G2LM20 230VAC
G2LM20 230VAC
    TELE
    TELE - G2LM20 230VAC - LEVEL MONITORING, 230VAC
G2LM20 230VAC 数据手册
G2LM20 Level monitoring of conductive liquids Monitoring relays - GAMMA series Multifunction Secure isolation of the measuring circuit 2 change-over contacts Width 22.5mm Industrial design Technical data 1. Functions Level monitoring of conductive liquid, timing for tripping delay and turn-off delay separately adjustable and the following functions (selectable by means of rotary switch) Pump up pump up or minimum monitoring Pump down pump down or maximum monitoring 2. Time ranges Adjustment range Tripping delay (Delay ON): 0.5s 10s Turn-off delay (Delay OFF): 0.5s 10s 3. Indicators Green LED ON: Yellow LED ON/OFF: indication of supply voltage indication of relay output 4. Mechanical design Self-extinguishing plastic housing, IP rating IP40 Mounted on DIN-Rail TS 35 according to EN 60715 Mounting position: any Shockproof terminal connection according to VBG 4 (PZ1 required), IP rating IP20 Tightening torque: max. 1Nm Terminal capacity: 1 x 0.5 to 2.5mm² with/without multicore cable end 1 x 4mm² without multicore cable end 2 x 0.5 to 1.5mm² with/without multicore cable end 2 x 2.5mm² flexible without multicore cable end 5. Input circuit Supply voltage: 24V AC 110V AC 230V AC Tolerance: 24V AC 110V AC 230V AC Rated frequency: Rated consumption: 24V AC 110V AC 230V AC Duration of operation: Reset time: Residual ripple for DC: Drop-out voltage: Overvoltage category: Rated surge voltage: terminals A1-A2 (G2LM20 24VAC) terminals A1-A2 (G2LM20 110VAC) terminals A1-A2 (G2LM20 230VAC) -15% to +10% (G2LM20 24VAC) -15% to +10% (G2LM20 110VAC) -15% to +15% (G2LM20 230VAC) 48 to 63Hz 2VA (1.5W) (G2LM20 24VAC) 2VA (1.5W) (G2LM20 110VAC) 2VA (1.5W) (G2LM20 230VAC) 100% 500ms >30% of the supply voltage III (in accordance with IEC 60664-1) 4kV Fusing: Mechanical life: Electrical life: Switching frequency: Overvoltage category: Rated surge voltage: 5A fast acting 20 x 106 Operations 2 x 105 Operations at 1000VA resistive load max. 60/min at 100VA resistive load max. 6/min at 1000VA resistive load (in accordance with IEC 60947-5-1) III (in accordance with IEC 60664-1) 4kV 7. Measuring circuit Input: conductive probes (type SK1, SK2, SK3) terminals E1-E2-E3 Sensitivity: 0.25 to 100kΩ (4mS to 10µS) Sensor voltage: 12V AC Sensor current: max. 7mA Wiring distance (capacity of cable 100nF/km): max. 1000m (set value
G2LM20 230VAC
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。 3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚发光二极管正极,4脚发光二极管负极,5脚集电极,6脚发射极。 4. 参数特性:EL817的主要参数包括正向电流为50mA,反向电压为5V,输入电流为10mA,输出电流为10mA。 5. 功能详解:EL817通过光电效应实现电信号的隔离传输,输入端控制发光二极管发光,光敏三极管导通实现信号传输。 6. 应用信息:EL817广泛应用于工业控制系统、仪器仪表、通信设备等领域,实现信号隔离和保护。 7. 封装信息:EL817采用DIP-6封装,尺寸为9.1mm x 3.6mm x 3.9mm。
G2LM20 230VAC 价格&库存
很抱歉,暂时无法提供与“G2LM20 230VAC”相匹配的价格&库存,您可以联系我们找货
