G2PF400VS02
G2PF400VS02
    TELE
G2PF400VS02 数据手册
Voltage monitoring in 3-phase mains G2PF...S02 Monitoring relays - GAMMA series Monitoring of phase sequence and phase failure Detection of reverse voltage Connection of neutral wire optional Supply voltage = measuring voltage 2 change-over contacts Width 22.5mm Industrial design Technical data 1. Functions Monitoring of phase sequence, phase failure and detection of return voltage (by means of evaluating the asymmetry) 2. Time ranges Start-up suppression time: Tripping delay: Adjustment range fixed, max. 500ms fixed, max. 350ms 3. Indicators Green LED ON: Yellow LED ON/OFF: indication of supply voltage indication of relay output 4. Mechanical design Self-extinguishing plastic housing, IP rating IP40 Mounted on DIN-Rail TS 35 according to EN 60715 Mounting position: any Shockproof terminal connection according to VBG 4 (PZ1 required), IP rating IP20 Tightening torque: max. 1Nm Terminal capacity: 1 x 0.5 to 2.5mm² with/without multicore cable end 1 x 4mm² without multicore cable end 2 x 0.5 to 1.5mm² with/without multicore cable end 2 x 2.5mm² flexible without multicore cable end 5. Input circuit Supply voltage: 3(N)~ 115/66V 3(N)~ 230/132V 3(N)~ 400/230V Tolerance: 3(N)~ 115/66V 3(N)~ 230/132V 3(N)~ 400/230V Rated frequency: Rated consumption: 3(N)~ 115/66V 3(N)~ 230/132V 3(N)~ 400/230V Duration of operation: Reset time: Residual ripple for DC: Drop-out voltage: Overvoltage category: Rated surge voltage: terminals (N)-L1-L2-L3 (G2PF115VS02) (= measuring voltage) terminals (N)-L1-L2-L3 (G2PF230VS02) (= measuring voltage) terminals (N)-L1-L2-L3 (G2PF400VS02) (= measuring voltage) 3(N)~ 99 to 132V (G2PF115VS02) 3(N)~ 198 to 264V (G2PF230VS02) 3(N)~ 342 to 457V (G2PF400VS02) 48 to 63Hz 3VA (G2PF115VS02) 6VA (G2PF230VS02) 9VA (G2PF400VS02) 100% 20% of the supply voltage III (in accordance with IEC 60664-1) 4kV Mechanical life: Electrical life: Switching frequency: Overvoltage category: Rated surge voltage: 7. Measuring circuit Measured variable: Input: 3(N)~ 115/66V 3(N)~ 230/132V 3(N)~ 400/230V Overload capacity: 3(N)~ 115/66V 3(N)~ 230/132V 3(N)~ 400/230V Input resistance: 3(N)~ 115/66V 3(N)~ 230/132V 3(N)~ 400/230V 20 x 106 operations 2 x 105 operations at 1000VA resistive load max. 60/min at 100VA resistive load max. 6/min at 1000VA resistive load (in accordance with IEC 60947-5-1) III (in accordance with IEC 60664-1) 4kV AC Sinus, 48 to 63Hz terminals (N)-L1-L2-L3 (G2PF115VS02) (= supply voltage) terminals (N)-L1-L2-L3 (G2PF230VS02) (= supply voltage) terminals (N)-L1-L2-L3 (G2PF400VS02) (= supply voltage) 3(N)~ 132/76V (G2PF115VS02) 3(N)~ 264/152V (G2PF230VS02) 3(N)~ 457/264V (G2PF400VS02) 5kΩ (G2PF115VS02) 10kΩ (G2PF230VS02) 15kΩ (G2PF400VS02) Asymmetry: Overvoltage category: Rated surge voltage: fixed, typ. 30% III (according to IEC 60664-1) 4kV 8. Accuracy Base accuracy: Frequency response: Adjustment accuracy: Repetition accuracy: Voltage influence: Temperature influence: ≤3% (of maximum scale value) ≤2% ≤0.05% / °C 9. Ambient conditions Ambient temperature: Storage temperature: Transport temperature: Relative humidity: Pollution degree: Vibration resistance: Shock resistance: -25 to +55°C (in accordance with IEC 60068-1) -25 to +40°C (in accordance with UL 508) -25 to +70°C -25 to +70°C 15% to 85% (in accordance with IEC 60721-3-3 class 3K3) 3 (in accordance with IEC 60664-1) 10 to 55Hz 0.35mm (in accordance with IEC 60068-2-6) 15g 11ms (in accordance with IEC 60068-2-27) 6. Output circuit 2 potential free change-over contacts Rated voltage: 250V AC Switching capacity (distance 5mm): 1250VA (5A / 250V AC) Fusing: 5A fast acting www.tele-online.com G2PF...S02 Functions Connections Phase sequence monitoring When all the phases are connected in the correct sequence and the measured asymmetry is less than the fixed value, the output relays switch into on-position (yellow LED illuminated). When the phase sequence changes, the output relays switch into off-position (yellow LED not illuminated). Detection of reverse voltage (by means of evaluation of asymmetry) The output relays switch into off-position (yellow LED not illuminated) when the asymmetry between the phase voltages exceeds the fixed value of the asymmetry. An asymmetry caused by the reverse voltage of a consumer (e.g. a motor which continues to run on two phases only) does not effect the disconnection. Dimensions Phase failure monitoring When one of the three phases fails, the output relays switch into off-position (yellow LED not illuminated). RELEASE 2009/07 Subject to alterations and errors www.tele-online.com
G2PF400VS02
- 物料型号:G2PF...S02 - 器件简介:该继电器用于监控三相电源的相序和相位故障,检测反向电压,并且可以选择性地连接中性线。供电电压等于测量电压,具有2个转换接点,宽度为22.5mm,采用工业设计。 - 引脚分配:文档中提到了不同电压等级的输入端子分配,例如G2PF115VS02型号的输入端子为3(N)~ 115/66V,对应L1、L2、L3。 - 参数特性:包括电气寿命、机械寿命、过电压类别、额定浪涌电压、输入电路的供电电压和频率、不对称性、测量电路的测量变量等。 - 功能详解:包括相序监控、反向电压检测和相位故障监控。例如,当所有相位正确连接且测量不对称性小于固定值时,继电器输出接点切换到开位置。 - 应用信息:适用于工业环境中的三相电源监控。 - 封装信息:自熄性塑料外壳,IP等级为IP40,可安装在DIN导轨上,具有防震端子连接。
G2PF400VS02 价格&库存
很抱歉,暂时无法提供与“G2PF400VS02”相匹配的价格&库存,您可以联系我们找货
