8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO NO.
DESCRIPTION
DATE
BY
M
4551
ADD POSITION 24
8/24/2022
MM
N
4524
ADD POSITION 02, 09, 16, 59
2/23/2023
MM
P
4762
ADD C14008 TO P/N CODING, REMOVE S73, S1860
2/1/2024
JH
E
D
B
A
F
2X
.125 3.18
THRU
F
.075[1.90]
CARD SLOT
SEE NOTE 13
.100 2.54
F
E
E
C
.030 0.76
A
.265 6.73
INSERTION
DEPTH
.431 10.95
.245 6.22
D
.032 0.81 X .007[0.18]
_ _ C _ _ DRXH
_ _ C _ _ DRJH
.025 0.64
A
D
TAIL LENGTH
RX= .185±.025 4.70±0.64
RJ = .165 .025[4.19 0.64]
RX= .200 5.08
RJ= .250[6.35]
SECTION A - A
A
.100 2.54
A
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING
2. CONTACT MATERIAL: SEE PART NUMBER CODING
3. PLATING: SEE PART NUMBER CODING
4. OPERATING TEMPERATURE: SEE PART NUMBER CODING
5. PROCESSING TEMP: SEE PART NUMBER CODING
6. UL FLAMMABILITY RATING: 94V-0
7. OPERATING VOLTAGE: 700 VAC
8. CURRENT RATING: 3 AMP
9. CONTACT RESISTANCE: 30 MILLI OHMS MAX
10. INSULATION RESISTANCE: 5000 MEGA OHMS
11. DURABILITY: 500 CYCLES MINIMUM
12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20]
14. INSERTION FORCE: 16 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE
INTERNAL INSPECTION TO BE PER SULLINS WORK INSTRUCTION WI-8.6-03
15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062[1.57] TEST BLADE
16. MODIFICATION: SEE PART NUMBER CODING
8
7
6
C
2X .125 3.18
FOR H, I OR F
MOUNTING
.043 1.09 MIN
RECOMMENDED PCB LAYOUT
B
CONTACT IDs:
B 1 2 3 ... 60 B
A 1 2 3 ... 60 A
ROW SPACING
RX = .200 5.08
RJ = .250 [6.35]
D
C
5
B
CONTACT ID
SCALE 6:1
CUSTOMER COPY
Pb
RoHS COMPLIANT
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
DIMENSIONS ARE IN INCHES [MM]
6/14/2012 JH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
THE INFORMATION HEREIN CONTAINS
PROPRIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
PART NUMBER
_ _ C _ _ D(RX,RJ)_-(S38, S81, S328, S1098)
SIZE
C
CAGE CODE
54453
SCALE: 2:1
4
3
A
EDGECARD, .100 CC LP
2
DWG. NO.
C10881
REV
P
SHEET 1 OF 3
1
FILE NAME: C10881, _ _C_ _D(RX,RJ)_-OMIT, S38, S81, S328, S1098, S_ _ _ _ MOLDED KEY
8
7
5
6
4
1
2
3
F
F
C
2X
D
.125 3.18 THRU
2X .135 3.43
E
_ _ C _ _ DRXN
_ _ C _ _ DRJN
E
_ _ C _ _ DRXS
_ _ C _ _ DRJS
2X #4-40
THREADED INSERTS
2X FLOATING BOBBIN
.116 [2.95] CLEARANCE
FOR # 4 SCREW
D
D
.280 7.11
_ _ C _ _ DRXI
_ _ C _ _ DRJI
C
_ _ C _ _ DRXF
_ _ C _ _ DRJF
A
B
C
2X .065 1.65
B
L±.015[0.38]
(L= DIM 'A' + .130[3.30])
CUSTOMER COPY
_ _ C _ _ DRXB
_ _ C _ _ DRJB
A
Pb
RoHS COMPLIANT
6/14/2012 JH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2.5:1
8
7
6
5
4
3
A
2
DWG. NO.
C10881
REV
P
SHEET 2 OF 3
1
8
F
E
D
PART
NUMBER
_ _ C02D(RX,RJ)_
_ _ C03D(RX,RJ)_
_ _ C04D(RX,RJ)_
_ _ C05D(RX,RJ)_
_ _ C06D(RX,RJ)_
_ _ C07D(RX,RJ)_
_ _ C08D(RX,RJ)_
_ _ C09D(RX,RJ)_
_ _ C10D(RX,RJ)_
_ _ C12D(RX,RJ)_
_ _ C13D(RX,RJ)_
_ _ C14D(RX,RJ)_
_ _ C15D(RX,RJ)_
_ _ C16D(RX,RJ)_
_ _ C17D(RX,RJ)_
_ _ C18D(RX,RJ)_
_ _ C19D(RX,RJ)_
_ _ C20D(RX,RJ)_
_ _ C22D(RX,RJ)_
_ _ C23D(RX,RJ)_
_ _ C24D(RX,RJ)_
_ _ C25D(RX,RJ)_
_ _ C26D(RX,RJ)_
_ _ C28D(RX,RJ)_
_ _ C29D(RX,RJ)_
_ _ C30D(RX,RJ)_
_ _ C31D(RX,RJ)_
_ _ C32D(RX,RJ)_
_ _ C35D(RX,RJ)_
_ _ C36D(RX,RJ)_
_ _ C40D(RX,RJ)_
_ _ C41D(RX,RJ)_
_ _ C43D(RX,RJ)_
_ _ C44D(RX,RJ)_
_ _ C49D(RX,RJ)_
_ _ C50D(RX,RJ)_
_ _ C52D(RX,RJ)_
_ _ C59D(RX,RJ)_
_ _ C60D(RX,RJ)_
_ _ C65D(RX,RJ)_
_ _ C70D(RX,RJ)_
7
NO. OF
POS.
2
3
4
5
6
7
8
9
10
12
13
14
15
16
17
18
19
23
24
25
26
28
29
30
31
32
35
36
40
41
43
44
49
50
52
59
60
65
70
A±.008[0.20]
IN
MM
0.100
2.54
0.200
5.08
0.300
7.62
0.400 10.16
0.500 12.70
0.600 15.24
0.700 17.78
0.800 20.32
0.900 22.86
1.100 27.94
1.200 30.48
1.300 33.02
1.400 35.56
1.500 38.10
1.600 40.64
1.700 43.18
1.800 45.72
1.900 48.26
2.100 53.34
2.200 55.88
2.300 58.42
2.400 60.96
2.500 63.50
2.700 68.58
2.800 71.12
2.900 73.66
3.000 76.20
3.100 78.74
3.400 86.36
3.500 88.90
3.900 99.06
4.000 101.60
4.200 106.68
4.300 109.22
4.800 121.92
4.900 124.46
5.100 129.54
5.800 147.32
5.900 149.86
6.400 162.56
6.900 175.26
C±.015[0.38]
IN
MM
0.475
12.07
0.575
14.61
0.675
17.15
0.775
19.69
0.875
22.23
0.975
24.77
1.075
27.31
1.175
29.85
1.275
32.39
1.475
37.47
1.575
40.01
1.675
42.55
1.775
45.09
1.875
47.63
1.975
50.17
2.075
52.71
2.175
55.25
2.275
57.79
2.475
62.87
2.575
65.41
2.675
67.95
2.775
70.49
2.875
73.03
3.075
78.11
3.175
80.65
3.275
83.19
3.375
85.73
3.475
88.27
3.775
95.89
3.875
98.43
4.275
108.59
4.375
111.13
4.575
116.21
4.675
118.75
5.175
131.45
5.275
133.99
5.475
139.07
6.175
156.85
6.275
159.39
6.775
172.09
7.275
184.79
4
5
6
B±.008[0.20]
IN
MM
0.300
7.62
0.400
10.16
0.500
12.70
0.600
15.24
0.700
17.78
0.800
20.32
0.900
22.86
1.000
25.40
1.100
27.94
1.300
33.02
1.400
35.56
1.500
38.10
1.600
40.64
1.700
43.18
1.800
45.72
1.900
48.26
2.000
50.80
2.100
53.34
2.300
58.42
2.400
60.96
2.500
63.50
2.600
66.04
2.700
68.58
2.900
73.66
3.000
76.20
3.100
78.74
3.200
81.28
3.300
83.82
3.600
91.44
3.700
93.98
4.100
104.14
4.200
106.68
4.400
111.76
4.500
114.30
5.000
127.00
5.100
129.54
5.300
134.62
6.000
152.40
6.100
154.94
6.600
167.64
7.100
180.34
D±.010[0.25]
IN
MM
0.775
19.69
0.875
22.23
0.975
24.77
1.075
27.31
1.175
29.85
1.275
32.39
1.375
34.93
1.475
37.47
1.575
40.01
1.775
45.09
1.875
47.63
1.975
50.17
2.075
52.71
2.175
55.25
2.275
57.79
2.375
60.33
2.475
62.87
2.575
65.41
2.775
70.49
2.875
73.03
2.975
75.57
3.075
78.11
3.175
80.65
3.375
85.73
3.475
88.27
3.575
90.81
3.675
93.35
3.775
95.89
4.075
103.51
4.175
106.05
4.575
116.21
4.675
118.75
4.875
123.83
4.975
126.37
5.475
139.07
5.575
141.61
5.775
146.69
6.475
164.47
6.575
167.01
7.075
179.71
7.575
192.41
E±.020[0.51]
IN
MM
1.075
27.31
1.175
29.85
1.275
32.39
1.375
34.93
1.475
37.47
1.575
40.01
1.675
42.55
1.775
45.09
1.875
47.63
2.075
52.71
2.175
55.25
2.275
57.79
2.375
60.33
2.475
62.87
2.575
65.41
2.675
67.95
2.775
70.49
2.875
73.03
3.075
78.11
3.175
80.65
3.275
83.19
3.375
85.73
3.475
88.27
3.675
93.35
3.775
95.89
3.875
98.43
3.975 100.97
4.075 103.51
4.375 111.13
4.475 113.67
4.875 123.83
4.975 126.37
5.175 131.45
5.275 133.99
5.775 146.69
5.875 149.23
6.075 154.31
6.775 172.09
6.875 174.63
7.375 187.33
7.875 200.03
F
KEY IN POSITION
.070±.002 1.78±0.05
0.330
8.38
G
E
('H' MOUNTING AS SHOWN FOR EXAMPLE)
0.400
KEY BETWEEN POSITIONS
.030±.002 0.76±0.05
MATERIAL (INSULATOR/CONTACT)
B
A
E = BLUE PBT/PHOSPHOR BRONZE
OPERATING TEMP: -65°C TO +125°C
PROCESSING TEMP: WAVE/ MANUAL SOLDERING ONLY
R = GREEN PPS/PHOSPHOR BRONZE
PROCESSING TEMP: 260°C MAX FOR 20 SECONDS
G = BLACK PA9T/PHOSPHOR BRONZE
H = BLUE PBT/BERYLLIUM COPPER
A = GREEN PPS/BERYLLIUM COPPER
OPERATING TEMP: -65°C TO +150°C
J = BLACK PA9T/BERYLLIUM COPPER
F = GREEN PPS/SPINODAL (CONSULT FACTORY)
OPERATING TEMP: -65°C TO +200°C
(CONSULT FACTORY FOR SPECIAL SOLDERING GUIDELINES)
AVAILABLE IN OVERALL GOLD ONLY (S OR M PLATING CODE)
C = GREEN PPS/BERYLLIUM NICKEL (CONSULT FACTORY)
X = TAN PEEK/SPINODAL (CONSULT FACTORY)
W = TAN PEEK/BERYLLIUM NICKEL (CONSULT FACTORY)
OPERATING TEMP: -65°C TO +250°C
AVAILABLE IN OVERALL M PLATING ONLY
MODIFICATION CODE
C
OMIT = STANDARD WITHOUT MOLDED KEY, EX: 'EBC22DRXH'
S38 = BLACK PBT WITHOUT MOLDED KEY (MATERIAL CODES 'E' OR 'H' ONLY)
S81 = GREEN PBT WITHOUT MOLDED KEY (MATERIAL CODES 'E' OR 'H' ONLY)
S328 = BROWN PPS WITHOUT MOLDED KEY (MATERIAL CODES 'R', 'A', 'F', OR 'C' ONLY)
S1098 = BLACK PPS WITHOUT MOLDED KEY (MATERIAL CODES 'R', 'A', 'F', OR 'C' ONLY)
SEE KEY LOCATION DRAWINGS FOR MODIFICATION NUMBER (S#), 'G' AND 'H' DIMENSION:
DRAWING C13556 FOR STANDARD COLOR
DRAWING C14008 FOR NON-STANDARD COLOR
H
MOUNTING STYLE
H = .125" DIA. CLEARANCE HOLES
N = NO MOUNTING EARS
S = .125" DIA. SIDE MOUNTING
I = #4-40 THREADED INSERT
F = FLOATING BOBBIN
B = OPEN CARDSLOT
B
TERMINATION
RX =
RJ =
.200[5.08] ROW SPACING X .185[4.70] DIP SOLDER TAIL LENGTH
.250[6.35] ROW SPACING X .165[4.19] DIP SOLDER TAIL LENGTH
(SEE SECTION A-A ON PAGE 1)
NUMBER OF POSITIONS
PLATING
CUSTOMER COPY
(CONTACTS PER ROW)
ALL PLATINGS HAVE .000050" NICKEL UNDERPLATE
CONTACT SURFACE
TERMINATION
B = .000010" GOLD
.000100" PURE TIN, MATTE
C = .000030" GOLD
G = .000010" GOLD
.000005" GOLD
Y = .000030" GOLD
.000005" GOLD
S = .000010" GOLD
.000010" GOLD OVERALL
M = .000030" GOLD
*E = .000100" PURE TIN, MATTE .000100" PURE TIN, MATTE OVERALL
*OVERALL TIN ONLY AVAILABLE ON MATERIAL CODES E, R, & G
Pb
RoHS COMPLIANT
6/14/2012 JH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
7
6
5
4
3
A
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 3:1
8
D
10.16
PART NUMBER CODING
_ _ C _ _ D_ _ _ -S_ _ _ _
C
1
2
3
F+.005/-.015[+0.13/-0.38]
IN
MM
2
DWG. NO.
C10881
REV
P
SHEET 3 OF 3
1
