8
7
4
5
6
1
2
3
REVISIONS
F
REV.
ECO. NO
DESCRIPTION
DATE
BY
D
2565
ADDED 'R' & 'A' MATERIAL OPTION
5/17/2012
KV
E
2695
UPDATE INSULATOR BLADE TO .050" WITH STEP,
ADD MARKING 'USA'
10/25/2012
JH
F
3177
UPDATE DWG FORMAT, UPDATE INSERT INSTALLATION 3/10/2015
IN 'V' MOUNTING
MG
H
3182
UPDATE GAP FROM PIN TO BODY TO .050 FROM .030
4/23/2015
F
MG
D
C
A
+.005
+0.13
.370
9.40
- .015
- 0.38
E
.125 3.18
2X
.156 3.96
E
(.025 0.64 ) DEPTH
FROM TOP OF INSULATOR
TO TOP OF PIN
FITS EDGECARDS THAT
ACCEPT .062[1.57] PCB'S
B
D
MA = .100±.025 2.54±0.64
MV = .130 .025 [3.30 0.64]
MB = .180 .025 [4.57 0.64]
MD = .250 .025 [6.35 0.64]
MJ = .500 .025 [12.70 0.64]
MK = .560 .025 [14.22 0.64]
A
.540±.010 13.72±0.25
D
.250 6.35
.030 0.76
C
A
.025 0.64
C
SECTION A-A
STD = .150 3.81 ROW SPACING
S189 = .200 [5.08] ROW SPACING
_ _M_ _M_ _D
2X .125 3.18
USED FOR Z & V
MOUNTING
.050±.010 1.27±0.25
C
A
B
B
.145 3.68
.156 3.96
A
NOTES:
RECOMMENDED PCB LAYOUT
1. INSULATOR MATERIAL: SEE PART NUMBER CODING
2. CONTACT MATERIAL: SEE PART NUMBER CODING
3. PLATING: SEE PART NUMBER CODING
4. OPERATING TEMPERATURE: SEE PART NUMBER CODING
5. PROCESSING TEMP: SEE PART NUMBER CODING
6. UL FLAMMABILITY RATING: 94V-0
7. OPERATING VOLTAGE: 950 VAC
8. CURRENT RATING: 3 AMP
9. CONTACT RESISTANCE: 30 MILLI OHMS MAX
10. INSULATION RESISTANCE: 5000 MEGA OHMS
11. CONNECTOR IDENTIFICATION: PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
RoHS COMPLIANT
12. MODIFICATION: SEE PART NUMBER CODING
Pb
8
7
6
.150 3.81 (FOR STANDARD)
.200[5.08] (FOR S189)
.043 1.09 MIN
5
4
CUSTOMER COPY
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
DIMENSIONS ARE IN INCHES [MM]
03/14/08 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
PART NUMBER
_ _M_ _M_ _ _ (MA,MV,MB,MD,MJ,MK)
SIZE
C
CAGE CODE
54453
SCALE: 3:1
3
A
MALE, RIGHT ANGLE BEND, .156 CC
2
DWG. NO.
C11076
SHEET 1 OF 3
1
REV
H
FILE NAME: C11076, _ _M_ _M_ _ _, (MA, MV, MB, MD, MJ, MK), (-S189)
8
7
4
5
6
1
2
3
F
C
F
E
2X #4-40
THREADED
INSERTS
E
E
_ _M_ _M_ _N
_ _M_ _M_ _T
D
D
C
C
C
C
2X
.125 3.18
.125 3.18
B
.125 3.18
_ _M_ _M_ _Z
B
2X #4-40
THREADED
INSERTS
_ _M_ _M_ _V
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
8
7
6
5
4
03/14/08 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
3
A
2
DWG. NO.
C11076
SHEET 2 OF 3
1
REV
H
8
7
4
5
6
1
2
3
F
F
E
E
D
D
C
C
B
B
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
8
7
6
5
4
03/14/08 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
3
A
2
DWG. NO.
C11076
SHEET 3 OF 3
1
REV
H
