DHN-04F-T-V-T/R
DHN-04F-T-V-T/R
    DIPTRONICS(圜达)
    SMD8
    拨码开关 SMD8
DHN-04F-T-V-T/R 数据手册
ZITEM DESC. Q’TY 1. COVER 1 2. ACTUATOR 3. CONTACT 4. TERMINAL 5. BASE 6. TAPE c 1 MATERIALS HIGH – TEMP. THERMOPLASTIC NYLON UL94V-0 HIGH – TEMP. THERMOPLASTIC LCP TREATMENT REMARK MOLDED BLACK - MOLDED WHITE - PHOSPHOR BRONZE GOLD PLATED - BRASS GOLD PLATED - MOLEDE BLACK - - - HIGH – TEMP. THERMOPLASTIC NYLON UL94V-0 KATPON Prod. No.: D H N (F) - † † † F- †- V - † DHNF TERMINAL LENGTH 8.1 ㎜ Package Style: † = Tube DHN TERMINAL LENGTH 6.7 mm T/R= Tape & Reel V=Lead Free Number Of Position: 02 04 06 08 10 = 2 = 4 = 6 = 8 =10 Seal: †=Regular T =Top Tape Sealed F =in OFF position Position Position Position Position Position † =Gold 3u” MIN A =Gold 10u” MIN TITLE: HALF PITCH DIP SWITCH A DWG. REL. 邱明義 REV. ECO. NO. APPD. APPD. : 邱明義 CHKD. : 邱明義 RROD. NO.: DHN(F)-†††F-V PR. FILE NO. : E-V-CD19 : 蔡麗娟 REV : A SHEET : 1 of 1 P.3/3 DHN(F)-V SPECIFICATION FILE No. REV. Page : E-V-AD17 : A : 1 / 4 1. Style: This specification describes "WASHABLE OF DUAL IN-LINE PACKAGE SWITCHES", mainly used as signal switch of electric devices, with the general requirements of mechanical and electrical characteristics. 1.1 Operating Temperature Range : -40℃~+85℃ 1.2 Storage Temperature Range :-40℃~+85℃ 2. Current Range: 2.1 Non-Switching: 100mA, 50V DC 2.2 Switching: 25mA, 24V DC 3. Type of Actuation: Actuated by sliding 4. Test Sequence: MELECTRIC PERFORMANCE ITEM DESCRIPTION 1. Visual Examination 2. Contact Resistance 3. Insulation Resistance TEST CONDITIONS There shall be no By visual examination check without defects that affect the any out pressure & testing. serviceability of the product. 1)To be measured between the two terminals associated with each switch pole. 100mΩ max. (initial) 2)Measurements shall be made with a 1 kHz shall current contact resistance meter. 500 V DC , 1 minute±5 sec. 300 V AC (50Hz or 60 Hz) shall be Dielectric applied between all the adjacent 4. withstanding terminals and between the terminal Voltage and the frame for 1 minute. 5. Capacitance REQUIREMENTS 1MHz±10kHz 100MΩ min There shall be no breakdown or flashover. 5 pF max. DHN(F)-V SPECIFICATION FILE No. REV. Page : E-V-AD17 : A : 2 / 4 1)Applied in the direction of operation. ONÆOFF 30°~120° OFFÆON 6 500 gf max (4.9N max) Operation Force MECHANICAL PERFORMANCE 2)We suggest to operate the actuator at 30°~120° from Z direction and the force is 300gf max. and 10sec. max Stop 7 Strength 1 kgf is applied in the operating direction There shall be no sign of and pulling direction operated for a damage mechanically. period of 15 seconds. 1)Soldering Temperature : 8 Soldering Heat Resistance 9 Vibration 10 Shock PROD SMT TYPE TERMINAL SERIES TEMP 260±5℃ TIME 5~10sce 2)Duration of Solder Immersion: 5±1seconds. 3)Frequency of Solder Process: 1 times max. (PCB is 1.6 mm in thickness.) Shall be vibrated in accordance with Method 201A of MIL-STD-202F 1)Frequency: 10-55-10 Hz 1 min/cycle. 2)Direction: 3 vertical directions including the direction of operation 3)Test Time: 2 hours each direction. Shall be shocked in accordance with Method 213B Condition A of MIL-STD202F 1)Acceleration : 50G 2)Action Time : 11±1 m seconds 3)Testing Direction : 6 sides 4)Test cycle : 3 times in each direction 1)As shown in item 3~6 2)Contact Resistance: 2Ω max. (final-after test) 1)As shown in item 2~6 2)Contact Resistance: 2Ω max.) (final-after test) 1)As shown in item 2~6 2)Contact Resistance: 2Ω max. (final-after test) WEATHER-PROOF DURABILITY DHN(F)-V SPECIFICATION FILE No. REV. Page Measurements shall be made following the test set forth below: 1)25mA,24 V DC resistive load 11 Operation Life 2)Rate of Operation : 15~20 cycles/minute 3)Cycle of Operation : 1000 cycles Following the test set forth below the sample shall be left in normal temperature and humidity conditions Resistance Low for an hour before measurements are 12 Temperature made : 1)Temperature : -40±3℃ 2)Time : 96 hours : E-V-AD17 : A : 3 / 4 1)As shown in item 3,4 2)Contact Resistance: 2Ω max. (final-after test) 1)As shown in item 2~6 2)Contact Resistance: 2Ω max. (final-after test) Following the test set forth below the 1)As shown in item sample shall be left in normal 3~6 Resistance High temperature and humidity conditions for 13 2)Contact Resistance : an hour before measurements are made : Temperature 2Ωmax. 1)Temperature :85±2℃ (final-after test) 2)Time : 96 hours 14 Resistance Humidity 1)As shown in item Following the test set forth below the sample shall be left in normal 4~6 temperature and humidity conditions for 2)Contact Resistance : an hour before measurements are made : 2Ωmax. 1)Temperature : 40±2℃ 3)Insulation 2)Relative Humidity : 90~95% Resistance: 3)Time : 96 hours 10 MΩ min . DHN(F)-V SPECIFICATION 5. ƒ FILE No. REV. Page : E-V-AD17 : A : 4 / 4 SOLDERING CONDITIONS: Condition for Soldering MAX 260° 255° 230° 150° Room Temperature 120~150sec 5~10sec 60sec TIME(sec) ƒ The condition mentioned above is the temperature on the Cu foil of the PCB surface. There are cases where board's temperature greatly differs from switch's surface temperature depending on board's material, size, thickness, etc. Care, therefore, should be used not to allow switch's surface temperature to exceed 260℃. ƒ Manual Soldering Soldering Temperature Max,350℃ Continuous Soldering Time Max,5 seconds ƒ Precautions in Handling 1. Care should be exercised so that flux from the upper part of the printed circuit board does not adhere to the switch. 2. Don’t clean the switch body except with top tape sealed type, which can only spray of cleaning method from top of s/w. 3. Slide the DHN(F) actuator from Z axial direction with in 30°~120°of max 300 gf / 10 sec operation. 30°~12 4. The suggest tool for actuator adjust is as below. ( example for 4 position )
DHN-04F-T-V-T/R 价格&库存
很抱歉,暂时无法提供与“DHN-04F-T-V-T/R”相匹配的价格&库存,您可以联系我们找货
DHN-04F-T-V-T/R
  • 1+6.16070
  • 10+4.99880
  • 30+4.42230
  • 100+3.85900
  • 500+3.62460
  • 1000+3.44050
库存:5729
DHN-04F-T-V-T/R
库存:5181
