DLT/4700
DLT/4700
    OXLEY
    Ceramic
    陶瓷电容/独石电容 Ceramic
DLT/4700 数据手册
TH3 Range Miniature Threaded C Circuit Filters [Key Characteristics Applications • High Density Panels • Bulkhead Filter Arrays Rugged • Discoidal construction • High Performance Performance • ≤100nF • ≤100Vdc • High frequency • Temperature -40°C to +100°C [Ordering Information Circuit Cap Current Voltage dc IL (dB) 0.1Mhz 1MHz 10MHz 100MHz 1GHz Colour Code (hex end/ thread end) C 22pF 10A 100v * - - - 3 15 Black/White C 47pF 10A 100v * - - - 5 20 Yellow/White C 100pF 10A 100v * - - - 8 28 White/White C 330pF 10A 100v * - - 2 18 34 Green/White C 470pF 10A 100v * - - 3 20 40 Orange/White C 680pF 10A 100v * - - 4 22 40 Grey/White C 1000pF 10A 100v * - - 9 27 40 Brown/White C 4700pF 10A 100v * - 3 20 38 53 Red/White C 10000pF 10A 100v * 1 8 27 44 63 Blue/White C 47000pF 10A 100v * 4 20 41 45 74 Lt Blue/White C 100000pF 10A 50v * 2 25 45 57 75 Lt Brown/White * Voltage derates linearly to 50% of quoted voltage dc from 85°C to 100°C [Ordering Information Capacitance 22 - 22pF 47 - 47pF 100 - 100pF 330 - 330pF 470 - 470pF 680 - 680pF 1000 - 1000pF 4700 - 4700pF 10000 - 10000pF 47000 - 47000pF 100000 - 100000pF Lead Options Blank - Plain lead Ref1 - with PIP DLT/ / / Thread Blank - 2BA M - M5 x 0.8 Telephone: +44 (0)1229 483226 • sales@oxleygroup.com • www.oxleygroup.com EMC FILTERS TH3 Range ALL DIMENSIONS IN MM L1 L2 L3 max max min 34 40 27 13.4 14.8 6.4 DLT & DLTM DLT/-/Ref 1 & DLTM/-/Ref 1 [Mounting Details THREAD DLT/-, DLT/-/Ref 1 DLTM/, DLTM/-/Ref 1 2BA M5 x 0.8 MOUNTING HOLE 5.1mm MOUNTING TORQUE 0.35Nm CHASSIS THICKNESS 1.2 - 1.6mm MINIMUM PITCH (with nut) 8mm MINIMUM PITCH (without nut) 8mm [Technical Information CASE & NUT Brass, Tin finish FEEDTHROUGH TERMINATIONS Copper Alloy, Tin Lead or Silver finish Distributed by *ROHS versions available upon request - please speak to the sales department Telephone: +44 (0)1229 483226 • sales@oxleygroup.com • www.oxleygroup.com EMC FILTERS ODC:SM:40822/2
DLT/4700 价格&库存
很抱歉,暂时无法提供与“DLT/4700”相匹配的价格&库存,您可以联系我们找货
