DIO2022SO8
DIO2022SO8
    DIOO(帝奥)
    SOIC-8
    DIO2022SO8
DIO2022SO8 数据手册
Rev 1.0 DIO202x 190µA, 3MHz RRIO CMOS Amplifier Features Descriptions Rail-to-Rail Input and Output The DIO202x is a rail-to-rail I/O operational ±1mV Typical offset (VOS) amplifier which allows low load impedances to be VOSMAX Specificity: driven. With a 3MHz unity-gain frequency and low ±4.9mV Low Distortion noise, low distortion and high output current Gain Bandwidth Product: 3MHz capability, the DIO202x provides excellent choice Wide supply range: 2.5V to 5.5V for high quality systems. The input common-mode 190µA/Amplifier typical supply current voltage range includes ground, and the maximum Slew rate: 1.7V/µs input offset voltage is ±1mV (guaranteed). They are Small size packaging best for portable also applications. capacitive loads. DIO2021: Available in SOT23-5 DIO202x is offered in RoHS or Green package and DIO2022: Available in SOIC-8 ESD (HBM) 8kV. It is specified over the extended DIO2024: Available in SOIC-14 and TSSOP-14 -40 to +125°C capable of comfortably driving large Typical Application Applications Portable Equipment Active Filters Data Acquisition Portable Equipment Test Equipment Broadband Communication Process Control Audio and Video Processing Ordering Information Order Part Number Top Marking TA Package DIO2021ST5 YW(X)Z RoHS or Green -40 to +125°C SOT23-5 Tape & Reel, 3000 DIO2022SO8 DIO2022 RoHS or Green -40 to +125°C SOIC-8 Tape & Reel, 2500 DIO2024CS14 DIO2024 RoHS or Green -40 to +125°C SOIC-14 Tape & Reel, 2500 DIO2024CT14 DIO2024 RoHS or Green -40 to +125°C TSSOP-14 Tape & Reel, 2500 www.dioo.com © 2016 DIOO MICROCIRCUITS CO., LTD DIO202x• Rev. 1.0 DIO202x SOT23-5 SOIC-8 OUT 1 V+ 5 V- 2 +IN 3 4 OUTA 1 8 -INA 2 7 OUTB +INA 3 6 V- 4 5 +INB V+ -INB -IN TSSOP-14/SOIC-14 +INA 3 V+ 4 +INB 5 -INB 6 OUTB 7 - 13 -IND + 12 +IND 11 V- 10 +INC 9 -INC 8 OUTC + - 2 OUTD + -INA 14 + 1 - OUTA - Figure 1 Pin Assignment (Top View) Pin Description www.dioo.com Pin name Description V+ Positive supply V- Negative supply +INX Positive Input -INX Negative Input OUTX Output © 2016 DIOO MICROCIRCUITS CO., LTD DIO202x• Rev. 1.0 190µA, RRIO CMOS Amplifier Pin Assignments DIO202x Stresses beyond those listed under “Absolute Maximum Rating” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maxim rating conditions for extended periods may affect device reliability. Parameter Rating Unit 7.5 V (V-)-0.5 to (V+)+0.5 V -65 to 150 °C Junction Temperature 150 °C Lead Temperature Range 260 °C Supply Voltage Input Voltage Storage Temperature Range HBM, JEDEC: JESD22-A114 8 CDM, JEDEC: JESD22-C101 2 ESD kV Recommended Operating Conditions The Recommended Operating Conditions table defines the conditions for actual device operation to ensure optimal performance to the datasheet specifications. DIOO does not recommend exceeding them or designing to Absolute Maximum Ratings. Parameter Supply Voltage Input Voltage Operating Temperature Range www.dioo.com Rating Unit 2.5 to 5.5 V 0 to 5 V -40 to 125 °C © 2016 DIOO MICROCIRCUITS CO., LTD DIO202x• Rev. 1.0 190µA, RRIO CMOS Amplifier Absolute Maximum Ratings DIO202x Typical value: V+=5V, RL=100kΩ to V+/2, TA = 25°C, unless otherwise specified. Symbol Parameter Conditions Min. Typ. Max. Unit TA=25°C ±1 ±4.9 mV -40°C≤TA≤85°C ±1 ±5.2 mV -40°C≤TA≤125°C ±1 ±5.3 mV INPUT CHARACTERISTICS VOS Input Offset Voltage V+=2.5V to 5.5V IB Input Bias Current -40°C≤TA≤125°C, V+=2.5V to 5.5V 1 10 pA IOS Input Offset Current -40°C≤TA≤125°C, V+=2.5V to 5.5V 1 10 pA VCM Common Mode Voltage Range V+=5.5V 5.6 V CMRR Common Mode Rejection Ratio -40°C≤TA≤125°C, VCM=-0.1 to 5.6V, V+=5.5V 80 120 dB AOL Open Loop Voltage Gain RL=600Ω, Vo= 0.1 to 4.9 90 120 dB ∆VOS/∆T Input Offset Voltage Drift -40°C≤TA≤125°C 2.5 µV/°C -0.1 OUTPUT CHARACTERISTICS Output Voltage Swing from Rail RL=600Ω -40°C≤TA≤125°C 0.1 RL=10kΩ -40°C≤TA≤125°C 0.015 V IOUT Output Current V+= 5V 80 mA Ro Closed Loop Output Impedance F=100kHz, G=+1 3.1 Ω 80 dB POWER SUPPLY PSRR IS 70 Power Supply Rejection Ration Supply Current per Channel/Amp V+= 5V , -40°C≤TA≤125°C 190 250 V+= 2.5V , -40°C≤TA≤125°C 180 250 µA DYNAMIC PERFORMANCE GBP SR tS Gain Bandwidth Product RL=10kΩ Slew Rate RL=600Ω, G=1, 2V Output Step Setting Time RL=600Ω, G=1, 2V Output Step 3 MHz 1.7 V/µs 1 µs NOISE PERFORMANCE THD en Total Harmonic Distortion f=10kHz, 1V Output Step, RL=600Ω and 100pF 0.015 f=1kHz, V+= 5V 27 f=10kHz, V+= 5V 18 % nV/√Hz Voltage Noise Density Specifications subject to change without notice. www.dioo.com © 2016 DIOO MICROCIRCUITS CO., LTD DIO202x• Rev. 1.0 190µA, RRIO CMOS Amplifier Electrical Characteristics DIO202x 190µA, RRIO CMOS Amplifier Physical Dimensions: SOT-23-5 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.25 A1 0 0.15 A2 1.00 1.10 1.20 A3 0.60 0.65 0.70 b 0.36 0.50 b1 0.36 0.38 0.45 c 0.14 0.20 c1 0.14 0.15 0.16 D 2.826 2.926 3.026 E 2.60 2.80 3.00 E1 1.526 1.626 1.726 e 0.90 0.95 1.00 e1 1.80 1.90 2.00 L 0.35 0.45 0.60 L1 0.59REF L2 0.25BSC R 0.10 R1 0.10 0.25 Θ 0° 8° Θ1 3° 5° 7° Θ2 6° 14° www.dioo.com © 2016 DIOO MICROCIRCUITS CO., LTD DIO202x• Rev. 1.0 DIO202x 190µA, RRIO CMOS Amplifier Physical Dimensions: SOIC-8 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.35 1.55 1.75 A1 0.10 0.15 0.25 A2 1.25 1.40 1.65 A3 0.50 0.60 0.70 b 0.38 0.51 b1 0.37 0.42 0.47 c 0.17 0.25 c1 0.17 0.20 0.23 D 4.80 4.90 5.00 E 5.80 6.00 6.20 E1 3.80 3.90 4.00 e 1.27BSC L 0.45 0.60 0.80 L1 1.04REF L2 0.25BSC R 0.07 R1 0.07 h 0.30 0.40 0.50 0° 8° Θ 15° 17° 19° Θ1 11° 13° 15° Θ2 15° 17° 19° Θ3 11° 13° 15° Θ4 www.dioo.com © 2016 DIOO MICROCIRCUITS CO., LTD DIO202x• Rev. 1.0 DIO202x 0.25 A2 A θ c A1 A3 D L L1 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) NOM MAX A - - 1.20 A1 0.05 - 0.15 A2 0.90 1.00 1.05 A3 0.39 0.44 0.49 b 0.20 - 0.30 b1 0.19 0.22 0.25 c 0.13 - 0.19 c1 0.12 0.13 0.14 b D 4.86 4.96 5.06 b1 E1 4.30 4.40 4.50 E 6.20 6.40 6.60 b e c B c1 B BASE METAL E MIN E1 Symbol e 0.65BSC L WITH PLATING SECTION B-B 0.45 L1 0.75 1.00BSC 0° Θ L/F 载体尺 寸(mil) www.dioo.com - - 79*79 8° 90*110 118*153 © 2016 DIOO MICROCIRCUITS CO., LTD DIO202x• Rev. 1.0 190µA, RRIO CMOS Amplifier Physical Dimensions: TSSOP-14 DIO202x 190µA, RRIO CMOS Amplifier 0.25 Physical Dimensions: SOIC-14 D L L1 E E1 h θ b e A3 A A2 A1 b b1 c c1 BASE METAL WITH PALTING COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A - - 1.75 A1 0.05 - 0.225 A2 1.30 1.40 1.50 A3 0.60 0.65 0.70 b 0.39 - 0.47 b1 0.38 0.41 0.44 c 0.20 - 0.24 c1 0.19 0.20 0.21 D 8.55 8.65 8.75 E 5.80 6.00 6.20 E1 3.80 3.90 4.00 SECTION B-B e 1.27BSC h 0.25 - 0.50 L 0.50 - 0.80 L1 θ www.dioo.com 1.05REF 0° - 8° © 2016 DIOO MICROCIRCUITS CO., LTD DIO202x• Rev. 1.0 DIO202x Dioo is a professional design and sales corporation for high-quality and performance analog semiconductors. The company focuses on industry markets, such as, cell phone, handheld products, laptop, and medical equipment and so on. Dioo’s product families include analog signal processing and amplifying, LED drivers and charger IC. Go to http://www.dioo.com for a complete list of Dioo product families. For additional product information, or full datasheet, please contact with our Sales Department or Representatives. www.dioo.com © 2016 DIOO MICROCIRCUITS CO., LTD DIO202x• Rev. 1.0 190µA, RRIO CMOS Amplifier CONTACT US
DIO2022SO8 价格&库存
很抱歉,暂时无法提供与“DIO2022SO8”相匹配的价格&库存,您可以联系我们找货
