8
7
5
6
4
1
2
3
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
1269
INITIAL RELEASE
2/3/2007
MV
B
1390
6/18/2007
MNH
C
1662
ADD PIN WIDTH CALL-OUT; ADD CURRENT RATING
TO F MATERIAL
UPDATE DRAWING FORMAT &
PART NUMBER CODING
4/24/2008
VJ
F
F
E
D
B
A
.075 1.91
CARDSLOT
E
.156 3.96
2X
E
.125 3.18
C
D
.265 6.73
INSERTION
DEPTH
F
A
.186 4.72
D
.431 10.95
.245 6.22
A
_ _M_ _DSXH
C
.014 0.36
.025 0.64
.041 1.04
FITS .051[1.30] MIN. HOLE
.070±.025 1.78±0.64
TAIL LENGTH
SECTION A-A
C
CONTACT MARKINGS
(LETTERS G, I, O, & Q NOT USED)
SIZE 02 THRU 25:
1 2 3 ... 23 24...
A B C ...AA BB ...
SIZE 28 THRU 44:
1 2 3 ... 23 24 ...
A B C ... A B ...
B
A
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING.
2. CONTACT MATERIAL: SEE PART NUMBER CODING.
CONTACT ID
3. PLATING: SEE PART NUMBER CODING.
SCALE 4 : 1
4. TEMPERATURE: SEE PART NUMBER CODING.
5. PROCESSING TEMP: SEE PART NUMBER CODING.
6. UL FLAMMABILITY RATING: 94V-0.
7. VOLTAGE RATING: 1800 VDC MINIMUM AT SEA LEVEL.
8. CURRENT RATING: SEE PART NUMBER CODING.
9. VOLTAGE DROP: 30 MILLI VOLT AT RATED CURRENT.
10. INSULATION RESISTANCE: 5000 MEGA OHMS.
11. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND BARCODE.
12. BOARD THICKNESS ACCOMMMODATED: .062 .008[1.57 0.20].
13. BOARD INSERTION FORCE: 16 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE.
INTERNAL INSPECTION TO BE PER SULLIN'S WORK INSTRUCTION W17.3-01.
14. BOARD WITHDRAWAL FORCE: 1 OUNCE MINIMUM PER CONTACT PAIR USING .062[1.57] PCB.
8
7
6
5
B
CUSTOMER COPY
UNLESS OTHERWISE SPECIFIED:
Pb
DIMENSIONS ARE IN INCHES[MM]
TOLERANCES:
ANGULAR: 30'
.XX= .02 [.508]
.XXX= .005 [.1270]
.XXXX= .0005 [.0127]
SURFACE FINISH: 63 Ra
REMOVE ALL BURRS AND SHARP EDGES .010 MAX
RoHS COMPLIANT
4
DRAWN
NAME
MV
A
EDGECARD, .156 CC, LP
_ _M_ _DSX_
SIZE DWG. NO.
INTERPRET DIMENSIONS AND GEOMETRIC
TOLERANCING
PER: ANSI Y14.5M-1994
3
DATE
2/3/2007
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT DESCRIPTION
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
PART NUMBER
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
C
REV
C10891
SCALE: 2:1
2
C
SHEET 1 OF 3
1
FILE NAME: Z:\COMPONENTS\Part Assemblies\Customer Drawings\Customer Drawings for Catalog\C10891, _ _M_ _DSX_ PRINT: 6/24/2008
8
7
4
5
6
2X #4-40
THREADED
INSERT
F
1
2
3
D
F
C
E
E
_ _M_ _DSXN
_ _ M _ _ DSXI
2X FLOATING BOBBIN
.116 2.95 CLEARANCE
FOR # 4 SCREW
D
C
D
D
C
D
.280 7.11
.135 3.43
_ _ M _ _ DSXS
_ _M_ _DSXF
B
B
CUSTOMER COPY
Pb
A
TOLERANCES:
ANGULAR: 30'
.XX= .02 [.508]
.XXX= .005 [.1270]
RoHS COMPLIANT
8
7
6
5
4
DRAWN
NAME
MV
A
_ _M_ _DSX_
SIZE DWG. NO.
TOLERANCING
3
DATE
2/3/2007
PART NUMBER
C
REV
C10891
SCALE: 2:1
2
C
SHEET 2 OF 3
1
8
7
4
5
6
1
2
3
Only applies for
PPS/PEEK
insulators with
threaded inSXrts
or floats
F
PART NUMBER
E
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
M02DSXN
M03DSXN
M06DSX _
M08DSX _
M10DSX _
M11DSX _
M12DSX _
M15DSX _
M18DSX _
M22DSX _
M24DSX _
M25DSX _
M28DSX _
M36DSX _
M43DSX _
M44DSX _
NO. OF
POS.
2
3
6
8
10
11
12
15
18
22
24
25
28
36
43
44
A ± .008[0.20]
B ±.008[0.20]
C ±.015[0.38]
IN
0.156
0.312
0.780
1.092
1.404
1.560
1.716
2.184
2.652
3.276
3.588
3.744
4.212
5.460
6.552
6.708
IN
0.476
0.632
1.100
1.412
1.724
1.880
2.036
2.504
2.972
3.596
3.908
4.064
4.532
5.780
6.872
7.028
IN
0.596
0.752
1.220
1.532
1.844
2.000
2.156
2.624
3.092
3.716
4.028
4.184
4.652
5.900
6.992
7.148
MM
3.96
7.92
19.81
27.74
35.66
39.62
43.59
55.47
67.36
83.21
91.14
95.10
106.98
138.68
166.42
170.38
MM
12.09
16.05
27.94
35.86
43.79
47.75
51.71
63.60
75.49
91.34
99.26
103.23
115.11
146.81
174.55
178.51
MM
15.14
19.10
30.99
38.91
46.84
50.80
54.76
66.65
78.54
94.39
102.31
106.27
118.16
149.86
177.60
181.56
D ±.010[0.25]
IN
MM
A
MM
IN
MM
1.882
2.194
2.506
2.662
2.818
3.286
3.754
4.378
4.690
4.846
5.314
6.562
7.654
7.810
47.80
55.73
63.65
67.61
71.58
83.46
95.35
111.20
119.13
123.09
134.98
166.67
194.41
198.37
F
F ±.005[0.13]
IN
MM
0.325
8.26
"N" MOUNTING
1.533
1.845
2.157
2.313
2.469
2.937
3.405
4.029
4.341
4.497
4.965
6.213
7.305
7.461
38.94
46.86
54.79
58.75
62.71
74.60
86.49
102.34
110.26
114.22
126.11
157.81
185.55
189.51
1.782
2.094
2.406
2.562
2.718
3.186
3.654
4.278
4.590
4.746
5.214
6.462
7.554
7.710
45.26
53.19
61.11
65.07
69.04
80.92
92.81
108.66
116.59
120.55
132.44
164.13
191.87
195.83
E
0.438
11.13
0.500
12.70
D
MATERIAL (INSULATOR/CONTACT)
B
IN
E ±.020[0.51]
PART NUMBER CODING
_ _ M _ _ DSX _
D
C
E ±.020[0.51]
MOUNTING STYLE
E = PBT/PHOSPHOR BRONZE
OPERATING TEMP: -65°C TO +125°C @ 3 AMPS PER CONTACT
OPERATING TEMP: -65°C TO +21°C @ 5 AMPS PER CONTACT
PROCESSING TEMP: 260°C FOR 10 SECS MAX
R = PPS/PHOSPHOR BRONZE
PROCESSING TEMP: 260°C FOR 120 SECS MAX
CURRENT RATING PER CONTACT: 5 AMPS
G = PA9T/PHOSPHOR BRONZE
H = PBT/BERYLLIUM COPPER
OPERATING TEMP: -65°C TO +105°C @ 5 AMPS PER CONTACT
A = PPS/BERYLLIUM COPPER
OPERATING TEMP: -65°C TO +150°C
J = PA9T/BERYLLIUM COPPER
F = PPS/SPINODAL (CONSULT FACTORY)
AVAILABLE IN OVERALL GOLD ONLY (S OR M PLATING CODE)
OPERATING TEMP: -65°C TO +200°C
CURRENT RATING PER CONTACT: 3 AMPS
C = PPS/BERYLLIUM COPPER (CONSULT FACTORY)
OPERATING TEMP: -65°C TO +200°C @ 2 AMPS PER CONTACT
OPERATING TEMP: -65°C TO +173°C @ 3 AMPS PER CONTACT
W = PEEK/BERYLLIUM COPPER (CONSULT FACTORY)
OPERATING TEMP: -65°C TO +250°C
(CONSULT FACTORY FOR OTHER MATERIALS)
8
7
NUMBER OF POSITIONS
(CONTACTS PER ROW)
H=
N=
S=
I=
F=
.125" DIA. CLEARANCE HOLES (PAGE 1)
NO MOUNTING EARS (PAGE 2)
.125" DIA. SIDE MOUNTING (PAGE 2)
#4-40 THREADED INSERT (PAGE 2)
FLOATING BOBBIN (PAGE 2)
PLATING
ALL PLATINGS ARE LEAD FREE AND HAVE .000050" NICKEL UNDERPLATE
CONTACT SURFACE
TERMINATION
G = .000010" GOLD
.000005" GOLD
Y = .000030" GOLD
.000005" GOLD
B = .000010" GOLD
.000100" PURE TIN, MATTE
C = .000030" GOLD
**E = .000100" PURE TIN, MATTE, OVERALL
S = .000010" GOLD OVERALL
M = .000030" GOLD
** OVERALL TIN ONLY AVAILABLE ON MATERIAL CODES E, R AND G
C
B
CUSTOMER COPY
Pb
TOLERANCES:
ANGULAR: 30'
.XX= .02 [.508]
.XXX= .005 [.1270]
RoHS COMPLIANT
6
5
4
DRAWN
NAME
MV
A
_ _M_ _DSX_
SIZE DWG. NO.
TOLERANCING
3
DATE
2/3/2007
PART NUMBER
C
REV
C10891
SCALE: 1:1
2
C
SHEET 3 OF 3
1
很抱歉,暂时无法提供与“EBM22DSXH-S388”相匹配的价格&库存,您可以联系我们找货
