FLTM/P/1500/ROHS
FLTM/P/1500/ROHS
    OXLEY
    Ceramic
    陶瓷电容/独石电容 Ceramic
FLTM/P/1500/ROHS 数据手册
TL1 Range Miniature Threaded C and Pi Circuit Filters [Key Characteristics Applications • High density panels • Bulkhead filter arrays Rugged • Robust thick walled tubular construction Performance • ≤10nF • ≤500Vdc • High frequency • Temperature -55°C to +125°C [Electrical Characteristics Circuit Cap Current Voltage dc I.L. (dB) 1MHz 10 MHz 100 MHz 1 GHz Colour Code C 47pF 10A 500v* - - 6 23 Yellow/Yellow C 470pF 10A 500v* - 3 18 30 Orange/Orange C 1000pF 10A 500v* - 7 26 32 Brown/Brown C 4700pF 10A 350v* 1 17 34 42 Red/Red C 8200pF 10A 350v* 6 23 40 50 Dark Blue/Dark Blue P 680pF 10A 350v** - 4 35 70 Grey/White P 1500pF 10A 350v** 1 12 50 75 Red/White P 5000pF 10A 350v* 4 25 70 75 Green/White *Voltage derates linearly to 100v dc from 85°C to 125°C ** Voltage derates linearly to 200v dc from 85°C to 125°C [Ordering Information Circuit Type /P - Pi /C - C FLT Thread Type Blank - UNF /M - Metric / Capacitance C Type - 47 470 1000 4700 8200 P Type - 680 1500 5000 47pF 470pF 1000pF 4700pF 8200pF 680pF 1500pF 5000pF Example: FLTM/P/5000 Telephone: +44 (0)1229 483226 • sales@oxleygroup.com • www.oxleygroup.com 8 EMC FILTERS TL1 Range Colour Coding Colour Coding ALL DIMENSIONS IN MM [Mechanical Information TYPE FLTM/- FLT/- Thread M5 x 0.8 12-32 UNEF Mounting Hole Diameter 5.1mm 5.62mm Chassis Thickness (max.) 3.1mm 3.1mm Minimum Pitch (with nut) 7.05mm 7.45mm Minimum Pitch (without nut) 6.5mm 6.5mm Nut A/F 6mm 6.35mm Mounting Torque 0.35Nm 0.35Nm [Technical Information BODY & NUT Brass, Silver finish WASHER Tin plated Beryllium Copper Alloy TERMINATIONS Copper Alloy, Tin Lead or Silver finish *ROHS versions available upon request - please speak to the sales department Telephone: +44 (0)1229 483226 • sales@oxleygroup.com • www.oxleygroup.com 9 EMC FILTERS ODC:SM:40819/2
FLTM/P/1500/ROHS 价格&库存
很抱歉,暂时无法提供与“FLTM/P/1500/ROHS”相匹配的价格&库存,您可以联系我们找货
