30x30x15 mm
MagLev Green Motor Fan
4.8~6.0 CFM
Model
P/N
GM0503PHV1-8
GM0503PHV2-8
GM1203PHV1-8
GM1203PHV2-8
Rating
Voltage
Power
Current
Power
Consumption
Speed
Air
Flow
Static
Pressure
Noise
Weight
VAPO
2BALL
(VDC)
(AMP)
(WATTS)
(RPM)
(CFM)
(Inch-H2O)
(dBA)
(g)
6.0
4.8
6.0
4.8
0.17
0.12
0.17
0.12
27
Bearing
GN
GN
GN
GN
0.11
0.07
0.054
0.029
5
5
12
12
0.6
0.4
0.6
0.4
8500
7000
8500
7000
13.5
13.5
13.2
13.2
0.18
28
UL1571,#28AWG
0.15
3- 3.2
V2
150 +- 30
0.12
.4
V1
0.09
OUTLET
5 +- 0.3
Static Pressure (Inch-H2O)
INLET
0.06
0.03
24 +- 0.3
30 +- 0.5
15 +- 0.5
2
3
4
5
6
7
( Units : mm )
Airflow (CFM)
*All model could be customized on voltage or any other requirements to fit your need.
*Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information.
13
Fan 3rd Wire Signal
Fan with switching driving circuit designed for rpm
measurement:
These fan motors have three lead wires:
+:Red,
-:Black,
output signal for 3rd wire:
F Type : Yellow
R Type : White
F Type (Frequency Generator)
1Pulse
a
R Type (Rotation Detector)
1Rotation
b
c
Locked
Run
Vcc
Vcc
DC FAN
Ic
Red(+)
RL
3 rd wire
Black(-)
Locked
Run
Customer's Circuit
Vcc
The relationship between rotation & output
pulses signal from 3rd wire are as follows:
(a) 1 Rotation=2 Pulses(4 poles' motor)
(b) 1 Rotation=3 Pulses(6 poles' motor)
(c) 1 Rotation=4 Pulses(8 poles' motor)
DC FAN
Red(+)
Ic
RL
3 rd wire
Black(-)
Notice:
For 8 poles' motor: normally,
1Rotation=4 pulses, if frequency divided
circuit is implemented in this motor then
1Rotation=2 pulses.
Customer's Circuit
Safety
Certification
02
DC Fan and Blower Model Numbering System
GM
05
02
P
F
V
FAN SERIES
GM Series GB Series
KDE Series PMD Series
PMB Series
VOLTAGE
05:5VDC
12:12VDC
24:24VDC
48:48VDC
FRAME SIZ
17:17mm
01:20mm
02:25mm
03:30mm
35:35mm
38:38mm
04:40mm
45:45mm
05:50mm
55:55mm
1
8
MOTOR POLES
8: 8 Poles
6: 6 Poles
Blank: 4 Poles
06:60mm
07:70mm
75:75mm
08:80mm
09:92mm
SPEED
X:SUPER 3:LOW
1:HIGH
4:EXTRA LOW
2:MIDDLE
97:97mm
12:120mm
BEARING SYSTEM
V:VAPO
B:BALL
FRAME THICKNESS
E:6mm B:24mm
D:8mm T:25mm
F:10mm Q:28mm
G:12mm N:30mm
H:15mm L:32mm
K:20mm Y:33mm
FRAME MATERIAL
P:PBT Plastic
A:Aluminum
P/N
I:35mm
M:38mm
O:40mm
P:56mm
Example: KDE1208PTV1 P/N:13.MS.A.GN
11/13
MS
(2)
G
(9)
N
A
F
R
U
GN
Motor model
MagLev Design
Two ball bearing
Big hub
9 Blades
Smaller hub
Auto restart
3rd wire with frequency generation waveform
3rd wire with rotation detector waveform
Upgrade
RoHS compliance
Sunon Connector recommendation
Connector pitch
1.25mm
1.5mm
2.0mm
2.54mm
2.50mm
Manufacturer
HIROSE
MOLEX
JST
JST
ECI
Molex
Molex
Molex
Molex
Molex
JAM
JST
JST
JST
JST
JWT
JWT
Molex
Molex
Housing
Terminal
DF13-2S-1.25C
51021-0300
ZHR-2
PHR-2
2510-02
50-57-9405
2695-02RP
2695-03RP
6471-021
6471-031
SC25-02HG
SMR-02V-B
XHP-2
EHR-2(H28J-2)
SMP-02V-BC
A2502H02-2P
A2502H02-3P
5051-02
5264-02
DF13-2630SCF
50058-8200
SZH-002T-P0.5 or SZH-003T-P0.5
SPH-002T-P0.5S
2511-P
16-02-0069(70058-0004) or 16-02-0082(70058-0006)
2759T(39-00-0372)
2759T(39-00-0372)
4809-C-P914
4809-C-P914
725462-2MA
SYM-001T-P0.6
SXH-001T-0.6
SEH-001T-P0.6
SHF-001T-0.8BS
A2502TOP-2
A2502TOP-2
2759T(39-00-0372)
5263PBT(08-70-1039)
03
很抱歉,暂时无法提供与“GM1203PHV2-8.GN”相匹配的价格&库存,您可以联系我们找货
