G2ZI20
G2ZI20
    TELE
G2ZI20 数据手册
Timer - Multifunctional G2ZI20 GAMMA series 6 Functions 7 time ranges Wide supply voltage range 2 change over contacts Width 22.5 mm Industrial design Technical data 1. Functions Ip Asymmetric flasher pause first Ii Asymmetric flasher pulse first ER ON delay and OFF delay with control input EWu ON delay and single shot leading edge with control input EWs ON delay single shot leading edge voltage controlled WsWa Single shot leading and single shot trailling edge with control contact 2. Time ranges Time range Adjustment range 1s 50ms 1s 10s 500ms 10s 1min 3s 1min 10min 30s 10min 1h 3min 1h 10h 30min 10h 100h 5h 100h 7. Control contact Input not potential free: terminals A1-B1 Loadable: yes Max. line length: 10m Trigger level (sensitivity): automatic adaption to supply voltage Min. control pulse length: DC 50 ms / AC 100 ms 3. Indication Green LED U/t ON: indication of supply voltage Green LED U/t slow flashing: indication of time period t1 Green LED U/t fast flashing: indication of time period t2 Yellow LED R ON/OFF: indication of relay output 4. Mechanical design Self-extinguishing plastic housing, IP rating IP40 Mounted DIN-rail TS 35 according to EN 50022 Mounting position: any Shockproof terminal connection according to VBG 4 (PZ1 required), IP rating IP20 Tightening torque: max. 1Nm Terminal capacity: 1 x 0.5 to 2.5mm² with/without multicore cable end 1 x 4mm² without multicore cable end 2 x 0.5 to 1.5mm² with/without multicore cable end 2 x 2.5mm² flexible without multicore cable end 5. Input circuit Supply voltage: Types G2Z..12-240VAC/DC: Tolerance: Rated consumption: Rated frequency: Duty cycle: Reset time: Residual ripple of DC: Drop out voltage: Overvoltage category: Rated surge voltage: 6. Output circuit 2 potential free change over contacts Rated surge 250V AC Switching capacity (distance 5mm): 1250V (5A / 250V AC) Fusing: 5A fast acting Mechanical life: 20 x 106 operations Electrical life: 2 x 105 operations at 1000VA resistive load Switching frequency: max. 60/min at 100VA resistive load max. 6/min at 1000VA resistive load (according to IEC 947-5-1) Overvoltage category: III. (according to IEC 60664-1) Rated surge voltage: 4kV terminals A1(+)-A2 12 to 240V AC/DC 12V-10% to 240V+10% 6VA (2W) AC 48 to 63Hz 100% 100ms 10% >30% minimum rated supply voltage III (according to IEC 60664-1) 4kV 8. Accuracy Base accuracy: Adjusting accuracy: Repedition accuracy: Voltage influence: Temperature influence: ±1% of maximum scale value
G2ZI20 价格&库存
很抱歉,暂时无法提供与“G2ZI20”相匹配的价格&库存,您可以联系我们找货
