DIO2034TP14
DIO2034TP14
    DIOO(帝奥)
    TSSOP-14
    DIO2034TP14
DIO2034TP14 数据手册
Limited Datasheet For full content datatasheet, please go to www.dioo.com/support/doc.html Email datasheet.requiry@dioo.com DIO2031/2032/2033/2034/2036 500μA, 6MHz, Rail-to-Rail I/O CMOS Operational Amplifiers Features Descriptions  Supply Voltage Range: 2.5V to 5.5V The DIO2031 (single), DIO2032 (dual), DIO2033  Low Supply Current: 500μA Typically (single with shutdown), DIO2034 (quad) and  Rail-to-Rail Input and Output DIO2036 (Triple) are amplifiers with very low noise,  6MHz High Gain-Bandwidth Product low voltage, and low power operational. The  High Slew Rate: 3.6V/μs DIO2031/2/3/4/6  Settling Time to 0.1% with 2V Step: 2.1μs product of 6MHz, a slew rate of 3.6V/μs, and a  Overload Recovery Time: 0.9μs quiescent  Packages: typically. has current a of high gain-bandwidth 500μA/amplifier at 5V DIO2031 Available in: SOT23-5/SOIC-8 DIO2032 Available in: SOIC-8/MSOP-8 The DIO2031/2/3/4/6 is designed to provide optimal DIO2033 Available in: SOT23-6/SOIC-8 performance in low voltage and low noise systems. DIO2034 Available in: TSSOP-14/SOIC-14 All these chips provide rail-to-rail output swing DIO2036 Available in: QFN4*4-20 into heavy loads. The input common-mode voltage range includes ground, and the maximum input offset voltage is 3.5mV for DIO2031/2/3/4/6. Applications     Audio Output Sensor Interface Active Filters A/D Converters  Cellular and Cordless Phones  Laptops and PDAs  Photodiode Amplification  Battery-Powered Instrumentation The DIO2033 has a power-down disable feature that reduces the supply current to 90nA individually. They are specified over the extended industrial temperature range (-40℃ to +125℃). The operating range is from 2.5V to 5.5V. Ordering Information Order Part Number Top Marking DIO2031ST5 YWXM RoHS/Green -40 to +125°C SOT23-5 Tape & Reel, 3000 DIO2031SO8 DIO2031 RoHS/Green -40 to +125°C SOIC-8 Tape & Reel, 2500 RoHS/Green -40 to +125°C SOIC-8 Tape & Reel, 2500 DIO2032SO8 DIO2032MP8 DIO2032 TA Package RoHS/Green -40 to +125°C MSOP-8 Tape & Reel, 3000 DIO2033SO8 DIO2033 RoHS/Green -40 to +125°C SOIC-8 Tape & Reel, 2500 DIO2033ST6 YWXM RoHS/Green -40 to +125°C SOT23-6 Tape & Reel, 3000 RoHS/Green -40 to +125°C SOP-14 Tape & Reel, 2500 RoHS/Green -40 to +125°C TSSOP-14 Tape & Reel, 2500 RoHS/Green -40 to +125°C QFN4*4-20 Tape & Reel, 5000 DIO2034SO14 DIO2034TP14 DIO2036QN20 www.dioo.com DIO2034 D2036 © 2014 DIOO MICROCIRCUITS CO., LTD DIO2031/2032/2033/2034/2036• Rev. 0.3 DIO2031/2032/2033/2034/2036 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.25 A1 0 0.15 A2 1.00 1.10 1.20 A3 0.60 0.65 0.70 b 0.36 0.50 b1 0.36 0.38 0.45 c 0.14 0.20 c1 0.14 0.15 0.16 D 2.826 2.926 3.026 E 2.60 2.80 3.00 E1 1.526 1.626 1.726 e 0.90 0.95 1.00 e1 1.80 1.90 2.00 L 0.35 0.45 0.60 L1 0.59REF L2 0.25BSC R 0.10 R1 0.10 0.25 Θ 0° 8° Θ1 3° 5° 7° Θ2 6° 14° www.dioo.com © 2014 DIOO MICROCIRCUITS CO., LTD DIO2031/2032/2033/2034/2036• Rev. 0.3 500μA, 6MHz, Rail-to-Rail I/O CMOS Operational Amplifiers Physical Dimensions: SOT-23-5 DIO2031/2032/2033/2034/2036 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.25 A1 0 0.15 A2 1.00 1.10 1.20 A3 0.60 0.65 0.70 b 0.36 0.50 b1 0.36 0.38 0.45 c 0.14 0.20 c1 0.14 0.15 0.16 D 2.826 2.926 3.026 E 2.60 2.80 3.00 E1 1.526 1.626 1.726 e 0.90 0.95 1.00 e1 1.80 1.90 2.00 L 0.35 0.45 0.60 L1 0.59REF L2 0.25BSC R 0.10 R1 0.10 0.25 Θ 0° 8° Θ1 3° 5° 7° Θ2 6° 14° www.dioo.com © 2014 DIOO MICROCIRCUITS CO., LTD DIO2031/2032/2033/2034/2036• Rev. 0.3 500μA, 6MHz, Rail-to-Rail I/O CMOS Operational Amplifiers Physical Dimensions: SOT-23-6 DIO2031/2032/2033/2034/2036 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.35 1.55 1.75 A1 0.10 0.15 0.25 A2 1.25 1.40 1.65 A3 0.50 0.60 0.70 b 0.38 0.51 b1 0.37 0.42 0.47 c 0.17 0.25 c1 0.17 0.20 0.23 D 4.80 4.90 5.00 E 5.80 6.00 6.20 E1 3.80 3.90 4.00 e 1.27BSC L 0.45 0.60 0.80 L1 1.04REF L2 0.25BSC R 0.07 R1 0.07 h 0.30 0.40 0.50 0° 8° Θ 15° 17° 19° Θ1 11° 13° 15° Θ2 15° 17° 19° Θ3 11° 13° 15° Θ4 www.dioo.com © 2014 DIOO MICROCIRCUITS CO., LTD DIO2031/2032/2033/2034/2036• Rev. 0.3 500μA, 6MHz, Rail-to-Rail I/O CMOS Operational Amplifiers Physical Dimensions: SOIC-8 DIO2031/2032/2033/2034/2036 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.10 A1 0 0.15 A2 0.75 0.85 0.95 A3 0.25 0.35 0.39 b 0.28 0.37 b1 0.27 0.30 0.33 c 0.15 0.20 c1 0.14 0.15 0.16 D 2.90 3.00 3.10 E 4.70 4.90 5.10 E1 2.90 3.00 3.10 e 0.55 0.65 0.75 L 0.45 0.60 0.80 L1 0.95REF L2 0.25BSC R 0.07 R1 0.07 0° 8° Θ 9° 12° 15° Θ1 www.dioo.com © 2014 DIOO MICROCIRCUITS CO., LTD DIO2031/2032/2033/2034/2036• Rev. 0.3 500μA, 6MHz, Rail-to-Rail I/O CMOS Operational Amplifiers Physical Dimensions: MSOP-8 DIO2031/2032/2033/2034/2036 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A - - 1.20 A1 0.05 - 0.15 A2 0.90 1.00 1.05 A3 0.34 0.44 0.54 b 0.20 - 0.28 b1 0.20 0.22 0.24 c 0.10 - 0.19 c1 0.10 0.13 0.15 D 4.86 4.96 5.06 E 6.20 6.40 6.60 E1 4.30 4.40 4.50 e L 0.65BSC 0.45 L1 0.75 1.00REF L2 www.dioo.com 0.60 0.25BSC R 0.09 - - R1 0.09 - - S 0.20 - - Θ1 0° - 8° Θ2 10° 12° 14° Θ3 10° 12° 14° © 2014 DIOO MICROCIRCUITS CO., LTD DIO2031/2032/2033/2034/2036• Rev. 0.3 500μA, 6MHz, Rail-to-Rail I/O CMOS Operational Amplifiers Physical Dimensions: TSSOP-14 DIO2031/2032/2033/2034/2036 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.35 1.60 1.75 A1 0.10 0.15 0.25 A2 1.25 1.45 1.65 A3 0.55 0.65 0.75 b 0.36 - 0.49 b1 0.35 0.40 0.45 c 0.17 - 0.25 c1 0.17 0.20 0.23 D 8.53 8.63 8.73 E 5.80 6.00 6.20 E1 3.80 3.90 4.00 e L www.dioo.com 1.27BSC 0.45 0.60 L1 1.04REF L2 0.25BSC 0.80 R 0.07 - - R1 0.07 - - h 0.30 0.40 0.50 Θ 0° - 8° Θ1 6° 8° 10° Θ2 6° 8° 10° Θ3 5° 7° 9° Θ4 5° 7° 9° © 2014 DIOO MICROCIRCUITS CO., LTD DIO2031/2032/2033/2034/2036• Rev. 0.3 500μA, 6MHz, Rail-to-Rail I/O CMOS Operational Amplifiers Physical Dimensions: SOIC-14 DIO2031/2032/2033/2034/2036 QFN-20 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 0.70 0.75 0.80 A1 0 0.02 0.05 A3 0.20REF b 0.18 0.25 0.30 D 3.90 4.00 4.10 E 3.90 4.00 4.10 D2 1.90 2.00 2.10 E2 1.90 2.00 2.10 e 0.40 0.50 0.60 K 0.20 L 0.35 0.40 0.45 R 0.09 - www.dioo.com © 2014 DIOO MICROCIRCUITS CO., LTD DIO2031/2032/2033/2034/2036• Rev. 0.3 500μA, 6MHz, Rail-to-Rail I/O CMOS Operational Amplifiers Physical Dimensions: DIO2031/2032/2033/2034/2036 Dioo is a professional design and sales corporation for high-quality and performance analog semiconductors. The company focuses on industry markets, such as, cell phone, handheld products, laptop, and medical equipments and so on. Dioo’s product families include analog signal processing and amplifying, LED drivers and charger IC. Go to http://www.dioo.com for a complete list of Dioo product families. For additional product information, or full datasheet, please contact with our Sales Department or Representatives. www.dioo.com © 2014 DIOO MICROCIRCUITS CO., LTD DIO2031/2032/2033/2034/2036• Rev. 0.3 500μA, 6MHz, Rail-to-Rail I/O CMOS Operational Amplifiers CONTACT US
DIO2034TP14 价格&库存
很抱歉,暂时无法提供与“DIO2034TP14”相匹配的价格&库存,您可以联系我们找货
