DM650PMBD001620
DM650PMBD001620
    STATUS
    STATUS - DM650PMBD001620 - BATT POWERED PRESSURE DISPLAY 0/30 BAR
DM650PMBD001620 数据手册
DM650PM FIELD/WALL MOUNTED PRESSURE DISPLAY UP TO 100 BAR PRESSURE / TEMPERATURE DISPLAY WITH SCALING / LINEARISATION BATTERY POWERED ALARM RELAY, MAX / MIN INFORMATION USER SET DISPLAY MESSAGING 5000 POINT DATA LOGGER WITH USB AND NFC INTERFACE INTRODUCTION The DM650PM battery powered indicator accepts gauge pressure inputs up to 100 bar and displays the sensor pressure in BAR, PSI or the user’s engineering unit on a 6digit LCD display. The instrument offers an advanced display mode allowing the user to also display one or two (1 to 32) character messages. Additional to the messages, the user may select an alert event to occur when the pressure is within a band. A change-over relay can be used together with the messaging and alerts to provide switching at user-set points. In addition to this, on board datalogging is also available to record process details at up to 5000 points. Force calculations (Ram force for example) can also be performed and displayed. FEATURE HIGHLIGHTS RELAY The instrument is equipped with single volt-free change-over type relay. The user may select one of several actions, including deviation operation, with fully adjustable set point and dead-band. An option is provided to trigger an alert event when a relay contact is on. DATA LOGGING FUNCTION DM650PM also provides a powerful data logging function. The log points can be set up to 5000 points, each point is time and date stamped together with process value, and relay state information. The log rate is selectable in steps. The start of log can be delayed if required. Either fixed or rolling logs may be performed. Two methods of reading the log are available. The USB configuration reads the log and allows the user to save to a text file for export to other programs. The NFC android interface allows data transfer to android phones or tablets, and using the downloadable App, the data can be graphed and forwarded by email, Bluetooth etc. The NFC interface is also capable of starting a new log with different log period and modes. CALIBRATION / USER LINEARIZATION 5-point calibration can be applied using the USBSpeedLink software. As well as straight line interpolation, up to 22 points (x,y) of user linearization are available for creating custom curves and corrections. REAL TIME CLOCK Date and time can also be displayed with the input pressure. The real-time clock is used to record the data logged points. D2611-01-01 DM650PM Data sheet, Page 1 of 5 DM650PM FIELD/WALL MOUNTED PRESSURE DISPLAY INPUT PRESSURE Type Sealed gauge *1 SPECIFICATIONS @20°C Range Accuracy/stability (0 to 3) bar ±0.5% of full scale between (0 to 50) °C *2 (0 to 30) bar ±0.7% of full scale between (-10 to 80) °C *2 (0 to 100) bar Other ranges Contact sales@status.co.uk Overpressure 4 x pressure range Up to maximum 350 Bar Thermal drift (-10 to 80) °C compensated *1 Shows zero bar at 1.0 bar absolute *2 Total error band: Maximum deviation within specified pressure and operating temperature range To maintain full accuracy annual calibration is required contact support@status.co.uk for details INPUT Temperature Type SPECIFICATIONS @20°C Range (-40 to 110)°C Accuracy/stability Typically, ±2.0°C DISPLAY Type / options / function Display height Display information options Some information is displayed scrolling. High intensity LED Description 7.9 mm non-backlit 6 digits 14 segment input value plus “Warning”,” Transmit”, “NFC”, “USB”, “Log”, icons, 8 segment log volume indicators. Maximum, minimum. Date and time. Custom messages for visual alarms/information. Relay condition. Alarm and warning options RELAY Type/ options/ function Independent relay Rating Description Single pole change-over (common, N/o, N/c) 48 VDC maximum @ 1 A (5 mA minimum) 28 VAC RMS maximum @ 1 A USB CONFIGURATION USER INTERFACE Type / options / function Configuration hardware Configuration software Operating system Sensor configuration Display configuration Description USB Mini B port USBSpeedLink Microsoft Windows User calibration Off-set in Bar Display mode Pressure units Pre-set sensor to setpoint LED alert (advanced mode) Warning symbol D2611-01-01 DM650PM Data sheet, Page 2 of 5 Custom units Locks input value to setpoint Eight user adjustable pressure bands Out of range Low battery level Notes Cable not included Download www.status.co.uk Win 7 or later Up to 5 points Applied by button action Basic with advanced options °C or °F Bar, PS I, mBar, Pa, KPa, MPa Kgf/m², Kgf/cm², Kgf/mm² Atm, custom units (any) With 22-point linearization For diagnostics Alert LED flash Warning symbol will flash on LCD display DM650PM FIELD/WALL MOUNTED PRESSURE DISPLAY Basic display mode Update rate Display variable options 1 s, 5 s Input, input + units, input + units + temperature °C or °F Temperature units Alert LED Advanced display mode *1 Display variable (see basic mode) with messaging options Battery monitor Alert LED plus message Relay option link in software Logger Set device passkey number Device passkey is used to protect the Clear, start new log NFC interface. Other device options Synchronise clock Write tag, contact address Read, reset maximum and minimum input values Latitude longitude settings Relay control Name(s) 10 characters Action High, low, band, low battery, on, off Setpoint In engineering units Dead band In engineering units Latch On, off Live data Read sensor pressure bar Read displayed value Selected engineering unit Read sensor temperature °C Relay 1 state. Relay 2 state Time and date *1 Only use advanced display above -5°C ambient temperature, below use basic display USB LOGGER USER INTERFACE Type / options / function Logger hardware Logger software Operating system Logger NFC LOGGER USER INTERFACE ANDROID Type / options / function Logger software Operating system Logger D2611-01-01 DM650PM Data sheet, Page 3 of 5 Description USB Mini B port USBLogLink Microsoft Windows Start/set log parameters Read log parameters Stop, start new log Synchronise device clock Reset maximum and minimum Synchronise, read clock View log data, graph log data Notes Cable not included Download www.status.co.uk Win 7 or later Interval, rate, (delay) start, number of points, rolling or fixed log Description NFCLogLink Android V4.4 Kitkat or later Start, set log parameters Read log parameters Stop, start new log Synchronise, read clock Reset maximum and minimum View log data, graph log data Transfer data via email etc. Notes @ Google Play Store NFC enabled Interval, rate, (delay) start, number of points, rolling or fixed log Save data to CSV file Save data to text file Standard Android functions DM650PM FIELD/WALL MOUNTED PRESSURE DISPLAY GENERAL Function Update rate Relay response time Battery Battery life Clock accuracy Description 1 or 5 seconds < 10 seconds 1 x (AA 3.6 V lithium) 1 year minimum @20°C (longer depending on options selected) ±2 seconds per month typically ENVIRONMENTAL Function Ambient housing temperature Ambient sensor temperature Ambient humidity Protection USB configuration ambient Description Operating/storage (-30 to 70)°C Operating (-40 to 110)°C Operating/storage (10 to 90) %RH non-condensing IP67, cable entry must be sealed to IP67 (10 to 30)°C CONNECTIONS Sensor to process Output relay USB connection ¼ inch BSP male with adaptor options (see accessories) Two-part screw connectors USB mini B port MECHANICAL Enclosure (case) Display cover Case entry Front bezel diameter Weight (approximate) Material in contact with media O-ring ABS, grey base, grey clamp ring, side or base mount options Polycarbonate, clear 1 x M20 female thread, blanking plug supplied 65 mm 250 g Stainless steel 316L Viton APPROVALS EMC Ingress protection RoHS BS EN 61326 BS EN 60529 Directive 2011/65/EU D2611-01-01 DM650PM NAME Data sheet, Page 4 of 5 DM650PM FIELD/WALL MOUNTED PRESSURE DISPLAY DM650PM ORDER CODE Case Style Input range Base entry Side entry 1 Side entry 2 Options Side mounted sensor can be wall mounted Base mounted sensor /B /option /00 /16 /option /C /option /16 /option /00 Entry options 20 = M20 NPT = ½ inch NPT Input range options in bar C = (0 to 3), D = (0 to 30) G = (0 to 100) Example (0 to 30) bar side mounted sensor M20 entry DM650PM /B /D /00 Style B /16 /20 Style C ACCESSORIES Swivel adaptor ¼ BSPP Swivel adaptor ½ BSPP Swivel adaptor ¼ NPT Swivel adaptor ½ NPT Swivel adaptor other options available Hygienic fittings available Configuration software USB logging software NFC logging software USB lead Battery 3.6 V lithium SA14BSP SA12BSP SA14NPT SA12NPT sales@status.co.uk sales@status.co.uk USBSpeedLink free of charge from www.status.co.uk USBLogLink free of charge from www.status.co.uk NFCLogLink free of charge refer to Google Play Store USB lead part number 42-200-0001-01 Contact sales@status.co.uk To maintain full accuracy annual calibration is required contact support@status.co.uk for details The data in this document is subject to change. Status Instruments assumes no responsibility for errors Status Instruments Ltd Status Business Park Gannaway Lane, Tewkesbury Gloucestershire, UK GL20 8FD Tel: +44 (0)1684 296818 Fax: +44 (0)1684 293746 Email: sales@status.co.uk Website: www.status.co.uk D2611-01-01 DM650PM NAME Data sheet, Page 5 of 5
DM650PMBD001620 价格&库存
很抱歉,暂时无法提供与“DM650PMBD001620”相匹配的价格&库存,您可以联系我们找货
