030/30P/KP2 SILVER
030/30P/KP2 SILVER
    OXLEY
    OXLEY - 030/30P/KP2 SILVER - IC & Component Socket, 1 Contacts, Terminal, 2.5 mm, KINKY PIN Series, ...
030/30P/KP2 SILVER 数据手册
Kinky Pin Connector Series Kinked Retention Plated Through Hole Connector with Solder Posts [Key Characteristics Functionality • Plated Through Hole Applications (PTH) • Unique kinked retention mechanism • Design enhances solderability • Low insertion force Adaptable • Hand and semi automatic insertion • Wide range of diameters Resilient • -55 to +125° C Kinky Pins were designed specifically to meet the demands of plated through hole (PTH) technology introduced in printed circuit boards. They tend to be used with flexicircuit terminations and as solder terminals, connectors and in multiway pin arrays. They use a unique kinked retention mechanism which gives a fit in the PTH that is unsurpassed. The kinked leg provides a tight non-aggressive spring loaded fit whilst the straight leg ensures the pin is kept perpendicular to the PCB prior to soldering. [Technical Information Minimum Pitch using Assembly Tool 2.5mm (0.098”) 028,030,040 Series 3.0mm (0.118”) 050,060 Series Pin Copper Alloy with Tin Lead Finish (option Gold, Silver, Tin) Solderability Exceeds Requirements of BS2011 (IEC 68) Test T Assembly Tools Socket Assembly AT1/KP1 (-/30P/KP2, -/30P/KP2/L) AT1/KP2 (028-040/T/KP2) AT1/KP3 (-/10P/30P/KP2/L, 050-060/T/KP2) Line Socket 30/LS/093 - to suit -/30P/KP2 and -/30P/KP2/L Minimum Board Thickness 1.4 (0.055”) 2.36 (0.093”) for -/10P Telephone: +44 (0)1229 483226 • sales@oxleygroup.com • www.oxleygroup.com 5 INTERCONNECT ing Hole Diameter: 020/C/KP2 [I = 3.7 mm (0.146")] m (0.027") - 0.84 mm (0.033") Through 020/PT/KP2 [I = 6.1 mm (0.240")] itch Using Assembly Tool: 020/PT/KP2/L [I = 7.3 mm (0.287")] ctors m (0.098") der Diameter A: m (0.063") KINKY PIN Plated Through Kinky Pin Test Points Hole (PTH) Connectors x: 030/- 030/30P/KP2 040/30P/KP2 050/30P/KP2 060/30P/KP2 Kinky Pin Connector Series [Ordering Information er: KINKY PIN Plated Through ing Diameter: mmHole (0.027") Hole (PTH) Connectors m (0.032") - 0.96 mm (0.038") Mounting Hole Diameter mbly Tool: itch Using Assembly Tool: 020/Prefix: 028/--0.68mm (0.027”) to 0.84mm Kinky (0.033”)Pin Test Points m (0.098") Mounting Hole Diameter: 028/30P/LA/KP2 028/30P/KP2/L Prefix:-020/Kinky Pin Test Points 0.52 mm (0.020") 0.68 mm (0.027") der Diameter A: 030/--0.81mm (0.032”) to 0.96mm (0.038”) 030/30P/LA/KP2 030/30P/KP2/L Mounting Hole Diameter: Min. Pitch Using Assembly Tool: m (0.063") 040/30P/LA/KP2 040/30P/KP2/L 0.52 mm (0.020") - 0.68 mm (0.027") 040/--0.96mm (0.038”) to 1.12mm (0.044”)050/30P/KP2/L 2.5 mm (0.098") 050/30P/LA/KP2 x: er:040/- Min. Pitch Using Assembly Tool: Shoulder Diameter A: 060/30P/LA/KP2 028/30P/KP2 2.5 mm (0.098") 050/--1.21mm (0.048”) to 1.37mm (0.054”)060/30P/KP2/L 030/30P/KP2 1.0 mm 020/C/KP2 [I = (0.039") 3.7Shoulder mm (0.146")] Diameter A: mmHole (0.033") 040/30P/KP2 ing Diameter: 020/PT/KP2 [I = 6.1 1.0mm mm(0.240")] (0.039") 060/--1.50mm (0.059”) to 1.65mm (0.065”) 050/30P/KP2 mbly Tool: Prefix: 028/020/PT/KP2/L [I = 7.3 mm (0.287")] m (0.038") - 1.12 mm (0.044") 060/30P/KP2 Prefix: 028/Mounting EXAMPLE: 028/30P/KP2/L itch Using Assembly Tool: Hole Diameter: 020/C/KP2 [I = 3.7 mm (0.146")] Mounting Holemm Diameter: 0.68 mm (0.027") - 0.84 (0.033") 020/PT/KP2 [I = 6.1 020/C/KP2 [I =mm 3.7 (0.240")] mm (0.146")] m (0.098") mmAssembly (0.027") - 0.84 mm (0.033") Min. Pitch0.68 Using Tool: 020/PT/KP2 [I = mm 6.1 mm (0.240")] 020/PT/KP2/L [I = 7.3 (0.287")] Min. Pitch Using Assembly Tool: Kinky Pin Test der Diameter A: Points 020/PT/KP2/L [I = 7.3 mm (0.287")] 2.5 mm (0.098") 2.5 mm (0.098") m (0.063") Shoulder Diameter A: Through er: ctors x:mm 050/(0.038") 028/10P/30P/LA/KP2 mbly Tool: Mounting Min. HolePitch Diameter: 030/10P/30P/LA/KP2 ---/10P/30P/LA/KP2 060/30P/KP2 040/10P/30P/LA/KP2 040/10P/30P/KP2/L Using Assembly Tool: 060/10P/30P/LA/KP2 1.21 mm (0.048") - 1.37 mm (0.054") 3.0 mm (0.118") 050/10P/30P/LA/KP2 040/10P/30P/LA/KP2 050/10P/30P/KP2/L 050/10P/30P/LA/KP2 028/30P/KP2/L 060/10P/30P/LA/KP2 060/10P/30P/KP2/L Min. Pitch Using Assembly Tool: Oxley Shoulder Diameter A: Oxley Developments Company Oxley ley Developments Company Ltd Ltd Oxley Inc.Inc. Group Australia Pty Ltd 060/10P/30P/LA/KP2 2ail:sales@oxley.co.uk 030/30P/KP2/L Email: sales@oxley.co.uk 3.0 Email: 2.4 mmsales@oxleyinc.com (0.094) sales@oxleyinc.com Email: sales@oxleygroup.com mm Email: (0.118") 2: Tel: 040/30P/KP2/L (0)1229 483226 +1 (203) 1033 +44+44 (0)1229 840607 Tel: Tel: +1 (203) 488488 1033 Tel +61 (2) 9967 9193 Shoulder Diameter A: 050/30P/KP2/L Prefix: 060/2.4 mm (0.094) 060/30P/KP2/L O 0.9 mm (0.035") 2 2 1.6mm (0.063”) 2.4mm (0.094”) 2.4mm (0.094”) 028/30P/KP2 030/30P/KP2 028/30P/KP2 040/30P/KP2 030/30P/KP2 040/30P/KP2 050/30P/KP2 050/30P/KP2 060/30P/KP2 060/30P/KP2 028/30P/KP2/L 028/30P/KP2/L ---/30P/KP2/L 030/30P/KP2/L 030/30P/KP2/L 040/30P/KP2/L 040/30P/KP2/L 050/30P/KP2/L 050/30P/KP2/L 060/30P/KP2/L 060/30P/KP2/L Mounting Holemm Diameter: 060/30P/KP2 0.96 (0.038") - 1.12 mm (0.044") - 1.12 mm (0.044") Tool: Min. Pitch Using Assembly ing Hole Diameter: 0.96 mm (0.038") 2.5 mm (0.098") Pitch Using Assembly Tool: m (0.059") - 1.65 mmMin. (0.065") Shoulder Diameter A: 2.5 mm (0.098") 028/T/KP2 ---/T/KP2 1.6 mm (0.063") itch Using Assembly Tool: Diameter Shoulder A: 030/T/KP2 028/30P/KP2 mter: (0.118") 1.6 mm (0.063") 040/T/KP2 Prefix: 050/030/30P/KP2 028/10P/30P/LA/KP2 [I = 3.7 mm (0.146")] 4der mmDiameter (0.033") A: 020/C/KP2 050/T/KP2 Mounting Hole Diameter: 040/30P/KP2 030/10P/30P/LA/KP2 028/10P/30P/LA/KP2 028/10P/30P/KP2/L 020/PT/KP2 [I = 6.1 mm (0.240")] Prefix: 050/040/10P/30P/LA/KP2 028/10P/30P/LA/KP2 060/T/KP2 050/30P/KP2 mbly Tool: 030/10P/30P/LA/KP2 030/10P/30P/KP2/L mer: (0.094) 020/PT/KP2/L [I =1.21 7.3 mm mm (0.048") (0.287")]- 1.37 mm (0.054") 050/10P/30P/LA/KP2 mm (0.054") mbly Tool: 2 1.6mm (0.063”) 028/10P/30P/KP2/L 030/10P/30P/KP2/L 040/10P/30P/KP2/L 050/10P/30P/KP2/L 060/10P/30P/KP2/L 040/10P/30P/LA/KP2 m (0.048") - 1.37 mm0.81 (0.054") 0.81 mm- (0.032") - 0.96 mm (0.038") mm (0.032") 0.96 mm (0.038") 050/10P/30P/LA/KP2028/30P/KP2/L 028/30P/LA/KP2 Min. Pitch Using Assembly Tool: itch Using Assembly Tool: Min. Pitch Using Assembly Tool: 030/30P/LA/KP2 060/10P/30P/LA/KP2030/30P/KP2/L 2.5 mm (0.098") Kinky Pin Test Points 2.5 mm (0.098") m (0.118") 040/30P/LA/KP2 040/30P/KP2/L 028/30P/LA/KP2 028/30P/LA/KP2 Shoulder Diameter A: 030/30P/LA/KP2 ter: 050/30P/LA/KP2 050/30P/KP2/L Shoulder Diameter A: 030/30P/LA/KP2 der Diameter A: 028/30P/KP2 1.6 mm (0.063") 040/30P/LA/KP2 060/30P/LA/KP2 060/30P/KP2/L 1.6 mm (0.063") 8 mm (0.027") 040/30P/LA/KP2 ---/30P/KP2 050/30P/LA/KP2 030/30P/KP2 m0.146")] (0.094) 050/30P/LA/KP2 060/30P/LA/KP2 Prefix: 040/040/30P/KP2 mbly Tool: er: (0.240")] 060/30P/LA/KP2 Prefix: 040/050/30P/KP2 Mounting Hole Diameter: m (0.287")] 1.6mm (0.063”) Shoulder Diameter A: 1.6 mm (0.063") 1.6 mm (0.063") Prefix: 030/Prefix: 030/ing Hole 030/10P/30P/LA/KP2 mbly Tool:Diameter: Mounting Mounting Hole Diameter: Hole Diameter: (0.044") x:mm 060/- Shoulder Diameter ‘A’ 028/10P/30P/KP2/L 030/10P/30P/KP2/L 040/10P/30P/KP2/L 028/10P/30P/KP2/L 050/10P/30P/KP2/L 030/10P/30P/KP2/L 060/10P/30P/KP2/L 040/10P/30P/KP2/L ---/10P/30P/KP2/L 050/10P/30P/KP2/L www.oxleygroup.com www.oxleygroup.com/interconnect 060/10P/30P/KP2/L ODC:SM:40566/5/2009 ODCSM:40566/4/2006 11.5 mm (0.453") max Connecting Wire O 3.2 mm (0.126") (Insulation O 1.3mm (0.051")max) Mounting Hole Diameter: (Wire O 0.8mm (0.031") max) 1.50 mm (0.059") - 1.65 mm (0.065") Prefix: 060/028/T/KP2 Min. Pitch Using Assembly Tool: 030/T/KP2 Mounting 3.0 Hole mmDiameter: (0.118") 040/T/KP2 1.50 mm (0.059") 1.65 mm (0.065") Shoulder Diameter A: 050/T/KP2 028/T/KP2 028/30P/LA/KP2 028/30P/KP2/L 060/T/KP2 Min. Pitch2.4 Using Assembly Tool: mm (0.094) 30/LS/093 028/T/KP2 030/T/KP2 030/30P/LA/KP2 030/30P/KP2/L 3.0 mm (0.118") ---/30P/LA/KP2 030/T/KP2 040/T/KP2 040/30P/LA/KP2 040/30P/KP2/L 040/T/KP2 Shoulder Diameter A: Oxley Developments Company Oxley www.oxleygroup.com 050/T/KP2 Oxley Developments Company Ltd Ltd Oxley Inc.Inc. Oxley Group Australia Pty Ltd www.oxleygroup.com/interconnect 050/30P/LA/KP2 050/30P/KP2/L Email: sales@oxley.co.uk Email: sales@oxleyinc.com Email: sales@oxleygroup.com Email: sales@oxleyinc.com 060/T/KP2 050/T/KP2 2.4 mm (0.094)Email:sales@oxley.co.uk Tel: +44 (0)1229 483226 Tel: +1 (203) 488 1033 ODC:SM:40566/5/2009 Tel: +44 (0)1229 840607 Tel: +1 (203) 488 1033 Tel +61 (2) 9967 9193 ODCSM:40566/4/2006 060/30P/LA/KP2 060/30P/KP2/L 060/T/KP2 P2 028/10P/30P/KP2/L ter: Oxley Developments Company Oxley www.oxleygroup.com Oxley Developments Company Ltd Ltd Oxley Inc.Inc. Oxley Group Australia Pty Ltd www.oxleygroup.com/interconnect 030/10P/30P/KP2/L 2P2 mm (0.044") Email: sales@oxley.co.uk Email: sales@oxleyinc.com Email: sales@oxleygroup.com Email:sales@oxley.co.uk Email: sales@oxleyinc.com Company Ltd Oxley Inc. www.oxleygroup.com mpany Oxley Inc. Oxley Group Australia PtyTel: LtdTel: www.oxleygroup.com/interconnect P2 Ltd 040/10P/30P/KP2/L (0)1229 483226 +1 (203) 1033 ODC:SM:40566/5/2009 Tel: Tel: +44+44 (0)1229 840607 +1 (203) 488488 1033 Tel +61 (2) 9967 9193 ODCSM:40566/4/2006 mbly Tool: uk Email: sales@oxleyinc.com Email: sales@oxleyinc.com Email: sales@oxleygroup.com P2 050/10P/30P/KP2/L 6 +1 (203) 1033 ODC:SM:40566/5/2009 Tel: Tel: +1 (203) 488488 1033 Tel +61 (2) 9967 9193 ODCSM:40566/4/2006 P2 060/10P/30P/KP2/L ter: 6 mm (0.038") mbly Tool: er: mm (0.065") mbly Tool: 88 88 028/10P/30P/LA/KP2 028/10P/30P/KP2/L ter: 030/10P/30P/LA/KP2 030/10P/30P/KP2/L 040/10P/30P/LA/KP2 040/10P/30P/KP2/L 7 mm (0.054") 050/10P/30P/LA/KP2 050/10P/30P/KP2/L mbly Tool: 060/10P/30P/LA/KP2 060/10P/30P/KP2/L Telephone: +44 (0)1229 483226 • sales@oxleygroup.com • www.oxleygroup.com 028/T/KP2 030/T/KP2 6 INTERCONNECT ODC:SM:40808/1
030/30P/KP2 SILVER 价格&库存
很抱歉,暂时无法提供与“030/30P/KP2 SILVER”相匹配的价格&库存,您可以联系我们找货
