DIO2362LSO8
DIO2362LSO8
    DIOO(帝奥)
    SOIC-8
    DIO2362LSO8 停产
DIO2362LSO8 数据手册
Rev 1.1 DIO236XL Ultra Low Vos, Low Power Amplifier Features  Descriptions Ultra low VOS: DIO2361LA/2LA:10μV(Max) DIO236xL is a family of ultra low VOS operational DIO2361LB/2LB: 20μV(Max) amplifier, with rail-to-rail CMOS input/output and DIO2361L/2L: 40μV(Max) single/dual channels selectable. DIO236xL family DIO2361LM/2LM: 65μV(Max) has a gain-bandwidth product of 110kHz(typ.),  Low Power: 7.0μA(typ.) wide operating supply voltage from 1.8V to 5.5V  Unity Gain Stable and broad output voltage swing.  Gain Bandwidth Product: 110kHz(typ.)  Wide supply range: 1.8V to 5.5V  Available in MSOP-8, SOT23-5, DFN2*2-8 SC70-5, and packages  SOIC-8, DFN3*3-8 DIO236xL consumes ultra low power, with each channel 7.0μA(typ.) of bias current, which makes DIO236xL be ideal for battery powered device, temperature-sense device, etc. Temperature Range: -Industrial: -40°C to 85°C -Extended: -40°C to 125°C Typical Applications Applications  Portable Equipment  Broadband Communication  Active Filters  Process Control  Data Acquisition  Audio and Video Processing  Test Equipment www.dioo.com   © 2018 DIOO MICROCIRCUITS CO., LTD DIO236XL• Rev. 1.1 Order Part Number Top Marking TA Package DIO2361LASC5 W36L Green or RoHS -40 to 125°C SC70-5 Tape & Reel, 3000 DIO2361LAST5 W36L Green or RoHS -40 to 125°C SOT23-5 Tape & Reel, 3000 DIO2361LASO8 D2361L Green or RoHS -40 to 125°C SOIC-8 Tape & Reel, 2500 DIO2361LAMP8 D2361L Green or RoHS -40 to 125°C MSOP-8 Tape & Reel, 3000 DIO2361LBSC5 W36L Green or RoHS -40 to 125°C SC70-5 Tape & Reel, 3000 DIO2361LBST5 W36L Green or RoHS -40 to 125°C SOT23-5 Tape & Reel, 3000 DIO2361LBSO8 D2361L Green or RoHS -40 to 125°C SOIC-8 Tape & Reel, 2500 DIO2361LBMP8 D2361L Green or RoHS -40 to 125°C MSOP-8 Tape & Reel, 3000 DIO2361LSC5 W36L Green or RoHS -40 to 125°C SC70-5 Tape & Reel, 3000 DIO2361LST5 W36L Green or RoHS -40 to 125°C SOT23-5 Tape & Reel, 3000 DIO2361LSO8 D2361L Green or RoHS -40 to 125°C SOIC-8 Tape & Reel, 2500 DIO2361LMP8 D2361L Green or RoHS -40 to 125°C MSOP-8 Tape & Reel, 3000 DIO2361LMSC5 W36L Green or RoHS -40 to 125°C SC70-5 Tape & Reel, 3000 DIO2361LMST5 W36L Green or RoHS -40 to 125°C SOT23-5 Tape & Reel, 3000 DIO2361LMSO8 D2361L Green or RoHS -40 to 125°C SOIC-8 Tape & Reel, 2500 DIO2361LMMP8 D2361L Green or RoHS -40 to 125°C MSOP-8 Tape & Reel, 3000 DIO2362LACN8 236L Green or RoHS -40 to 125°C DFN2*2-8 Tape & Reel, 3000 DIO2362LACD8 2362L Green or RoHS -40 to 125°C DFN3*3-8 Tape & Reel, 5000 DIO2362LASO8 D2362L Green or RoHS -40 to 125°C SOIC-8 Tape & Reel, 2500 DIO2362LAMP8 D2362L Green or RoHS -40 to 125°C MSOP-8 Tape & Reel, 3000 DIO2362LBCN8 236L Green or RoHS -40 to 125°C DFN2*2-8 Tape & Reel, 3000 DIO2362LBCD8 2362L Green or RoHS -40 to 125°C DFN3*3-8 Tape & Reel, 5000 DIO2362LBSO8 D2362L Green or RoHS -40 to 125°C SOIC-8 Tape & Reel, 2500 DIO2362LBMP8 D2362L Green or RoHS -40 to 125°C MSOP-8 Tape & Reel, 3000 DIO2362LCN8 236L Green or RoHS -40 to 125°C DFN2*2-8 Tape & Reel, 3000 DIO2362LCD8 2362L Green or RoHS -40 to 125°C DFN3*3-8 Tape & Reel, 5000 DIO2362LSO8 D2362L Green or RoHS -40 to 125°C SOIC-8 Tape & Reel, 2500 DIO2362LMP8 D2362L Green or RoHS -40 to 125°C MSOP-8 Tape & Reel, 3000 DIO2362LMCN8 236L Green or RoHS -40 to 125°C DFN2*2-8 Tape & Reel, 3000 DIO2362LMCD8 2362L Green or RoHS -40 to 125°C DFN3*3-8 Tape & Reel, 5000 DIO2362LMSO8 D2362L Green or RoHS -40 to 125°C SOIC-8 Tape & Reel, 2500 DIO2362LMMP8 D2362L Green or RoHS -40 to 125°C MSOP-8 Tape & Reel, 3000 Ordering Information Complimentary Note Ordering Code = Part No. + Package Code SC5: stands for SC70-5 ST5: stands for SOT23-5 SO8: stands for SOIC-8 DIO2361LA/2LA MP8: stands for MSOP-8 DIO2361LB/2LB CN8: stands for DFN2*2-8 DIO2361L/2L CD8: stands for DFN3*3-8 DIO2361LM/2LM www.dioo.com   © 2018 DIOO MICROCIRCUITS CO., LTD DIO236XL• Rev. 1.1 Ultra Low Vos, Low Power Amplifier Ordering Information DIO236XL DIO236XL MSOP-8 / SOIC-8 SO T23-5/SC70-5 OUT 1 V- 2 5 + +IN V+ NC 1 8 NC -IN 2 7 V+ +IN 3 6 OUT V- 4 5 NC 8 V+ 7 O UTB 3 6 -INB 4 5 +INB - 4 3 -IN DIO2361L DIO2361L SOIC-8/M SOP-8 OUTA DFN2*2-8/DFN3*3-8 V+ OUTA 1 8 -INA 2 7 OUTB +INA 3 6 -INB V- 4 5 +INB GND -INA +INA V- 1 2 - + +- DIO 2362L DIO2362L Figure 1 Top View Pin Description www.dioo.com   Pin name Description V+ Positive supply V- Negative supply +INX Positive Input -INX Negative Input OUTX Output NC No connect © 2018 DIOO MICROCIRCUITS CO., LTD DIO236XL• Rev. 1.1 Ultra Low Vos, Low Power Amplifier Pin Assignments DIO236XL Stresses beyond those listed under “Absolute Maximum Rating” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maxim rating conditions for extended periods may affect device reliability. Parameter Rating Unit 7 V (V-)-0.3V to (V+)+0.3V V |V+ – V-| V -65 to 150 °C Junction Temperature 150 °C Lead Temperature Range 260 °C 8 kV Supply Voltage ( V+ – V-) Input Voltage Difference Input Voltage Storage Temperature Range ESD HBM, JEDEC: JESD22-A114 Recommended Operating Conditions The Recommended Operating Conditions table defines the conditions for actual device operation to ensure optimal performance to the datasheet specifications. DIOO does not recommend exceeding them or designing to Absolute Maximum Ratings. Parameter Supply Voltage Input Voltage Operating Temperature Range www.dioo.com   Rating Unit 1.8 to 5.5 V 0 to 5 V -40 to 125 °C © 2018 DIOO MICROCIRCUITS CO., LTD DIO236XL• Rev. 1.1 Ultra Low Vos, Low Power Amplifier Absolute Maximum Ratings DIO236XL Typical value: V+=5V, RL=1MΩ to V+/2, VCM=1/2V+, TA = 25°C, unless otherwise specified. Symbol Parameter Conditions Min. Typ. Max. Unit INPUT CHARACTERISTICS VOS Input Offset Voltage V+=1.8V to 5.5V DIO2361LA/2LA -10 10 DIO2361LB/2LB -20 20 DIO2361L/2L -40 40 DIO2361LM/2LM -65 65 μV IB Input Bias Current V+=1.8V to 5.5V 1 pA IOS Input Offset Current V+=1.8V to 5.5V 1 pA VCM Common Mode Voltage Range (V+) -0.1 CMRR Common Mode Rejection Ratio -40°C≤TA≤125°C AOL Open Loop Voltage Gain RL=50kΩ, VO= 0.1 to (V+)-0.1 ∆VOS/∆T Input Offset Voltage Drift +0.1 V 130 dB 110 dB -40°C≤TA≤125°C 0.02 µV/°C 80 OUTPUT CHARACTERISTICS VOH Output Voltage High RL=50kΩ, -40°C≤TA≤125°C 4.992 V VOL Output Voltage Low RL=50kΩ, -40°C≤TA≤125°C 8 mV Output Short Circuit Current Source ISC, V+=5V 34 ISC Sink ISC, V+=5V 34 mA POWER SUPPLY PSRR IS Power Supply Rejection Ration Supply Current per Channel/Amp 100 -40°C≤TA≤125°C dB 7 11 μA DYNAMIC PERFORMANCE GBP SR tS Θm tr Gain Bandwidth Product CL=100pF, RL=1MΩ 110 kHz Slew Rate G=1, 2V Output Step 80 V/ms Setting Time G=1, 2V Output Step 2 ms Phase Margin 70 Deg Overload Recovery Time 3.9 ms www.dioo.com   © 2018 DIOO MICROCIRCUITS CO., LTD DIO236XL• Rev. 1.1 Ultra Low Vos, Low Power Amplifier Electrical Characteristics DIO236XL THD en Total Harmonic Distortion f=1kHz, 4VPP, RL=5kΩ 0.33 % Voltage Noise Density f=1kHz 100 nV/√Hz Specifications subject to change without notice. Typical Performance Characteristics IS vs. VCC VOS vs. VCC www.dioo.com   IS vs. Temperature VOS vs. Temperature © 2018 DIOO MICROCIRCUITS CO., LTD DIO236XL• Rev. 1.1 Ultra Low Vos, Low Power Amplifier NOISE PERFORMANCE DIO236XL Small-signal Response (VCC=5V, CL=200pF) Small-signal Response (VCC=5V, CL=200pF) Large-signal Response (VCC=5V, RL=5.1kΩ) www.dioo.com   © 2018 DIOO MICROCIRCUITS CO., LTD DIO236XL• Rev. 1.1 Ultra Low Vos, Low Power Amplifier Typical Performance Characteristics (Continue) DIO236XL COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 0.85 1.05 A1 0 0.10 A2 0.80 0.90 1.00 A3 0.47 0.52 0.57 b 0.23 0.33 b1 0.22 0.25 0.28 c 0.12 0.18 c1 0.115 0.13 0.14 D 2.02 2.07 2.12 E 2.20 2.30 2.40 E1 1.25 1.30 1.35 e 0.65BSC e1 1.30BSC L 0.28 0.33 0.38 L1 0.50REF L2 0.15BSC R 0.10 R1 0.10 0.25 0° 8° Θ 6° 9° 12° Θ1 6° 9° 12° Θ2 www.dioo.com   © 2018 DIOO MICROCIRCUITS CO., LTD DIO236XL• Rev. 1.1 Ultra Low Vos, Low Power Amplifier Physical Dimensions: SC70-5 DIO236XL COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.25 A1 0 0.15 A2 1.00 1.10 1.20 A3 0.60 0.65 0.70 b 0.36 0.50 b1 0.36 0.38 0.45 c 0.14 0.20 c1 0.14 0.15 0.16 D 2.826 2.926 3.026 E 2.60 2.80 3.00 E1 1.526 1.626 1.726 e 0.90 0.95 1.00 e1 1.80 1.90 2.00 L 0.35 0.45 0.60 L1 0.59REF L2 0.25BSC R 0.10 R1 0.10 0.25 Θ 0° 8° Θ1 3° 5° 7° Θ2 6° 14° www.dioo.com   © 2018 DIOO MICROCIRCUITS CO., LTD DIO236XL• Rev. 1.1 Ultra Low Vos, Low Power Amplifier Physical Dimensions: SOT23-5 DIO236XL Ultra Low Vos, Low Power Amplifier Physical Dimensions: DFN2*2-8 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 0.50 0.55 0.65 A1 0.00 0.02 0.05 A3 0.10REF b 0.20 0.25 0.30 D 1.90 2.00 2.10 E 1.90 2.00 2.10 D2 0.80 0.90 1.00 E2 1.50 1.60 1.70 e 0.40 0.50 0.60 H www.dioo.com   0.20REF K 0.15 0.25 0.35 L 0.25 0.30 0.35 © 2018 DIOO MICROCIRCUITS CO., LTD DIO236XL• Rev. 1.1 DIO236XL COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 0.80 0.85 0.90 A1 0.00 0.02 0.05 A3 0.20REF b 0.25 0.30 0.35 D 2.90 3.00 3.10 E 2.90 3.00 3.10 D2 1.40 1.50 1.60 E2 2.20 2.30 2.40 e 0.55 0.65 0.75 H 0.30REF K 0.25 0.35 0.45 L 0.35 0.40 0.45 R 0.13 - www.dioo.com   © 2018 DIOO MICROCIRCUITS CO., LTD DIO236XL• Rev. 1.1 Ultra Low Vos, Low Power Amplifier Physical Dimensions: DFN3*3-8 DIO236XL COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.35 1.55 1.75 A1 0.10 0.15 0.25 A2 1.25 1.40 1.65 A3 0.50 0.60 0.70 b 0.38 0.51 b1 0.37 0.42 0.47 c 0.17 0.25 c1 0.17 0.20 0.23 D 4.80 4.90 5.00 E 5.80 6.00 6.20 E1 3.80 3.90 4.00 e 1.27BSC L 0.45 0.60 0.80 L1 1.04REF L2 0.25BSC R 0.07 R1 0.07 h 0.30 0.40 0.50 Θ 0° 8° Θ1 15° 17° 19° Θ2 11° 13° 15° Θ3 15° 17° 19° Θ4 11° 13° 15° www.dioo.com   © 2018 DIOO MICROCIRCUITS CO., LTD DIO236XL• Rev. 1.1 Ultra Low Vos, Low Power Amplifier Physical Dimensions: SOIC-8 DIO236XL COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.10 A1 0 0.15 A2 0.75 0.85 0.95 A3 0.25 0.35 0.39 b 0.28 0.37 b1 0.27 0.30 0.33 c 0.15 0.20 c1 0.14 0.15 0.16 D 2.90 3.00 3.10 E 4.70 4.90 5.10 E1 2.90 3.00 3.10 e 0.55 0.65 0.75 L 0.40 0.60 0.80 L1 0.95REF L2 0.25BSC R 0.07 R1 0.07 Θ 0° 8° Θ1 9° 12° 15° www.dioo.com   © 2018 DIOO MICROCIRCUITS CO., LTD DIO236XL• Rev. 1.1 Ultra Low Vos, Low Power Amplifier Physical Dimensions: MSOP-8 DIO236XL Dioo is a professional design and sales corporation for high-quality and performance analog semiconductors. The company focuses on industry markets, such as, cell phone, handheld products, laptop, and medical equipment and so on. Dioo’s product families include analog signal processing and amplifying, LED drivers and charger IC. Go to http://www.dioo.com for a complete list of Dioo product families. For additional product information, or full datasheet, please contact with our Sales Department or Representatives. www.dioo.com   © 2018 DIOO MICROCIRCUITS CO., LTD DIO236XL• Rev. 1.1 Ultra Low Vos, Low Power Amplifier CONTACT US
DIO2362LSO8 价格&库存
很抱歉,暂时无法提供与“DIO2362LSO8”相匹配的价格&库存,您可以联系我们找货
