方成电子
子(东莞)有限公司
司
S
SPECIFICA
ATION FO
OR APPRO
OVAL
CUSTOMEER:
富士
士康科技集团
团
Part Nuumber
: DIP Coommon Linee Filter
CUSTOMEER Number::
共模滤波器
共
CUSTOMEER Part :
Fangcheeng part : FC- DLSF
F1010-12mmH/3A-L-S
DATE:
01
REV:
made in fangcheng
g:
CUSTOMER APPRODD:
prepad
checd
Approd
黄敏
刘凡
袁宏乐
乐
prepad
checd
App
prod
THE INFO
ORMATION CONTAINED
C
IN THIS DOCU
UMENT IS OF
F A PROPRIET
TARY NATUR
RE AND IS INT
TENDED TO B
E KEPT CONFIDENTIA
C
AL BETWEEN
N THE SENDE
ER AND THE INTENDED RECIPIENT.
R
IT
T MAY NOT BE
E REPRODUC
C
ED OR USED
U
WITHOU
UT EXPRESS
S WRITTEN PERMISSION
P
OF FC TECHNOLOGIES, O
OR FC
方成电
电子(东莞)
)有限公司
司
Tel: +86
6 0769-82988010
Fax: +8
86 0769-8298
88065
E-mail: yhl@fangch
hengcoils.com
m
URL: www.fangche
w
ngcoils.com
Address: Building 3, Jinmei Technology
T
P
Park,
No.16
6 Huanchang
g West Roa
ad, Changping Town,
Donggu
uan City
Fangch
heng Electro
onics (China
a-Taiwan)
Address: No. 31, MRT Road, Zh
honghe Distrrict, New Taip
pei City
Tel: +88
869-9834913
379
Customer:
made :
富士康科技集团
方成电子(东莞)有限公司
Part Number:FC-DLSF1010-12mH-3.0A
Page: 2 ------- 8
Description of Revision
REV
01
2021-8-9
Initial Release
Prepad
Checd
黄敏
Notes
Prepad
DATE
张丽
Approd
刘凡
袁了
Customer: 富士康科技集团
made :
方成电子(东莞)有限公司
Notice of Use
Page: 3 ------- 8
For the parameters not prescribed in the Specification for Approval, please refer to the following
standards or the relative industry standards.
1. Product in packing storage condition : temperature 540, RH70%.
2.A storage of - F C -Electronic productsfor longer than 12 months is not recommended,Within other
effects, the terminals may suffer degradation, resulting in bad solderability.Therefore, all products shall
be used within the period of 12 months based on the day of shipment.
3. Do not keep products in unsuitable storage conditions, such as areas susceptible to high temperatures,
high humidity, dust or corrosion.
4 Always handle products with care.
5 Don't touch electrodes directly with bare hands as oil secretions may inhibit soldering.
Always ensure optimum conditions for soldering.
6 When this product will be used on a similar or new project to the original one,
sometimes it might be unable to satisfy the specifications due to different condition of usage.
7 This inductor itself does not have any protective function in abnormal condition, such as overload,
short-circuit, open-circuit conditions, etc. Therefore, it shall be confirmed that there is no risk of smoke,
fire, dielectric withstand voltage, insulation resistance, etc., or use in abnormal conditions protective
devicesor protection circuit in the end product.
8 Hi-Pot test with higher voltage than spec value will damage insulating material and shorten its life.
IPC 020D Joint Industry standard
IEC1007 《Transformer and inductors for use in electronic and telecommunication
equipment—Measuring methods and test procedures》
(ROHS or other environmental request)
Prepad
Checd
黄敏
Approd
刘凡
袁了
Custo
omer:
mad
de :
1.
富
富士康科技
技集团
方成电子(东
方
东莞)有限公司
Partt Number:FC-DLSF10
010-12mH-3.0A
Page
e: 4 -------- 8
Appearan
nce and Dimensions(mm)
Appplication Fig: 85V‐265V
V AC/50‐60HZZ
I= 2.5‐3.0A
2.
Schematiic:
3.
Electriccal Characteristics:
TESST CONDITION
N: TEMPERATTURE AT 25℃,, HUMIDITY A
AT 65±5% RH // 测试条件:温度 25℃,湿度 65±5%R
RH
NO
TERM
MINAL
SPCIFFICATION
TTEST INSTERUMENTS
PARAMETER
序号
号
参
参数
脚
脚位
规格
规
测试设备
备
UCTANCE
INDU
1
1.0KHz,0.25V 320X
1
1
12.0mH
L=(1-2
2) (4-3)
CH
HROMA 3250 o
or EQUAL
电感
1
1.0KHz,0.25V 320X
2
2
3.0A
A/MIN
I=(1-2
2) (4-3)
工作电流 I =A
CH
HROMA 3250 o
or EQUAL
85V
V‐265V
3
3
压范围
V=(1-2) (4-3)
宽电压输
输入
电压
AC/50
0‐60HZ
DCR
4
4
GKT2511 2
25°C
R= (1-2) (4-3)
0.2Ω Max
直流
流铜阻
5
5
6
6
压测试
高压
ULATION
INSU
RESISTANCE
绝
绝缘电阻
COILL‐CORE
AC 1500
0V50‐60HZ
CH19503
COILL‐CORE
500VDC/1
100MΩ MIN
CH
HROMA 19053
3 DC500V
Prep
pad
Checd
黄敏
Approd
刘凡
袁了
袁
Customer:
made :
富士康科技集团
方成电子(东莞)有限公司
Page: 5 ------- 8
4.Reliability and test condition:
Test item
test condition
Cold Operating Test
GB2423.1 Ad
Heat Operating Test
GB2423.2 Bd
Cold Storage Test
GB2423.1 Ab
Heat Storage Test
GB2423.2 Bb
Steady Damp Heat Test
GB2423.3 Cb
Circular Damp Heat Test
GB2423.4 Db
Temperature Cycling Test
GB2423.22 Nb
Temperature Shock Test
GB2423.22 Na
Vibration Test
Remark
GB2423.10~15 Fc, Fdb
Mechanical Shock Test(Bump)
GB2423.5 Eb
Free Fall Test
GB2423.8 Ed
Solderability
GJB360A-96
High Temperature Step Stress Test
Low Temperature Step Stress Test
Enhancement Test
Specifications
High-speed Thermal Cycling
Limit Vibration
Composite Stress
Highly-Accelerated Temperature and Humidity Stress
Test(HAST)(
Prepad
Checd
黄敏
Approd
刘凡
袁了
Customer:
made :
富士康科技集团
方成电子(东莞)有限公司
Page: 6 ------- 8
5. Soldering Specification:
5.1 R eflow P rofile f or C omponents.
5.2 波峰焊温度:255℃±5℃;时间:不少于 7 秒.
波峰焊预热温度:100 至 160℃;时间:不少于 10 秒.
5.3 高温耐热性:
在 260℃的熔融钎料中,停留时间不少于 10 秒,无质量问题。
5.4 返修温度和时间:
温度:350OC;时间:不少于 5 秒。
5.5 焊接次数:
元器件能承受的焊接次数不少于 5 次。
6.1 包装:
1)包装箱上应标明产品型号、名称、数量、出厂日期、承制方名称及出厂检验章;
2)货物运达客户方后,包装箱封条应完好,箱体无破损、开裂等现象;
3)电感用木箱或其他材料包装,方便拆卸,四周用软性材料填充;
6.2 外观:
1)产品应有合格证和耐擦防水洗标签,应注明型号、规格;
2)产品外观整洁,应无破损、划伤;
6.3 检验:
1)产品生产中必须全数进行电气性能,抗电强度检测;箱内应有 100%电气性能合格保证书或检测报告;
2)产品出货前按批次,必须根据承认书按国家行业标准进行抽样检验,合格后出具出厂检验报告,记录抽样测试数据,
在每批次包装尾箱中放置一份;检验报告须注明 100%耐压测试合格。注:批次按定单号发货为准
Prepad
Checd
黄敏
Approd
刘凡
袁了
很抱歉,暂时无法提供与“DLSF1010-12MH-L-S”相匹配的价格&库存,您可以联系我们找货
