EB40200S2-0000-999
EB40200S2-0000-999
    SUNON
    插件
EB40200S2-0000-999 数据手册
DR MagLev motor fan [ [ DR MagLev = Dust-Resistance MagLev Features - Better oil leak prevention - Better dust-resistance - Higher reliability - Longer life expectancy Design Concepts The two innovative design concepts of DR MagLev development are B&S (Blanked & Seamless) Technology and S&C (Seal & Clip) Design. S&C Design (Seal& Clip) These innovative designs bring three excellent efficiencies to extend fan life: Bearing Shaft Retaining ring MagLev Plate B & S Technology (Blanked & Seamless) (1) To avoid dust invasion and extend motor life. (2) To prevent oil leakage (3) To prevent the motor components from falling off. Note: DR MagLev Motor can be used with different motors types (radial, axial) and sizes, so the final design may vary from the above, according to the different motor structures. 1 Characteristic   S&C (Seal & Clip) Design The innovative S&C (Seal & Clip) Design provides the best resistance to dust invasion. 2   Innovative B&S (Blanked & Seamless) Technology DR MagLev’s one-piece structure with the B&S (Blanked & Seamless) Technology and S&C (Seal & Clip) Design provides the best prevention of oil leakage. 3   High Relliabillity Design The S&C (Seal & Clip) Design can prevent the stator and impeller from falling off and help reduce noise that is caused by stator and impeller movement after a period of usage. The design greatly improves the life expectancy and the reliability 01 New Model Numbering System M- E 80 25 1 V 1 0000 999 Function Code 999: standard model A99: AutoRestart C99: F type (3rd wire) D99: with PWM F99: AutoRestart and R type(3rd wire) G99: AutoRestart and F type(3rd wire) H99: AutoRestart and with PWM Q99: AutoRestart , R type and with PWM S99: AutoRestart , F type and with PWM Customer Code 0000 stand for standard model Speed X:Super High 3: Low 4: Super Low 1: High 2: Medium Bearing V: Vapo B: 2 Ball S: Sleeve Voltage 0: 5VDC 1: 12VDC 2: 24VDC 3: 36VDC 4: 48VDC Fan Thickness 0~9; A~Z (except O) Frame Size 0~9; A~Z (except O) Motor Type Series Code E Series M Series Code 01~09 10~19 20~29 30~39 40~49 50~59 60~69 70~79 80~89 90~99 Size(mm) 01~09 10~19 20~29 30~39 40~49 50~59 60~69 70~79 80~89 90~99 Code A0~A9 B0~B9 C0~C9 D0~D9 E0~E9 F0~F9 G0~G9 H0~H9 I0~I9 J0~J0 Size(mm) Code K0~K9 L0~L9 M0~M9 N0~N9 P0~P9 Q0~Q9 R0~R9 S0~S9 T0~T9 U0~U9 100~109 110~119 120~129 130~139 140~149 150~159 160~169 170~179 180~189 190~199 Certification Size(mm) 200~209 210~219 220~229 230~239 240~249 250~259 260~269 270~279 280~289 290~299 P Series Code V0~V9 W0~W9 X0~X9 Y0~Y9 Z0~Z9 Size(mm) 300~309 310~319 320~329 330~339 340~349 Safety * Note: For critical or extreme environments, including non stop operation, please contact Sunon and we will gladly provide assistance with your product selection to ensure an appropriate cooling product for your application. * Note: The “Life Expectancy” of the fan has not been evaluated for use in combination with any end application. Therefore, the Life Expectancy Test Reports(L10 and MTTF Report) that relate to the fan are only for reference. 02 Dustproof 40x40x20 Bearing Model VAPO Rating Voltage (VDC) Power Power Current Consumption (mA) (WATTS) Oil Free High Air Flow Static Pressure (Inch-H2O) Noise Weight (RPM) Air Flow (CFM) (dBA) (g) Speed MB40200V1-0000-A99 5 190 0.95 7200 8.9 0.21 25.5 30.0 MB40200V2-0000-A99 5 123 0.32 6200 7.7 0.16 21.0 30.0 MB40200V3-0000-A99 5 81 0.41 5200 6.3 0.11 18.0 30.0 MB40201VX-0000-A99 12 115 1.38 8200 10.8 0.27 27.5 31.0 MB40201V1-0000-A99 12 70 0.84 7200 8.9 0.21 25.5 31.0 MB40201V2-0000-A99 12 50 0.60 6200 7.7 0.16 21.0 31.0 MB40201V3-0000-A99 12 40 0.48 5200 6.3 0.11 18.0 31.0 MB40202VX-0000-A99 24 64 1.54 8200 10.8 0.27 27.5 31.0 MB40202V1-0000-A99 24 50 1.20 7200 8.9 0.21 25.5 31.0 MB40202V2-0000-A99 24 33 0.80 6200 7.7 0.16 21.0 31.0 Model Bearing SLEEVE (VDC) (mA) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) EB40200S1-0000-999 5 218 1.09 7200 8.9 0.21 25.5 30.0 EB40200S2-0000-999 5 140 0.70 6200 7.7 0.16 21.0 30.0 EB40200S3-0000-999 5 100 0.50 5200 6.3 0.11 18.0 30.0 EB40201SX-0000-999 12 120 1.44 8200 10.8 0.27 27.5 31.0 EB40201S1-0000-999 12 90 1.08 7200 8.9 0.21 25.5 31.0 EB40201S2-0000-999 12 63 0.76 6200 7.7 0.16 21.0 31.0 EB40201S3-0000-999 12 45 0.54 5200 6.3 0.11 18.0 31.0 EB40202S1-0000-999 24 54 1.30 7200 8.9 0.21 25.5 31.0 EB40202S2-0000-999 24 33 0.80 6200 7.7 0.16 21.0 31.0 50x50x15 (VDC) (mA) (WATTS) (RPM) (CFM) ME50151V1-0000-A99 12 145 1.74 7000 ME50151V2-0000-A99 12 125 1.50 6100 ME50151V3-0000-A99 12 65 0.78 ME50152V1-0000-A99 24 95 ME50152V2-0000-A99 24 80 Model 60x60x15 Model Bearing VAPO Bearing VAPO (Inch-H2O) (dBA) (g) 18.6 0.26 40.1 27.6 16.1 0.20 36.0 27.6 4900 12.9 0.14 30.1 27.6 2.28 7000 18.6 0.26 40.1 27.6 1.92 6100 16.1 0.20 36.0 27.6 (VDC) (mA) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) ME60151V1-0000-A99 12 160 1.92 5400 25.2 0.15 36.2 30.5 ME60151V2-0000-A99 12 140 1.68 4700 21.9 0.12 32.5 30.5 ME60151V3-0000-A99 12 75 0.90 3900 18.1 0.08 28.2 30.5 ME60152V1-0000-A99 24 100 2.40 5400 25.2 0.15 36.2 30.5 ME60152V2-0000-A99 24 85 2.04 4700 21.9 0.12 32.5 30.5 * If you need special specification. Please contact Sunon sales. * Specifications are subject to change without notice. Specifications in this catalog are for reference. More Sunon products information please visit SUNON web site at http://www.sunon.com. *2010 / 05 / 31 04
EB40200S2-0000-999 价格&库存
很抱歉,暂时无法提供与“EB40200S2-0000-999”相匹配的价格&库存,您可以联系我们找货
