G2ASMA20
G2ASMA20
    TELE
    TELE - G2ASMA20 - Contactor, DIN Rail
G2ASMA20 数据手册
G2ASMA20 E1ZM Pump-Alternator - GAMMA series  Alternated access of two pumps or other devices  Even distribution of duty  Parallel duty at high demand  Operation using 1 or 2 input signals (two modes of operation)  Timing offset of the two loads to avoid water hammer effcects  Supply voltage selectable via TR2 power modules  2 separate change over relays for device control  Width 22.5mm  Industrial design Subject to alternations and errors Änderungen und Irrtümer vorbehalten  Technical data  1. Function One of two redundant motors will operate on demand signalised by input Y1. Successive requests will operate the motors in an alternating sequence (sharing the duty between the devices). On demand both devices (pumps) will operate in parallel: Mode A (parallel operation by separate input signal): Input Y2 initiates parallel operation. Without signal at input Y2, only one single motor will operate at each request. Mode B (parallel operation by timing): If an operation request on input Y1 exceeds the ajdusted delay, the unit will start the second motor for parallel operation.  2. Time ranges Adjusment range 2s 5min (use for mode B only) 2s fixed t1 (for parallel operation) t2 (offset timing)  3. Indicators Green LED U/t ON: Green LED U/t flashing: Red LED Failure: Yellow LED Rel. 1 ON/OFF: Yellow LED Rel. 2 ON/OFF: indication of supply voltage indication of time periode t1 or t2 irregular input; Y2 is activ while Y1 is off indication of relay output Rel. 1 indication of relay output Rel. 2  4. Mechanical design Self -extinguishing plastic housing, IP rating IP 40 Mounted on DIN-rail TS 35 according to EN 50022 Mounting position : any Shockproof terminal connection according to VBG 4 (PZ1 required) IP rating IP20 Tightening torque: 1 Nm max. Terminal capacity: 1 x 0.5 bis 2.5mm2 with/without multicore cable end 1 x 4mm2 without multicore cable end 2 x 0.5 bis 1.5mm2 with/without multicore cable end 2 x 2.5mm2 flexible without multicore cable end  7. Control inputs Y1 operation request: Y2 parallel operation: Potential free: Loadable: Control voltage: Schort circuit current: Wiring length: Coltrol pulse length :  8. Accuracy Adjustment accuracy (t1): Repetition accuracy:  9. Ambient conditions Ambient temperature: Storage temperature: Transport temperature: Relative humidity: Pollution degree: Vibration resistance:  5. Input circuit Supply voltage: 12 to 400V AC terminals A1-A2 (galvanically separated) selectable by powermodule typeTR2 according to specification of power module according to specification of power module 2VA (1.5W) 100% 500ms > 30% of nominal supply voltage III (according to IEC 60444-1) 4kV Tolerance: Rated frequency: Rated consumption: Duty cycle: Reset time: Residual ripple for DC: Drop out voltage: Overvoltage category: Rated surge voltage: 654 Version 04/05  6. Output circuit 2 potential free change over contacts Rated voltage: 250V AC Switching capacity (distance 5mm): 1250VA (5A / 250V) Fusing: 5A fast acting 6 Mechanical life: 20x10 operations Electrical life 2x105 operations at 1000VA resistive load Switching frequency: max. 60/min at 100VA at resistive load max. 6/min at 1000VA at resistive load according to IEC 947-5-1) Over-voltage category: III (according to IEC 60664-1) rated surge voltage: 4kV Shock resistance: activation by link Y1-Y3 activation by link Y2-Y3 (mode A only) yes, seperated from supply input and output circuit by basic insulation no 10V max. 1mA max. 10m max. 50ms min. ±5s in the Range up to 30s ±30s in the Range above 30s
G2ASMA20 价格&库存
很抱歉,暂时无法提供与“G2ASMA20”相匹配的价格&库存,您可以联系我们找货
