DT7926-XJ
DT7926-XJ
    DEWALT(得伟)
DT7926-XJ 数据手册
Drill Bit Set, Extreme-2, 29pc MPN: DT7926-XJ Kit Contents:  Drill bits – 1, 1.5, 2, 2.5, 3, 3.2, 3.5, 4, 4.2, 4.5, 4.8, 5, 5.5, 6, 6.5, 7, 7.5, 8, 8.5, 9, 9.5, 10, 10.5, 11, 11.5, 12, 12.5, 13mm Features:  Extreme-2™ metal tip drills on contact, eliminating ‘walking’ for accurate holes (Ø 3.2mm and over)  Innovative tapered web greatly reduces breakage  No-slip shank with 3 flats eliminates slipping in the chuck (Ø 5.0mm and above only)  Permanent size markings located above the shank for increased visibility (Ø 3.0mm and above only)  Up to 4 times faster drilling than standard HSS-R drill bits  Suitable for portable drilling of steel, alloyed and non-alloyed up to 900N/mm²  For drilling sheet or thin materials where accurate burr-free holes are required  Also suitable for use in wood and plastics http://www.dewalt.co.uk/
DT7926-XJ 价格&库存
很抱歉,暂时无法提供与“DT7926-XJ”相匹配的价格&库存,您可以联系我们找货
DT7926-XJ
    • 1+998.54118
    库存:91
