Rev 1.2
DIO6803
Ultra Low Power Microprocessor Reset Circuit
Features
Descriptions
140ms min Reset Pulse Width
DIO6803
series
are
micro-processor
(μP)
10μA Typ Supply Current @VCC = 3V
supervisory circuits used to monitor the power
Guaranteed Reset Valid to VCC = 1.0V
supplies in μP and digital systems. They provide
Temperature coefficient of reset threshold:
excellent circuit reliability and low cost by
21ppm/°C
eliminating external components.
Power Supply Transient Immunity
Operating Temperature Range:
These circuits perform a single function: they
-40°C to 125°C
assert a reset signal whenever the VCC supply
Available in SOT23 and SOT23-3
voltage
declines
below
a
preset
threshold,
keeping it asserted for at least 140ms after VCC has
risen above the reset threshold.
Pin Assignment
The DIO6803 has Open drain outputs. The
DIO6803
has
an
active-low
/RESET
output,
Thereset comparator is designed to ignore fast
transients on VCC, and the outputs are guaranteed
to be in the correct logic state for VCC down to 1.0V
over the temperature range.
The device is available in 3 pin SOT23 and
SOT23-3 packages.
(Top View)
Applications
Computers
Controllers
Intelligent Instruments
Portable/Battery-Powered Equipment
Ordering Information
Order Part
TA
Number
Package
DIO6803XST3
RoHS
-40 to 125°C
SOT23
Tape & Reel, 3000
DIO6803XSU3
RoHS
-40 to 125°C
SOT23-3
Tape & Reel, 3000
www.dioo.com
© 2019 DIOO MICROCIRCUITS CO., LTD
DIO6803• Rev. 1.2
DIO6803
Ordering Code = Part No. + Package Code
ST3: Stands for SOT23
SU3: stands for SOT23-3
X: Refer to Device Function Reference
Table on Page 2
Device Function Reference Table
Part No.
Reset threshold
Reset active Low or High
Output Type
Marking
DIO6803RST3
2.63V
Low
Open Drain
ABD
DIO6803RSU3
2.63V
Low
Open Drain
ABD
DIO6803SST3
2.93V
Low
Open Drain
ABC
DIO6803SSU3
2.93V
Low
Open Drain
ABC
Block Diagram
OSC
VCC
/RESET
1.25V
COMP
Delay
Generator
GND
Figure 1 Block Diagram
www.dioo.com
DIO6803• Rev. 1.2
Ordering Information Complimentary Note
DIO6803
Symbol
/RESET
GND
VCC
Description
Open Drain output. This output remains low if VCC drops below VRES-VHYST, and for at least 140ms after
VCC rises above VRES
Ground terminal
Analog input. This pin is both the power supply to internal circuit and the voltage to be monitored
Absolute Maximum Ratings
Stresses beyond those listed under “Absolute Maximum Rating” may cause permanent damage to the device. These are stress
ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections
of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
Parameter
Rating
VCC
-0.3 to 6.0
/RESET
-0.3 to 6.0
Terminal Voltage (With respect to GND)
V
VCC
/RESET
mA
Input Current
Thermal Resistance
Lead Temperature Range (soldering 10s)
Storage Temperature
ESD HBM, JEDEC: JESD22-A114
www.dioo.com
Units
300
°C/W
-40 to 125
°C
300
°C
-65 to 150
°C
4500
V
DIO6803• Rev. 1.2
Pin Descriptions
DIO6803
Typical value: VCC=3V, TA=25°C, unless otherwise noted.
Parameters
Symbol
Maximum input voltage
VCCMAX
Minimum input voltage
VCCMIN
Supply current
Reset Threshold
reset threshold
Reset Threshold hysteresis
IVCC
Test Conditions
Min
Typ
Max
Unit
5.5
V
1.0
V
Vcc=2.0V
8
Vcc=3.0V
10
Vcc=5.0V
14
uA
DIO6803S
2.75
2.93
3.05
DIO6803R
2.53
2.63
2.73
VRES
V
ppm/°
TC
21
VHYST
0.03VRES
V
23
us
VCC transitions from VRES+0.1V to
VCC to /RESET Delay
VRES-0.1V
/RESET Output Voltage Low
VOL
Reset Pulse Width
TRES
VCC=2V, VRES>2V, ISINK=1.5mA
140
240
C
0.3
V
500
ms
Specifications subject to change without notice.
Detailed Description
A microprocessor’s (μP’s) reset input starts the μP in a known state. The DIO6803 series assert reset to prevent
code-execution errors during power-up, power-down, or brownout conditions. The device consists of a
comparator, a low current high precision voltage reference, voltage divider, output delay circuit and output driver.
They assert a reset signal whenever the VCC supply voltage declines below a preset threshold, keeping it
asserted for at least 140ms after VCC has risen above the reset threshold.
The DIO6803 has an open drain output stage. The DIO6803 have an active-low /RESET output, The reset
comparator is designed to ignore fast transients on VCC, and the outputs are guaranteed to be in the correct logic
state for VCCdown to 1.0V over the temperature range.
The operation of the device can be best understood by referring to figure 2.
www.dioo.com
DIO6803• Rev. 1.2
DC Electrical Characteristics
DIO6803
Applications Information
Negative-Going VCC Transients
In addition to issuing a reset to the μP during power-up, power-down, and brownout conditions, the DIO6803
series are relatively immune to short-duration negative-going VCCtransients (glitches). As the magnitude of the
transient increases (goes farther below the reset threshold), the maximum allowable pulse width decreases.
Typically, a VCCtransient that goes 100mV below the reset threshold and lasts 10μs or less will not cause a reset
pulse. A 0.1μF bypass capacitor mounted as close as possible to the VCC pin provides additional transient
immunity.
Typical Performance Characteristics
All typical value: VCC=5V, TA=25°C, unless otherwise specified.
www.dioo.com
DIO6803• Rev. 1.2
Figure 2 Timing Waveform
DIO6803
E
B
K
D
H
Symbol
Min
Max
A
2.70
3.10
B
1.10
1.50
C
1.0 Typical
D
0.4 Typical
E
0.35
0.48
G
1.80
2.00
H
0.02
0.1
J
K
www.dioo.com
Dimensions In
Millimeters
0.1 Typical
2.20
2.60
DIO6803• Rev. 1.2
Physical Dimensions: SOT23
DIO6803
Physical Dimensions: SOT23-3
Dimensions In
Millimeters
Dimensions In
Inches
Min
Max
Min
Max
A
1.050
1.250
0.041
0.049
A1
0.000
0.100
0.000
0.004
A2
1.050
1.150
0.041
0.045
b
0.300
0.500
0.012
0.020
c
0.100
0.200
0.004
0.008
D
2.820
3.020
0.111
0.119
E
1.500
1.700
0.059
0.067
E1
2.650
2.950
0.104
0.116
Symbol
e
www.dioo.com
0.950 TYP.
0.037 TYP.
e1
1.800
2.000
0.071
0.079
L
0.300
0.600
0.012
0.024
Θ
0°
8°
0°
8°
DIO6803• Rev. 1.2
DIO6803
Dioo is a professional design and sales corporation for high-quality and performance analog semiconductors. The company focuses on
industry markets, such as, cell phone, handheld products, laptop, and medical equipment and so on. Dioo’s product families include
analog signal processing and amplifying, LED drivers and charger IC. Go to http://www.dioo.com for a complete list of Dioo product
families.
For additional product information, or full datasheet, please contact with our Sales Department or Representatives.
www.dioo.com
DIO6803• Rev. 1.2
CONTACT US
很抱歉,暂时无法提供与“DIO6803SST3”相匹配的价格&库存,您可以联系我们找货
