您可以联系我们找货
