EEC0382B3-000C-A99
EEC0382B3-000C-A99
    SUNON
    120*120*38
EEC0382B3-000C-A99 数据手册
2010.02.10 2010.02.10 2010.02.10 2010.02.10 2010.02.10 2010.02.10 LABEL BLACK WORD COLOR:PANTONE 199C SUNON KD2406PKB2 EEC0382B3-000C-A99 13.(2).A.GN.I21 DC24V 3.1W DC24V 1.4W EP BLACK WORD COLOR :SILVER ZP MA TUV Rheinl and TUV Product RheinlSafety and Product Safety DE IN 3.0 DATE CODE 建 準 電 機 SUNONWEALTH Page 7 of 14 2010.02.10 2010.02.10 IV. CHARACTERISTIC DEFINITION The following is a general description of certain tests that are performed on representative Sunon fans in order to determine the specifications of the fan. Nothing in this document is intended to suggest that these tests are performed on every model of Sunon fan. Moreover, the descriptions that follow each test are meant only to provide a general explanation of each test. If you would like a more detailed explanation as to any test identified in this Section, Sunon can provide such an explanation upon request. 1. ACOUSTICAL NOISE Measured in a semi-anechoic chamber with background noise level below 15dB(A). 1 METER FROM MICROPHONE TO FAN INTAKE The fan is running in free air under shaft horizontal condition with the microphone at distance of one meter from the fan intake. 2. INPUT POWER Measured after continuous 10 minute operation at rated voltage in clean air ( STATIC PRESSURE=0), and at ambient temperature of 25 degrees C under shaft horizontal condition. 3. RATED CURRENT Measured after continuous 10 minute operation at rated voltage in clean air ( STATIC PRESSURE=0), and at ambient temperature of 25 degrees C under shaft horizontal condition. 建 準 電 機 SUNONWEALTH Page 9 of 14 2010.02.10 2010.02.10 2010.02.10 2010.02.10 2010.02.10 Declaration of RoHS Control declaration of environment-related substances/materials 1. In accordance with the Restriction of Hazardous Substances (RoHS) Directive, Sunon product have complied with law and discipline not to employ the forbidden substances, and restrict the allowable concentration of some limited substances deliberately in our components. No 1 2 3 4 Substance Criteria CFCs & HCFCs (ozone depleting substances) Forbidden Chlorinated Organic Solvent Forbidden Lead and its compounds Cadmium and its compounds Plastic (Frame, Impeller, wire harness, etc.)
EEC0382B3-000C-A99 价格&库存
很抱歉,暂时无法提供与“EEC0382B3-000C-A99”相匹配的价格&库存,您可以联系我们找货
