DL-S100P
DL-S100P
    TAKEX(竹中)
DL-S100P 数据手册
photoelectric sensors DLS SERIES INDUSTRIAL • Background suppression by optical focusing • Detects objects of any colour, material or shape against similar background • Powerful beam for good operation even in dirty object, dirty lens conditions • Relay or solid state output options • Adjustable range: 0.2m to 1m - DL-S100, 0.2m to 2m - DL-S200, 150mm to 600mm - DL-7050 • IP66 Sealed TECHNICAL DATA Type DLS100P Detection Adjustable Range Power Supply Current Consumption Output Rating Operating Mode Response Time Light Source Sensing Cell LED IND. Range Protection Housing Connection Ambient Light Operating Temp 0.2 - 1m DLS200P DL7050 DLS100TC DLS200TC 0.2 - 2m Convergent reflection 150mm - 600mm 0.2 - 1m 0.2 - 2m 24V - 240V AC/DC ±10% 50/60HZ 12 - 24V DC±10%, 10% Max ripple 30mA (max) AC, 4W (max) DC Relay (3A, 250VAC 750VA) (3A, 30VDC 90W) 50mA Max NPN/PNP Open collector (100mA, 30VDC Max) Light on - Dark on selectable 20ms (Max) 2ms light on 5ms light off Infrared LED (880nm) Half dividing photodiode Output=red LED Stability=green LED Adjustable Mechanically - Short Circuit Polycarbonate/Acrylic sealed to IP66 Screw Terminals 10,000 Lux (Max) -25°C To +55°C DIMENSIONS 4 3 2 1 near Red Light on far BRACKET (SUPPLIED) 50 60 6 12 26 17 28 68 10 PF 12 (GLAND SUPPLIED) Green Dark on 12 10° 68 TERMINALS LIGHT ON - DARK ON RANGE ADJUSTMENT L E D INDICATORS 50 ELECTRICAL CONNECTIONS Relay Output Types DL - S100P DL - S200P DL-7050 4 3 2 PNP/NPN Output Types DL - S100TC DL - S200TC 1 N/O 24 -240V AC/DC PNP NPN 4 3 + – NOTE: Do not use a mirror or reflector as a background 2 – 1 + 12 -24 VDC ORDERING GUIDE Type Number DLS100P DLS200P DL7050 Description Convergent Reflection - Range 0.2 - 1M 0.2 - 2M 150 - 600mm Output Relay Relay Relay Type Number DLS100TC DLS200TC BG11553X Description Range Convergent Reflection 0.2 - 1M 0.2 - 2M Connector adaptor M12* Output PNP/NPN PNP/NPN *For Connector types add -J to the part number. e.g. DLS100P-J. Refer to page 194 for connection details. 230 0800 731 3186 www.oem.co.uk
DL-S100P 价格&库存
很抱歉,暂时无法提供与“DL-S100P”相匹配的价格&库存,您可以联系我们找货
