DIO2084CS14
DIO2084CS14
    DIOO(帝奥)
    SOIC-14
    DIO2084CS14
DIO2084CS14 数据手册
Rev 1.3 DIO2081/2/4 600nA,Rail-to-Rail Rail Input/ Output Low Power Amplifier Features Descriptions s Ultra low power: 600nA A per channel DIO208x is a family of ultra low power operational Unity Gain Stable amplifier, with rail-to-rail rail CMOS input/output and Hz Gain Bandwidth Product: 14kHz single/dual channels selectable. DIO208x family Wide supply range: 1.2V to 5.5V 5.5 has a gain-bandwidth product of 14kHz, wide Available in SOT23-5, SOIC-8, 8, operating supply voltage from 1.2V to 5.5V and MSOP-8 and SOIC-14 package broad output voltage swing. wing. Temperature Range: DIO208x consumes ultra low power, with each -Industrial: -40°C to +85°C channel 600nA of bias current, which makes -Extended: -40°C to +125°C DIO208x be ideal for battery powered device, Typical Applications temperature-sense sense device, etc. The DIO208x operational amplifier family is available in single (DIO2081), and dual (DIO2082), and quad (DIO2084) configurations. configurations Furthermore, the DIO2081 is offered in the 5-lead 5 SOT23 package. All types of amplifiers are fully specified over the extended -40°C to +125°C temperature range. Applications Portable Equipment Test Equipment Active Filters Broadband Communication Data Acquisition Process Control Portable Equipment Audio and Video Processing Ordering Information Order Part Number Top Marking TA Package DIO2081ST5 YW(X)Z Green or RoHS -40 to +125°C SOT23-5 Tape & Reel, 3000 DIO2081SO8 DIO2081 Green or RoHS -40 to +125°C SOIC-8 Tape & Reel, 2500 DIO2081MP8 DIO2081 Green or RoHS -40 to +125°C MSOP-8 Tape & Reel, 3000 DIO2082SO8 DIO2082 Green or RoHS -40 to +125°C SOIC-8 Tape & Reel, 2500 DIO2082MP8 DIO2082 Green or RoHS -40 to +125°C MSOP-8 Tape & Reel, 3000 DIO2084CS14 DIO2084 Green or RoHS -40 to +125°C SOIC-14 Tape & Reel, 2500 www.dioo.com © 2014 DIOO MICROCIRCUITS CO., LTD DIO2081/2/4 2081/2/4• Rev. 1.3 DIO2081/2/4 SOT23-5 OUT 1 V- 2 +IN 3 + MSOP-8 / SOIC -8 5 V+ 4 -IN - NC 1 8 NC -IN 2 7 V+ +IN 3 6 OUT V- 4 5 NC DIO2081 DIO DIO2081 1 -INA 2 +INA 3 V- + OUTA + SOIC-8 M SOP-8 8 4 8 V+ 7 OUTB 6 -INB 5 +INB DIO 2082 Figure 1 Top View Pin Description www.dioo.com Pin name Description V+ Positive supply V- Negative supply +INX Positive Input -INX Negative Input OUTX Output © 2014 DIOO MICROCIRCUITS CO., LTD DIO2081/2/4 2081/2/4• Rev. 1.3 , Rail-to-Rail Input/ Output Low Power Amplifier 600nA Pin Assignments DIO2081/2/4 Stresses beyond those listed under “Absolute Maximum Rating” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maxim rating conditions for extended periods may affect device reliability. rel Parameter Rating Unit 7 V (V-)-0.3V 0.3V to (V+)+0.3V V |V+ – V-| V -65 to 150 °C Junction Temperature 150 °C Lead Temperature Range 260 °C Supply Voltage ( V+ – V-) Input Voltage Difference Input Voltage Storage Temperature Range HBM, JEDEC: JESD22-A114 JESD22 8 CDM, JEDEC: JESD22-C101 JESD22 2 ESD kV Recommended Operating Conditions The Recommended Operating Conditions table defines the conditions for actual device operation to ensure optimal performance to t the datasheet specifications. DIOO does not recommend exceeding them or designing to Absolute Maximum Ratings. Ratin Parameter Supply Voltage Input Voltage Operating Temperature Range www.dioo.com Rating Unit 1.2 to 5.5 V 0 to 5 V -40 to 125 °C © 2014 DIOO MICROCIRCUITS CO., LTD DIO2081/2/4 2081/2/4• Rev. 1.3 , Rail-to-Rail Input/ Output Low Power Amplifier 600nA Absolute Maximum Ratings DIO2081/2/4 Typical value: V+=5V, RL=1MΩ to V+/2, VCM=1/2V+, TA = 25°C, unless otherwise specified. Symbol Parameter Conditions Min. Typ. Max. Unit +2 mV INPUT CHARACTERISTICS VOS -2 Input Offset Voltage -40°C≤TA≤125°C, V+=1.2V to 5.5V IB Input Bias Current V+=1.2V to 5.5V 1 pA IOS Input Offset Current V+=1.2V to 5.5V 1 pA VCM Common Mode Voltage Range CMRR Common Mode Rejection Ratio -40°C≤TA≤125°C, 100 AOL Open Loop Voltage Gain RL=50kΩ, VO= 0.1 to (V+)-0.1 70 ∆VOS/∆T Input Offset Voltage Drift -40°C≤TA≤125°C (V+) -0.1 +0.1 V dB 87 dB ±5 µV/°C V OUTPUT CHARACTERISTICS VOH Output Voltage High RL=50kΩ -40°C≤TA≤125°C 4.992 VOL Output Voltage Low RL=50kΩ -40°C≤TA≤125°C 8 Source ISC, V+=5V 30 ISC Output Short Circuit Current Sink ISC, V+=5V 30 15 mV mA POWER SUPPLY PSRR IS 100 Power Supply Rejection Ration dB -40°C≤TA≤125°C 600 Gain Bandwidth Product CL=60pF 14 kHz Slew Rate G=1, 2V Output Step 3.5 V/ms Setting Time G=1, 2V Output Step 150 µs Phase Margin 49 Deg Overload Recovery Time 110 µs Supply Current per Channel/Amp 1000 nA DYNAMIC PERFORMANCE GBP SR tS Θm tr NOISE PERFORMANCE THD en Total Harmonic Distortion f=100Hz, 4VPP, RL=50kΩ, 0.09 % Voltage Noise Density f=1kHz 190 nV/√Hz Specifications subject to change without notice. notice www.dioo.com © 2014 DIOO MICROCIRCUITS CO., LTD DIO2081/2/4 2081/2/4• Rev. 1.3 , Rail-to-Rail Input/ Output Low Power Amplifier 600nA Electrical Characteristics DIO2081/2/4 , Rail-to-Rail Input/ Output Low Power Amplifier 600nA Typical Performance Characteristics All typical value are at V+=5V, TA = 25°C, C, unless otherwise specified. www.dioo.com © 2014 DIOO MICROCIRCUITS CO., LTD DIO2081/2/4 2081/2/4• Rev. 1.3 DIO2081/2/4 www.dioo.com Large Signal Response © 2014 DIOO MICROCIRCUITS CO., LTD DIO2081/2/4 2081/2/4• Rev. 1.3 , Rail-to-Rail Input/ Output Low Power Amplifier 600nA Small Signal Response DIO2081/2/4 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.25 A1 0 0.15 A2 1.00 1.10 1.20 A3 0.60 0.65 0.70 b 0.36 0.50 b1 0.36 0.38 0.45 c 0.14 0.20 c1 0.14 0.15 0.16 D 2.826 2.926 3.026 E 2.60 2.80 3.00 E1 1.526 1.626 1.726 e 0.90 0.95 1.00 e1 1.80 1.90 2.00 L 0.35 0.45 0.60 L1 0.59REF L2 0.25BSC R 0.10 R1 0.10 0.25 Θ 0° 8° Θ1 3° 5° 7° Θ2 6° 14° www.dioo.com © 2014 DIOO MICROCIRCUITS CO., LTD DIO2081/2/4 2081/2/4• Rev. 1.3 , Rail-to-Rail Input/ Output Low Power Amplifier 600nA Physical Dimensions: SOT-23-5 DIO2081/2/4 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.35 1.55 1.75 A1 0.10 0.15 0.25 A2 1.25 1.40 1.65 A3 0.50 0.60 0.70 b 0.38 0.51 b1 0.37 0.42 0.47 c 0.17 0.25 c1 0.17 0.20 0.23 D 4.80 4.90 5.00 E 5.80 6.00 6.20 E1 3.80 3.90 4.00 e 1.27BSC L 0.45 0.60 0.80 L1 1.04REF L2 0.25BSC R 0.07 R1 0.07 h 0.30 0.40 0.50 0° 8° Θ 15° 17° 19° Θ1 11° 13° 15° Θ2 15° 17° 19° Θ3 11° 13° 15° Θ4 www.dioo.com © 2014 DIOO MICROCIRCUITS CO., LTD DIO2081/2/4 2081/2/4• Rev. 1.3 , Rail-to-Rail Input/ Output Low Power Amplifier 600nA Physical Dimensions: SOIC-8 DIO2081/2/4 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.10 A1 0 0.15 A2 0.75 0.85 0.95 A3 0.25 0.35 0.39 b 0.28 0.37 b1 0.27 0.30 0.33 c 0.15 0.20 c1 0.14 0.15 0.16 D 2.90 3.00 3.10 E 4.70 4.90 5.10 E1 2.90 3.00 3.10 e 0.55 0.65 0.75 L 0.45 0.60 0.80 L1 0.95REF L2 0.25BSC R 0.07 R1 0.07 0° 8° Θ 9° 12° 15° Θ1 www.dioo.com © 2014 DIOO MICROCIRCUITS CO., LTD DIO2081/2/4 2081/2/4• Rev. 1.3 , Rail-to-Rail Input/ Output Low Power Amplifier 600nA Physical Dimensions: MSOP-8 DIO2081/2/4 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A - - 1.75 A1 0.05 - 0.225 A2 1.30 1.40 1.50 A3 0.60 0.65 0.70 b 0.39 - 0.48 b1 0.38 0.41 0.43 c 0.21 - 0.26 c1 0.19 0.20 0.21 D 8.45 8.65 8.85 E 5.80 6.00 6.20 E1 3.70 3.90 4.10 e 1.27BSC h 0.25 L 0.50 L1 Θ - 0.50 - 0.80 1.05BSC 0° 70*70 L/F 载体尺 寸(mil) 8° - 90*110 98*150 100.4*210 www.dioo.com © 2014 DIOO MICROCIRCUITS CO., LTD DIO2081/2/4 2081/2/4• Rev. 1.3 , Rail-to-Rail Input/ Output Low Power Amplifier 600nA Physical Dimensions: SOIC-14 DIO2081/2/4 Dioo is a professional design and sales corporation for high-quality high quality and performance analog semiconductors. The company focuses on industry markets, such as, cell phone, handheld products, laptop, and medical equipments and so on. Dioo’s product families include analog signal processing and amplifying, LED drivers d and charger IC. Go to http://www.dioo.com for a complete list of Dioo product families. uct information, or full datasheet, please contact with our Sales Department or Representatives. For additional product www.dioo.com © 2014 DIOO MICROCIRCUITS CO., LTD DIO2081/2/4 2081/2/4• Rev. 1.3 , Rail-to-Rail Input/ Output Low Power Amplifier 600nA CONTACT US
DIO2084CS14 价格&库存
很抱歉,暂时无法提供与“DIO2084CS14”相匹配的价格&库存,您可以联系我们找货
