GBB60DHBS-S793
GBB60DHBS-S793
    SULLINS
GBB60DHBS-S793 数据手册
8 7 4 5 6 REV. D F .590 14.99 2.490 63.25 .500 12.70 (11 POSITIONS) .050 1.27 PIN A2 2.400 60.96 (49 POSITIONS) E F .014 0.36 X .012[0.30] 2X PIN A1 E FIRST POSITION INDICATOR PIN B1 REVISIONS ECO. NO DESCRIPTION UPDATE BOARD LOCK DIST. 3.200 (WAS 3.192), CARD SLOT LENGTH 0.590 (WAS .595), WIDTH BETWEEN CARDSLOTS .070 2240 (WAS .065), UPDATE DAUGHTER CARD & PCB LAYOUT, REMOVE E & H MTL OPTIONS, UPDATE INSERTION FORCE TO 6 OZ MAX 2535 UPDATED NOTES AND FORMAT FROM .018[0.46] TO .014[0.36], 3062 UPDATE PIN DIMENSION UPDATE DRAWING FORMAT H .150 3.81 1 2 3 3218 DATE BY 1/19/2011 JH F UPDATE MODIFICATION NOTE, ROTATE VIEWS ON SHEET 2, ADD BACK VIEW, UPDATE WITHDRAWL FORCE TO 1/2 OZ (WAS 1 OZ, REF : STR-153, STR-134, STR-079) 3/19/2012 SE 9/12/2014 JHSU 5/5/2015 MG .125 3.18 THRU .075 1.91 SEE NOTE 13 .070 1.78 E 3.050 77.47 PIN B2 3.150 80.01 3.626±.010 92.10±0.25 3.940±.020 100.08±0.51 D D +.005 +0.13 .370 - .015 9.40 - 0.38 3.340±.015 84.84±0.38 A .030 0.76 .300 7.62 INSERTION DEPTH .360 9.14 .595±.010 15.11±0.25 .915 23.24 .250 6.35 B A C HA = .100±.025 2.54±0.64 HB = .170 .025[4.32 0.64] _ _B60DHAD-S793 _ _B60DHBD-S793 C 3X .100 2.54 SECTION A-A PIN A1 PIN A2 B A B NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING 2. CONTACT MATERIAL: SEE PART NUMBER CODING 3. PLATING: SEE PART NUMBER CODING 4. OPERATING TEMPERATURE: SEE PART NUMBER CODING 5. PROCESSING TEMP: SEE PART NUMBER CODING 6. UL FLAMMABILITY RATING: 94V-0 7. OPERATING VOLTAGE: 300 VAC 8. CURRENT RATING: 1 AMP 9. CONTACT RESISTANCE: 30 MILLI OHMS MAX 10. INSULATION RESISTANCE: 5000 MEGA OHMS 11. DURABILITY: 500 CYCLES MIN 12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE 13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20] 14. INSERTION FORCE: 6 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE 15. WITHDRAWAL FORCE: 1/2 OZ MIN PER CONTACT PAIR USING .062[1.57] PCB 16. MODIFICATION: PCI 32 BIT, 3.3 VOLT 60 (11/49), RIGHT ANGLE BEND TOWARD LEFT 8 7 6 5 PIN B1 PIN B2 DETAIL B SCALE 4:1 CUSTOMER COPY Pb RoHS COMPLIANT 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 05/12/06 MNH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C _ _B60D_ _ _-S793, (DHA, DHB) CAGE CODE 54453 SCALE: 3:2 3 A CONNECTOR, .050 CC RAB LEFT 2 DWG. NO. C10370 SHEET 1 OF 3 1 REV H FILE NAME: C10370, _ _B60D_ _ _ -S793, (DHA, DHB) 8 7 4 5 6 1 2 3 3.626 92.10 F 2X #4-40 THREADED INSERTS F 3.626±.010 92.10±0.25 E E 2X .485 12.32 2X .125 3.18 THRU .110 2.79 _ _B60DHAT-S793 _ _B60DHBT-S793 _ _B60DHAS-S793 _ _B60DHBS-S793 D D 2X BOARD LOCK 3.200 81.28 C C 3.340 84.84 .174 4.41 3.340 84.84 B B _ _B60DHAN-S793 _ _B60DHBN-S793 .150 3.80 _ _B60DHAR-S793 _ _B60DHBR-S793 Pb A RoHS COMPLIANT 8 7 6 5 4 CUSTOMER COPY UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 05/12/06 MNH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C _ _B60D_ _ _-S793, (DHA, DHB) CAGE CODE 54453 SCALE: 2:1 3 A CONNECTOR, .050 CC RAB LEFT 2 DWG. NO. C10370 SHEET 2 OF 3 1 REV H FILE NAME: C10370, _ _B60D_ _ _ -S793, (DHA, DHB) 8 7 4 5 6 1 2 3 F F E E 2.400 60.96 .500 12.70 .050 1.27 D D .150 3.81 .062 1.57 .300 7.62 MIN .040 1.02 MAX PIN B1 (PIN A1 ON OPPOSITE SIDE) 60° .310 7.87 MIN .084 2.13 .575 14.61 .613 15.57 C .030 0.76 .250 6.35 MIN C 2.513 63.83 3.626 92.10 3.200 81.28 PIN A1 PIN A2 B .288 7.32 .075 1.91 .110 2.79 2X .125 3.18 FOR 'S' MOUNTING .040 1.02 MIN B 2X .104 2.64 FOR 'R' MOUNTING .150 3.81 .150 3.81 PIN B1 PIN B2 .500 12.70 .050 1.27 3X .100 2.54 CUSTOMER COPY 2.400 60.96 RECOMMENDED PCB LAYOUT CONNECTOR SIDE A Pb RoHS COMPLIANT 8 7 6 5 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 05/12/06 MNH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE CONNECTOR, .050 CC RAB LEFT PART NUMBER SIZE C _ _B60D_ _ _-S793, (DHA, DHB) CAGE CODE 54453 SCALE: 2:1 3 A 2 DWG. NO. C10370 SHEET 3 OF 3 1 REV H FILE NAME: C10370, _ _B60D_ _ _ -S793, (DHA, DHB)
GBB60DHBS-S793 价格&库存
很抱歉,暂时无法提供与“GBB60DHBS-S793”相匹配的价格&库存,您可以联系我们找货
