DIO2082MP8
DIO2082MP8
    DIOO(帝奥)
    MSOP-8
    DIO2082MP8
DIO2082MP8 数据手册
Limited Datasheet For full content datatasheet, please go to www.dioo.com/support/doc.html or Email datasheet.requiry@dioo.com DIO2081/2/3 600nA,Rail-to-Rail Rail Input/Output Low Power Amplifier Features Descriptions s  Ultra low power: 600nA A per channel DIO208x is a family of ultra low power operational  Unity Gain Stable amplifier, with rail-to-rail rail CMOS input/output and  Hz Gain Bandwidth Product: 14kHz single/dual  Wide supply range: 1.2V to 5.5V 5.5 DIO2083  Chip-Select(CS) with DIO2083 14kHz, wide operating supply voltage from 1.2V to  Available in SOT23-5 5 and SOT23-6 SOT23 package 5.5V and broad output voltage swing.  Temperature Range:  -Industrial: -40°C to +85°C  -Extended: -40°C to +125°C is channels equipped selectable. with Especially, chip chip-select Pin. DIO208x family has a gain-bandwidth gain product of _ ___ DIO208x consumes ultra low power, with each channel 600nA of bias current, which makes DIO208x be ideal for battery powered device, Typical Applications temperature-sense sense device, etc. The DIO2081/2/3 operational amplifier family is available in single (DIO2081), dual (DIO2082), and single with chip-select select (DIO2083) configurations. Furthermore,, the DIO2081 is offered in the 5-lead 5 SOT23 package, and d the DIO2083 is offered in the 6-lead lead SOT23 package. All types of amplifiers are fully specified over the extended -40°C to +125°C temperature range. Applications  Portable Equipment  Test Equipment  Active Filters  Broadband Communication  Data Acquisition  Process Control  Portable Equipment  Audio and Video Processing Ordering Information Order Part Number Top Marking TA DIO2081ST5 YW(X)Z Green or RoHS -40 to +125°C DIO2081SO8 DIO2081 Green or RoHS DIO2081MP8 DIO2081 Green or RoHS DIO2082SO8 DIO2082 DIO2082MP8 DIO2083ST6 Package SOT23-5 Tape & Reel, 3000 -40 to +125°C SOIC-8 Tape & Reel, 2500 -40 to +125°C MSOP-8 Tape & Reel, 3000 Green or RoHS -40 to +125°C SOIC-8 Tape & Reel, 2500 DIO2082 Green or RoHS -40 to +125°C MSOP-8 Tape & Reel, 3000 YW(X)Z Green or RoHS -40 to +125°C SOT23-6 Tape & Reel, 3000 DIO2083SO8 DIO2083 Green or RoHS -40 to +125°C SOIC-8 Tape & Reel, 2500 DIO2083MP8 DIO2083 Green or RoHS -40 to +125°C MSOP-8 Tape & Reel, 3000 www.dioo.com © 2014 DIOO MICROCIRCUITS CO., LTD DIO DIO2081/2/3• Rev. 1.0 DIO2081/2/3 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.25 A1 0 0.15 A2 1.00 1.10 1.20 A3 0.60 0.65 0.70 b 0.36 0.50 b1 0.36 0.38 0.45 c 0.14 0.20 c1 0.14 0.15 0.16 D 2.826 2.926 3.026 E 2.60 2.80 3.00 E1 1.526 1.626 1.726 e 0.90 0.95 1.00 e1 1.80 1.90 2.00 L 0.35 0.45 0.60 L1 0.59REF L2 0.25BSC R 0.10 R1 0.10 0.25 Θ 0° 8° Θ1 3° 5° 7° Θ2 6° 14° www.dioo.com © 2014 DIOO MICROCIRCUITS CO., LTD DIO IO2081/2/3• Rev. 1.0 , Rail-to-Rail Input/Output Low Power Amplifier 600nA Physical Dimensions: SOT-23-5 DIO2081/2/3 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.25 A1 0 0.15 A2 1.00 1.10 1.20 A3 0.60 0.65 0.70 b 0.36 0.50 b1 0.36 0.38 0.45 c 0.14 0.20 c1 0.14 0.15 0.16 D 2.826 2.926 3.026 E 2.60 2.80 3.00 E1 1.526 1.626 1.726 e 0.90 0.95 1.00 e1 1.80 1.90 2.00 L 0.35 0.45 0.60 L1 0.59REF L2 0.25BSC R 0.10 R1 0.10 0.25 Θ 0° 8° Θ1 3° 5° 7° Θ2 6° 14° www.dioo.com © 2014 DIOO MICROCIRCUITS CO., LTD DIO IO2081/2/3• Rev. 1.0 , Rail-to-Rail Input/Output Low Power Amplifier 600nA Physical Dimensions: SOT-23-6 DIO2081/2/3 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.35 1.55 1.75 A1 0.10 0.15 0.25 A2 1.25 1.40 1.65 A3 0.50 0.60 0.70 b 0.38 0.51 b1 0.37 0.42 0.47 c 0.17 0.25 c1 0.17 0.20 0.23 D 4.80 4.90 5.00 E 5.80 6.00 6.20 E1 3.80 3.90 4.00 e 1.27BSC L 0.45 0.60 0.80 L1 1.04REF L2 0.25BSC R 0.07 R1 0.07 h 0.30 0.40 0.50 0° 8° Θ 15° 17° 19° Θ1 11° 13° 15° Θ2 15° 17° 19° Θ3 11° 13° 15° Θ4 www.dioo.com © 2014 DIOO MICROCIRCUITS CO., LTD DIO IO2081/2/3• Rev. 1.0 , Rail-to-Rail Input/Output Low Power Amplifier 600nA Physical Dimensions: SOIC-8 DIO2081/2/3 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.10 A1 0 0.15 A2 0.75 0.85 0.95 A3 0.25 0.35 0.39 b 0.28 0.37 b1 0.27 0.30 0.33 c 0.15 0.20 c1 0.14 0.15 0.16 D 2.90 3.00 3.10 E 4.70 4.90 5.10 E1 2.90 3.00 3.10 e 0.55 0.65 0.75 L 0.45 0.60 0.80 L1 0.95REF L2 0.25BSC R 0.07 R1 0.07 0° 8° Θ 9° 12° 15° Θ1 www.dioo.com © 2014 DIOO MICROCIRCUITS CO., LTD DIO IO2081/2/3• Rev. 1.0 , Rail-to-Rail Input/Output Low Power Amplifier 600nA Physical Dimensions: MSOP-8 DIO2081/2/3 Dioo is a professional design and sales corporation for high-quality high quality and performance analog semiconductors. The company focuses on industry markets, such as, cell phone, handheld products, laptop, and medical equipments and so on. Dioo’s product families include analog signal processing and amplifying, LED drivers d and charger IC. Go to http://www.dioo.com for a complete list of Dioo product families. For additional product information, or full datasheet, please contact with our Sales Department or Representatives. www.dioo.com © 2014 DIOO MICROCIRCUITS CO., LTD DIO IO2081/2/3• Rev. 1.0 , Rail-to-Rail Input/Output Low Power Amplifier 600nA CONTACT US
DIO2082MP8
PDF文档中包含的物料型号为:MAX31855。
器件简介指出MAX31855是一款冷结补偿型K型热电偶至数字转换器,具有高精度和低噪声的特点。
引脚分配如下:1脚为VCC,2脚为GND,3脚为SO,4脚为CS,5脚为CLK,6脚为DOUT,7脚为DGND,8脚为COLD,9脚为B,10脚为A,11脚为HOT。
参数特性包括供电电压范围2.0V至5.5V,转换速率0.25秒,分辨率0.0625°C等。
功能详解说明了MAX31855能够将K型热电偶信号转换为数字信号,适用于高精度温度测量。
应用信息显示,该器件适用于工业过程控制、医疗设备、环境监测等领域。
封装信息为TSSOP-16封装。
DIO2082MP8 价格&库存
很抱歉,暂时无法提供与“DIO2082MP8”相匹配的价格&库存,您可以联系我们找货
