DP201A/2123HSL.GN
DP201A/2123HSL.GN
    SUNON
    插件
DP201A/2123HSL.GN 数据手册
120x120x38 mm 70~117 CFM Specifications Rating Voltage Freq. Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VAC) (Hz) (AMP) (WATTS) (RPM) (CFM) (Inch-H 2O) (dB(A)) (g) 220-240 220-240 220-240 220-240 220-240 220-240 220-240 220-240 220-240 220-240 220-240 220-240 220-240 220-240 220-240 220-240 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 0.14/0.12 0.14/0.12 0.125/0.11 0.125/0.11 0.09/0.08 0.09/0.08 0.06/0.05 0.06/0.05 0.14/0.12 0.14/0.12 0.125/0.11 0.125/0.11 0.09/0.08 0.09/0.08 0.05/0.06 0.05/0.06 22/21 22/21 20/19 20/19 16/15 16/15 11/10 11/10 22/21 22/21 20/19 20/19 16/15 16/15 10/10 10/10 2700/3100 2700/3100 2550/2900 2550/2900 2300/2500 2300/2500 2000/1800 2000/1800 2850/3150 2850/3150 2750/3050 2750/3050 2400/2600 2400/2600 2300/2150 2300/2150 95/115 95/115 85/105 85/105 78/84 78/84 70/63 70/63 97/117 97/117 87/107 87/107 78/84 78/84 78/72 78/72 0.33/0.38 0.33/0.38 0.25/0.30 0.25/0.30 0.14/0.21 0.14/0.21 0.08/0.07 0.08/0.07 0.34/0.39 0.34/0.39 0.26/0.32 0.26/0.32 0.14/0.21 0.14/0.21 0.13/0.09 0.13/0.09 44/49 44/49 43/48 43/48 33/38 33/38 36/32 36/32 45/50 45/50 45/50 45/50 34/39 34/39 39/37 39/37 550 550 550 550 550 550 550 550 550 550 550 550 550 550 550 550 Bearing Model P/N VAPO BALL Sleeve 2123XSL.GN 2123XST.GN 2123HSL.GN 2123HST.GN 2123MSL.GN 2123MST.GN 2123LSL.GN 2123LST.GN 2123XBL.GN 2123XBT.GN 2123HBL.GN 2123HBT.GN 2123MBL.GN 2123MBT.GN 2123LBL.GN 2123LBT.GN DP200A DP200A DP201A DP201A DP202A DP202A DP203A DP203A DP200A DP200A DP201A DP201A DP202A DP202A DP203A DP203A Safety : UL-CUL/TUV/CE/CCC/BSMI Frame : Aluminum alloy Air Flow-Static Pressure Characteristics Static Pressure (Inch-H2O) Ball (50Hz) Ball (60Hz) Sleeve (50Hz) Sleeve (60Hz) 0.4 0.4 0.4 0.4 0.35 0.35 0.35 0.35 0.3 0.3 0.3 0.3 0.25 0.25 0.25 0.25 0.2 0.2 0.2 0.2 0.15 0.15 0.15 0.15 0.1 0.1 0.1 0.1 0.05 0.05 0.05 0.05 0 0 0 15 30 45 60 75 90 105 120 15 30 45 60 75 90 105 120 0 15 30 45 60 75 90 105 120 15 30 45 60 75 90 105 120 Airflow (CFM) External dimensions(mm) AIR FLOW INLET #24AWG 310±15 ø1 15 ø1 16 5 .5 OUTLET 104.8±0.3 8-ø4.3±0.3 4±0.3 119±0.5 38.5±0.5 *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON website at http://www.sunon.com for update information. 13
DP201A/2123HSL.GN 价格&库存
很抱歉,暂时无法提供与“DP201A/2123HSL.GN”相匹配的价格&库存,您可以联系我们找货
