DM650/TM/C
DM650/TM/C
    STATUS
    STATUS - DM650/TM/C - Temperature Indicator, Digital, DM650TM Series, RTD, Thermocouple, LCD, 6 Digi...
DM650/TM/C 数据手册
DM650TM SENSOR / WALL MOUNTED TEMPERATURE DISPLAY DM650TM UNIVERSAL RTD OR THERMOCOUPLE INPUT BATTERY POWERED USB AND NFC INTERFACE ALARM RELAY / USER SET DISPLAY MESSAGES 5000 POINT DATA LOGGER INTRODUCTION The DM650TM battery powered indicator accepts RTD or thermocouple temperature sensors and displays the sensor temperature in °C or °F on a 6-digit LCD display. The instrument offers an advanced display mode allowing the user to also display one or two (1 to 32) character messages. Additional to the messages, the user may select an alert event to occur when the temperature is within a band. The change-over relay can be used together with the messaging and alert to provide switching at user-set switch points. In addition to this, on board datalogging is also available to record process details at up to 5000 points. FEATURE HIGHLIGHTS RELAY TRIP The instrument is equipped with a volt-free change over type relay. The user may select one of seven actions, including deviation operation, with fully adjustable set point and hysteresis. The Relay may be turned off if not required to extend battery life. An option is provided to trigger a display alert event when the relay contact is on. The relay can optionally be used to indicate a low battery condition. DATA LOGGING FUNCTION DM650TM also provides a powerful data logging function. The log points can be set up to 5000 points, each point is time and date stamped together with temperature and relay state information. The log rate is selectable in steps. The start of log can be delayed if required. Either fixed or rolling logs may be performed. Two methods of reading the log are available. USB interfaced software reads the log and allows the user to save to a text file for export to other programs. The NFC android interface allows data transfer to android phones or tablets and using the downloadable App. The data can be graphed and forwarded by email, Bluetooth etc. The NFC interface is also capable of starting a new log with different log period and modes. BATTERY POWERED The instrument is powered by a single AA 3.6 V lithium battery. The battery life is dependent on the number of active features such as the relay contact and alert LED. Battery life 1-year minimum (longer depending on options selected) REAL TIME CLOCK (RTC) Date and time can also be displayed with the input temperature. The RTC is also used to time stamp the data logged points which will also give relay state. D2604-01-02 CN5553 DM650TM Data Sheet, Page 1 of 5 DM650TM SENSOR / WALL MOUNTED TEMPERATURE DISPLAY INPUT RTD (3 Wire) Type Pt100 (IEC) Ni100 Ni120 Cu53 Cu100 Thermal drift SPECIFICATIONS @20°C Range (-200 to 850) °C (-60 to 180) °C (-70 to 180) °C (-40 to 180) °C (-80 to 260) °C 0°C at 20°C Accuracy / stability ±0.2°C ±0.05% of reading (plus, sensor error) Typically, 0.01 Ω/°C Example Pt100 0.03°C/°C To maintain full accuracy annual calibration is required contact support@status.co.uk for details INPUT Thermocouple Type K J N E T Range (-150 to (-200 to (-270 to (-260 to (-270 to R S (0 to 1760) °C (0 to 1760) °C SPECIFICATIONS @20°C 1370) °C 1200) °C 1300) °C 1000) °C 400) °C Accuracy / stability ±0.1% of full scale ±0.5°C ± CJ error (plus, sensor error) ±0.2% of full scale ±0.5°C ± CJ error (plus, sensor error) ±0.1% of full scale ±0.5°C ± CJ error (plus, sensor error) over range (800 to 1760) °C L (-200 to 900) °C ±0.1% of full scale ±0.5°C U (0 to 600) °C ± CJ error B (0 to 1820) °C (plus, sensor error) C (0 to 2300) °C D (0 to 2300) °C G (0 to 2300) °C Thermal drift 0°C at 20°C Typically, ±5 uV/°C To maintain full accuracy annual calibration is required contact support@status.co.uk for details CASE SENSOR / COLD JUNCTION (CJ) Type Thermistor 10K Beta 3380 Thermal drift Range (-30 to 70) °C 0°C at 20°C SPECIFICATIONS @20°C Accuracy / stability ±0.2°C ±0.05°C/°C DISPLAY Type / options / function Display height Display information options some information is displayed scrolling. Description 7.9 mm non-backlit 6 digits 14 segment input value plus “Warning”,” Transmit”, “NFC”, “USB”, “Log”, icons, 8 segment log volume indicators. Maximum, minimum, average *1. Date and time, case temperature. Custom messages for visual alarms/information. Relay condition. High intensity LED Alarm and warning options *1 Rolling average log is independent of data logging RELAY Type/ options/ function Type Rating Description Single pole change-over (common, N/o, N/c) 48 VDC maximum @ 1 A (5 mA minimum) 28 VAC RMS maximum @ 1 A D2604-01-02 CN5553 DM650TM Data Sheet, Page 2 of 5 DM650TM SENSOR / WALL MOUNTED TEMPERATURE DISPLAY USB CONFIGURATION USER INTERFACE Type / options / function Configuration hardware Configuration software Operating system Sensor configuration Description Notes USB mini B port Cable not included USBSpeedLink Download www.status.co.uk Microsoft Windows Win 7 or later Select sensor type TC options/RTD options Trim sensor offset ± 10 °C, ± 18 °F Sensor fail High/ low Display configuration Display mode Basic or advanced Set display units °C or °F Display offset for zero (-270 to Differential from set point is displayed 5000) °C range Pre-set sensor to setpoint Locks display value For diagnostics Advanced display mode *1 Temperature and or message A, B (32 character) and or alert LED flash. Update every 5 seconds/alternates between message A and B Basic display mode Temperature Display Seven custom messages Message A and message B Pre-set display messages Eight user adjustable options temperature bands LED alert Eight user adjustable Alert LED flash temperature bands Warning symbol Out of range Warning symbol will flash on LCD Open circuit display Low battery level Battery monitor Alert LED plus message Relay option Logger Set device passkey number Device passkey is used to protect the Clear, start new log NFC interface. Other device options Synchronise clock To PC system date and time Write tag, contact address Read, reset maximum and minimum values Set device location Latitude and Longitude Relay control Name 10 characters Action High/low/band/low battery Set point °C °F Dead band °C °F Live data Read sensor temperature °C °F Read cold junction Internal case temperature Relay 1 state Off, on *1 Advanced display reverts to basic display below -5°C case temperature. USB LOGGER USER INTERFACE Type / options / function Logger hardware Logger software Operating system Logger Description USB mini B USBLogLink Microsoft Windows Start, set log parameters Read log parameters Stop, start new log Reset maximum and minimum Synchronise, read clock View log data, graph log data D2604-01-02 CN5553 DM650TM Data Sheet, Page 3 of 5 Notes Download www.status.co.uk Win 7 or later Interval, rate, (delay) start, number of points, rolling or fixed log Save data to CSV file DM650TM SENSOR / WALL MOUNTED TEMPERATURE DISPLAY NFC LOGGER USER INTERFACE ANDROID Type / options / function Logger software Operating system Logger NFC ENABLED ANDROID DEVICE REQUIRED Description NFCLogLink Android V4.4 Kitkat or later Start, set log parameters Read log parameters Stop, start new log Synchronise, read clock Reset maximum and minimum View log data, graph log data Transfer data via email etc. Notes @ Google Play Store NFC enabled Interval, rate, (delay) start, number of points, rolling or fixed log Save data to text file Standard Android functions GENERAL Function Update rate Relay response time Battery Battery life Clock accuracy Description 5 seconds < 10 seconds 1 x (AA 3.6 V lithium) 1-year minimum (longer depending on options selected) ±2 seconds per month typically ENVIRONMENTAL Function Ambient temperature Ambient humidity Protection USB configuration ambient Description Operating/storage (-30 to 70) °C Operating/storage (10 to 90) %RH non-condensing IP67, cable/probe entries must be sealed to IP67 to maintain (10 to 30) °C CONNECTIONS Function Input sensor Output relays USB connection Description Two-part screw connector 2 x Two-part screw connectors USB mini B socket MECHANICAL Function Enclosure Display cover Case entries Front of display diameter Weight (approximate) Description ABS, grey base, grey clamp ring Polycarbonate, clear Base and side entry options see ORDER CODES below 65 mm 170 g APPROVALS EMC Ingress protection RoHS BS EN 61326: Note - Sensor input wires to be less than 3 m to comply BS EN 60529 Directive 2011/65/EU D2604-01-02 CN5553 DM650TM Data Sheet, Page 4 of 5 DM650TM SENSOR / WALL MOUNTED TEMPERATURE DISPLAY DM650TM ORDER CODE Case type Entry options Wall mount 2 x side entry B 0 00 Sensor mount 1 x base entry 1 x side entry C 0 option option 00 2420 = 1 x M24 side with 1 x M20 side entries 2020 = 2 x M20 side entries (for flying lead probe) NTNT = 2 x ½ “NPT side entries 2420 = M24 base, M20 side entry 2024 = M20 base, M24 side entry (lollypop style) NTNT = ½ “NPT base and side entry Example 2 x side entry M20 with M20 B DM650TM 0 00 20 20 For further options please contact sales@status.co.uk 2 x side entry 1 x base entry with 1 x side entry ACCESSORIES USB configuration software USB logging software NFC logging software USB programming lead Battery AA 3.6 V lithium Calibration certificates Probe options USBSpeedLink free of charge from www.status.co.uk USBLogLink free of charge from www.status.co.uk NFCLogLink free of charge refer to Google Play Store USB programming lead part number 42-200-0001-01 Refer to sales@status.co.uk Refer to sales@status.co.uk Refer to www.status.co.uk To maintain full accuracy annual calibration is required contact support@status.co.uk for details The data in this document is subject to change. Status Instruments assumes no responsibility for errors Status Instruments Ltd Status Business Park Gannaway Lane, Tewkesbury Gloucestershire, UK GL20 8FD Tel: +44 (0)1684 296818 Fax: +44 (0)1684 293746 Email: sales@status.co.uk Website: www.status.co.uk D2604-01-02 CN5553 DM650TM Data Sheet, Page 5 of 5
DM650/TM/C 价格&库存
很抱歉,暂时无法提供与“DM650/TM/C”相匹配的价格&库存,您可以联系我们找货
