TL4 Range
Miniature/Microslim Threaded C & L Circuit Filters
[Key Characteristics
Applications
• High Density Panels
• Bulkhead Filter Arrays
Rugged
• Discoidal construction
• High performance
Performance
• ≤22nF
• ≤200Vdc
• High frequency
• Temperature -55°C to +125°C
[Electrical Characteristics
IL (dB)
1MHz
10
MHz
100
MHz
1 GHz
10
GHz
Colour Code
(Hex end/Thread end)
Marking**
200v*
2
18
35
60
Green/White
OXC n33
10A
200v*
1
4
22
35
70
Grey/White
OXC 268
1000pF
10A
200v*
1
9
26
40
70
Brown/White
OXC 1n0
C
4700pF
10A
200v*
3
50
70
Red/White
OXC 4n7
C
10000pF
10A
200v*
8
27
44
63
70
Black/White
OXC 10n
C
22000pF
10A
200v*
12
30
50
68
70
Blue/White
OXC 22n
L
330pF
10A
200v*
2
60
Green/Red
OXL n33
L
680pF
10A
200v*
1
4
24
38
70
Grey/Red
OXL n68
L
1000pF
10A
200v*
1
9
28
43
70
Brown/Red
OXL 1n0
L
4700pF
10A
200v*
3
56
70
Red/Red
OXL 4n7
L
10000pF
10A
200v*
8
28
48
70
70
Black/Red
OXL 10n
L
22000pF
10A
200v*
12
31
54
70
40
Blue/Red
OXL 22n
Circuit
Cap
Current Voltage
C
330pF
10A
C
680pF
C
* Voltage derates linearly to 50% of quoted voltage from 85°C to 125°C
** Marking at manufacturers discretion
[Ordering Information
DLT4/
Example: DLT4/C/4700 - C circuit, 4700pF
Capacitance
/330 - 330pF
/680 - 680pF
/1000 - 1000pF
/4700 - 4700pF
/10000 - 10000pF
/22000 - 22000pF
Circuit
/C - C Filter
/L - L Filter
Microslim
XH - Microslim
Telephone: +44 (0)1229 483226 • sales@oxleygroup.com • www.oxleygroup.com
26
EMC FILTERS
TL4 Range
[Miniature Threaded Data
Thread
6-32 UNC (2A)
Minimum Component
Pitch (with nut)
6mm
Minimum Component
Pitch (without nut)
5mm
Mounting Torque
0.3 Nm
ALL DIMENSIONS IN MM
[Microslim Threaded Data
Thread
6-32 UNC 2A
Mounting Hole
3.7mm
Max. Chassis Thickness
3.2mm
Minimum Pitch
(with and without nut)
4.8mm
Mounting Torque
0.3 Nm
NOTE: DLT4/NUT/XH supplied separately
[Technical Information
CASE & NUT
Brass, Silver finish
FEEDTHROUGH TERMINATIONS
Copper Alloy, Tin Lead or Silver finish
MICROSLIM ASSEMBLY TOOLS PART NUMBER
ATXH/01 & ATXH/02
*ROHS versions available upon request - please speak to the sales department
27
EMC FILTERS
ODC:SM:40824/2
很抱歉,暂时无法提供与“DLT4/L/22000/ROHS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+185.93449
- 50+184.29351
- 100+181.17923
- 250+177.83737
