DM670/PM/1/100
DM670/PM/1/100
    STATUS
    STATUS - DM670/PM/1/100 - PRESSURE DISPLAY, 6DIGIT, 0BAR TO 100BAR
DM670/PM/1/100 数据手册
DM670PM FIELD/WALL MOUNTED PRESSURE DISPLAY UP TO 100 BAR PRESSURE/ TEMPERATURE DISPLAY WITH SCALING/ LINERIZATION BATTERY POWERED, USB AND NFC INTERFACE DUAL RELAYS, MAX/ MIN INFORMATION USER SET DISPLAY MESSAGING 3600 POINT LOGGER WITH USB AND NFC INTERFACE INTRODUCTION The DM670PM series of battery powered indicators accept gauge pressure inputs up to 100 bar and displays the sensor pressure in BAR, PSI or the user’s engineering unit on a 6digit LCD display. The instrument offers an advanced display mode allowing the user to also display one or two (1 to 32) character messages. Additional to the messages, the user may select an alert event to occur when the pressure is within a band. The two change-over relays can be used together with the messaging and alerts to provide switching at user set points. In addition to this on board datalogging is also available to record process details at up to 3600 points. FEATURE HIGHLIGHTS DUAL RELAYS The instrument is equipped with dual volt-free change over type relays, operating independently. The user may select one of seven actions including deviation, latched or non-latched operation, with fully adjustable set point and dead-band. The Relays may be turned off if not required to extend battery life. An option is provided to trigger an alert event when a relay contact is on. DATA LOGGING FUNCTION DM670PM also provides a powerful data logging function. The log points can be set up to 3600 points, each point is time and date stamped together with process value, temperature and relay state information. The log rate is selectable in steps. The start of log can be delayed if required. Either fixed or rolling logs may be performed. Two methods of reading the log are available. The USB configuration reads the log and allows the user to save to a text file for export to other programs. While the NFC android interface allows data transfer to android phones or tablets and using the downloadable App the data can be graphed and forwarded by email, Bluetooth etc. The NFC interface is also capable of starting a new log with different log period and modes. CALIBRATION/ USER LINEARIZATION 5-point calibration can be applied using the USBSpeedLink software As well as straight line interpolation up to 22 points (x,y) of user linearization are available for creating custom curves and corrections. REAL TIME CLOCK Date and time stamped maximum, minimum and average temperature values as well as relay on and relay off data is recorded and can be displayed along with the current time and date. The real time clock is also used to record the data logged points. D2607-01-03 CN5590 DM670PM Data Sheet, Page 1 of 5 DM670PM INPUT PRESSURE Type Sealed gauge *1 FIELD/WALL MOUNTED PRESSURE DISPLAY SPECIFICATIONS @20°C Range (0 to 3) bar (0 to 30) bar (0 to 100) bar 4 x pressure range Accuracy/ stability ±0.5% of full scale between (0 to 50) °C *2 ±0.7% of full scale between (-10 to 80) °C *2 Overpressure Up to maximum 350 Bar Thermal drift (-10 to 80) °C compensated *1 Shows zero Bar at 1.0 Bar absolute *2 Total error band: Maximum deviation within specified pressure and operating temperature range To maintain full accuracy annual calibration is required contact support@status.co.uk for details INPUT Temperature Type SPECIFICATIONS @20°C Range (-40 to 110)°C Accuracy/ stability Typically, ±2.0°C DISPLAY Type/ options/ function Display height Display information options Some information is displayed scrolling. Description 15.8 mm non-backlit 6 digits 14 segment input value plus “Warning”,” Transmit”, “NFC”, “USB”, “Log”, “Battery”,” Off-set” icons, 8 segment log volume indicators. Maximum, minimum, average*1. Date and time. Custom messages for visual alarms/ information. Relay condition. High intensity LED Alarm and warning options *1 Rolling average data log is independent of data logging RELAYS Relay 1 and Relay 2 Type/ options/ function 2 x independent relays Rating Description Single pole change-over (common, N/o, N/c) 48 VDC maximum @ 1 A (5 mA minimum) 28 VAC RMS maximum @ 1 A USB CONFIGURATION USER INTERFACE Type/ options/ function Configuration hardware Configuration software Operating system Sensor configuration Display configuration Description USB Mini B port USBSpeedLink Microsoft Windows User calibration Off-set in Bar Display mode Pressure units Pre-set sensor to setpoint LED alert (advanced mode) Warning symbol Custom units Locks input value to setpoint Eight user adjustable pressure bands Out of range Low battery level D2607-01-03 CN5590 DM670PM Data Sheet, Page 2 of 5 Notes Cable not included Download www.status.co.uk Win 7 or later Up to 5 points Applied by button action Basic with advanced options °C or °F Bar/ PSI/ mBar/ Pa/ KPa/MPa Kgf/m²/ Kgf/cm²/ Kgf/mm² Atm/ custom units (any) With 22-point linearization For diagnostics Alert LED flash Warning symbol will flash on LCD display DM670PM Basic display mode FIELD/WALL MOUNTED PRESSURE DISPLAY Update rate Display variable options Temperature units Push buttons 1 s/ 5 s Input/ input + units/ input + units + temperature °C or °F Active/ active with time stamp/ off Options Period/ number of samples Alert LED Rolling average Advanced display mode *1 Display variable (see basic mode) with messaging options Battery monitor Alert LED plus message Relay option Logger Set device passkey number Device passkey is used to protect the Clear/ start new log NFC interface. Other device options Synchronise clock Write tag/ contact address Read/ reset maximum and minimum input values Latitude longitude settings Relay control Name(s) 10 characters Action High/ low/ band/ low battery/ on/ off Setpoint In engineering units Dead band On/ off Latch Live data Read sensor pressure bar Read displayed value Selected engineering unit Read sensor temperature °C Relay 1 state. Relay 2 state Time and date *1 Only use advanced display above -5°C ambient temperature, below use basic display USB LOGGER USER INTERFACE Type/ options/ function Logger hardware Logger software Operating system Logger NFC LOGGER USER INTERFACE ANDROID Type/ options/ function Logger software Operating system Logger Description USB Mini B port USBLogLink Microsoft Windows Start/set log parameters Read log parameters Stop/ start new log Synchronise device clock Reset maximum and minimum Synchronise/ read clock View log data/ graph log data Notes Cable not included Download www.status.co.uk Win 7 or later Interval/ rate/ (delay) start/ number of points/ rolling or fixed log Description NFCLogLink Android V4.4 Kitkat or later Start/set log parameters Read log parameters Stop/ start new log Synchronise/ read clock Reset maximum and minimum View log data/ graph log data Transfer data via email etc. Notes @ Google Play Store NFC enabled Interval/rate/ (delay) start/ number of points/ rolling or fixed log D2607-01-03 CN5590 DM670PM Data Sheet, Page 3 of 5 Save data to CSV file Save data to text file Standard Android functions DM670PM FIELD/WALL MOUNTED PRESSURE DISPLAY PUSH BUTTON USER INTERFACE Button Maximum and minimum Description Notes Display/ display and reset Time and date stamp option Offset/ offset reset Rolling average option Number and rate options Relay Display relay configuration Time and date stamp option Reset latched relay Relay setpoint adjustment is not possible using front panel buttons, USBSpeedLink required Buttons can be locked out to avoided tampering GENERAL Function Update rate Relay response time Battery Battery life Clock accuracy Description 1 or 5 seconds < 10 seconds 1 x (AA 3.6 V lithium) 1 year minimum @20°C (longer depending on options selected) ±2 seconds per month typically ENVIRONMENTAL Function Ambient housing temperature Ambient sensor temperature Ambient humidity Protection USB configuration ambient Description Operating/storage (-30 to 70)°C Operating (-40 to 110)°C Operating/storage (10 to 90) %RH non-condensing IP65, cable entry must be sealed to IP65 (10 to 30)°C CONNECTIONS Sensor to process Output relays USB connection ¼ inch BSP male with adaptor options (see accessories) 2 x Two-part screw connectors USB mini B port MECHANICAL Enclosure (case) Stainless steel, side or base mount options Case entry Front bezel diameter Weight (approximate) Material in contact with media O-ring 1 x M16 female thread, blanking plug supplied 113 mm 520 g Stainless steel 316L Viton APPROVALS EMC BS EN 61326 D2607-01-03 CN5590 DM670PM Data Sheet, Page 4 of 5 DM670PM FIELD/WALL MOUNTED PRESSURE DISPLAY ORDER CODE Choose from options below DM670PM / case type Case option Side entry Rear entry Wall mount Range options (0 to 3) Bar (0 to 30) Bar (0 to 100) Bar Example: - / range I J L 3 30 100 DM670PM /I /3 Shown with swivel adaptor fitted. ACCESSORIES Swivel adaptor ¼ BSPP Swivel adaptor ½ BSPP Swivel adaptor ¼ NPT Swivel adaptor ½ NPT Swivel adaptor other options available Configuration software USB logging software NFC logging software USB lead Battery 3.6 V lithium SA14BSP SA12BSP SA14NPT SA12NPT sales@status.co.uk USBSpeedLink free of charge from www.status.co.uk USBLogLink free of charge from www.status.co.uk NFCLogLink free of charge refer to Google Play Store USB lead part number 42-200-0001-01 Contact sales@status.co.uk The data in this document is subject to change. Status Instruments assumes no responsibility for errors Status Instruments Ltd Tel: +44 (0)1684 296818 Status Business Park Fax: +44 (0)1684 293746 Gannaway Lane, Tewkesbury Email: sales@status.co.uk Gloucestershire, UK Website: www.status.co.uk GL20 8FD D2607-01-03 CN5590 DM670PM Data Sheet, Page 5 of 5
DM670/PM/1/100 价格&库存
很抱歉,暂时无法提供与“DM670/PM/1/100”相匹配的价格&库存,您可以联系我们找货
