DP201A-2123HST.GN
DP201A-2123HST.GN
    SUNON
    DP201A-2123HST.GN
DP201A-2123HST.GN 数据手册
AC Axial Fan & Blower *All products are RoHS compliant. www.sunon.com Table of Contents SUNON AC Axial Fan & Blower Page Engineering Information Fan Model Numbering System p.01 p.02 Air Flow (CFM) 17.5 ~ 18 28 ~ 29 40 ~ 41 17 ~ 22 23 ~ 31 52 ~ 54 21 ~ 37 46 ~ 80 46 ~ 80 70 ~ 117 70 ~ 117 85 ~ 100 95 ~ 117 112 ~ 124 95 ~ 115 49 ~ 50 180 ~ 200 203 ~ 239 203 ~ 239 315 ~ 335 425 ~ 870 20 ~ 22 AC Fan Series 60x60x25mm (MagLev Motor AC Fan) 70x70x25mm (MagLev Motor AC Fan) 80x80x25 mm (MagLev Motor AC Fan) 80x80x25mm 80x80x38mm 92x92x25mm (MagLev Motor AC Fan) 92x92x25mm 120x120x25mm (115V) 120x120x25mm (220-240V) 120x120x38mm (115V) 120x120x38mm (220-240V) 120x120x38mm (Plastic Frame) 120x120x38mm (New Type) 120x120x38mm (New Type-High Air Flow) 120x120x38mm (Dual AC Voltage) 120x120x38mm (Low Power Consumption) 171x151x51mm 171x151x51mm ( Alveolate Motor) ø171x51mm ( Alveolate Motor) 176x176x89mm ( Alveolate Motor) ø254x89mm ( Alveolate Motor) 120x120x31mm (Blower) p.03 p.04 p.05 p.06 p.07 p.08 p.09 p.10 p.11 p.12 p.13 p.14 p.15 p.16 p.17 p.18 p.19 p.20 p.21 p.22 p.23 p.24 Certification 01 0 T ISO9 ISO/ 16 N N N N S 949 :2000 * Note: For critical or extreme environments, including non stop operation, please contact SUNON and we will gladly provide assistance with your product selection to ensure an appropriate cooling product for your application. * Note: The “Life Expectancy” of the fan has not been evaluated for use in combination with any end application. Therefore, the Life Expectancy Test Reports(L10 and MTTF Report) that relate to the fan are only for reference. ENGINEERING INFORMATION Alveolate Motor AC fan series with automatic motor-wire wrapping technology ensures stable performance of high wind volume, low acoustic noise, also available with functions of dual spinning rate, and thermal cutout. SUNON-Alveolate Motor VS. Traditional Shaded-pole Motor SUNON-Alveolate Motor Traditional Shaded-Pole Motor 1.The Traditional Shaded-Pole Motor, designed 1.The Alvolate Motor is equipped with starting stator coils and working ones. The starting coils with single-wire wrapping, is started by “the form a low starting voltage with the capacitors. starting copper”and cannot be started with For example, an 115VAC (the fixed voltage) low voltage. An 115VAC Traditional Shaded- Alveolate Motor can be started with 60 VAC. Pole motor will need more than 80VAC to run, 20VAC more than the Alveolate one. 2.The Traditional Shaded-Pole Motor consumes 2.The coils do not produce high temperature and consumes less electricity. The temperature is electricity twice as much as the Alveolate normally around 50℃. Therefore, the motor is Motor. It is not reliable because the always stable and reliable. temperature is usually higher than 70℃. 3.The Thermal Cutout can protect the motor. 3.The Thermal Cutout is an option. 4.The motor has a large torsion to produce high 4.General wind pressure and wind volume. wind pressure and wind volume. 5.The motor is equipped with the third wire, ready 5.Without the third wire. to comply with the customer’s systems. 01 AC Fan Model Numbering System General AC Fan Ex) SF11580AT 1 08 2 H B L .GN MODEL SERIES SFxxx SPxxx DPxxx RoHS Compliance TERMINALS T : Terminal L : Lead wire VOLTAGE 1 : 115 VAC 2 : 220 -240 VAC BEARING SYSTEM B : Ball S : Sleeve FRAME SIZE 08 : 80 mm 09 : 92 mm 12 : 120 mm SPEED X : Super H : High M : Middle L : Low FRAME THICKNESS 2 : 25 mm 3 : 38 mm New Type AC Fan Ex) A 1 17 5 H B T MODEL SERIES A : New AC fan series AB : New AC blower series MA : MagLev AC Fan series TERMINALS T : Terminal L : Lead wire VOLTAGE 1 : 115 VAC 3 : 380 VAC 2 : 220-240 VAC FRAME SIZE 08 : 80 mm 09 : 92 mm 12 : 120 mm BEARING SYSTEM V: MagLev S : Sleeve B : Ball 17 : 172 mm 25 : 254 mm SPEED X : Super H : High M : Middle L : Low FRAME THICKNESS 2 : 25 mm 7 : 72 mm 3 : 31~38mm 9 : 89~90mm 5 : 50~51 mm P/N P/N Suffixes have the following significance : T : Thermal Cutout TC : Alveolate Motor with Thermal Cutout and Capacitor TC.R : Round Frame , Alveolate Motor with Thermal Cutout and Capacitor N : New frame GN : RoHS compliance * Alveolate Motor only available in P/N : TC model 02 60x60x25 mm MagLev Motor AC Fan 17.5~18 CFM Specifications Bearing P/N Rating Voltage Freq. Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VAC) (Hz) (AMP) (WATTS) (RPM) (CFM) (Inch-H 2O) (dB(A)) (g) VAPO BALL Sleeve MA1062-HVL GN 115 50/60 0.191/0.185 3.6/3.6 4100/4200 17.5/18 0.19/0.20 30/31 81 MA2062-HVL GN 220-240 50/60 0.198/0.211 4.1/4.4 4100/4200 17.5/18 0.19/0.20 30/31 81 Safety : UL-CUL/TUV/CE/CCC Frame : PBT Plastic Air Flow-Static Pressure Characteristics Vapo (50Hz) Vapo (60Hz) Static Pressure (Inch-H2O) 0.2 0.2 0.18 0.18 0.16 0.16 0.14 0.14 0.12 0.12 0.1 0.1 0.08 0.08 0.06 0.06 0.04 0.04 0.02 0.02 0 0 5 10 15 20 5 10 15 20 Airflow (CFM) External dimensions(mm) 8-ø ROTATION 4.3 AIR FLOW OUTLET INLET ±0 .3 .6 5 ø6 3.5 ø6 50±0.3 60±0.5 5±0.3 300±30 #24AWG 25± 0.5 0 *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON website at http://www.sunon.com for update information. 03 70x70x25 mm MagLev Motor AC Fan 28~29 CFM Specifications Bearing P/N Rating Voltage Freq. Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VAC) (Hz) (AMP) (WATTS) (RPM) (CFM) (Inch-H 2O) (dB(A)) (g) VAPO BALL Sleeve MA1072-HVL GN 115 50/60 0.208/0.197 3.7/3.7 3800/3900 28/29 0.17/0.18 30/31 90 MA2072-HVL GN 220-240 50/60 0.207/0.220 4.3/4.4 3800/3900 28/29 0.17/0.18 30/31 90 Safety : UL-CUL/TUV/CE/CCC Frame : PBT Plastic Air Flow-Static Pressure Characteristics Static Pressure (Inch-H2O) 0.18 Vapo (50Hz) Vapo (60Hz) 0.18 HVL HVL 0.15 0.15 0.12 0.12 0.09 0.09 0.06 0.06 0.03 0.03 0 6 12 18 24 30 0 6 12 18 24 30 Airflow (CFM) External dimensions(mm) 8- ROTATION ø4 .3 #24AWG AIR FLOW ±0 OUTLET INLET .3 9 0.3 ø8 5±0.3 300±10 ø7 60±0.3 70±0.5 25± 0.5 0 *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON website at http://www.sunon.com for update information. 04 80x80x25 mm MagLev Motor AC Fan 40~41 CFM Specifications Bearing P/N VAPO BALL Sleeve Rating Voltage Freq. Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VAC) (Hz) (AMP) (WATTS) (RPM) (CFM) (Inch-H 2O) (dB(A)) (g) MA1082-HVL GN 115 50/60 0.22/0.21 3.6/3.6 3200/3300 40/41 0.14/0.15 32/33 102.2 MA2082-HVL GN 220-240 50/60 0.215/0.225 4.6/4.6 3200/3300 40/41 0.14/0.15 32/33 102.2 Safety : UL-CUL/TUV/CE/CCC Frame : PBT Plastic Air Flow-Static Pressure Characteristics Vapo (50Hz) 0.16 0.16 Vapo (60Hz) Static Pressure (Inch-H2O) HVL HVL 0.14 0.14 0.12 0.12 0.1 0.1 0.08 0.08 0.06 0.06 0.04 0.04 0.02 0.02 0 7 14 21 28 35 42 0 7 14 21 28 35 42 Airflow (CFM) External dimensions(mm) #24AWG 8- ø4 ROTATION .3 ±0 INLET AIR FLOW OUTLET .3 7.2 1.8 ø9 5±0.3 300±10 ø8 71.5±0.3 80±0.5 25±0.5 0 *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON website at http://www.sunon.com for update information. 05 80x80x25 mm 17~22 CFM Specifications Bearing Model P/N VAPO BALL Sleeve Rating Voltage Freq. Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VAC) (Hz) (AMP) (WATTS) (RPM) (CFM) (Inch-H 2O) (dB(A)) (g) SF11580AT 1082HSL.GN 115 50/60 0.12/0.10 12/11 2300/2750 17/21 0.12/0.18 29/33 260 SF11580AT 1082HBL.GN 115 50/60 0.12/0.10 12/11 2450/2900 18/22 0.13/0.19 30/34.5 260 SF23080AT 2082HSL.GN 220-240 50/60 0.07/0.07 14/13.5 2300/2750 17/21 0.12/0.18 29/33 260 SF23080AT 2082HBL.GN 220-240 50/60 0.07/0.07 14/13.5 2450/2900 18/22 0.13/0.19 30/34.5 260 Frame : Aluminum alloy Safety : UL-CUL/TUV NORD/CE/CCC Air Flow-Static Pressure Characteristics Static Pressure (Inch-H2O) Ball (50Hz) Ball (60Hz) Sleeve (50Hz) Sleeve (60Hz) 0.2 0.2 0.2 0.2 0.16 0.16 0.16 0.16 0.12 0.12 0.12 0.12 0.08 0.08 0.08 0.08 0.04 0.04 0.04 0.04 6 12 18 24 0 0 0 0 6 12 18 6 24 12 18 6 24 12 18 24 Airflow (CFM) External dimensions(mm) #24AWG ROTATION AIR FLOW INLET ø7 7 ø7 6 5 330±15 GROUND LUG M4 OUTLET 3.7±0.3 71.5±0.3 8-ø4.3±0.3 25.5±0.5 80±0.5 *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON website at http://www.sunon.com for update information. 06 80x80x38 mm 23~31 CFM Specifications Bearing Model P/N Rating Voltage Freq. Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VAC) (Hz) (AMP) (WATTS) (RPM) (CFM) (Inch-H 2O) (dB(A)) (g) VAPO BALL Sleeve SF11580A 1083HSL.GN 115 50/60 0.15/0.13 14/12 2300/2750 23/30 0.12/0.18 31/35 340 SF11580A 1083HBL.GN 115 50/60 0.15/0.13 14/12 2400/2850 24/31 0.13/0.19 32/36.5 340 SF23080A 2083HSL.GN 220-240 50/60 0.09/0.08 18/16 2300/2750 23/30 0.12/0.18 31/35 340 SF23080A 2083HBL.GN 220-240 50/60 0.09/0.08 18/16 2400/2850 24/31 0.13/0.19 32/36.5 340 Frame : Aluminum alloy Safety : UL-CUL/TUV NORD/CE/CCC Air Flow-Static Pressure Characteristics Static Pressure (Inch-H2O) 0.2 Ball (50Hz) 0.2 Ball (60Hz) 0.2 Sleeve (50Hz) 0.2 0.16 0.16 0.16 0.16 0.12 0.12 0.12 0.12 0.08 0.08 0.08 0.08 0.04 0.04 0.04 0.04 4 8 12 16 20 24 28 32 0 0 0 0 4 8 12 16 20 24 28 32 Sleeve (60Hz) 4 8 12 16 20 24 28 32 4 8 12 16 20 24 28 32 Airflow (CFM) External dimensions(mm) ROTATION #24AWG AIR FLOW INLET 2 GROUND LUG M4 ø7 ø7 4.8 5 330±15 6.6 OUTLET 4±0.3 71.5±0.3 8-ø4.3±0.3 38.5±0.5 80±0.5 *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON website at http://www.sunon.com for update information. 07 92x92x25 mm MagLev Motor AC Fan 52~54 CFM Specifications Bearing P/N VAPO BALL Sleeve Rating Voltage Freq. Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VAC) (Hz) (AMP) (WATTS) (RPM) (CFM) (Inch-H 2O) (dB(A)) (g) MA1092-HVL GN 115 50/60 0.114/0.118 3.6/3.6 2900/3000 52/54 0.12/0.14 31/32 119.7 MA2092-HVL GN 220-240 50/60 0.103/0.106 4.6/4.6 2900/3000 52/54 0.12/0.14 31/32 119.7 Frame : PBT Plastic Safety : UL-CUL/TUV/CE/CCC Air Flow-Static Pressure Characteristics Static Pressure (Inch-H2O) 0.14 Vapo (50Hz) 0.14 Vapo (60Hz) HVL HVL 0.12 0.12 0.1 0.1 0.08 0.08 0.06 0.06 0.04 0.04 0.02 0.02 0 5 15 25 35 45 55 0 5 15 25 35 45 55 Airflow (CFM) External dimensions(mm) #24AWG 8- ø4 ROTATION .3 ±0 INLET AIR FLOW .3 OUTLET 1.8 .5 03 ø1 5±0.3 300±10 ø9 82.5±0.3 92±0.5 25± 0.5 0 *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON website at http://www.sunon.com for update information. 08 92x92x25 mm 21~37 CFM Specifications Rating Voltage Freq. Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VAC) (Hz) (AMP) (WATTS) (RPM) (CFM) (Inch-H 2O) (dB(A)) (g) 115 115 115 115 115 115 115 115 220-240 220-240 220-240 220-240 220-240 220-240 220-240 220-240 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 0.12/0.11 0.12/0.11 0.06/0.06 0.06/0.06 0.12/0.11 0.12/0.11 0.07/0.06 0.07/0.06 0.07/0.06 0.07/0.06 0.07/0.07 0.07/0.07 0.07/0.06 0.07/0.06 0.07/0.07 0.07/0.07 13/12 13/12 7/6 7/6 13/12 13/12 7/6 7/6 14.5/14 14.5/14 15/14 15/14 14.5/14 14.5/14 15/14 15/14 2250/2750 2250/2750 1550/1700 1550/1700 2350/2850 2350/2850 1800/2100 1800/2100 2250/2750 2250/2750 2000/2500 2000/2500 2350/2850 2350/2850 2200/2700 2200/2700 29/36 29/36 21/26 21/26 30/37 30/37 23/28 23/28 29/36 29/36 27/33 27/33 30/37 30/37 28/35 28/35 0.12/0.18 0.12/0.18 0.08/0.09 0.08/0.09 0.13/0.19 0.13/0.19 0.10/0.11 0.10/0.11 0.12/0.18 0.12/0.18 0.11/0.16 0.11/0.16 0.13/0.19 0.13/0.19 0.12/0.18 0.12/0.18 36/39 36/39 28/30 28/30 37/40 37/40 31/33 31/33 36/39 36/39 32/37 32/37 37/40 37/40 35/38 35/38 280 280 280 280 280 280 280 280 280 280 280 280 280 280 280 280 Bearing Model P/N VAPO BALL Sleeve 1092HSL.GN 1092HST.GN 1092MSL.GN 1092MST.GN 1092HBL.GN 1092HBT.GN 1092MBL.GN 1092MBT.GN 2092HSL.GN 2092HST.GN 2092MSL.GN 2092MST.GN 2092HBL.GN 2092HBT.GN 2092MBL.GN 2092MBT.GN SF11592A SF11592A SF11592A SF11592A SF11592A SF11592A SF11592A SF11592A SF23092A SF23092A SF23092A SF23092A SF23092A SF23092A SF23092A SF23092A Safety : UL-CUL/TUV NORD/CE/CCC Frame : Aluminum alloy Air Flow-Static Pressure Characteristics Ball (50Hz) Ball (60Hz) Static Pressure (Inch-H2O) 0.2 0.18 0.16 Sleeve (50Hz) 0.2 HBL/HBT MBL/MBT(220V) MBL/MBT(110V) 0.2 HBL/HBT MBL/MBT(220V) MBL/MBT(110V) 0.18 0.16 HSL/HST MSL/MST(220V) MSL/MST(110V) 0.18 0.16 0.2 0.16 0.14 0.14 0.14 0.12 0.12 0.12 0.12 0.1 0.1 0.1 0.1 0.08 0.08 0.08 0.08 0.06 0.06 0.06 0.06 0.04 0.04 0.04 0.04 0.02 0.02 0.02 0.02 0 5 10 15 20 25 30 35 40 0 0 5 10 15 20 25 30 35 40 HSL/HST MSL/MST(220V) MSL/MST(110V) 0.18 0.14 0 Sleeve (60Hz) 5 10 15 20 25 30 35 40 5 10 15 20 25 30 35 40 Airflow (CFM) External dimensions(mm) #24AWG ROTATION INLET AIR FLOW OUTLET 8-ø4.3±0.3 ø8 9 ø8 7 5 310±15 TERMINAL TYPE 7.5 (THICK 0.5) 3.5±0.3 GROUND LUG M4 82.5±0.3 25.5±0.5 91.5±0.5 *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON website at http://www.sunon.com for update information. 09 120x120x25 mm 46~80 CFM Specifications Bearing Model P/N Rating Voltage Freq. Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VAC) (Hz) (AMP) (WATTS) (RPM) (CFM) (Inch-H 2O) (dB(A)) (g) VAPO BALL Sleeve SP101AT 1122HSL.GN 115 50/60 0.21/0.19 19/18 2000/2300 64/78 0.13/0.16 43/46 330 SP101AT 1122HST.GN 115 50/60 0.21/0.19 19/18 2000/2300 64/78 0.13/0.16 43/46 330 SP103AT 1122LSL.GN 115 50/60 0.14/0.13 14/13 1600/1800 46/53 0.11/0.12 35/38 330 SP103AT 1122LST.GN 115 50/60 0.14/0.13 14/13 1600/1800 46/53 0.11/0.12 35/38 330 SP101AT 1122HBL.GN 115 50/60 0.21/0.19 19/18 2150/2500 66/80 0.14/0.17 44/48 330 SP101AT 1122HBT.GN 115 50/60 0.21/0.19 19/18 2150/2500 66/80 0.14/0.17 44/48 330 SP103AT 1122LBL.GN 115 50/60 0.12/0.11 12.5/11.5 1700/1900 47/54 0.12/0.13 37/40 330 SP103AT 1122LBT.GN 115 50/60 0.12/0.11 12.5/11.5 1700/1900 47/54 0.12/0.13 37/40 330 Safety : UL-CUL/TUV/CE/CCC Frame : Aluminum alloy Air Flow-Static Pressure Characteristics Static Pressure (Inch-H2O) Ball (50Hz) Ball (60Hz) Sleeve (50Hz) Sleeve (60Hz) 0.18 0.18 0.18 0.18 0.16 0.16 0.16 0.14 0.14 0.14 0.14 0.12 0.12 0.12 0.12 0.1 0.1 0.1 0.1 0.08 0.08 0.08 0.08 HSL/HST 0.06 0.06 0.06 0.06 0.04 0.04 0.04 0.04 0.02 0.02 0.02 0.02 0 0 0 14 28 42 56 70 84 14 28 42 56 70 84 HSL/HST 0.16 LSL/LST LSL/LST 0 14 28 42 56 70 84 14 28 42 56 70 84 Airflow (CFM) External dimensions(mm) #24AWG INLET AIR FLOW ø1 15 ø1 15 .5 5 320±10 TERMINAL TYPE 7.5 (THICK 0.5) OUTLET GROUND LUG M4 8-ø4.3±0.3 104.8±0.3 3.5±0.3 25.5±0.5 119±0.5 *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON website at http://www.sunon.com for update information. 10 120x120x25 mm 46~80 CFM Specifications Bearing Model P/N Rating Voltage Freq. Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VAC) (Hz) (AMP) (WATTS) (RPM) (CFM) (Inch-H 2O) (dB(A)) (g) VAPO BALL Sleeve DP201AT 2122HSL.GN 220/240 50/60 0.09/0.09 19/19 2000/2300 64/78 0.13/0.16 43/46 295 DP201AT 2122HST.GN 220/240 50/60 0.09/0.09 19/19 2000/2300 64/78 0.13/0.16 43/46 295 DP203AT 2122LSL.GN 220/240 50/60 0.07/0.07 14/13 1600/1800 46/53 0.11/0.12 35/38 330 DP203AT 2122LST.GN 220/240 50/60 0.07/0.07 14/13 1600/1800 46/53 0.11/0.12 35/38 330 DP201AT 2122HBL.GN 220/240 50/60 0.09/0.09 19/19 2150/2500 66/80 0.14/0.17 44/48 295 DP201AT 2122HBT.GN 220/240 50/60 0.09/0.09 19/19 2150/2500 66/80 0.14/0.17 44/48 295 DP203AT 2122LBL.GN 220/240 50/60 0.07/0.07 14/13 1700/1900 47/54 0.12/0.13 37/40 330 DP203AT 2122LBT.GN 220/240 50/60 0.07/0.07 14/13 1700/1900 47/54 0.12/0.13 37/40 330 Safety : UL-CUL/TUV/CE/CCC Frame : Aluminum alloy Air Flow-Static Pressure Characteristics Ball (50Hz) Ball (60Hz) 0.18 Sleeve (50Hz) 0.18 Sleeve (60Hz) 0.18 0.18 Static Pressure (Inch-H2O) HSL/HST HSL/HST 0.16 0.16 0.16 0.14 0.14 0.14 0.16 0.14 0.12 0.12 0.12 0.12 0.1 0.1 0.1 0.1 0.08 0.08 0.08 0.08 LSL/LST 0.06 0.06 0.06 0.06 0.04 0.04 0.04 0.04 0.02 0.02 0.02 0.02 0 0 0 14 28 42 56 70 84 14 28 42 56 70 84 LSL/LST 0 14 28 42 56 70 84 14 28 42 56 70 84 Airflow (CFM) External dimensions(mm) #24AWG INLET AIR FLOW ø1 15 .5 5 320±10 ø1 15 OUTLET GROUND LUG M4 8-ø4.3±0.3 104.8±0.3 3.5±0.3 25.5±0.5 119±0.5 *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON website at http://www.sunon.com for update information. 11 120x120x38 mm 70~117 CFM Specifications Bearing Model P/N Rating Voltage Freq. Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VAC) (Hz) (AMP) (WATTS) (RPM) (CFM) (Inch-H 2O) (dB(A)) (g) 115 115 115 115 115 115 115 115 115 115 115 115 115 115 115 115 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 0.26/0.24 0.26/0.24 0.21/0.18 0.21/0.18 0.17/0.16 0.17/0.16 0.13/0.11 0.13/0.11 0.26/0.24 0.26/0.24 0.21/0.18 0.21/0.18 0.17/0.16 0.17/0.16 0.13/0.11 0.13/0.11 22/20 22/20 20/18 20/18 15/15 15/15 11/11 11/11 22/20 22/20 20/18 20/18 16/15 16/15 11/11 11/11 2700/3100 2700/3100 2550/2900 2550/2900 2400/2600 2400/2600 2200/2000 2200/2000 2850/3150 2850/3150 2750/3050 2750/3050 2500/2700 2500/2700 2150/2300 2150/2300 95/115 95/115 85/105 85/105 78/84 78/84 76/70 76/70 97/117 97/117 87/107 87/107 80/88 80/88 72/78 72/78 0.33/0.38 0.33/0.38 0.25/0.30 0.25/0.30 0.14/0.21 0.14/0.21 0.12/0.08 0.12/0.08 0.34/0.39 0.34/0.39 0.26/0.32 0.26/0.32 0.15/0.22 0.15/0.22 0.09/0.13 0.09/0.13 44/49 44/49 43/48 43/48 33/38 33/38 38/36 38/36 45/50 45/50 45/50 45/50 35/40 35/40 37/39 37/39 550 550 550 550 550 550 550 550 550 550 550 550 550 550 550 550 VAPO BALL Sleeve 1123XSL.GN 1123XST.GN 1123HSL.GN 1123HST.GN 1123MSL.GN 1123MST.GN 1123LSL.GN 1123LST.GN 1123XBL.GN 1123XBT.GN 1123HBL.GN 1123HBT.GN 1123MBL.GN 1123MBT.GN 1123LBL.GN 1123LBT.GN SP100A SP100A SP101A SP101A SP102A SP102A SP103A SP103A SP100A SP100A SP101A SP101A SP102A SP102A SP103A SP103A Safety : UL-CUL/TUV/CE/CCC Frame : Aluminum alloy Air Flow-Static Pressure Characteristics Ball (50Hz) Ball (60Hz) Static Pressure (Inch-H2O) 0.4 XBL/XBT HBL/HBT MBL/MBT LBL/LBT 0.35 0.4 0.4 XBL/XBT HBL/HBT MBL/MBT LBL/LBT 0.35 Sleeve (50Hz) Sleeve (60Hz) XSL/XST HSL/HST MSL/MST LSL/LST 0.35 0.4 0.3 0.3 0.3 0.3 0.25 0.25 0.25 0.25 0.2 0.2 0.2 0.2 0.15 0.15 0.15 0.15 0.1 0.1 0.1 0.1 0.05 0.05 0.05 0.05 0 0 0 15 30 45 60 75 90 105 120 15 30 45 60 75 90 105 120 XSL/XST HSL/HST MSL/MST LSL/LST 0.35 0 15 30 45 60 75 90 105 120 15 30 45 60 75 90 105 120 Airflow (CFM) External dimensions(mm) ROTATION #24AWG AIR FLOW INLET TERMINAL TYPE 7.5 (THICK 0.5) ø1 15 ø1 16 5 310±15 .5 OUTLET 104.8±0.3 8-ø4.3±0.3 4±0.3 119±0.5 38.5±0.5 *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON website at http://www.sunon.com for update information. 12 120x120x38 mm 70~117 CFM Specifications Rating Voltage Freq. Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VAC) (Hz) (AMP) (WATTS) (RPM) (CFM) (Inch-H 2O) (dB(A)) (g) 220-240 220-240 220-240 220-240 220-240 220-240 220-240 220-240 220-240 220-240 220-240 220-240 220-240 220-240 220-240 220-240 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 0.14/0.12 0.14/0.12 0.125/0.11 0.125/0.11 0.09/0.08 0.09/0.08 0.06/0.05 0.06/0.05 0.14/0.12 0.14/0.12 0.125/0.11 0.125/0.11 0.09/0.08 0.09/0.08 0.05/0.06 0.05/0.06 22/21 22/21 20/19 20/19 16/15 16/15 11/10 11/10 22/21 22/21 20/19 20/19 16/15 16/15 10/10 10/10 2700/3100 2700/3100 2550/2900 2550/2900 2300/2500 2300/2500 2000/1800 2000/1800 2850/3150 2850/3150 2750/3050 2750/3050 2400/2600 2400/2600 2300/2150 2300/2150 95/115 95/115 85/105 85/105 78/84 78/84 70/63 70/63 97/117 97/117 87/107 87/107 78/84 78/84 78/72 78/72 0.33/0.38 0.33/0.38 0.25/0.30 0.25/0.30 0.14/0.21 0.14/0.21 0.08/0.07 0.08/0.07 0.34/0.39 0.34/0.39 0.26/0.32 0.26/0.32 0.14/0.21 0.14/0.21 0.13/0.09 0.13/0.09 44/49 44/49 43/48 43/48 33/38 33/38 36/32 36/32 45/50 45/50 45/50 45/50 34/39 34/39 39/37 39/37 550 550 550 550 550 550 550 550 550 550 550 550 550 550 550 550 Bearing Model P/N VAPO BALL Sleeve 2123XSL.GN 2123XST.GN 2123HSL.GN 2123HST.GN 2123MSL.GN 2123MST.GN 2123LSL.GN 2123LST.GN 2123XBL.GN 2123XBT.GN 2123HBL.GN 2123HBT.GN 2123MBL.GN 2123MBT.GN 2123LBL.GN 2123LBT.GN DP200A DP200A DP201A DP201A DP202A DP202A DP203A DP203A DP200A DP200A DP201A DP201A DP202A DP202A DP203A DP203A Safety : UL-CUL/TUV/CE/CCC Frame : Aluminum alloy Air Flow-Static Pressure Characteristics Static Pressure (Inch-H2O) Ball (50Hz) Ball (60Hz) Sleeve (50Hz) Sleeve (60Hz) 0.4 0.4 0.4 0.4 0.35 0.35 0.35 0.35 0.3 0.3 0.3 0.3 0.25 0.25 0.25 0.25 0.2 0.2 0.2 0.2 0.15 0.15 0.15 0.15 0.1 0.1 0.1 0.1 0.05 0.05 0.05 0.05 0 0 0 15 30 45 60 75 90 105 120 15 30 45 60 75 90 105 120 0 15 30 45 60 75 90 105 120 15 30 45 60 75 90 105 120 Airflow (CFM) External dimensions(mm) AIR FLOW INLET #24AWG 310±15 ø1 15 ø1 16 5 .5 OUTLET 104.8±0.3 8-ø4.3±0.3 4±0.3 119±0.5 38.5±0.5 *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON website at http://www.sunon.com for update information. 13 120x120x38 mm 85~100 CFM Specifications Bearing Model P/N Rating Voltage Freq. Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VAC) (Hz) (AMP) (WATTS) (RPM) (CFM) (Inch-H 2O) (dB(A)) (g) VAPO BALL Sleeve SP109WR 1123HST.GN 115 50/60 0.25/0.22 22/20 2500/2900 85/100 0.28/0.35 41/47 465 SP109WR 1123HSL.GN 115 50/60 0.25/0.22 22/20 2500/2900 85/100 0.28/0.35 41/47 465 SP109WR 1123HBT.GN 115 50/60 0.25/0.22 22/20 2500/2900 85/100 0.25/0.30 42/48 465 SP109WR 1123HBL.GN 115 50/60 0.25/0.22 22/20 2500/2900 85/100 0.25/0.30 42/48 465 DP209WR 2123HST.GN 220-240 50/60 0.13/0.12 22/21 2500/2900 85/100 0.28/0.35 41/47 465 DP209WR 2123HSL.GN 220-240 50/60 0.13/0.12 22/21 2500/2900 85/100 0.28/0.35 41/47 465 DP209WR 2123HBT.GN 220-240 50/60 0.13/0.12 22/21 2500/2900 85/100 0.25/0.30 42/48 465 DP209WR 2123HBL.GN 220-240 50/60 0.13/0.12 22/21 2500/2900 85/100 0.25/0.30 42/48 465 Safety : UL-CUL/TUV/CE/CCC Frame : PBT Plastic Air Flow-Static Pressure Characteristics Ball / Sleeve (50Hz) Ball / Sleeve (60Hz) Static Pressure (Inch-H2O) 0 .3 0 .4 HST/HSL HBT/HBL HST/HSL HBT/HBL 0 .3 5 0 .2 5 0 .3 0 .2 0 .2 5 0 .1 5 0 .2 0 .1 5 0 .1 0 .1 0 .0 5 0 .0 5 0 0 15 30 45 60 75 90 15 30 45 60 75 90 105 Airflow (CFM) External dimensions(mm) 300±10 5±0.3 AIR FLOW INLET 104.0±0.3 119.5±0.5 4-ø4.3±0.3 4-ø4.3±0.3 #24AWG ø1 15 .5 OUTLET ø1 16 7.0±0.5 38.5±0.5 *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON website at http://www.sunon.com for update information. 14 120x120x38 mm 95~117 CFM Specifications Bearing Model P/N Rating Voltage Freq. Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VAC) (Hz) (AMP) (WATTS) (RPM) (CFM) (Inch-H 2O) (dB(A)) (g) VAPO BALL Sleeve A1123-HST GN 115 50/60 0.28/0.25 23/20 2700/3100 95/115 0.33/0.38 44/49 525 A1123-HSL GN 115 50/60 0.28/0.25 23/20 2700/3100 95/115 0.33/0.38 44/49 525 A1123-HBT GN 115 50/60 0.28/0.25 23/20 2700/3100 97/117 0.34/0.39 45/50 525 A1123-HBL GN 115 50/60 0.28/0.25 23/20 2700/3100 97/117 0.34/0.39 45/50 525 A2123-HST GN 220-240 50/60 0.14/0.12 23/20 2700/3100 95/115 0.33/0.38 44/49 525 A2123-HSL GN 220-240 50/60 0.14/0.12 23/20 2700/3100 95/115 0.33/0.38 44/49 525 A2123-HBT GN 220-240 50/60 0.14/0.12 23/20 2700/3100 97/117 0.34/0.39 45/50 525 A2123-HBL GN 220-240 50/60 0.14/0.12 23/20 2700/3100 97/117 0.34/0.39 45/50 525 Safety : UL-CUL/TUV/CE/CCC Frame : Aluminum alloy Air Flow-Static Pressure Characteristics Static Pressure (Inch-H2O) Ball (50Hz) Ball (60Hz) Sleeve (50Hz) Sleeve (60Hz) 0.4 0.4 0.4 0.4 0.35 0.35 0.35 0.35 0.3 0.3 0.3 0.3 0.25 0.25 0.25 0.25 0.2 0.2 0.2 0.2 0.15 0.15 0.15 0.15 0.1 0.1 0.1 0.1 0.05 0.05 0.05 0.05 0 0 15 30 45 60 0 75 90 105 120 15 30 45 60 75 90 105 120 0 15 30 45 60 15 30 75 90 105 120 45 60 75 90 105 120 Airflow (CFM) External dimensions(mm) AIR FLOW INLET OUTLET 5 300±15 #24AWG 15 ø1 8- 104.8±0.3 119.5±0.5 14 ø1 ø4 .3 ±0 4±0.3 .3 38.5±0.5 *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON website at http://www.sunon.com for update information. 15 120x120x38 mm High Air Flow 112~124 CFM Specifications Bearing Model P/N Rating Voltage Freq. Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VAC) (Hz) (AMP) (WATTS) (RPM) (CFM) (Inch-H 2O) (dB(A)) (g) VAPO BALL Sleeve A1123-HST (7).GN 115 50/60 0.28/0.25 23/21 2500/2750 112/124 0.30/0.28 43/46 525 A1123-HSL (7).GN 115 50/60 0.28/0.25 23/21 2500/2750 112/124 0.30/0.28 43/46 525 A1123-HBT (7).GN 115 50/60 0.28/0.25 23/21 2500/2750 112/124 0.30/0.28 44/47 525 A1123-HBL (7).GN 115 50/60 0.28/0.25 23/21 2500/2750 112/124 0.30/0.28 44/47 525 A2123-HST (7).GN 220-240 50/60 0.14/0.12 24/22 2500/2750 112/124 0.30/0.28 43/46 525 A2123-HSL (7).GN 220-240 50/60 0.14/0.12 24/22 2500/2750 112/124 0.30/0.28 43/46 525 A2123-HBT (7).GN 220-240 50/60 0.14/0.12 24/22 2500/2750 112/124 0.30/0.28 44/47 525 A2123-HBL (7).GN 220-240 50/60 0.14/0.12 24/22 2500/2750 112/124 0.30/0.28 44/47 525 Safety : UL-CUL/TUV/CE/CCC Frame : Aluminum alloy Air Flow-Static Pressure Characteristics Ball (50Hz) Ball (60Hz) Static Pressure (Inch-H2O) 0.35 HBL/HBT HST/HSL 0.3 0.35 0.35 HBL/HBT HST/HSL 0.3 Sleeve (50Hz) HBL/HBT HST/HSL 0.3 0.35 0.25 0.25 0.25 0.2 0.2 0.2 0.2 0.15 0.15 0.15 0.15 0.1 0.1 0.1 0.1 0.05 0.05 0.05 0.05 0 0 0 40 60 80 100 120 140 20 40 60 80 100 120 140 HBL/HBT HST/HSL 0.3 0.25 20 Sleeve (60Hz) 0 20 40 60 80 100 120 140 20 40 60 80 100 120 140 Airflow (CFM) External dimensions(mm) AIR FLOW INLET #24AWG OUTLET 5±1 4 8- 104.8±0.3 119.5±0.5 15 ø1 G 300±15 TERMINAL TYPE 7.5 (THICK0.5) ø4 14 ø1 4±0.3 .3 ±0 .3 38.5±0.5 *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON website at http://www.sunon.com for update information. 16 120x120x38 mm Dual AC Voltage 95~115 CFM Specifications Bearing Model P/N Rating Voltage Freq. Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VAC) (Hz) (AMP) (WATTS) (RPM) (CFM) (Inch-H 2O) (dB(A)) (g) VAPO BALL Sleeve SL.GN SF1212AD BL.GN SF1212AD 115 50/60 0.27/0.24 21.5/19 2700/3100 95/115 0.33/0.38 44/49 550 220-240 50/60 0.13/0.12 19.5/19 2700/3100 95/115 0.33/0.38 44/49 550 115 50/60 0.27/0.24 21.5/19 2700/3100 95/115 0.33/0.38 44/49 550 220-240 50/60 0.13/0.12 19.5/19 2700/3100 95/115 0.33/0.38 44/49 550 Frame : Aluminum alloy Safety : UL-CUL/TUV/CE/CCC Air Flow-Static Pressure Characteristics Static Pressure (Inch-H2O) Ball/Sleeve (50Hz) Connection Ball/Sleeve (60Hz) 0.4 0.4 black 0.35 0.35 red 0.3 0.3 0.25 0.25 white 0.2 0.15 black 0.1 0.1 red 0.05 0.05 white 0 45 60 red white blue black blue 0.2 15 30 start 115VAC 0.15 0 Wire start 75 90 105 120 15 30 45 60 75 90 105 120 230VAC blue Wire Connection diagram Airflow (CFM) External dimensions(mm) ROTATION AIR FLOW INLET #26AWG OUTLET .5 8 15 ø1 4 6 ø11 5±1 310±15 G 8- 104.8±0.3 119±0.5 ø4 4±0.3 .3 ±0 .3 38.5±0.5 *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON website at http://www.sunon.com for update information. 17 120x120x38 mm Low Power Consumption 49~50 CFM Specifications Bearing Model P/N VAPO BALL Sleeve Rating Voltage Freq. Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VAC) (Hz) (AMP) (WATTS) (RPM) (CFM) (Inch-H 2O) (dB(A)) (g) DP203A 2123LBL.(5).GN 220-240 50/60 0.04/0.04 8/8 1650/1600 50/49 0.08/0.07 26/25 550 DP203A 2123LBT.(5).GN 220-240 50/60 0.04/0.04 8/8 1650/1600 50/49 0.08/0.07 26/25 550 Frame : Aluminum alloy Safety : TUV/CE/CCC Air Flow-Static Pressure Characteristics 0.08 Ball (50Hz) 0.08 Ball (60Hz) Static Pressure (Inch-H2O) LBL/LBT LBL/LBT 0.07 0.07 0.06 0.06 0.05 0.05 0.04 0.04 0.03 0.03 0.02 0.02 0.01 0.01 0 10 20 30 40 50 60 0 10 20 30 40 50 60 Airflow (CFM) ROTATION AIR FLOW INLET ø1 15 .5 OUTLET ø1 16 SUNON 50±0.5 310±15 #24AWG 8-ø4 .3±0.3 External dimensions(mm) 4±0.3 104.8±0.3 119±0.5 38.5±0.5 *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON website at http://www.sunon.com for update information. 18 171x151x51 mm 180~200 CFM Specifications Bearing Model P/N Rating Voltage Freq. Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VAC) (Hz) (AMP) (WATTS) (RPM) (CFM) (Inch-H 2O) (dB(A)) (g) VAPO BALL Sleeve A1175-HBL T.GN 115 50/60 0.59/0.48 39/36 2650/2950 180/200 0.48/0.38 52/55 957 A1175-HBT T.GN 115 50/60 0.59/0.48 39/36 2650/2950 180/200 0.48/0.38 52/55 957 A2175-HBL T.GN 220-240 50/60 0.28/0.24 39/36 2650/2950 180/200 0.48/0.38 52/55 957 A2175-HBT T.GN 220-240 50/60 0.28/0.24 39/36 2650/2950 180/200 0.48/0.38 52/55 957 Frame : Aluminum alloy Safety : UL-CUL/TUV/CE/CCC Air Flow-Static Pressure Characteristics Ball (50Hz) Ball (60Hz) Static Pressure (Inch-H2O) 0.5 0.5 HBL/HBT HBL/HBT 0.4 0.4 0.3 0.3 0.2 0.2 0.1 0.1 0 0 40 80 120 160 200 240 40 80 120 160 200 240 Airflow (CFM) External dimensions(mm) #18AWG 280±10 8 ROTATION AIR FLOW INLET OUTLET 7.8 4 ø1 3 . ±0 151±0.5 .5 ø4 4- SUNON 162±0.5 ø1 45 TERMINAL TYPE 7.5 (THICK 0.5) 51±0.5 171.5±0.5 *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON website at http://www.sunon.com for update information. 19 171x151x51 mm Alveolate Motor 203~239 CFM Specifications Bearing Model P/N VAPO BALL Sleeve Rating Voltage Freq. Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VAC) (Hz) (AMP) (WATTS) (RPM) (CFM) (Inch-H 2O) (dB(A)) (g) A1175-HBL TC.GN 115 50/60 0.22/0.23 25/27 2800/3200 203/239 0.62/0.69 51/58 908 A1175-HBT TC.GN 115 50/60 0.22/0.23 25/27 2800/3200 203/239 0.62/0.69 51/58 908 A2175-HBL TC.GN 220-240 50/60 0.11/0.11 25/26 2800/3200 203/239 0.62/0.69 51/58 908 A2175-HBT TC.GN 220-240 50/60 0.11/0.11 25/26 2800/3200 203/239 0.62/0.69 51/58 908 Frame : Aluminum alloy Safety : UL-CUL/TUV/CE/CCC Air Flow-Static Pressure Characteristics Static Pressure (Inch-H2O) Ball (50Hz) Ball (60Hz) 0.7 0.7 0.6 0.6 0.5 0.5 0.4 0.4 0.3 0.3 0.2 0.2 0.1 0.1 0 0 40 80 120 160 200 240 40 80 120 160 200 240 Airflow (CFM) External dimensions(mm) 8-ø4.5±0.3 AIR FLOW 6 ø1 6 4 ø1 INLET OUTLET 6 151±0.5 280±10 5 134±0.5 #18AWG 161.5±0.5 46±0.3 171.5±0.5 51±0.5 *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON website at http://www.sunon.com for update information. 20 ø171x51 mm Alveolate Motor 203~239 CFM Specifications Bearing Model P/N VAPO BALL Sleeve Rating Voltage Freq. Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VAC) (Hz) (AMP) (WATTS) (RPM) (CFM) (Inch-H 2O) (dB(A)) (g) A1175-HBL TC.R.GN 115 50/60 0.22/0.23 25/27 2800/3200 203/239 0.62/0.69 51/58 908 A1175-HBT TC.R.GN 115 50/60 0.22/0.23 25/27 2800/3200 203/239 0.62/0.69 51/58 908 A2175-HBL TC.R.GN 220-240 50/60 0.11/0.11 25/26 2800/3200 203/239 0.62/0.69 51/58 908 A2175-HBT TC.R.GN 220-240 50/60 0.11/0.11 25/26 2800/3200 203/239 0.62/0.69 51/58 908 Frame : Aluminum alloy Safety : UL-CUL/TUV/CE/CCC Air Flow-Static Pressure Characteristics Static Pressure (Inch-H2O) Ball (50Hz) Ball (60Hz) 0.8 0.8 0.7 0.7 0.6 0.6 0.5 0.5 0.4 0.4 0.3 0.3 0.2 0.2 0.1 0.1 0 40 80 120 160 200 240 280 0 40 80 120 160 200 240 280 Airflow (CFM) External dimensions(mm) AIR FLOW INLET 8-ø4.5±0.3 #18AWG ø1 66 280±10 5 134±0.5 46 OUTLET ø1 161.5±0.3 171.5±0.5 46±0.3 51±0.5 *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON website at http://www.sunon.com for update information. 21 176x176x89 mm Alveolate Motor 315~335 CFM Specifications Bearing Model P/N VAPO BALL Sleeve Rating Voltage Freq. Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VAC) (Hz) (AMP) (WATTS) (RPM) (CFM) (Inch-H 2O) (dB(A)) (g) A1179-HBT TC.GN 115 50/60 0.25/0.27 24/30 2800/3250 315/335 0.65/0.8 62/66 1960 A1179-HBL TC.GN 115 50/60 0.25/0.27 24/30 2800/3250 315/335 0.65/0.8 62/66 1960 A2179-HBT TC.GN 220-240 50/60 0.11/0.15 23/30 2800/3250 315/335 0.65/0.8 62/66 1960 A2179-HBL TC.GN 220-240 50/60 0.11/0.15 23/30 2800/3250 315/335 0.65/0.8 62/66 1960 Frame : Aluminum alloy Safety : UL-CUL/TUV/CE/CCC Air Flow-Static Pressure Characteristics Ball (50Hz) Ball (60Hz) Static Pressure (Inch-H2O) 0.9 0.9 HBT/HBL HBT/HBL 0.8 0.8 0.7 0.7 0.6 0.6 0.5 0.5 0.4 0.4 0.3 0.3 0.2 0.2 0.1 0.1 0 0 40 80 120 160 200 240 280 320 360 40 80 120 160 200 240 280 320 360 Airflow (CFM) External dimensions(mm) AIR FLOW #20AWG 300±10 8 .3 ±0 5.8 TERMINAL TYPE 7.5 (THICK 0.5) INLET ø1 60 152.7±0.3 176±0.5 OUTLET 8-ø ø1 61 6±0.3 89±0.5 *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON website at http://www.sunon.com for update information. 22 ø254x89 mm Alveolate Motor 425~870 CFM Specifications Rating Voltage Bearing Model P/N VAPO BALL Sleeve A1259-MBL A1259-MBT A1259-HBL A1259-HBT A1259-XBL A1259-XBT A2259-MBL A2259-MBT A2259-HBL A2259-HBT TC.N.GN TC.N.GN TC.N.GN TC.N.GN TC.N.GN TC.N.GN TC.N.GN TC.N.GN TC.N.GN TC.N.GN Freq. Power Current Power Consumption Weight Speed Air Flow Static Pressure Noise (CFM) (Inch-H 2O) (dB(A)) (g) 54/57 54/57 62/60 62/60 68/70 68/70 54/57 54/57 62/60 62/60 2300 2300 2300 2300 2400 2400 2300 2300 2300 2300 (VAC) (Hz) (AMP) (WATTS) (RPM) 115 115 115 115 115 115 220-240 220-240 220-240 220-240 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 0.23/0.23 0.23/0.23 0.60/0.65 0.60/0.65 0.83/1.10 0.83/1.10 0.15/0.13 0.15/0.13 0.24/0.27 0.24/0.27 20/23 20/23 63/72 63/72 88/120 88/120 23/30 23/30 56/60 56/60 1400/1600 1400/1600 2100/1900 2100/1900 2600/2900 2600/2900 1400/1600 1400/1600 2100/1900 2100/1900 425/500 425/500 650/585 650/585 800/870 800/870 425/500 425/500 650/585 650/585 0.27/0.31 0.27/0.31 0.35/0.31 0.35/0.31 0.76/0.62 0.76/0.62 0.27/0.31 0.27/0.31 0.35/0.31 0.35/0.31 Safety : UL-CUL/TUV/CE/CCC Frame : Aluminum alloy Air Flow-Static Pressure Characteristics Static Pressure (Inch-H2O) 0.8 0.7 Ball (50Hz) XBL/XBT HBL/HBT MBL/MBT 0.8 XBL/XBT HBL/HBT MBL/MBT 0.7 0.6 0.6 0.5 0.5 0.4 0.4 0.3 0.3 0.2 0.2 0.1 0.1 0 Ball (60Hz) 0 100 200 300 400 500 600 700 800 900 100 200 300 400 500 600 700 800 900 Airflow (CFM) External dimensions(mm) ROTATION 320±10 10±1 AIR FLOW TERMINAL TYPE 7.5 (THICK 0.5) #20AWG ø2 23 ROTATION 16-ø4.5 INLET .6 OUTLET ø23 1.9 AIR FLOW SUNON M5 ø245.5±0.5 ø254± 1 0.5 89±0.5 *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON website at http://www.sunon.com for update information. 23 120x120x31 mm 20~22 CFM Specifications Rating Voltage Bearing Model P/N VAPO BALL Sleeve GN GN GN GN GN GN GN GN AB1123-HST AB1123-HSL AB1123-HBT AB1123-HBL AB2123-HST AB2123-HSL AB2123-HBT AB2123-HBL Freq. Power Current Power Consumption Weight Speed Air Flow Static Pressure Noise (CFM) (Inch-H 2O) (dB(A)) (g) 48/50 48/50 48/50 48/50 48/50 48/50 48/50 48/50 678 678 678 678 678 678 678 678 (VAC) (Hz) (AMP) (WATTS) (RPM) 115 115 115 115 220-240 220-240 220-240 220-240 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 0.25/0.21 0.25/0.21 0.25/0.21 0.25/0.21 0.14/0.11 0.14/0.11 0.14/0.11 0.14/0.11 20/18 20/18 20/18 20/18 20/18 20/18 20/18 20/18 2600/2900 2600/2900 2600/2900 2600/2900 2600/2900 2600/2900 2600/2900 2600/2900 20/22 20/22 20/22 20/22 20/22 20/22 20/22 20/22 0.32/0.46 0.32/0.46 0.32/0.46 0.32/0.46 0.32/0.46 0.32/0.46 0.32/0.46 0.32/0.46 Safety : UL-CUL/TUV/CE/CCC Frame : Aluminum alloy Air Flow-Static Pressure Characteristics Static Pressure (Inch-H2O) 0.5 Ball / Sleeve (50Hz) 0.5 Ball / Sleeve (60Hz) HBT/HST HBL/HSL HBT/HST HBL/HSL 0.4 0.4 0.3 0.3 0.2 0.2 0.1 0.1 0 0 3 6 9 12 15 18 21 24 3 6 9 12 15 18 21 24 Airflow (CFM) External dimensions(mm) 120.5±0.5 48.7±0.5 37±0.5 31±0.5 M4 NUT 52.5±0.5 AIR FLOW 55±0.5 43.5±0.5 52.5±0.5 18.75±0.5 52.5±0.5 120.5±0.5 52.5±0.5 *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON website at http://www.sunon.com for update information. 24 Headquarters Sunonwealth Electric Machine Industry Co., Ltd. Sunon Taipei Office (Taiwan) TEL:+886-7-8135888 TEL:+886-2-27992383 E-mail:sunon@email.sunon.com.tw Sunon Shen Zhen Office (China) Sunon Inc. (U.S.A.) TEL:+1-714-255-0208 E-mail:info@sunon.com TEL:+86-755-26880688 E-mail:sunon@email.sunon.com.tw Sunon Beijing Office (China) TEL:+86-10-62669511 Sunon SAS (Europe) TEL:+33-1-46154515 E-mail:info@sunoneurope.com E-mail:sunon@email.sunon.com.tw Sunon Wuhan Office (China) TEL:+86-27-81388268 E-mail:sunon@email.sunon.com.tw 2017/07/30 (241-W) © 2017 SUNONWEALTH Electric Machine Industry Co., Ltd.
DP201A-2123HST.GN 价格&库存
很抱歉,暂时无法提供与“DP201A-2123HST.GN”相匹配的价格&库存,您可以联系我们找货
DP201A-2123HST.GN
    DP201A-2123HST.GN
    • 1+182.20050
    库存:373
