ECC30DRXN
ECC30DRXN
    SULLINS
    CONN EDGECARD 60POS DIP .100 SLD
ECC30DRXN 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO NO. DESCRIPTION DATE BY M 4551 ADD POSITION 24 8/24/2022 MM N 4524 ADD POSITION 02, 09, 16, 59 2/23/2023 MM P 4762 ADD C14008 TO P/N CODING, REMOVE S73, S1860 2/1/2024 JH E D B A F 2X .125 3.18 THRU F .075[1.90] CARD SLOT SEE NOTE 13 .100 2.54 F E E C .030 0.76 A .265 6.73 INSERTION DEPTH .431 10.95 .245 6.22 D .032 0.81 X .007[0.18] _ _ C _ _ DRXH _ _ C _ _ DRJH .025 0.64 A D TAIL LENGTH RX= .185±.025 4.70±0.64 RJ = .165 .025[4.19 0.64] RX= .200 5.08 RJ= .250[6.35] SECTION A - A A .100 2.54 A NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING 2. CONTACT MATERIAL: SEE PART NUMBER CODING 3. PLATING: SEE PART NUMBER CODING 4. OPERATING TEMPERATURE: SEE PART NUMBER CODING 5. PROCESSING TEMP: SEE PART NUMBER CODING 6. UL FLAMMABILITY RATING: 94V-0 7. OPERATING VOLTAGE: 700 VAC 8. CURRENT RATING: 3 AMP 9. CONTACT RESISTANCE: 30 MILLI OHMS MAX 10. INSULATION RESISTANCE: 5000 MEGA OHMS 11. DURABILITY: 500 CYCLES MINIMUM 12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE 13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20] 14. INSERTION FORCE: 16 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE INTERNAL INSPECTION TO BE PER SULLINS WORK INSTRUCTION WI-8.6-03 15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062[1.57] TEST BLADE 16. MODIFICATION: SEE PART NUMBER CODING 8 7 6 C 2X .125 3.18 FOR H, I OR F MOUNTING .043 1.09 MIN RECOMMENDED PCB LAYOUT B CONTACT IDs: B 1 2 3 ... 60 B A 1 2 3 ... 60 A ROW SPACING RX = .200 5.08 RJ = .250 [6.35] D C 5 B CONTACT ID SCALE 6:1 CUSTOMER COPY Pb RoHS COMPLIANT UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 6/14/2012 JH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER _ _ C _ _ D(RX,RJ)_-(S38, S81, S328, S1098) SIZE C CAGE CODE 54453 SCALE: 2:1 4 3 A EDGECARD, .100 CC LP 2 DWG. NO. C10881 REV P SHEET 1 OF 3 1 FILE NAME: C10881, _ _C_ _D(RX,RJ)_-OMIT, S38, S81, S328, S1098, S_ _ _ _ MOLDED KEY 8 7 5 6 4 1 2 3 F F C 2X D .125 3.18 THRU 2X .135 3.43 E _ _ C _ _ DRXN _ _ C _ _ DRJN E _ _ C _ _ DRXS _ _ C _ _ DRJS 2X #4-40 THREADED INSERTS 2X FLOATING BOBBIN .116 [2.95] CLEARANCE FOR # 4 SCREW D D .280 7.11 _ _ C _ _ DRXI _ _ C _ _ DRJI C _ _ C _ _ DRXF _ _ C _ _ DRJF A B C 2X .065 1.65 B L±.015[0.38] (L= DIM 'A' + .130[3.30]) CUSTOMER COPY _ _ C _ _ DRXB _ _ C _ _ DRJB A Pb RoHS COMPLIANT UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 6/14/2012 JH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER _ _ C _ _ D(RX,RJ)_-(S38, S81, S328, S1098) SIZE C CAGE CODE 54453 SCALE: 2.5:1 8 7 6 5 4 3 A EDGECARD, .100 CC LP 2 DWG. NO. C10881 REV P SHEET 2 OF 3 1 FILE NAME: C10881, _ _C_ _D(RX,RJ)_-OMIT, S38, S81, S328, S1098, S_ _ _ _ MOLDED KEY 8 F E D PART NUMBER _ _ C02D(RX,RJ)_ _ _ C03D(RX,RJ)_ _ _ C04D(RX,RJ)_ _ _ C05D(RX,RJ)_ _ _ C06D(RX,RJ)_ _ _ C07D(RX,RJ)_ _ _ C08D(RX,RJ)_ _ _ C09D(RX,RJ)_ _ _ C10D(RX,RJ)_ _ _ C12D(RX,RJ)_ _ _ C13D(RX,RJ)_ _ _ C14D(RX,RJ)_ _ _ C15D(RX,RJ)_ _ _ C16D(RX,RJ)_ _ _ C17D(RX,RJ)_ _ _ C18D(RX,RJ)_ _ _ C19D(RX,RJ)_ _ _ C20D(RX,RJ)_ _ _ C22D(RX,RJ)_ _ _ C23D(RX,RJ)_ _ _ C24D(RX,RJ)_ _ _ C25D(RX,RJ)_ _ _ C26D(RX,RJ)_ _ _ C28D(RX,RJ)_ _ _ C29D(RX,RJ)_ _ _ C30D(RX,RJ)_ _ _ C31D(RX,RJ)_ _ _ C32D(RX,RJ)_ _ _ C35D(RX,RJ)_ _ _ C36D(RX,RJ)_ _ _ C40D(RX,RJ)_ _ _ C41D(RX,RJ)_ _ _ C43D(RX,RJ)_ _ _ C44D(RX,RJ)_ _ _ C49D(RX,RJ)_ _ _ C50D(RX,RJ)_ _ _ C52D(RX,RJ)_ _ _ C59D(RX,RJ)_ _ _ C60D(RX,RJ)_ _ _ C65D(RX,RJ)_ _ _ C70D(RX,RJ)_ 7 NO. OF POS. 2 3 4 5 6 7 8 9 10 12 13 14 15 16 17 18 19 20 22 23 24 25 26 28 29 30 31 32 35 36 40 41 43 44 49 50 52 59 60 65 70 A±.008[0.20] IN MM 0.100 2.54 0.200 5.08 0.300 7.62 0.400 10.16 0.500 12.70 0.600 15.24 0.700 17.78 0.800 20.32 0.900 22.86 1.100 27.94 1.200 30.48 1.300 33.02 1.400 35.56 1.500 38.10 1.600 40.64 1.700 43.18 1.800 45.72 1.900 48.26 2.100 53.34 2.200 55.88 2.300 58.42 2.400 60.96 2.500 63.50 2.700 68.58 2.800 71.12 2.900 73.66 3.000 76.20 3.100 78.74 3.400 86.36 3.500 88.90 3.900 99.06 4.000 101.60 4.200 106.68 4.300 109.22 4.800 121.92 4.900 124.46 5.100 129.54 5.800 147.32 5.900 149.86 6.400 162.56 6.900 175.26 C±.015[0.38] IN MM 0.475 12.07 0.575 14.61 0.675 17.15 0.775 19.69 0.875 22.23 0.975 24.77 1.075 27.31 1.175 29.85 1.275 32.39 1.475 37.47 1.575 40.01 1.675 42.55 1.775 45.09 1.875 47.63 1.975 50.17 2.075 52.71 2.175 55.25 2.275 57.79 2.475 62.87 2.575 65.41 2.675 67.95 2.775 70.49 2.875 73.03 3.075 78.11 3.175 80.65 3.275 83.19 3.375 85.73 3.475 88.27 3.775 95.89 3.875 98.43 4.275 108.59 4.375 111.13 4.575 116.21 4.675 118.75 5.175 131.45 5.275 133.99 5.475 139.07 6.175 156.85 6.275 159.39 6.775 172.09 7.275 184.79 4 5 6 B±.008[0.20] IN MM 0.300 7.62 0.400 10.16 0.500 12.70 0.600 15.24 0.700 17.78 0.800 20.32 0.900 22.86 1.000 25.40 1.100 27.94 1.300 33.02 1.400 35.56 1.500 38.10 1.600 40.64 1.700 43.18 1.800 45.72 1.900 48.26 2.000 50.80 2.100 53.34 2.300 58.42 2.400 60.96 2.500 63.50 2.600 66.04 2.700 68.58 2.900 73.66 3.000 76.20 3.100 78.74 3.200 81.28 3.300 83.82 3.600 91.44 3.700 93.98 4.100 104.14 4.200 106.68 4.400 111.76 4.500 114.30 5.000 127.00 5.100 129.54 5.300 134.62 6.000 152.40 6.100 154.94 6.600 167.64 7.100 180.34 D±.010[0.25] IN MM 0.775 19.69 0.875 22.23 0.975 24.77 1.075 27.31 1.175 29.85 1.275 32.39 1.375 34.93 1.475 37.47 1.575 40.01 1.775 45.09 1.875 47.63 1.975 50.17 2.075 52.71 2.175 55.25 2.275 57.79 2.375 60.33 2.475 62.87 2.575 65.41 2.775 70.49 2.875 73.03 2.975 75.57 3.075 78.11 3.175 80.65 3.375 85.73 3.475 88.27 3.575 90.81 3.675 93.35 3.775 95.89 4.075 103.51 4.175 106.05 4.575 116.21 4.675 118.75 4.875 123.83 4.975 126.37 5.475 139.07 5.575 141.61 5.775 146.69 6.475 164.47 6.575 167.01 7.075 179.71 7.575 192.41 E±.020[0.51] IN MM 1.075 27.31 1.175 29.85 1.275 32.39 1.375 34.93 1.475 37.47 1.575 40.01 1.675 42.55 1.775 45.09 1.875 47.63 2.075 52.71 2.175 55.25 2.275 57.79 2.375 60.33 2.475 62.87 2.575 65.41 2.675 67.95 2.775 70.49 2.875 73.03 3.075 78.11 3.175 80.65 3.275 83.19 3.375 85.73 3.475 88.27 3.675 93.35 3.775 95.89 3.875 98.43 3.975 100.97 4.075 103.51 4.375 111.13 4.475 113.67 4.875 123.83 4.975 126.37 5.175 131.45 5.275 133.99 5.775 146.69 5.875 149.23 6.075 154.31 6.775 172.09 6.875 174.63 7.375 187.33 7.875 200.03 F KEY IN POSITION .070±.002 1.78±0.05 0.330 8.38 G E ('H' MOUNTING AS SHOWN FOR EXAMPLE) 0.400 KEY BETWEEN POSITIONS .030±.002 0.76±0.05 MATERIAL (INSULATOR/CONTACT) B A E = BLUE PBT/PHOSPHOR BRONZE OPERATING TEMP: -65°C TO +125°C PROCESSING TEMP: WAVE/ MANUAL SOLDERING ONLY R = GREEN PPS/PHOSPHOR BRONZE OPERATING TEMP: -65°C TO +125°C PROCESSING TEMP: 260°C MAX FOR 20 SECONDS G = BLACK PA9T/PHOSPHOR BRONZE OPERATING TEMP: -65°C TO +125°C PROCESSING TEMP: 260°C MAX FOR 20 SECONDS H = BLUE PBT/BERYLLIUM COPPER OPERATING TEMP: -65°C TO +125°C PROCESSING TEMP: WAVE/ MANUAL SOLDERING ONLY A = GREEN PPS/BERYLLIUM COPPER OPERATING TEMP: -65°C TO +150°C PROCESSING TEMP: 260°C MAX FOR 20 SECONDS J = BLACK PA9T/BERYLLIUM COPPER OPERATING TEMP: -65°C TO +150°C PROCESSING TEMP: 260°C MAX FOR 20 SECONDS F = GREEN PPS/SPINODAL (CONSULT FACTORY) OPERATING TEMP: -65°C TO +200°C (CONSULT FACTORY FOR SPECIAL SOLDERING GUIDELINES) AVAILABLE IN OVERALL GOLD ONLY (S OR M PLATING CODE) C = GREEN PPS/BERYLLIUM NICKEL (CONSULT FACTORY) OPERATING TEMP: -65°C TO +200°C PROCESSING TEMP: 260°C MAX FOR 20 SECONDS AVAILABLE IN OVERALL GOLD ONLY (S OR M PLATING CODE) X = TAN PEEK/SPINODAL (CONSULT FACTORY) OPERATING TEMP: -65°C TO +200°C (CONSULT FACTORY FOR SPECIAL SOLDERING GUIDELINES) AVAILABLE IN OVERALL GOLD ONLY (S OR M PLATING CODE) W = TAN PEEK/BERYLLIUM NICKEL (CONSULT FACTORY) OPERATING TEMP: -65°C TO +250°C PROCESSING TEMP: 260°C MAX FOR 20 SECONDS AVAILABLE IN OVERALL M PLATING ONLY MODIFICATION CODE C OMIT = STANDARD WITHOUT MOLDED KEY, EX: 'EBC22DRXH' S38 = BLACK PBT WITHOUT MOLDED KEY (MATERIAL CODES 'E' OR 'H' ONLY) S81 = GREEN PBT WITHOUT MOLDED KEY (MATERIAL CODES 'E' OR 'H' ONLY) S328 = BROWN PPS WITHOUT MOLDED KEY (MATERIAL CODES 'R', 'A', 'F', OR 'C' ONLY) S1098 = BLACK PPS WITHOUT MOLDED KEY (MATERIAL CODES 'R', 'A', 'F', OR 'C' ONLY) SEE KEY LOCATION DRAWINGS FOR MODIFICATION NUMBER (S#), 'G' AND 'H' DIMENSION: DRAWING C13556 FOR STANDARD COLOR DRAWING C14008 FOR NON-STANDARD COLOR H MOUNTING STYLE H = .125" DIA. CLEARANCE HOLES N = NO MOUNTING EARS S = .125" DIA. SIDE MOUNTING I = #4-40 THREADED INSERT F = FLOATING BOBBIN B = OPEN CARDSLOT B TERMINATION RX = RJ = .200[5.08] ROW SPACING X .185[4.70] DIP SOLDER TAIL LENGTH .250[6.35] ROW SPACING X .165[4.19] DIP SOLDER TAIL LENGTH (SEE SECTION A-A ON PAGE 1) ('H' MOUNTING AS SHOWN FOR EXAMPLE) NUMBER OF POSITIONS PLATING CUSTOMER COPY (CONTACTS PER ROW) ALL PLATINGS HAVE .000050" NICKEL UNDERPLATE CONTACT SURFACE TERMINATION B = .000010" GOLD .000100" PURE TIN, MATTE C = .000030" GOLD .000100" PURE TIN, MATTE G = .000010" GOLD .000005" GOLD Y = .000030" GOLD .000005" GOLD S = .000010" GOLD .000010" GOLD OVERALL M = .000030" GOLD .000010" GOLD OVERALL *E = .000100" PURE TIN, MATTE .000100" PURE TIN, MATTE OVERALL *OVERALL TIN ONLY AVAILABLE ON MATERIAL CODES E, R, & G Pb RoHS COMPLIANT UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 6/14/2012 JH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE 7 6 5 4 3 A EDGECARD, .100 CC LP PART NUMBER _ _ C _ _ D(RX,RJ)_-(S38, S81, S328, S1098) SIZE C CAGE CODE 54453 SCALE: 3:1 8 D 10.16 PART NUMBER CODING _ _ C _ _ D_ _ _ -S_ _ _ _ C 1 2 3 F+.005/-.015[+0.13/-0.38] IN MM 2 DWG. NO. C10881 REV P SHEET 3 OF 3 1 FILE NAME: C10881, _ _C_ _D(RX,RJ)_-OMIT, S38, S81, S328, S1098, S_ _ _ _ MOLDED KEY
ECC30DRXN 价格&库存
很抱歉,暂时无法提供与“ECC30DRXN”相匹配的价格&库存,您可以联系我们找货
